Киа Спортейдж 2 KM
Сообщений в теме: 22
Отправлено 11 May 2021 - 18:26
G 2.7 DOHC > Transmission > Automatic Transaxle
P0703 Stop Lamp Switch(Brake SW) - Short(B+)
P0721 A/T Output Speed Sensor Fail
P0722 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P1603 Can Communication Bus Off
P1604 NO ID from ECU
P1764 TCU Can Mi-Com Malfunction
P0885 A/T Control Relay Malfunction
U0100 No ID From ECU
U0001 No ID From ECU
D 2.0 WGT > Air Conditioner > Air Conditioner
B1200 Humidity Sensor Open(High)
B1201 Humidity Sensor Short(Low)
B1202 Water Temperature Sensor Open(HIGH)
B1203 Water Temperature Sensor Short(Low)
B1233 INCAR Temperature Sensor Short(Low)
B1234 INCAR Temperature Sensor Open(High)
B1237 Ambient Temperature Sensor Short(Low)
B1238 Ambient Temperature Sensor Open(High)
B1241 Evaporator Sensor Short(Low)
B1242 Evaporator Sensor Open(HIGH)
B1245 DR AIR MIX POTENTIOMETER OPEN(Low)
B1246 DR AIR MIX POTENTIOMETER Short(High)
B1249 DR DIRECTION POTENTIOMETER OPEN(low)
B1250 DR Direction POTENTIOMETER Short(High)
B2406 DR AIR MIX Motor
B2409 DR DIRECTION CONTROL MOTOR
D 2.0 WGT > Airbag > Airbag Control
B1101 Battery voltage high
B1102 Battery voltage low
B1326 FIS-Driver short to Ground
B1327 FIS-Driver short to Battery
B1328 FIS-Driver defect
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger short to Ground
B1332 FIS-Passenger short to Battery
B1333 FIS-Passenger defect
B1335 FIS-Passenger Wrong ID
B1400 SIS front-Driver defect
B1401 SIS front-Driver circuit short to Ground
B1402 SIS front-Driver circuit short to Battery
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1414 SIS front-Driver Wrong ID
B1415 SIS front-Passenger Wrong ID
B1527 Passenger airbag On/Off switch open or short to Battery
B1528 Passenger airbag On/Off switch short or short to Ground
B1529 Passenger airbag On/Off switch defect
B1701 Buckle pretensioner - Driver resistance too High
B1702 Buckle pretensioner - Driver resistance too Low
B1703 Buckle pretensioner - Driver resistance circuit short to Ground
B1704 Buckle pretensioner - Driver resistance circuit short to Battery
B1706 Buckle pretensioner - Passenger resistance too High
B1707 Buckle pretensioner - Passenger resistance too Low
B1708 Buckle pretensioner - Passenger resistance circuit short to Ground
B1709 Buckle pretensioner - Passenger resistance circuit short to Battery
B2500 Warning Lamp
B2505 Passenger Airbag off Warning Lamp Failure
D 2.0 WGT > Brake > Electronic Stability Program
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1112 Sensor source voltage
C1274 Longitudinal G sensor open/short
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yaw Rate & Lateral G Sensor-Electrical
C1503 TCS/ESC(ESP) Switch error
C1513 Brake switch error
C1604 ECU Hardware Error
C1605 CAN Hardware error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus off
C1647 CAN Hardware Error - Sensor Channel
C2112 Valve Relay Error
C2227 Excessive Temperature Of Brake Disc
C2380 ABS/TCS/ESC(ESP) valve error
C2402 Motor Failure
C1101 Battery voltage high
C1102 Battery voltage low
C1112 Sensor power voltage
C1200 Wheel speed sensor front-LH open/short
C1201 Wheel speed sensor front-LH range/performance/intermittent
C1202 Wheel speed sensor front-LH invalid/no signal
C1203 Wheel speed sensor front-RH open /short
C1204 Wheel speed sensor front-RH range/performance/intermittent
C1205 Wheel speed sensor front-RH invalid/no signal
C1206 Wheel speed sensor rear-LH open/short
C1207 Wheel speed sensor rear-LH range/performance/intermittent
C1208 Wheel speed sensor rear-LH invalid/no signal
C1209 Wheel speed sensor rear-RH open/short
C1210 Wheel speed sensor rear-RH range/performance/intermittent
C1211 Wheel speed sensor rear-RH invalid/no signal
C1235 Primary Pressure Sensor- Electrical
C1237 Primary Pressure Sensor - Signal
C1259 Steering angle sensor - electrical
C1260 Steering angle sensor - signal
C1274 Longitudinal G Sensor Open/Short
C1282 Yawrate and Lateral G Sensor - Electrical
C1283 Yawrate and Lateral G Sensor - Signal / Other
C1503 ESP switch error
C1605 CAN Hardware Error - Main Channel
C1611 CAN time-out ECM
C1612 CAN time-out TCM
C1613 CAN wrong message
C1616 CAN bus off
C2112 Valve relay error
C2227 Excessive temperature of brake disc
C2380 ABS/ESP valve Malfunction
C2402 Motor electrical
D 2.0 WGT > Driveshaft > 4WD Control
P1716 STEERING WHEEL ANGLE SENSOR SIGNAL(CAN ERROR)
P1717 STEERING WHEEL ANGLE SENSOR 1-INPUT SIGNAL
P1718 STEERING WHEEL ANGLE SENSOR 2-INPUT SIGNAL
P1719 STEERING WHEEL ANGLE SENSOR C-INPUT SIGNAL
P1726 TPS(APS) INPUT-LOSS OF SIGNAL
P1728 EMC OPEN/SHORTED to BATTERY
P1729 EMC SHORT/SHORTED to GROUND
P1738 4WD ECU INVALID PART NUMBER
P1750A FRONT LEFT SPEED SENSOR(Without ABS)
P1750B FRONT LEFT SPEED SENSOR(With ABS)
P1751A FRONT RIGHT SPEED SENSOR(Without ABS)
P1751B FRONT RIGHT SPEED SENSOR(With ABS)
P1752A REAR LEFT SPEED SENSOR(Without ABS)
P1752B REAR LEFT SPEED SENSOR(With ABS)
P1753A REAR RIGHT SPEED SENSOR(Without ABS)
P1753B REAR RIGHT SPEED SENSOR(With ABS)
P1764 ECU-ITM CAN ERROR
P1765 TCS-ITM CAN ERROR
P1766 CAN COMMUNICATIOM BUS OFF
P1767 ABS ACTIVE SIGNAL (CAN ERROR)
P1769 Tire Size Fault
P1770 EMC thermal Protection - Lock Mode
P1771 EMC Thermal Protection - Shutdown
D 2.0 WGT > Engine > Engine Control
P0100 Air Flow Sensor Circuit - General Error
P0101 Air Flow Sensor Circuit - Range/ Performance
P0102 Air Flow Sensor Circuit - Low Input
P0103 Air Flow Sensor Circuit - High Input
P0112 Intake Air Temperature Circuit - Low Input
P0113 Intake Air Temperature Circuit - High Input
P0116 Engine Coolant Temperature - Range/ Performance
P0117 Engine Coolant Temperature - Low Input
P0118 Engine Coolant Temperature - High Input
P0120 Acceleration Position Sensor 1 - General Error
P0123 Acceleration Position Sensor 1 - High Input
P0220 Acceleration Position Sensor 2 - General Error
P0223 Acceleration Position Sensor 2 - High Input
P2135 Acceleration Position Sensor 2 - Range/ Performance
P0182 Fuel Temperature Sensor - Low Input
P0183 Fuel Temperature Sensor - High Input
P0190 Fuel Rail Pressure Sensor - General Error
P0192 Fuel Rail Pressure Sensor - Low input
P0193 Fuel Rail Pressure Sensor - High Input
P0231 Electric Fuel Pump Relay - Open / Short Circuit
P0232 Electric Fuel Pump Relay - Short Circuit
P0261 CYL-1 Injector Circuit Low (Over current low side)
P0262 CYL-1 Injector Circuit High (Over current high side)
P0263 CYL-1 Injector Circuit Balance (Load drop is detected)
P0264 CYL-2 Injector Circuit Low (Over current low side)
P0265 CYL-2 Injector Circuit High (Over current high side)
P0266 CYL-2 Injector Circuit Balance (Load drop is detected)
P0267 CYL-3 Injector Circuit Low (Over current low side)
P0268 CYL-3 Injector Circuit High (Over current high side)
P0269 CYL-3 Injector Circuit Balance (Load drop is detected)
P0270 CYL-4 Injector Circuit Low (Over current low side)
P0271 CYL-4 Injector Circuit High (Over current high side)
P0272 CYL-4 Injector Circuit Balance (Load drop is detected)
P0336 Cam/Engine Speed Sensor - Range/ Performance
P0341 Cam/Engine Speed Sensor - Range/ Performance (CMP Sensor)
P0343 Cam/Engine Speed Sensor - High Input
P1300 Cam/Engine Speed Sensor - Synchronization Error (CKP/CMP Plausibility)
P0401 EGR Flow Insufficient Detected
P0402 EGR Flow Excessive Detected
P0405 EGR Solenoid Valve Circuit - Open or Short Circuit
P0406 EGR Solenoid Valve Circuit - Short Circuit
P0501 Vehicle Speed Sensor - Range / Performance
P0503 Vehicle Speed Sensor - High input
P0504 Brake Switch - Range/ Performance
P0562 Battery Voltage - Low Input
P0563 Battery Voltage - High Input
P0564 Cruise Control Switch - Low / High Input
P1661 Cruise Control Lamp - Open or Short Circuit
P0600 CAN Communication Line - ECM-TCM Error
P1602 CAN Communication Line - No Signal
P1603 CAN Communication - Bus Error
P0601 EEPROM - Checksum Error
P0602 EEPROM - Programming Error
P0603 EEPROM - Communication & Memory Error
P0650 Engine Check Lamp - Short Circuit
P0704 Clutch Switch - Range/ Performance
P1182 Rail Pressure Regulator - Short Circuit
P1183 Rail Pressure Regulator - Open or Short Circuit
P1184 Rail Pressure Regulator - Range/ Performance
P1185 Fuel Pressure Monitoring - Maximum Pressure Exceeded
P1186 Fuel Pressure Monitoring - Minimum Pressure at Engine Speed Too Low
P1187 Fuel Pressure Monitoring - Regulator Valve Stick
P1188 Fuel Pressure Monitoring - Leakage
P1189 Fuel Pressure Monitoring - Governor Deviation at Engine speed Too high
P1190 Intake Throttle Actuator - Open or Short Circuit
P1321 Glow Indicator Lamp - Short Circuit
P1322 Glow Indicator Lamp - Open or Short Circuit
P1326 Glow Relay - Short Circuit
P1327 Glow Relay - Open or Short Circuit
P1522 Sensor Supply Voltage 1 - Low Input
P1523 Sensor Supply Voltage 1 - High Input
P1524 Sensor Supply Voltage 2 - Low Input
P1525 Sensor Supply Voltage 2 - High Input
P1529 TCM Engine Check Lamp Request
P1545 1st Gear Recognition Switch - Short Circuit
P1546 1st Gear Recognition Switch - Open / Short Circuit
P1616 Main Relay - Range/ Performance
P1634 Water Heater Relay - Open or Short Curcuit
P1636 Voltage Regulator - MAL
P1638 Microcontroller - MAL
P1639 Monitoring ADC - MAL
P1646 Capacitor Voltage - Too High
P1647 Capacitor Voltage - Too Low
P1652 IG Switch - Open or Short Circuit
P1653 Error Check After IG Off - MAL
P1765 Torque Reduction Signal - MAL
P2228 Atmospheric Pressure Sensor - Low Input
P2229 Atmospheric Pressure Sensor - High Input
D 2.0 WGT > Transmission > Automatic Transaxle
P0500 Vehicle Speed Sensor Open Or Short
P0715 A/T Input Speed Sensor Circuit - Open or Short(GND)
P0720 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0742 Torque Converter Clutch Stuck On
P1604 Can-Bus-Off(TCU FAIL or CIRCUIT FAIL)
P0885 A/T CONTROL RELAY MALFUCTION
P1764 TCU Can MI-Com Malfunction
Отправлено 11 May 2021 - 18:27
D 2.0 VGT > Air Conditioner > Air Conditioner
D 2.0 VGT > Airbag > Airbag Control
B2500 Warning Lamp
D 2.0 VGT > Brake > Electronic Stability Program
C1616 CAN Bus off
C2402 Motor Failure
C1616 CAN bus off
Ещё обсуждения по Киа Спортейдж 2 KM на MyKia.club:
