Киа Спортейдж 2 KM
коды ошибок, расшифровка
Сообщений в теме: 23
  • 24639 сообщений
Отправлено 11 May 2021 - 18:24
Коды ошибок Kia Sportage 2 (KM)
G 2.0 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity Sensor Open(High)
B1201 Humidity Sensor Short(Low)
B1202 Water Temperature Sensor Open(HIGH)
B1203 Water Temperature Sensor Short(Low)
B1233 INCAR Temperature Sensor Short(Low)
B1234 INCAR Temperature Sensor Open(High)
B1237 Ambient Temperature Sensor Short(Low)
B1238 Ambient Temperature Sensor Open(High)
B1241 Evaporator Sensor Short(Low)
B1242 Evaporator Sensor Open(HIGH)
B1245 DR AIR MIX POTENTIOMETER OPEN(Low)
B1246 DR AIR MIX POTENTIOMETER Short(High)
B1249 DR DIRECTION POTENTIOMETER OPEN(low)
B1250 DR Direction POTENTIOMETER Short(High)
B2406 DR AIR MIX Motor
B2409 DR DIRECTION CONTROL MOTOR
G 2.0 DOHC > Airbag > Airbag Control
B1101 Battery voltage high
B1102 Battery voltage low
B1326 FIS-Driver short to Ground
B1327 FIS-Driver short to Battery
B1328 FIS-Driver defect
B1329 FIS-Driver communication error
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger short to Ground
B1332 FIS-Passenger short to Battery
B1333 FIS-Passenger defect
B1334 FIS-Passenger communication error
B1335 FIS-Passenger Wrong ID
B1346 Driver airbag resistance too High (1st stage)
B1347 Driver airbag resistance too Low (1st stage)
B1348 Driver airbag resistance circuit short to Ground (1st stage)
B1349 Driver airbag resistance circuit short to Battery (1st stage)
B1352 Passenger Airbag Resistance too High (1st Stage)
B1353 Passenger Airbag Resistance too Low (1st stage)
B1354 Passenger Airbag Resistance Circuit Short to Ground (1st Stage)
B1355 Passenger Airbag Resistance Circuit Short to Battery (1st Stage)
B1361 Pretensioner front-Driver resistance too High
B1362 Pretensioner front-Driver resistance too Low
B1363 Pretensioner front-Driver resistance circuit short to Ground
B1364 Pretensioner front-Driver resistance circuit short to Battery
B1367 Pretensioner front-Passenger resistance too High
B1368 Pretensioner front-Passenger resistance too Low
B1369 Pretensioner front-Passenger resistance circuit short to Ground
B1370 Pretensioner front-Passenger resistance circuit short to Battery
B1378 Side airbag front-Driver resistance too High
B1379 Side airbag front-Driver resistance too Low
B1380 Side airbag front-Driver resistance circuit short to Ground
B1381 Side airbag front-Driver resistance circuit short to Battery
B1382 Side airbag front-Passenger resistance too High
B1383 Side airbag front-Passenger resistance too Low
B1384 Side airbag front-Passenger resistance circuit short to Ground
B1385 Side airbag front-Passenger resistance circuit short to Battery
B1400 SIS front-Driver defect
B1401 SIS front-Driver circuit short to Ground
B1402 SIS front-Driver circuit short to Battery
B1403 SIS front-Passenger defect
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1409 SIS front-Driver communication error
B1410 SIS front-Passenger communication error
B1414 SIS front-Driver Wrong ID
B1415 SIS front-Passenger Wrong ID
B1473 Inflatable curtain airbag front-Driver resistance too High
B1474 Inflatable curtain airbag front-Driver resistance too Low
B1475 Inflatable curtain airbag front-Driver resistance circuit short to Ground
B1476 Inflatable curtain airbag front-Driver resistance circuit short to Battery
B1477 Inflatable curtain airbag front-Passenger resistance too High
B1478 Inflatable curtain airbag front-Passenger resistance too Low
B1479 Inflatable curtain airbag front-Passenger resistance circuit short to Ground
B1480 Inflatable curtain airbag front-Passenger resistance circuit short to Battery
B1527 Passenger airbag On/Off switch open or short to Battery
B1528 Passenger airbag On/Off switch short or short to Ground
B1529 Passenger airbag On/Off switch defect
B1620 Internal fault - Replace ECU
B1650 Crash recorded in 1st stage only(Frontal - Replace ECU)
B1651 Crash recorded in front-Driver side airbag(Replace ECU)
B1652 Crash recorded in front-Passenger side airbag(Replace ECU)
B1657 Crash recorded in Belt pretensioner only
B1658 Belt pretensioner 6 times deployment
B1701 Buckle pretensioner - Driver resistance too High
B1702 Buckle pretensioner - Driver resistance too Low
B1703 Buckle pretensioner - Driver resistance circuit short to Ground
B1704 Buckle pretensioner - Driver resistance circuit short to Battery
B1706 Buckle pretensioner - Passenger resistance too High
B1707 Buckle pretensioner - Passenger resistance too Low
B1708 Buckle pretensioner - Passenger resistance circuit short to Ground
B1709 Buckle pretensioner - Passenger resistance circuit short to Battery
B2500 Warning Lamp
B2505 Passenger Airbag off Warning Lamp Failure
#2 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
G 2.0 DOHC > Brake > Electronic Stability Program
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1112 Sensor source voltage
C1200 Wheel Speed Sensor Front-LH Open/Short
C1201 Wheel Speed Sensor Front-LH Range / Performance / Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/no Signal
C1203 Wheel Speed Sensor Front-RH Open/Short
C1204 Wheel Speed Sensor Front-RH Range / Performance / Intermittent
C1205 Wheel Speed Sensor Front-RH Invalid/no Signal
C1206 Wheel Speed Sensor Rear-LH Open/Short
C1207 Wheel Speed Sensor Rear-LH Range / Performance / Intermittent
C1208 Wheel Speed Sensor Rear-LH Invalid/no Signal
C1209 Wheel Speed Sensor Rear-RH Open/Short
C1210 Wheel Speed Sensor Rear-RH Range / Performance / Intermittent
C1211 Wheel Speed Sensor Rear-RH Invalid/no Signal
C1235 Primary Pressure Sensor-Electrical
C1237 Primary Pressure Sensor-Signal
C1259 Steering Angle Sensor – Electrical Malfunction
C1260 Steering Angle Sensor Circuit-Signal
C1274 Longitudinal G sensor open/short
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yaw Rate & Lateral G Sensor-Electrical
C1283 Yaw Rate & Lateral G Sensor-Signal
C1503 TCS/ESC(ESP) Switch error
C1513 Brake switch error
C1604 ECU Hardware Error
C1605 CAN Hardware error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus off
C1647 CAN Hardware Error - Sensor Channel
C2112 Valve Relay Error
C2227 Excessive Temperature Of Brake Disc
C2380 ABS/TCS/ESC(ESP) valve error
C2402 Motor Failure
#3 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
C1101 Battery voltage high
C1102 Battery voltage low
C1112 Sensor power voltage
C1200 Wheel speed sensor front-LH open/short
C1201 Wheel speed sensor front-LH range/performance/intermittent
C1202 Wheel speed sensor front-LH invalid/no signal
C1203 Wheel speed sensor front-RH open /short
C1204 Wheel speed sensor front-RH range/performance/intermittent
C1205 Wheel speed sensor front-RH invalid/no signal
C1206 Wheel speed sensor rear-LH open/short
C1207 Wheel speed sensor rear-LH range/performance/intermittent
C1208 Wheel speed sensor rear-LH invalid/no signal
C1209 Wheel speed sensor rear-RH open/short
C1210 Wheel speed sensor rear-RH range/performance/intermittent
C1211 Wheel speed sensor rear-RH invalid/no signal
C1235 Primary Pressure Sensor- Electrical
C1237 Primary Pressure Sensor - Signal
C1259 Steering angle sensor - electrical
C1260 Steering angle sensor - signal
C1274 Longitudinal G Sensor Open/Short
C1282 Yawrate and Lateral G Sensor - Electrical
C1283 Yawrate and Lateral G Sensor - Signal / Other
C1503 ESP switch error
C1605 CAN Hardware Error - Main Channel
C1611 CAN time-out ECM
C1612 CAN time-out TCM
C1613 CAN wrong message
C1616 CAN bus off
C2112 Valve relay error
C2227 Excessive temperature of brake disc
C2380 ABS/ESP valve Malfunction
C2402 Motor electrical
#4 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
G 2.0 DOHC > Driveshaft > 4WD Control
P1716 STEERING WHEEL ANGLE SENSOR SIGNAL(CAN ERROR)
P1717 STEERING WHEEL ANGLE SENSOR 1-INPUT SIGNAL
P1718 STEERING WHEEL ANGLE SENSOR 2-INPUT SIGNAL
P1719 STEERING WHEEL ANGLE SENSOR C-INPUT SIGNAL
P1726 TPS(APS) INPUT-LOSS OF SIGNAL
P1728 EMC OPEN/SHORTED to BATTERY
P1729 EMC SHORT/SHORTED to GROUND
P1738 4WD ECU INVALID PART NUMBER
P1750A FRONT LEFT SPEED SENSOR(Without ABS)
P1750B FRONT LEFT SPEED SENSOR(With ABS)
P1751A FRONT RIGHT SPEED SENSOR(Without ABS)
P1751B FRONT RIGHT SPEED SENSOR(With ABS)
P1752A REAR LEFT SPEED SENSOR(Without ABS)
P1752B REAR LEFT SPEED SENSOR(With ABS)
P1753A REAR RIGHT SPEED SENSOR(Without ABS)
P1753B REAR RIGHT SPEED SENSOR(With ABS)
P1764 ECU-ITM CAN ERROR
P1765 TCS-ITM CAN ERROR
P1766 CAN COMMUNICATIOM BUS OFF
P1767 ABS ACTIVE SIGNAL (CAN ERROR)
P1769 Tire Size Fault
P1770 EMC thermal Protection - Lock Mode
P1771 EMC Thermal Protection - Shutdown
#5 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
Отправлено 11 May 2021 - 18:25
G 2.0 DOHC > Engine > Unleaded EOBD
P0011 Camshaft Position-Timing Over-Advanced or System Performance(Bank 1)
P0016 Crankshaft Position-Camshaft Position Correlation(Bank 1)
P0030 O2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 1)
P0031 O2 Sensor Heater Circuit low (Bank 1 / Sensor 1)
P0032 O2 Sensor Heater Circuit high (Bank 1 / Sensor 1)
P0036 O2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 2)
P0037 O2 Sensor Heater Circuit low (Bank 1 / Sensor 2)
P0038 O2 Sensor Heater Circuit high (Bank 1 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low (Bank1)
P0077 Intake Valve Control Solenoid Circuit High (Bank1)
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0111 Intake Air Temperature Sensor 1 Circuit Range / Performance
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0116 Engine Coolant Temperature Circuit Range / Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0121 Throttle / Pedal Position Circuit Range/Performance Problem
P0122 Throttle / Pedal Position Circuit Low Input
P0123 Throttle / Pedal Position Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0130 O2 Sensor Circuit(Bank 1/ Sensor 1)
P0131 O2 Sensor Circuit Low Input(Bank 1 / Sensor 1)
P0132 O2 Sensor Circuit High Input(Bank 1 / Sensor 1)
P0133 O2-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
P0136 O2 Sensor Circuit Malfunction(Bank 1 / Sensor 2)
P0137 O2 Sensor Circuit Low Input (Bank 1 / Sensor 2)
P0138 O2 Sensor Circuit High Input (Bank 1 / Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P0170 O2 Sensor System - Lambda Controller at the Limit (Bank 1)
P0171 Fuel Trim Malfunction - System Too Lean (Bank 1)
P0172 Fuel Trim Malfunction - System Too Rich (Bank 1)
P0196 Engine Oil Temp. Sensor Range / Performance
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0230 Fuel Pump Circuit Malfunction
P0261 Cylinder 1 - Injector Circuit Low
P0262 Cylinder 1 - Injector Circuit High
P0264 Cylinder 2 - Injector Circuit Low
P0265 Cylinder 2 - Injector Circuit High
P0267 Cylinder 3 - Injector Circuit Low
P0268 Cylinder 3 - Injector Circuit High
P0270 Cylinder 4 - Injector Circuit Low
P0271 Cylinder 4 - Injector Circuit High
P0300 Multiple Cylinder Misfire Detected
P0301 Cylinder 1 - Misfire detected
P0302 Cylinder 2 - Misfire detected
P0303 Cylinder 3 - Misfire detected
P0304 Cylinder 4 - Misfire detected
P0315 Segment Time Acquisition Incorrect
P0325 Knock Sensor 1 Circuit Malfunction
P0335 Crankshaft Position Sensor Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction(Bank1 or Single Sensor)
P0420 Catalyst System Efficiency below Threshold (Bank 1)
P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted
P0501 Vehicle Speed Sensor Range / Performance
P0506 Idle Control System - RPM lower than expected
P0507 Idle Control System - RPM higher than expected
P0560 System Voltage Malfunction
P0562 System Voltage Low
P0563 System Voltage High
P0600 Serial Communication Link Malfunction
P0605 Internal Control Module Read Only Memory(ROM) Error
P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction
P0700 TCU Request for MIL ON/Freeze Frame to ECU via CAN
P1505 Idle Speed Control Actuator Signal Low of Coil #1
P1506 Idle Speed Control Actuator Signal High of Coil #1
P1507 Idle Speed Control Actuator Signal Low of Coil #2
P1508 Idle Speed Control Actuator Signal High of Coil #2
P1602 Serial Communication Problem with TCU (Timeout)
U0001 High Speed CAN Communication Bus off
U0101 Lost Communication With TCM
#6 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
G 2.0 DOHC > Transmission > Automatic Transaxle
P0703 Stop Lamp Switch(Brake SW) - Short(B+)
P0707 Transaxle Range Switch Circuit Low Input
P0708 Transaxle Range Switch Circuit High Input
P0711 Transaxle Fluid Temperature Sensor Rationality
P0712 Transaxle Fluid Temperature Sensor Circuit Low Input
P0713 Transaxle Fluid Temperature Sensor Circuit High Input
P0717 A/T Input Speed Sensor Circuit - Open or Short(GND)
P0721 A/T Output Speed Sensor Fail
P0722 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0741 Torque Converter Clutch Stuck Off
P0743 Torque Converter Clutch Control Solenoid Valve - Open or Short(GND)
P0750 Low and Reverse Solenoid Valve Circuit - Open or Short(GND)
P0755 Underdrive Solenoid Valve Circuit - Open or Short(GND)
P0760 Second Solenoid Valve Circuit - Open or Short(GND)
P0765 Overdrive Solenoid Valve Circuit - Open or Short(GND)
P1603 Can Communication Bus Off
P1604 NO ID from ECU
P1764 TCU Can Mi-Com Malfunction
P0885 A/T Control Relay Malfunction
U0100 No ID From ECU
U0001 No ID From ECU
#7 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
G 2.7 DOHC > Air Conditioner > Air Conditioner
G 2.7 DOHC > Airbag > Airbag Control
B2500 Warning Lamp
#8 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
G 2.7 DOHC > Brake > Electronic Stability Program
C1616 CAN Bus off
C2402 Motor Failure
#9 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
C1616 CAN bus off
#10 krionika Re: коды ошибок, расшифровка
  • 24639 сообщений
G 2.7 DOHC > Driveshaft > 4WD Control
Последние обсуждения по Киа Спортейдж 2 KM на MyKia.club
