Киа Теллурайд ON
Сообщений в теме: 16
Отправлено 11 January 2023 - 14:15
G 3.8 GDI LAMBDA II > Mood Lamp Module > Mood Lamp Module
B262200 Cockpit Mood Lamp 0 Malfunction Error
B262300 Cockpit Mood Lamp 0 LIN Communication Error
B262400 Cockpit Mood Lamp 1 Malfunction Error
B262500 Cockpit Mood Lamp 1 LIN Communication Error
B262A00 Front Left Door Mood Lamp 0 Malfunction Error
B262B00 Front Left Door Mood Lamp 0 LIN Communication Error
B262E00 Front Right Door Mood Lamp 0 Malfunction Error
B262F00 Front Right Door Mood Lamp 0 LIN Communication Error
B263200 Rear Left Door Mood Lamp 0 Malfunction Error
B263300 Rear Left Door Mood Lamp 0 LIN Communication Error
B263600 Rear Right Door Mood Lamp 0 Malfunction Error
B263700 Rear Right Door Mood Lamp 0 LIN Communication Error
G 3.8 GDI LAMBDA II > Multi Function Camera > Multi Function Camera
C110117 Battery Voltage High
C110216 Battery Voltage Low
C153211 LKAS Switch Failure
C153215 LKAS Switch Failure
C153223 LKAS Switch Failure
C160449 ECU Hardware Error
C160649 ECU Software Error
C160A87 Local CAN Bus Off
C161187 CAN Time-out EMS
C161287 CAN Time-out TCU
C161386 CAN Signal Error EMS
C161687 C-CAN Bus OFF
C162385 CAN Time-out Steering Angle Sensor
C162387 CAN Time-out Steering Angle Sensor
C162585 CAN Time-Out ABS/ESP
C162587 CAN Time-Out ABS/ESP
C162887 CAN Time-out Cluster
C164286 CAN Message Failure - Brake
C164686 CAN Message Failure - TCU
C165686 CAN Signal Error - Cluster
C166787 CAN Time-Out SCC
C167286 SAS Message Counter Error
C168785 CAN Time-out VSM2 (MDPS)
C168787 CAN Time-out VSM2 (MDPS)
C168886 VSM2 (MDPS) Signal Error
C16B687 CAN Timeout-AEB
C170246 Variant Coding Error
C170262 Variant Coding Error
C181287 CAN Time-out Gateway
C181786 CAN Signal Error Gateway
C186286 Invalid Signal of SCC
C223986 MDPS Steering Control Failure for LKAS
C272146 System Calibration Required
C272246 System Out of Calibration
G 3.8 GDI LAMBDA II > Power Seat Module > Power Seat Module
B160200 CAN LINE Error (B-CAN)
B160300 CAN Bus OFF (B-CAN)
B163700 System Not Initialized
G 3.8 GDI LAMBDA II > Power Tail Gate > Power Tailgate
B160200 CAN Line Error
B160300 CAN Bus Off
B24B000 Power Tailgate Module Inline Mode Not Deactivated
B24B100 PTG Spindle Hall Sensor Error
B24B300 PTG Anti-Pinch Sensor Error
B24B500 PTG Unlatch Error
B24B600 PTG Spindle LH Hall Sensor Error
B24B700 PTG Spindle Hall Sensor Error, RH
B24B800 PTG Anti-Pinch Sensor Error, LH
B24B900 PTG Anti-Pinch Sensor Error, RH
G 3.8 GDI LAMBDA II > Rear View Monitor > Rear View Monitor
B161F00 Camera Input Error
B162100 ECU hardware
B16A700 Camera Video Output Error
Отправлено 11 January 2023 - 14:16
G 3.8 GDI LAMBDA II > Smart Cruise Control > Smart Cruise Control
C120281 Wheel Speed Sensor Front-LH Invalid/no Signal
C120581 Wheel Speed Sensor Front-RH Invalid/no Signal
C120881 Wheel Speed Sensor Rear-LH Invalid/no Signal
C121181 Wheel Speed Sensor Rear-RH Invalid/no Signal
C126081 Steering Angle Sensor Circuit - Signal
C126082 Steering Angle Sensor Circuit - signal
C126083 Steering Angle Sensor Circuit - signal
C128381 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C136081 ESP Irreversible Error
C160404 ECU Hardware Error
C160A88 Local CAN Bus Off
C160C87 Local CAN Time-out
C161381 CAN Signal Error EMS
C161382 CAN Signal Error EMS
C161383 CAN Signal Error EMS
C161688 C-CAN Bus OFF
C162078 Alignment Failed
C162982 Cluster Invalid Counter
C163281 Cluster Control Switch Fail
C163381 Cluster Invalid Displayed Speed
C163881 ACC/SCC communication error
C164281 CAN Message Failure - Brake
C164282 CAN Message Failure - Brake
C164283 CAN Message Failure - Brake
C164681 CAN Message Failure - TCU
C16B881 AEB Communication Error
C170255 Variant Coding Error
C174181 ESC-not available VSM (Check ESC)
C174281 Variant Error - ESC (Check ESC)
C174755 Front Radar & Front view Camera Variant Coding Mismatch
C180487 CAN time-out LKAS
C180581 LKAS CAN Signal Error
C180582 LKAS CAN Signal Error
C180583 LKAS CAN Signal Error
C181782 CAN Signal Error Gateway
G 3.8 GDI LAMBDA II > Smart Key > Smart Key Code Saving
P167600 SMARTRA Message Error
P169000 SMARTRA no response
P169500 EMS Memory Error
P169600 Authentication Fail
P169900 Twice Overtrial
G 3.8 GDI LAMBDA II > Steering > Motor Driven Power Steering
C110921 IG1 Open - MDPS Fail Safe
C111201 Sensor Source Voltage
C125901 Steering Angle Sensor - Electrical
C126154 Steering Angle Sensor is not Calibrated
C126204 Temperature Sensor Failure
C129002 Torque Sensor Signal Fail
C160398 ECU thermal protection
C162286 EMS invalid Vehicle Speed
C163383 Cluster Invalid Counter
C165987 CAN Time-Out SAS
C169287 CAN Time-out ESC
C169383 ESC Signal Error
C170004 Byte Coding Error
C170401 ECU Fail-Safe Relay Fail
C170504 ECU Pre-Charge Circuit Fail
C171104 Improper program termination
C180487 CAN time out LKAS
C181483 CAN Message Failure - SAS
C181783 CAN Signal Error Gateway
C240101 Motor Circuit
C241201 Motor Short or Open
C241301 Motor Current Fail (Current Over)
C241396 Motor Current Fail (Current Over)
G 3.8 GDI LAMBDA II > Surround View Monitor > Surround View Monitor
B103000 No Camera Tolerance Correction
B162C00 Camera Power Line Short
B16B700 Front Camera Input Error
B16B800 Rear Camera Input Error
B16B900 Left Camera Input Error
B16BA00 Right Camera Input Error
C161600 C-CAN Bus OFF
G 3.8 GDI LAMBDA II > Wireless Power Charger > Wireless Power Charger
B160300 CAN BUS Off
B16B200 WPC ECU Internal Error
G 3.8 GDI LAMBDA II > Engine > Engine Control
P001100 "A(Intake)" Camshaft Position-Timing Over-Advanced or System Performance (Bank 1)
P001400 "B(Exhaust)" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P001600 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A(Intake))
P001700 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B(Exhaust))
P001800 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P001900 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
P002100 "A" Camshaft Position-Timing Over-Advanced or System Performance
P002400 "B" Camshaft Position-Timing Over-Advanced or System Performance
P003000 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P003100 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P003200 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P003600 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P003700 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P003800 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P005000 HO2S Heater Control Circuit (Bank 2 / Sensor 1)
P005100 HO2S Heater Circuit low (Bank 2 Sensor 1)
P005200 HO2S Heater Circuit high (Bank 2 Sensor 1)
P005600 HO2S Heater Control Circuit (Bank 2 / Sensor 2)
P005700 HO2S Heater Circuit low (Bank 2 Sensor 2)
P005800 HO2S Heater Circuit high (Bank 2 Sensor 2)
P007000 Ambient Air Temperature Sensor Circuit
P007100 Ambient Air Temperature Circuit Range / Performance
P007500 Intake Valve Control Solenoid Circuit (Bank 1)
P007600 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P007700 Intake Valve Control Solenoid Circuit-High (Bank 1)
P007800 Exhaust Valve Control Solenoid Circuit (Bank 1)
P007900 Exhaust Valve Control Solenoid Circuit Low(Bank 1)
P008000 Exhaust Valve Control Solenoid Circuit High(Bank 1)
P008100 Intake Valve Control Solenoid Circuit
P008200 Intake Valve Control Solenoid Circuit Low
P008300 Intake Valve Control Solenoid Circuit High
P008400 Exhaust Valve Control Solenoid Circuit
P008500 Exhaust Valve Control Solenoid Circuit Low
P008600 Exhaust Valve Control Solenoid Circuit High
P008700 Fuel Rail/System Pressure - Too Low
P008800 Fuel Rail/System Pressure - Too High
P008B00 Low Pressure Fuel Pressure -Too High
P009000 Fuel Pressure Regulator 1 Control Circuit/Open
P009100 Fuel Pressure Regulator 1 Control Circuit Low
P009200 Fuel Pressure Regulator 1 Control Circuit High
P010600 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P010700 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P010800 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P011100 Intake Air Temperature Sensor 1 Circuit Range / Performance
P011200 Intake Air Temperature Sensor 1 Circuit Low Input
P011300 Intake Air Temperature Sensor 1 Circuit High Input
P011600 Engine Coolant Temperature Circuit Range / Performance
P011700 Engine Coolant Temperature Circuit Low Input
P011800 Engine Coolant Temperature Circuit High Input
P011900 Engine Coolant Temperature Circuit Intermittent
P012100 Throttle Position Sensor 1 Signal Circuit Range/Performance
P012200 Throttle Position Sensor 1 Signal Circuit Low Input
P012300 Throttle Position Sensor 1 Signal Circuit High Input
P012500 Insufficient Coolant Temperature for Closed Loop Fuel Control
P012800 Coolant Thermostat (Coolant Temperature below Thermostat Regulating Temperature)
P013100 O2 Sensor Circuit Low Voltage(Bank 1 / Sensor 1)
P013200 O2 Sensor Circuit High Voltage(Bank 1 / Sensor 1)
P013300 O2-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P013500 O2 Sensor Heater Circuit (Bank 1 / Sensor 1)
P013600 O2 Sensor Circuit(Bank 1/ Sensor 2)
P013700 O2 Sensor Circuit Low Voltage (Bank 1 / Sensor 2)
P013800 O2 Sensor Circuit High Voltage (Bank 1 / Sensor 2)
P013900 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 2)
P014000 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P015100 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 1)
P015200 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 1)
P015300 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 1)
P015500 O2 Sensor Heater Circuit (Bank 2 Sensor1)
P015600 O2 Sensor Circuit (Bank 2 / Sensor 2)
P015700 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 2)
P015800 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 2)
P015900 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 2)
P016000 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 2)
P017100 System too Lean (Bank 1)
P017200 System too Rich (Bank 1)
P017400 System too Lean (Bank 2)
P017500 System too Rich (Bank 2)
P019100 Fuel Rail Pressure Sensor Circuit Range/Performance
P019200 Fuel Rail Pressure Sensor Circuit Low Input
P019300 Fuel Rail Pressure Sensor Circuit High Input
P019600 Engine Oil Temperature Sensor-Range / Performance
P019700 Engine Oil Temperature Sensor Low Input
P019800 Engine Oil Temperature Sensor High Input
P020000 Injector Circuit/Open
P020100 Injector Circuit/Open - Cylinder 1
P020200 Injector Circuit/Open - Cylinder 2
P020300 Injector Circuit/Open - Cylinder 3
P020400 Injector Circuit/Open - Cylinder 4
P020500 Injector Circuit/Open - Cylinder 5
P020600 Injector Circuit/Open - Cylinder 6
P022100 Throttle Position Sensor 2 Signal Circuit Range/Performance
P022200 Throttle Position Sensor 2 Signal Circuit Low Input
P022300 Throttle Position Sensor 2 Signal Circuit High Input
P023000 Fuel Pump Primary Circuit
P026100 Cylinder 1 Injector Circuit Low
P026200 Cylinder 1 Injector Circuit High
P026300 Cylinder 1 Contribution/Balance
P026400 Cylinder 2 Injector Circuit Low
P026500 Cylinder 2 Injector Circuit High
P026600 Cylinder 2 Contribution/Balance
P026700 Cylinder 3 Injector Circuit Low
P026800 Cylinder 3 Injector Circuit High
P026900 Cylinder 3 Contribution/Balance
P027000 Cylinder 4 Injector Circuit Low
P027100 Cylinder 4 Injector Circuit High
P027200 Cylinder 4 Contribution/Balance
P027300 Cylinder 5 Injector Circuit Low
P027400 Cylinder 5 Injector Circuit High
P027500 Cylinder 5 Contribution/Balance
P027600 Cylinder 6 Injector Circuit Low
P027700 Cylinder 6 Injector Circuit High
P027800 Cylinder 6 Contribution/Balance
P02CC00 Cylinder 1 Fuel Injector Offset Learning At Min Limit
P02CD00 Cylinder 1 Fuel Injector Offset Learning At Max Limit
P02CE00 Cylinder 2 Fuel Injector Offset Learning At Min Limit
P02CF00 Cylinder 2 Fuel Injector Offset Learning At Max Limit
P02D000 Cylinder 3 Fuel Injector Offset Learning At Min Limit
P02D100 Cylinder 3 Fuel Injector Offset Learning At Max Limit
P02D200 Cylinder 4 Fuel Injector Offset Learning at Min Limit
P02D300 Cylinder 4 Fuel Injector Offset Learning at Max Limit
P02D400 Cylinder 5 Fuel Injector Offset Learning at Min Limit
P02D500 Cylinder 5 Fuel Injector Offset Learning at Max Limit
P02D600 Cylinder 6 Fuel Injector Offset Learning at Min Limit
P02D700 Cylinder 6 Fuel Injector Offset Learning at Max Limit
P02EE00 Cylinder 1 Fuel Injector Circuit Range/Performance
P02EF00 Cylinder 2 Fuel Injector Circuit Range/Performance
P02F000 Cylinder 3 Fuel Injector Circuit Range/Performance
P02F100 Cylinder 4 Fuel Injector Circuit Range/Performance
P02F200 Cylinder 5 Fuel Injector Circuit Range/Performance
P02F300 Cylinder 6 Fuel Injector Circuit Range/Performance
P030000 Random/Multiple Cylinder Misfire Detected
P030100 Cylinder 1 - Misfire detected
P030200 Cylinder 2 - Misfire detected
P030300 Cylinder 3 - Misfire detected
P030400 Cylinder 4-Misfire detected
P030500 Cylinder 5-Misfire detected
P030600 Cylinder 6-Misfire detected
P031500 Crankshaft Position System Variation Not Learned
P032600 Knock Sensor 1 Circuit Range/Performance (Bank 1)
P033100 Knock Sensor 2 Circuit Range/Performance
P033500 Crankshaft Position Sensor "A" Circuit
P033600 Crankshaft Position Sensor "A" Circuit Range/Performance
P034000 Camshaft Position Sensor "A"(Intake) Circuit (Bank 1 or Single Sensor)
P034100 Camshaft Position Sensor "A"(Intake) Circuit Range/Performance (Bank 1)
P034500 Camshaft Position Sensor "A(Intake)" Circuit (Bank 2)
P034600 Camshaft Position Sensor "A"(Intake) Circuit Range/Performance (Bank 2)
P036500 Camshaft Position Sensor "B"(Exhaust) Circuit Malfunction (Bank 1)
P036600 Camshaft Position Sensor "B"(Exhaust) Circuit Range/Performance (Bank 1)
P039000 Camshaft Position Sensor "B" Circuit
P039100 Camshaft Position Sensor "B" Circuit Range/Performance
P039B00 Cylinder 1 Pressure Too High
P03A500 Cylinder 2 Pressure Too High
P03AF00 Cylinder 3 Pressure Too High
P03B900 Cylinder 4 Pressure Too High
P03C300 Cylinder 5 Pressure Too High
P03CD00 Cylinder 6 Pressure Too High
P042000 Catalyst System Efficiency Below Threshold (Bank 1)
P043000 Catalyst System Efficiency Below Threshold (Bank 2)
P044100 Evaporative Emission System Incorrect Purge Flow
P044200 Evaporative Emission System-Leak detected (small leak)
P044400 Evaporative Emission System-Purge Control Valve Circuit Open
P044500 Evaporative Emission System-Purge Control Valve Circuit Shorted
P046100 Fuel Level Sensor "A" Circuit Range/Performance
P046200 Fuel Level Sensor "A" Circuit Low Input
P046300 Fuel Level Sensor "A" Circuit High Input
P050400 Brake Switch "A"/"B" Correlation
P050600 Idle Air Control System-RPM Lower than Expected
P050700 Idle Air Control System-RPM Higher than Expected
P050A00 Cold Start Idle Air Control System Performance
P050B00 Cold Start Ignition Timing Performance
P052100 Engine Oil Pressure Sensor/Switch "A" Range/Performance
P052200 Engine Oil Pressure Sensor/Switch "A" Low
P052300 Engine Oil Pressure Sensor/Switch "A" High
P052400 Engine Oil Pressure Too Low
P052A00 Cold Start "A" Camshaft Position Timing Over-Advanced (Bank 1 In-cam)
P052C00 Cold Start "A" Camshaft Position Timing Over-Advanced (Bank 2 In-cam)
P053200 A/C Refrigerant Pressure Sensor "A" Circuit Low Input
P053300 A/C Refrigerant Pressure Sensor "A" Circuit High Input
P056000 System Voltage
P056200 System Voltage Low
P056300 System Voltage High
P056400 Cruise Control Multi-Function Input A Circuit
P059700 Thermostat Heater Control Circuit/Open
P059800 Thermostat Heater Control Circuit Low
P059900 Thermostat Heater Control Circuit High
P060500 Internal Control Module Read Only Memory(ROM) Error
P060600 ECM/PCM Processor
P060700 Control Module Performance
P061000 Control Module Vehicle Option Error
P061600 Starter Relay Circuit Low
P061700 Starter Relay Circuit High
P061B00 Torque Control Signal Failure
P063000 VIN Not Programmed or Incompatible-ECM/PCM
P063800 Throttle Actuator Control Range/Performance (Bank 1)
P064200 Sensor Reference Voltage "A" Circuit Low
P064300 Sensor Reference Voltage "A" Circuit High
P064600 A/C Clutch Relay Control Circuit Low
P064700 A/C Clutch Relay Control Circuit High
P064A00 Fuel Pump Control Module
P065200 Sensor Reference Voltage "B" Circuit Low
P065300 Sensor Reference Voltage "B" Circuit High
P066100 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
P066200 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
P066400 Intake Manifold Tuning Valve Control Circuit Low (Bank 2)
P066500 Intake Manifold Tuning Valve Control Circuit High (Bank 2)
P069800 Sensor Reference Voltage "C" Circuit Low
P069900 Sensor Reference Voltage "C" Circuit High
P0A1A00 Generator Control Module
P116000 Key Off Duration Implausible Short
P122000 Oil Pump Solenoid Control Circuit
P122200 Oil Pump Solenoid Control Circuit Low
P122300 Oil Pump Solenoid Control Circuit High
P123000 Fuel Pump malfunction
P123300 Low Pressure Fuel System - High deviation between target and current pressure
P209600 Post Catalyst Fuel Trim System too Lean (Bank 1)
P209700 Post Catalyst Fuel Trim System too Rich (Bank 1)
P209800 Post Catalyst Fuel Trim System Too Lean (Bank 2)
P209900 Post Catalyst Fuel Trim System Too Rich (Bank 2)
P210100 Throttle Actuator Control Motor Circuit Range/Performance
P210400 Limp Home Mode - Forced Idle
P210500 Limp Home Mode - Force Engine Shutdown
P210600 Limp Home Mode - Force Limited Power
P211000 Limp Home Mode - Forced Limited RPM
P211800 Throttle Actuator Control Motor Current Range/Performance
P211900 Throttle Actuator Control Throttle Body Range/Performance
P212200 Accelerator Position Sensor 1 Signal Circuit Low Input
P212300 Accelerator Position Sensor 1 Signal Circuit High Input
P212700 Accelerator Position Sensor 2 Signal Circuit Low Input
P212800 Accelerator Position Sensor 2 Signal Circuit-High Input
P213800 Accelerator Position Sensor 1 & 2 Signal Voltage Correlation
P214700 Fuel Injector Group "A" Supply Voltage Circuit Low
P214800 Fuel Injector Group "A" Supply Voltage Circuit High
P215000 Fuel Injector Group "B" Supply Voltage Circuit Low
P215100 Fuel Injector Group "B" Supply Voltage Circuit High
P215300 Fuel Injector Group "C" Supply Voltage Circuit Low
P215400 Fuel Injector Group "C" Supply Voltage Circuit High
P215900 Vehicle Speed Sensor "B" Range / Performance(Wheel Speed Sensor)
P217700 System Too Lean Off Idle Bank 1
P217800 System Too Rich Off Idle Bank 1
P217900 System Too Lean Off Idle Bank 2
P218000 System Too Rich Off Idle Bank 2
P218100 Cooling System Performance
P219500 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P219600 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
P219700 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 1)
P219800 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 1)
P222700 Barometric Pressure Circuit Range/Performance
P222800 Barometric Pressure Circuit Low Input
P222900 Barometric Pressure Circuit High Input
P223700 O2 Sensor Pumping Current Circuit/Open (Bank 1 Sensor 1)
P224000 O2 Sensor Pumping Current Circuit/Open (Bank 2 Sensor 1)
P224300 O2 Sensor Reference Voltage Circuit/Open (Bank 1 Sensor 1)
P224700 O2 Sensor Reference Voltage Circuit/Open (Bank 2 Sensor 1)
P225100 O2 Sensor Reference Ground Circuit/Open (Bank 1 Sensor 1)
P225400 O2 Sensor Reference Ground Circuit/Open (Bank 2 Sensor 1)
P227000 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 2)
P227100 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 2)
P227200 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 2)
P227300 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 2)
P229700 O2 Sensor Out of Range During Deceleration - (Bank 1 Sensor 1)
P229800 O2 Sensor Out of Range During Deceleration - (Bank 2 Sensor 1)
P241400 O2 Sensor Exhaust Sample Error (Bank 1 Sensor 1)
P241500 O2 Sensor Exhaust Sample Error (Bank 2 Sensor 1)
P250100 AMS Voltage Rationality
P250200 Charging System Voltage
P250300 Charging System Voltage Low
P250400 Charging System Voltage High
P254000 Low Pressure Fuel System Sensor Circuit Range/Performance
P254100 Low Pressure Fuel System Sensor Circuit Low
P254200 Low Pressure Fuel System Sensor Circuit High
P261000 ECM/PCM Internal Engine Off Timer Performance
P262600 O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
P262900 O2 Sensor Pumping Current Trim Circuit/Open (Bank 2 Sensor 1)
P2B9500 Cold Start Injection Pulse Performance
U000100 High Speed CAN Communication Bus off
U010100 Lost Communication with TCM
U010400 Lost Communication With Cruise Control Moudle
U010900 Lost Communication With Fuel Pump Control Module
U012A00 Lost Communication With ICSC Module
U012D00 Lost Communication With Generator Control Module
U015500 Lost Communication With Instrument Panel Cluster (IPC) Control Module
U016400 Lost Communication With HVAC Control Module(FATC CAN Time Out)
U040200 Invalid Data Received From TCM
U042B00 CAN Communication Failure with Hill Assist Module
U04B100 Invalid Data Received From Battery Monitor Module
U111100 Lin Message Timeout with EBS
G 3.8 GDI LAMBDA II > Transmission > Automatic Transaxle
P060100 Internal Control Module Memory Check Sum Error
P060148 Internal Control Module Memory Check Sum Error
P070512 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P070514 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P07051C Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P070661 Transmission Range Sensor Circuit Range/Performance
P070696 Transmission Range Sensor Circuit Range/Performance
P071100 Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
P071200 Transmission Fluid Temperature Sensor "A" Circuit Low Input
P071300 Transmission Fluid Temperature Sensor "A" Circuit High Input
P071700 Input/Turbine Speed Sensor "A" Circuit No Signal
P072100 Output Speed Sensor Circuit Range/Performance
P072200 Output Speed Sensor Circuit No Signal
P072900 Gear 6 Incorrect Ratio
P073000 Gear 8 Incorrect Ratio
P073100 Gear 1 Incorrect Ratio
P073200 Gear 2 Incorrect Ratio
P073300 Gear 3 Incorrect Ratio
P073400 Gear 4 Incorrect Ratio
P073500 Gear 5 Incorrect Ratio
P074100 Torque Converter Clutch Circuit Performance or Stuck Off
P074300 Torque Converter Clutch Circuit Electrical
P074800 Pressure Control Solenoid Valve(VFS) "A" Electrical
P075300 Shift Control Solenoid Valve "A" Electrical (UD/C)
P075800 Shift Control Solenoid Valve "B" Electrical (46/C)
P076300 Shift Control Solenoid Valve "C" Electrical (37R/C)
P076800 Shift Control Solenoid Valve "D" Electrical (OD&LR)
P076F00 Gear 7 Incorrect Ratio
P077300 Shift Control Solenoid Valve "E" Electrical (28/B)
P079100 Intermediate Shaft Speed Sensor "A" Circuit
P088000 TCM Power Input Signal
P095500 Auto Shift Manual Mode Circuit
P160200 No EOL Data
P1C2800 OPI Current High
P1C2B00 OPI Hall Sensor Error
P270900 Shift Control Solenoid Valve "F" Electrical
U010000 Lost Communication with ECM/PCM 'A'
U028700 Lost Communication With Transmission Fluid Pump Module
Ещё обсуждения по Киа Теллурайд ON на MyKia.club:
