Киа Соренто 1 BL
Сообщений в теме: 29
#21 krionika
Отправлено 22 April 2021 - 18:12
D 2.5 VGT > Immobilizer > Immobilizer
P1690 SMARTRA no response
P1692 Immobilizer Lamp error
P1693 Transponder no response error/Invalid response
P1695 EMS memory error
P1696 Authentication fail
P1697 Hi-Scan message error
P1698 TRANSPONDER INVALID
D 2.5 VGT > Transmission > Automatic Transaxle
P0705 Transmission Range Sensor Circuit Malfunction (PRND Input)
P0711 Transmission Fluid Temperature Sensor a Rationality
P0712 Transmission Fluid Temperature Sensor a Stuck Off(High Input)
P0713 Transmission Fluid Temperature Sensor a Stuck On(Low Input)
P0716 A/T Input Speed Sensor Circuit - Open or Short(GND)
P0721 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0743 TCC Control Solenoid Valve Circuit - Open or Short(GND)
P0748 Pressure Control Solenoid Valve-A Circuit - Open or Short(GND)
P0751 Shift Solenoid "A(I/C Solenoid)" Performance or Stuck Off
P0752 Shift Solenoid "A(I/C Solenoid)" Performance or Stuck On
P0753 Shift Solenoid "A(I/C Solenoid)" Circuit - Open or Short(GND)
P0756 Shift Solenoid "B(Fr/B Solenoid)" Performance or Stuck Off
P0757 Shift Solenoid "B(Fr/B SOLENOID)" Performance or Stuck On
P0758 Shift Solenoid "B(Fr/B SOLENOID)" Circuit - Open or Short(GND)
P0761 Shift Solenoid "C(D/C Solenoid)" Performance or Stuck Off
P0762 Shift Solenoid "C(D/C Solenoid)" Performance or Stick On
P0763 Shift Solenoid "C(D/C Solenoid)" Circuit - Open or Short(GND)
P0766 Shift Solenoid "D(H and LR/C Solenoid)" Performance or Stuck Off
P0767 Shift Solenoid "D(H and LR/C Solenoid)" Performance or Stuck On
P0768 Shift Solenoid "D(H and LR/C Solenoid)" Circuit - Open or Short(GND)
P0772 Shift Solenoid "D(LC/B Solenoid)" Performance or Stuck On
P0773 Shift Solenoid "E(LC/B Solenoid)" Circuit - Open or Short(GND)
P0863 CAN Communication Bus Off
P0893 Multiple Gears Engaged
G 2.4 DOHC > Steering > Electronic Power Steering
C1001 EPS ECU Failure
C1012 Vehicle Acceleration or Deceleration Excess
C1017 Solenoid Open, Short to Ground/Battery
G 2.4 DOHC > Airbag > Airbag Control
B1101 Battery voltage high
B1102 Battery voltage low
B1326 FIS-Driver short to Ground
B1327 FIS-Driver short to Battery
B1328 FIS-Driver defect
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger short to Ground
B1332 FIS-Passenger short to Battery
B1333 FIS-Passenger defect
B1335 FIS-Passenger Wrong ID
B1395 Firing loops interconnection fault
B1400 SIS front-Driver defect
B1401 SIS front-Driver circuit short to Ground
B1402 SIS front-Driver circuit short to Battery
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1414 SIS front-Driver Wrong ID
B1415 SIS front-Passenger Wrong ID
B1511 Buckle Switch Driver open or short to Battery
B1512 Buckle Switch Driver short or short to Ground
B1513 Buckle Switch Passenger open or short to Battery
B1514 Buckle Switch Passenger short or short to Ground
B1515 Buckle Switch Driver defect
B1516 Buckle Switch Passenger defect
B1650 Crash recorded in 1st stage only (Frontal - Replace ECU)
B1651 Crash recorded in front-Driver side airbag (Replace ECU)
B1652 Crash recorded in front-Passenger side airbag (Replace ECU)
B2500 Warning lamp
G 2.4 DOHC > Brake > Anti-Lock Brake
C0035 LF Wheel Speed Sensor Circuit Malfunction
C0040 RF Wheel Speed Sensor Circuit Malfunction
C0045 LR Wheel Speed Sensor Circuit Malfunction
C0050 RR Wheel Speed Sensor Circuit Malfunction
C0060 LF ABS Solenoid or Motor #1 Circuit Malfunction(Outlet Valve)
C0065 LF ABS Solenoid or Motor #2 Circuit Malfunction(Inlet Valve)
C0070 RF ABS Solenoid or Motor #1 Circuit Malfunction(Outlet Valve)
C0075 RF ABS Solenoid or Motor #2 Circuit Malfunction(Inlet Valve)
C0080 LR ABS Solenoid or Motor #1 Circuit Malfunction(Outlet Valve)
C0085 LR ABS Solenoid or Motor #2 Circuit Malfunction(Inlet Valve)
C0090 RR ABS Solenoid or Motor #1 Circuit Malfunction(Outlet Valve)
C0095 RR ABS Solenoid or Motor #2 Circuit Malfunction(Inlet Valve)
C0110 Electrical(Pump-motor) Circuit Malfunction
C0121 Valve Relay Circuit Malfunction
C0161 ABS Brake Switch Circuit Malfunction
C0245 Wheel Speed Sensor Frequency Error
C0550 ECU Malfunction
C0800 Device Power #1(Low Current #1)Circuit Malfunction
C0930 Longitudinal Acceleration Sensor
G 2.4 DOHC > Driveshaft > 4WD(EST-MANUAL)
P1739 General position encoder Fault
P1725 EEPROM checksum fault
P1726 TPS/APS input - loss of signal
P1727 TPS/APS input - out of signal
P1728 EMC-open/short to battery
P1729 EMC-shorted to ground
P1730 Front speed sensor voltage Low
P1731 Front speed sensor voltage High
P1732 Rear speed sensor voltage Low
P1733 Rear Speed sensor voltage High
P1734 Vehicle speed sensor reference Voltage Low
P1735 Vehicle speed sensor reference Voltage High
P1736 Shift motor-open/short to battery
P1737 Shift motor-shorted to ground
P1738 Shift system timeout
P1740 Position 1 shorted to ground
P1741 Position 2 shorted to ground
P1742 Position 3 shorted to ground
P1743 Position 4 shorted to ground
Отправлено 22 April 2021 - 18:13
G 2.4 DOHC > Driveshaft > 4WD(TOD-AUTO)
001 TCCU MODULE
010 SHIFT MOTOR
011 MAGNETIC S/CLUTCH
100 SPEED SENSOR
101 HUB SOLENOID VALVE
110 SELECTOR SWITCH
111 MOTOR POSITION SENSOR
G 2.4 DOHC > Engine > Unleaded All
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0103 Mass or Volume Air Flow Circuit High Input
P0107 Manifold Absolute Pressure Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure Sensor Circuit High Voltage
P0116 Engine Coolant Trmperature Sensor (ECTS) Circuit Range/Performance
P0117 Engine Coolant Temperature(ECT) Circuit Low
P0118 Engine Coolant Temperature(ECT) Circuit High
P0121 Throttle Position Sensor(TPS) Circuit Range/Performance Problem
P0122 Throttle Position Sensor Circuit Low Input
P0123 Throttle Position Sensor Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0130 HO2 Sensor Circuit Malfunction(Bank 1 / Sensor 1)
P0131 HO2 Sensor Circuit Low Voltage(Bank 1 / Sensor 1)
P0132 HO2 Sensor Circuit High Voltage(Bank 1 / Sensor 1)
P0133 HO2 Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 HO2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
P0135 HO2 Sensor Heater Circuit Malfunction(Bank 1/Sensor 1)
P0136 HO2 Sensor Circuit Malfunction (Bank 1/ Sensor 2)
P0137 HO2 Sensor Circuit Low Voltage(Bank 1 / Sensor 2)
P0138 HO2 Sensor Circuit High Voltage(Bank 1 / Sensor 2)
P0141 HO2S Sensor Heater Circuit Malfunction(Bank 1 / Sensor 2)
P0171 Fuel System Too Lean (Bank 1)
P0172 Fuel System Too Rich (Bank 1)
P0201 Injector Circuit/Open-Cylinder1
P0202 Injector Circuit/Open-Cylinder2
P0203 Injector Circuit/Open-Cylinder3
P0204 Injector Circuit/Open-Cylinder4
P0301 Cylinder 1-Misfire Detected
P0302 Cylinder 2-Misfire Detected
P0303 Cylinder 3-Misfire Detected
P0304 Cylinder 4-Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit
P0325 Knock Sensor 1 Circuit
P0335 Crankshaft Position Sensor Circuit Malfunciton
P0340 Camshaft Position Sensor Circuit Malfunciton
P0350 Ignition Coil Primary / Secondary Circuit
P0421 Warm up Catalyst Efficiency below Threshold (Bank 1)
P0441 Evap. Emission Ctrl. System Purge Solenoid Stuck
P0443 Evap. Emission Ctrl. System Purge Solenoid Valve Circuit Malfunction
P0500 Vehicle Speed Sensor Circuit Malfunction
P0700 TCU Request for MIL On/Freeze Frame to ECU via CAN
P1330 Spark Timing Adust
P1632 Serial Communication Link Malfunction
G 2.4 DOHC > Immobilizer > Immobilizer
ECM Request Signal Error
EEPROM Communication Error
Transponder Communication Error
ECM Communication Link Malfunction
P1690 Immobilizer - SMARTRA Error
P1692 Immobilizer - IND. Lamp Error
P1693 Immobilizer - Transponder Error
P1695 Immobilizer - EEPROM Error
P1696 Immobilizer - Key Mismatched
P1697 Immobilizer - Invalid Tester Request
P1698 Immobilizer - Key ID. not Valid
G 2.4 DOHC > Transmission > Automatic Transaxle
 G 3.5 DOHC > Steering > Electronic Power Steering
G 3.5 DOHC > Airbag > Airbag Control
B2500 Warning lamp
G 3.5 DOHC > Brake > Anti-Lock Brake
G 3.5 DOHC > Driveshaft > 4WD(EST-MANUAL)
G 3.5 DOHC > Driveshaft > 4WD(TOD-AUTO)
001 TCCU MODULE
010 SHIFT MOTOR
100 SPEED SENSOR
110 SELECTOR SWITCH
G 3.5 DOHC > Engine > Engine Control
P0037 HO2S Heater Circuit low (Bank 1 / Sensor 2)
P0038 HO2S Heater Circuit high (Bank 1 / Sensor 2)
P0051 HO2S Heater Circuit low (Bank 2 / Sensor 1)
P0052 HO2S Heater Circuit high (Bank 2 / Sensor 1)
P0057 HO2S Heater Circuit low (Bank 2 / Sensor 2)
P0058 HO2S Heater Circuit high (Bank 2 / Sensor 2)
P0101 Mass Air Flow Circuit Range / Performance
P0107 Manifold Absolute Pressure Sensor Circuit Low Input
P0108 Manifold Absolute Pressure Sensor Circuit High Input
P0116 Engine Coolant Trmperature Circuit Range/Performance Problem
P0121 Throttle Position Sensor Circuit Malfunction
P0150 HO2 Sensor Circuit Malfunction (Bank 2 / Sensor 1)
P0151 HO2 Sensor Circuit Low Voltage(Bank 2 / Sensor 1)
P0152 HO2 Sensor Circuit High Voltage(Bank 2 / Sensor 1)
P0153 HO2-Sensor Circuit Slow Response (Bank 2 / Sensor 1)
P0154 HO2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 1)
P0156 HO2 Sensor Circuit Malfunction (Bank 2/ Sensor 2)
P0157 HO2 Sensor Circuit Low Voltage(Bank 2 / Sensor 2)
P0158 HO2 Sensor Circuit High Voltage(Bank 2 / Sensor 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0205 Injector Circuit/Open – Cylinder 5
P0206 Injector Circuit/Open – Cylinder 6
P0305 Cylinder 5 - Misfire detected
P0306 Cylinder 6 - Misfire detected
P0350 Ignition Coil Circuit Malfunction
P0431 Warm up Catalyst Efficiency below Threshold (Bank 2)
P0506 Idle Air Control System - RPM lower than expected
P0507 Idle Air Control System - RPM higher than expected
P0510 Closed Throttle Position Switch
Отправлено 22 April 2021 - 18:14
G 3.5 DOHC > Immobilizer > Immobilizer
G 3.5 DOHC > Transmission > Automatic Transaxle
