Киа Соренто 1 BL
Сообщений в теме: 29
  • 24962 сообщений
Отправлено 22 April 2021 - 18:09
Коды ошибок Kia Sorento 1 (BL)
G 3.3 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1204 Air mix potentiometer open (Low) - Passenger
B1205 Air mix potentiometer short (High) - Passenger
B1208 Intake potentiometer open (Low)
B1209 Intake potentiometer short (High)
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B2406 Air mix motor (Driver)
B2408 Intake motor
B2409 Direction control motor (Driver)
B2415 Air mix motor (Driver)
  • 24962 сообщений
G 3.3 DOHC > Airbag > Airbag Control
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1103 Communication Voltage too Low
B1326 FIS-Driver short to Ground
B1327 FIS-Driver short to Battery
B1328 FIS-Driver defect
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger short to Ground
B1332 FIS-Passenger short to Battery
B1333 FIS-Passenger defect
B1335 FIS-Passenger Wrong ID
B1395 Firing loops interconnection fault
B1400 SIS front-Driver defect
B1401 SIS front-Driver circuit short to Ground
B1402 SIS front-Driver circuit short to Battery
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1414 SIS front-Driver Wrong ID
B1415 SIS front-Passenger Wrong ID
B1527 Passenger Airbag on-off switch open or leakage to Battery
B1528 Passenger Airbag on-off switch short or leakage to Ground
B1530 Passenger Airbag on-off switch instability
B1650 Crash recorded in 1st stage only (Frontal - Replace ECU)
B1651 Crash recorded in front-Driver side airbag (Replace ECU)
B1652 Crash recorded in front-Passenger side airbag (Replace ECU)
B2500 Warning lamp
B2507 PAB OFF W/LAMP FAILURE
  • 24962 сообщений
G 3.3 DOHC > Brake > ABS/ESP
C1101 Battery voltage high
C1101 Battery voltage high (ESP)
C1102 Battery voltage low
C1102 Battery voltage low (ESP)
C1200 Wheel speed sensor front-LH open/short
C1200 Wheel speed sensor front-LH open/short (ESP)
C1201 Wheel speed sensor front-LH range/performance/intermittent
C1201 Wheel speed sensor front-LH range/performance/intermittent (ESP)
C1202 Wheel speed sensor front-LH invalid/no signal
C1202 Wheel speed sensor front-LH invalid/no signal (ESP)
C1203 Wheel speed sensor front-RH open /short
C1203 Wheel speed sensor front-RH open/short (ESP)
C1204 Wheel speed sensor front-RH range/performance/intermittent
C1204 Wheel speed sensor front-RH range/performance/intermittent (ESP)
C1205 Wheel speed sensor front-RH invalid/no signal
C1205 Wheel speed sensor front-RH invalid/no signal (ESP)
C1206 Wheel speed sensor rear-LH open/short
C1206 Wheel speed sensor rear-LH open/short (ESP)
C1207 Wheel speed sensor rear-LH range/performance/intermittent
C1207 Wheel speed sensor rear-LH range/performance/intermittent (ESP)
C1208 Wheel speed sensor rear-LH invalid/no signal
C1208 Wheel speed sensor rear-LH invalid/no signal (ESP)
C1209 Wheel speed sensor rear-RH open/short
C1209 Wheel speed sensor rear-RH open/short (ESP)
C1210 Wheel speed sensor rear-RH range/performance/intermittent
C1210 Wheel speed sensor rear-RH range/performance/intermittent (ESP)
C1211 Wheel speed sensor rear-RH invalid/no signal
C1211 Wheel speed sensor rear-RH invalid/no signal (ESP)
C1213 Wheel speed frequency error
C1213 Wheel speed frequency error (ESP)
C1235 Primary Pressure Sensor- Electrical (ESP)
C1237 Pressure Sensor - Other (ESP)
C1260 Steering sensor circuit - signal (ESP)
C1261 Steering angle sensor not calibrated (ESP)
C1274 Longitudinal G sensor error
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yawrate and Lateral G Sensor - Electrical (ESP)
C1283 Yawrate and Lateral G Sensor - Signal / Other (ESP)
C1503 ESP switch error (ESP)
C1513 Brake switch error (ESP)
C1604 ECU Hardware Error
C1604 ECU Hardware Error (ESP)
C1605 CAN Hardware Error (ESP)
C1611 CAN time-out EMS (ESP)
C1612 CAN time-out TCU (ESP)
C1616 CAN bus off (ESP)
C1623 CAN time-out SAS (ESP)
C1625 CAN time-out ESP (ESP)
C1626 Implausible Control
C1626 Implausible Control (ESP)
C1627 CAN time-out 4WD (ESP)
C1702 Variant Coding (ESP)
C2112 Valve relay error
C2112 Valve relay error (ESP)
C2308 FL(IN) Valve error
C2308 FL(IN) Valve error (ESP)
C2312 FL(OUT) Valve error
C2312 FL(OUT) Valve error (ESP)
C2316 FR(IN) Valve error
C2316 FR(IN) Valve error (ESP)
C2320 FR(OUT) Valve error
C2320 FR(OUT) Valve error (ESP)
C2324 RL(IN) Valve error
C2324 RL(IN) Valve error (ESP)
C2328 RL(OUT) Valve error
C2328 RL(OUT) Valve error (ESP)
C2332 RR(IN) Valve error
C2332 RR(IN) Valve error (ESP)
C2336 RR(OUT) Valve error
C2336 RR(OUT) Valve error (ESP)
C2366 USV1 error (ESP)
C2370 USV2 error (ESP)
C2372 HSV1 error (ESP)
C2374 HSV2 error (ESP)
C2402 Motor electrical
C2402 Motor electrical (ESP)
  • 24962 сообщений
G 3.3 DOHC > Driveshaft > 4WD Control
P1739 General position encorder error
P1728 EMC-open/short to battery
P1729 EMC-shorted to ground
P1730 Front speed sensor voltage Low
P1731 Front speed sensor voltage High
P1732 Rear speed sensor voltage Low
P1733 Rear Speed sensor voltage High
P1734 Vehicle speed sensor reference Voltage Low
P1735 Vehicle speed sensor reference Voltage High
P1736 motor open/short to battery
P1737 Motor open/shorted to ground
P1738 Shift system timeout
P1740 Position 1 shorted to ground
P1741 Position 2 shorted to ground
P1742 Position 3 shorted to ground
P1743 Position 4 shorted to ground
P1781 Invalid TQ_STND signal
U0001 High Speed CAN Communication Bus
U0100 Lost Communication With ECM/PCM "A"
U0101 Lost Communication with TCM
U0122 Lost Communication With Vehicle Dynamics Control Module
  • 24962 сообщений
Отправлено 22 April 2021 - 18:10
G 3.3 DOHC > Immobilizer > Immobilizer
P1690 SMARTRA no response
P1692 Immobilizer Lamp error
P1693 Transponder no response error/Invalid response
P1695 EMS memory error
P1696 Authentication fail
P1697 Hi-Scan message error
P1698 TRANSPONDER INVALID
G 3.3 DOHC > Transmission > RXC
P0705 Transmission Range Sensor Circuit Malfunction (PRND Input)
P0711 Transmission Fluid Temperature Sensor a Rationality
P0712 Transmission Fluid Temperature Sensor a Stuck Off(High Input)
P0713 Transmission Fluid Temperature Sensor a Stuck On(Low Input)
P0716 A/T Input Speed Sensor Circuit - Open or Short(GND)
P0721 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0743 TCC Control Solenoid Valve Circuit - Open or Short(GND)
P0748 Pressure Control Solenoid Valve-A Circuit - Open or Short(GND)
P0751 Shift Solenoid "A(I/C Solenoid)" Performance or Stuck Off
P0752 Shift Solenoid "A(I/C Solenoid)" Performance or Stuck On
P0753 Shift Solenoid "A(I/C Solenoid)" Circuit - Open or Short(GND)
P0756 Shift Solenoid "B(Fr/B Solenoid)" Performance or Stuck Off
P0757 Shift Solenoid "B(Fr/B SOLENOID)" Performance or Stuck On
P0758 Shift Solenoid "B(Fr/B SOLENOID)" Circuit - Open or Short(GND)
P0761 Shift Solenoid "C(D/C Solenoid)" Performance or Stuck Off
P0762 Shift Solenoid "C(D/C Solenoid)" Performance or Stick On
P0763 Shift Solenoid "C(D/C Solenoid)" Circuit - Open or Short(GND)
P0766 Shift Solenoid "D(H and LR/C Solenoid)" Performance or Stuck Off
P0767 Shift Solenoid "D(H and LR/C Solenoid)" Performance or Stuck On
P0768 Shift Solenoid "D(H and LR/C Solenoid)" Circuit - Open or Short(GND)
P0772 Shift Solenoid "D(LC/B Solenoid)" Performance or Stuck On
P0773 Shift Solenoid "E(LC/B Solenoid)" Circuit - Open or Short(GND)
P0863 CAN Communication Bus Off
P0893 Multiple Gears Engaged
  • 24962 сообщений
D 2.5 WGT > Air Conditioner > Air Conditioner
B2408 Intake motor
  • 24962 сообщений
D 2.5 WGT > Airbag > Airbag Control
B2500 Warning lamp
  • 24962 сообщений
D 2.5 WGT > Brake > ABS/ESP
  • 24962 сообщений
D 2.5 WGT > Driveshaft > 4WD Control
  • 24962 сообщений
D 2.5 WGT > Driveshaft > 4WD FULLTIME(FR)
P0836 Four Wheel Drive (4WD) Switch Circuit
P1759 Hubs Control Circuit Fault
