аккумулятор
Сообщений в теме: 24
#11 getAway
  • 4010 сообщений
Отправлено 19 January 2013 - 15:06
Disconnect the terminals (A) from the battery. The negative terminal first.
Tightening torque
(-) terminal (without battery sensor):
7.8 ~ 9.8N.m (0.8 ~ 1.0kgf.m, 5.8 ~ 7.2lb-ft)
(-) terminal (with battery sensor):
4.0 ~ 6.0N.m (0.4 ~ 0.6kgf.m, 3.0 ~ 4.4lb-ft)
(+) terminal :
Прикрепленный файл  1 copy.jpg   48.8К   21 Количество загрузок:
Remove the battery (A) after removing the clamp bolt.
Tightening torque :
9.8 ~ 11.8N.m (1.0 ~ 1.2kgf.m, 7.2 ~ 8.7lb-ft)
Прикрепленный файл  2 copy.jpg   49.53К   28 Количество загрузок:
Remove the battery tray (A).
Tightening torque :
Прикрепленный файл  3 copy.jpg   53.46К   25 Количество загрузок:
4.
Installation is the reverse order of removal.
ISG (Idle stop & go) system equipped vehicle always use the AGM battery only. If flooded battery has installed, this can potentially lead to engine electrical trouble or ISG system error.
Replace same capacity of the AGM battery.
Ensure an AGM battery is fitted.
In all cases, an AGM battery must be installed and registered in the vehicle for the ISG function to work perfectly.
The vehicle with the new battery must be placed in the ignition switch OFF and door closed, hood switch OFF state for at least 4 hours.
ISG system’s stabilization may take 4 hours after new battery installation.
ISG function is operates about 4 hours later and 2 times cranking by user.
But first 25 times, the ISG function can operates regardless of ISG system stability for ISG function operating check.
Do not open the AGM battery.
The AGM battery must not be opened under any circumstances as the introduction of oxygen from the air will cause the battery to lose its chemical equilibrium and rendered non-operational.
#12 Елена ЕЕЕ Re: аккумулятор
Елена ЕЕЕ
Отправлено 22 August 2013 - 06:40
Помогите! Машинке 2 месяца (новая). уже сел аккумулятор. Это нормально? и что делать?
#13 krionika Re: аккумулятор
Отправлено 22 August 2013 - 09:59
Привет, Это не нормально. :)
Что делать:
    [*]Проверить ток утечки (возможно неправильно подключили какое-либо доп оборудование)
    [*]Проверить какая зарядка идет на акк при работающем двигателе
    [*]Зарядить аккумулятор
    [/list]А вообще, у вас машина на гарантии и все это должен делать сервисный центр по ГАРАНТИИ и БЕСПЛАТНО. Я бы на вашем месте написал претензию об этом и при повторном случае потребовал бы заменить акк. У меня такого не было ни на одной из машин.
#14 *Гоша* Re: аккумулятор
*Гоша*
Отправлено 13 October 2014 - 14:24
Перед зимой на своей Пике 2012 года смазал клеммы аккумулятора силиконовым спреем смазкой, естественно предварительно их зачистив. Всем стоит проделать данную процедуру....
#15 *Гость* Re: аккумулятор
Отправлено 21 October 2014 - 12:37
*Гоша*, Смажьте литолом, а лучше всего конечно графитовой смазкой, проверено.
#16 blue car Re: аккумулятор
blue car
  • 542 сообщений
Отправлено 24 October 2014 - 18:02
Станислав,привет!У меня лопнула +вая клемма.Все магазины объехала - ничего нет похожего. Как выйти из положения?
#17 krionika Re: аккумулятор
Отправлено 24 October 2014 - 21:49
сама клемма? та которая из железа? это как случилось? Машине не 20 лет же...
Я так понимаю что она вместе с проводом, хотя могу и ошибаться, на рисунке не очень понятно
Прикрепленный файл  Провода аккумулятора Киа Пиканто TA.gif   13.53К   0 Количество загрузок:
1140FB  БОЛТ М6  1140308127B
1141AC  БОЛТ М6  MULTI
1141AH  БОЛТ М6  1141508167B
13372  КРОНШТЕЙН  919813K100
1339CC  ГАЙКА-ФЛАНЕЦ  1339506007K
1339CD  ГАЙКА-ФЛАНЕЦ  MULTI
13395A  ГАЙКА-ФЛАНЕЦ  1339606007B
13396  ГАЙКА-ФЛАНЕЦ  1339606007K
91200F  ПРОВОДКА  MULTI
[color=#ff0000;]91200T  ПРОВОД АККУМУЛЯТОРА  MULTI  [/color]
91800C  ЖГУТ ПРОВОДОВ - КРЫШИ  MULTI
91850D  ПРОВОДКА АККУМУЛЯТОРА  MULTI
91850E  ПРОВОД ЗАЗЕМЛЕНИЯ ДВИГАТЕЛЯ  918601Y000
91890C  ПРОВОДА  918301Y000
91890Z  ЭЛЕКТРОПРОВОДКА  MULTI
91931  КРОНШТЕЙ ПРОВОДКИ  919310X930
91931W  BRACKET-ATM  919312G285
91960B  ЖГУТ ПРОВОДОВ - ДВ БАГАЖНИКА  MULTI
91980Q  BRACKET-MAIN  919803L210
#18 blue car Re: аккумулятор
blue car
  • 542 сообщений
Отправлено 26 October 2014 - 16:03
Прикрепленный файл  клемма аккумулятора Киа Пиканто TA.jpg   81.96К   0 Количество загрузок:
#19 krionika Re: аккумулятор
Отправлено 27 October 2014 - 11:20
blue car,
меняется только с проводом (если смотреть по оригинальным ЗЧ)
если я  правильно понял, то номер на рисунке [color=#ff0000;]91200T. отдельно клемма судя по рисунку не идет.[/color]
Или искать любую похожую по конструкции.
#20 *Олег* Re: аккумулятор
*Олег*
Отправлено 27 October 2014 - 15:25
Подскажите, а как лучше зарадить аккумулятор На Пиканте 12 года? Она стояла долго, аккумулятор подсел. Дали  прибор который позволяет регулировать ток зарядки. Так вот..... каким током его заряжать?
