G 3.8 GDI LAMBDA II > Airbag > Airbag(Event #1)
B110100 Battery Voltage High
B110200 Battery Voltage Low
B111600 Battery Voltage Unstable
B111700 B+ Line Disconnected
B132600 FIS(Front Impact Sensor)-Driver Short to Ground
B132700 FIS(Front Impact Sensor)-Driver Short to Battery
B132800 FIS(Front Impact Sensor)-Driver Defect
B132900 FIS(Front Impact Sensor)-Driver Communication Error
B133000 FIS(Front Impact Sensor)-Driver Wrong ID
B133100 FIS(Front Impact Sensor)-Passenger Short to Ground
B133200 FIS(Front Impact Sensor)-Passenger Short to Battery
B133300 FIS(Front Impact Sensor)-Passenger Defect
B133400 FIS(Front Impact Sensor)-Passenger Communication Error
B133500 FIS(Front Impact Sensor)-Passenger Wrong ID
B134600 Driver Airbag Resistance too High (1st Stage)
B134700 Driver Airbag Resistance too Low (1st Stage)
B134800 Driver Airbag Resistance Circuit Short to Ground (1st Stage)
B134900 Driver Airbag Resistance Circuit Short to Battery (1st Stage)
B135200 Passenger Airbag Resistance too High (1st Stage)
B135300 Passenger Airbag Resistance too Low (1st Stage)
B135400 Passenger Airbag Resistance Circuit Short to Ground (1st Stage)
B135500 Passenger Airbag Resistance Circuit Short to Battery (1st Stage)
B136100 Pretensioner Front-Driver Resistance too High
B136200 Pretensioner Front-Driver Resistance too Low
B136300 Pretensioner Front-Driver Resistance Circuit Short to Ground
B136400 Pretensioner Front-Driver Resistance Circuit Short to Battery
B136700 Pretensioner Front-Passenger Resistance too High
B136800 Pretensioner Front-Passenger Resistance too Low
B136900 Pretensioner Front-Passenger Resistance Circuit Short to Ground
B137000 Pretensioner Front-Passenger Resistance Circuit Short to Battery
B137800 Side Airbag Front-Driver Resistance too High
B137900 Side Airbag Front-Driver Resistance too Low
B138000 Side Airbag Front-Driver Resistance Circuit Short to Ground
B138100 Side Airbag Front-Driver Resistance Circuit Short to Battery
B138200 Side Airbag Front-Passenger Resistance too High
B138300 Side Airbag Front-Passenger Resistance too Low
B138400 Side Airbag Front-Passenger Resistance Circuit Short to Ground
B138500 Side Airbag Front-Passenger Resistance Circuit Short to Battery
B139500 Cross Coupling
B140000 SIS(Side Impact Sensor) Front-Driver Defect
B140100 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B140200 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B140300 SIS(Side Impact Sensor) Front-Passenger Defect
B140400 SIS(Side Impact Sensor) Front-Passenger Circuit Short to Ground
B140500 SIS(Side Impact Sensor) Front-Passenger Circuit Short to Battery
B140900 SIS(Side Impact Sensor) Front-Driver Communication Error
B141000 SIS(Side Impact Sensor) Front-Passenger Communication Error
B141200 SIS(Side Impact Sensor) Rear-Driver Communication error
B141300 SIS(Side Impact Sensor) Rear-Passenger Communication error
B141400 SIS(Side Impact Sensor) Front-Driver Wrong ID
B141500 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B141600 SIS(Side Impact Sensor) Rear-Driver Wrong ID
B141700 SIS(Side Impact Sensor) Rear-Passenger Wrong ID
B141800 SIS(Side Impact Sensor) Rear-Driver Defect
B141900 SIS(Side Impact Sensor) Rear-Passenger Defect
B145100 SIS(Side Impact Sensor) Rear-Driver Circuit Short to Ground
B145200 SIS(Side Impact Sensor) Rear-Driver Circuit Short to Battery
B145400 SIS(Side Impact Sensor) Rear-Passenger Circuit Short to Ground
B145500 SIS(Side Impact Sensor) Rear-Passenger Circuit Short to Battery
B147300 Inflatable Curtain Airbag Driver Resistance too High
B147400 Inflatable Curtain Airbag Driver Resistance too Low
B147500 Inflatable Curtain Airbag Driver Resistance Circuit Short to Ground
B147600 Inflatable Curtain Airbag Driver Resistance Circuit Short to Battery
B147700 Inflatable Curtain Airbag Passenger Resistance too High
B147800 Inflatable Curtain Airbag Passenger Resistance too Low
B147900 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Ground
B148000 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Battery
B151100 Buckle Switch Driver Open or Short to Battery
B151200 Buckle Switch Driver Short or Short to Ground
B151500 Buckle Switch Driver Defect
B162000 Internal Fault - Replace SRSCM
B164900 Crash Recorded-Rollover Event (Replace SRSCM)
B165000 Crash Recorded in 1st Stage Only (Frontal-Replace SRSCM)
B165100 Crash Recorded in Driver Side Airbag (Replace SRSCM)
B165200 Crash Recorded in Passenger Side Airbag (Replace SRSCM)
B165900 Rear Crash Detected
B167000 Crash Recorded in Full Stage (Frontal-Replace SRSCM)
B167600 Crash Recorded in Driver Side Restraint System With Frontal Crash (Replace ECU)
B167700 Crash Recorded in Passenger Side Restraint System With Frontal Crash (Replace ECU)
B167800 Scrap Recorded (Replace ECU)
B168300 Exceed Maximum Coding Number
B168400 Not Configured Device is Detected
B16D000 Internal Fault - Main Sensor
B16D100 Internal Fault - Safing Sensor
B16D200 Internal Fault - Roll Sensor (Gyro)
B16D300 Internal Fault - Roll Sensor (Low-g)
B16D400 Internal Fault - ESC Sensor (Gyro)
B16D500 Internal Fault - ESC Sensor (Low-g)
B16D600 Internal Fault - MCU (Except Memory)
B16D700 Internal Fault - ROM/RAM/EEPROM
B16D800 Internal Fault - Safing FET
B16D900 Internal Fault - System ASIC
B16DA00 Internal Fault - Squib ASIC (if equipped)
B16DC00 Internal Fault - Energy Reserve
B171100 Knee Airbag - Driver Resistance too High
B171200 Knee Airbag - Driver Resistance too Low
B171300 Knee Airbag - Driver Resistance Circuit Short to Ground
B171400 Knee Airbag - Driver Resistance Circuit Short to Battery
B173800 P-SIS(Side Impact Sensor, Pressure) Front-Driver Wrong ID
B173900 P-SIS(Side Impact Sensor, Pressure) Front-Driver Defect
B174000 P-SIS(Side Impact Sensor, Pressure) Front-Driver Short to Ground
B174100 P-SIS(Side Impact Sensor, Pressure) Front-Driver Short to Battery
B174200 P-SIS(Side Impact Sensor, Pressure) Front-Driver Communication Error
B174400 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Wrong ID
B174500 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Defect
B174600 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Short to Ground
B174700 P-SIS(Side Impact Sensor, Pressure) Front Passenger Short to Battery
B174800 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Communication Error
B176200 ACU Coding Error
B180000 Side Crash Detection for Door Unlock (NON-SAB)
B200000 Rollover Event information Transmission (Restraints Non-Activation)
B250500 Passenger Airbag On/Off Warning Lamp Failure
B261300 ACU Airbag Warning Lamp CAN Message Error
B261400 Cluster Airbag Warning Lamp Circuit Failure
B261500 ACU and Cluster Airbag Lamp CAN Message Mismatch
B261600 Cluster Airbag Warning Lamp CAN Message Invaild
B261700 Cluster Airbag Warning Lamp CAN Message Timeout
B261800 Cluster Airbag Warning Lamp CAN Message Timeout by CAN Bus
