D 2.0 VGT > Driveshaft > 4WD Control
P1716 STEERING WHEEL ANGLE SENSOR SIGNAL(CAN ERROR)
P1717 STEERING WHEEL ANGLE SENSOR 1-INPUT SIGNAL
P1718 STEERING WHEEL ANGLE SENSOR 2-INPUT SIGNAL
P1719 STEERING WHEEL ANGLE SENSOR C-INPUT SIGNAL
P1726 TPS(APS) INPUT-LOSS OF SIGNAL
P1728 EMC OPEN/SHORTED to BATTERY
P1729 EMC SHORT/SHORTED to GROUND
P1738 4WD ECU INVALID PART NUMBER
P1750A FRONT LEFT SPEED SENSOR(Without ABS)
P1750B FRONT LEFT SPEED SENSOR(With ABS)
P1751A FRONT RIGHT SPEED SENSOR(Without ABS)
P1751B FRONT RIGHT SPEED SENSOR(With ABS)
P1752A REAR LEFT SPEED SENSOR(Without ABS)
P1752B REAR LEFT SPEED SENSOR(With ABS)
P1753A REAR RIGHT SPEED SENSOR(Without ABS)
P1753B REAR RIGHT SPEED SENSOR(With ABS)
P1764 ECU-ITM CAN ERROR
P1765 TCS-ITM CAN ERROR
P1766 CAN COMMUNICATIOM BUS OFF
P1767 ABS ACTIVE SIGNAL (CAN ERROR)
P1769 Tire Size Fault
P1770 EMC thermal Protection - Lock Mode
P1771 EMC Thermal Protection - Shutdown
#21
Отправлено 11 May 2021 - 18:27
Re: коды ошибок, расшифровка
D 2.0 VGT > Engine > Engine Control
P0047 VGT Vaccum Modulator- Circuit Low
P0048 VGT Vaccum Modulator- Circuit High
P0069 Boost Press. Sensor - Malfunction
P0087 Rail Pressure Monitoring-Minimum Pressure at Engine Speed Too Low
P0088 Rail Pressure Monitoring-Maximum Pressure Exceeded
P0089 Rail Press. Regulator(PCV) - Circuit Over Current
P0091 Rail Press. Regulator(PCV) - Circuit Low
P0092 Rail Press. Regulator(PCV) - Circuit High
P0097 Intake Air Temperature Sensor - Circuit Low Input
P0098 Intake Air Temperature Sensor - Circuit High Input
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0103 Mass or Volume Air Flow Circuit High Input
P0107 Boost Press. Sensor Circuit-Low Input
P0108 Boost Press. Sensor Circuit-High Input
P0116 Engine Coolant Temperature Sensor 1 Circuit Range/Performance
P0192 Fuel Rail Press. Sensor-Low Input
P0193 Fuel Rail Press. Sensor-High Input
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0234 Turbocharger/Supercharger Overboost Condition
P0237 Boost Press. Sensor - Circuit Low Input
P0238 Boost Press. Sensor - Circuit High Input
P0252 Fuel Press. Regulator(MPROP) - Circuit Over Current
P0253 Fuel Press. Regulator(MPROP) - Circuit Low
P0254 Fuel Press. Regulator(MPROP) - Circuit High
P0262 Cylinder 1-Injector Circuit High
P0265 Cylinder 2-Injector Circuit High
P0268 Cylinder 3-Injector Circuit High
P0271 Cylinder 4-Injector Circuit High
P0299 Turbocharger/Supercharger Underboost
P0340 Camshaft Position Sensor A Circuit Malfunction (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or Single Sensor)
P0381 Glow Indicator Lamp - Circuit Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0472 Differential Pressure Sensor Low
P0473 Differential Pressure Sensor High
P0489 Exhaust Gas Recirculation Control Circuit Low Voltage
P0490 Exhaust Gas Recirculation Control Circuit High Voltage
P0545 Exhaust Gas TEMP. Sensor Circuit Low (Bank 1 Sensor 1)
P0546 Exhaust Gas TEMP. Sensor Circuit High (Bank 1 Sensor 1)
P0562 System Voltage Low
P0563 System Voltage High
P0602 EEPROM-Programing Error
P0606 ECM/PCM Processor(ECM-SELF TEST Failed)
P0611 Injector - Circuit Malfunction (More than Two Injectors)
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit High
P0652 Sensor Reference Voltage B Circuit Low
P0653 Sensor Reference Voltage B Circuit High
P0670 Glow Relay - Circuit Malfunction
P0698 Sensor Reference Voltage C Circuit Low
P0699 Sensor Reference Voltage C Circuit High
P0820 Neutral S/W Malfunction
P0830 Clutch S/W Malfunction
P1145 Overrun Monitoring Error
P1171 Minimum Rail Pressure Exceeded
P1172 Maximum Rail Pressure Exceeded
P1173 Set Value Of Rail Pressure Not In Plausibility Range
P1185 Fuel Pressure Monitoring-Maximum Pressure Exceeded
P1186 Fuel Pressure Monitoring-Minimum Pressure at Engine Speed Too Low
P1403 Differential Pressure not plausible (Hose Line Frozen)
P1405 CPF - Permanent Regeneration
P1406 Exhaust Gas Temperature Not Plausible Between Calculated And Simulated
P1407 Plausibility Of Temperature Calculated And Simulated Upstream Of Particulate Filter
P1586 MT/AT Encoding
P1587 CAN Communication Error (MT/AT Recognition Error)
P1588 Signal Change through MT/AT Line (During Engine Running)
P1634 AUX. Heater Malfunction
P1652 IG S/W Malfunction
P1670 Injector Classification Error
P1671 Check-Sum Error
P2002 Particulate Trap Efficiency Below Threshold
P2009 Variable Swirl Actuator Motor - Circuit Low
P2010 Variable Swirl Actuator Motor - Circuit High
P2015 Variable Swirl Actuator Motor - Malfunction
P2016 Variable Swirl Actuator Position Sensor - Circuit Low Input
P2017 Variable Swirl Actuator Position Sensor - Circuit High Input
P2030 Exhaust Temperture Value Not Plausible With Sensor 1 And 2
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 / Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 / Sensor 2)
P2034 Exhaust Gas Temperature Sensor Circuit (Bank 1 / Sensor 2)
P2111 Throttle Flap Vaccum Modulator- Circuit High
P2112 Throttle Flap Vaccum Modulator- Circuit Low
P2113 Throttle Control Actuator Circuit Malfunction - Range/Performance
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
P2238 HO2S Pumping Current Circuit Low-Bank 1, Sensor 1
P2239 HO2S Pumping Current Circuit High-Bank 1, Sensor 1
P2251 HO2S Reference Ground Circuit/Open-Bank 1 Sensor 1
P2264 Detection of Water in Fuel
P2299 Brake Switch and Accel Pedal Sensor Signals Input Simultaneously at Times
D 2.0 VGT > Transmission > Automatic Transaxle
P0703 Stop Lamp Switch(Brake SW) - Short(B+)
P0721 A/T Output Speed Sensor Fail
P0722 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P1603 Can Communication Bus Off
P1604 NO ID from ECU
P1764 TCU Can Mi-Com Malfunction
P0885 A/T Control Relay Malfunction
U0100 No ID From ECU
U0001 No ID From ECU
Ещё обсуждения по Киа Спортейдж 2 KM на MyKia.club:
Киа Спортейдж 2 KM
Киа Спортейдж клуб →
Электрика и Аудио Kia Sportage →
спидометр не работаетАвтор aleks34, 24 May 2025 |
Киа Спортейдж 2 KM
замена АКППАвтор krionika, 22 Aug 2011 |
Киа Спортейдж 2 KM
момент затяжки двигателяАвтор krionika, 10 Oct 2011 |
Киа Спортейдж 2 KM
Ходовая, тормоза, шины, диски Kia Sportage →
сход развалАвтор krionika, 17 Mar 2007 |
Киа Спортейдж 2 KM
рычаги и сайлентблокиАвтор *Леонид* , 20 Aug 2024 |
