D 2.5 WGT > Steering > Electronic Power Steering
C1001 EPS ECU Failure
C1012 Vehicle Acceleration or Deceleration Excess
C1017 Solenoid Open, Short to Ground/Battery
D 2.5 WGT > Engine > Engine Control
P0120 Accelerator Position Sensor 1-General Error
P0100 Mass or Volume Air Flow Circuit Malfunction
P0107 Barometric Pressure Circuit Low Input
P0108 Barometric Pressure Circuit High Input
P0123 Accelerator Position Sensor 1-High Input
P0190 Fuel Rail Pressure Sensor-General Error
P0192 Fuel Rail Pressure Sensor Circuit Low input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0220 Accelerator Position Sensor 2-General Error
P0223 Accelerator Position Sensor 2-High Input
P0234 Turbocharger/Supercharger Overboost Condition
P0261 Cylinder 1-Injector Circuit Low
P0263 Cylinder 1-Injector Circuit Balance
P0264 Cylinder 2-Injector Circuit Low
P0266 Cylinder 2-Injector Circuit Balance
P0267 Cylinder 3-Injector Circuit Low
P0269 Cylinder 3-Injector Circuit Balance
P0270 Cylinder 4-Injector Circuit Low
P0272 Cylinder 4-Injector Circuit Balance
P0299 Turbocharger/Supercharger Underboost
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0341 Camshaft Position Sensor "A" Circuit Range/Performance
P0343 Camshaft Position Sensor "A" Circuit High Input
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0503 Vehicle Speed Sensor A Intermittent/Erratic/High
P0504 Brake pedal position A/B correaltion
P0562 System Voltage Low
P0563 System Voltage High
P0600 CAN Communication BUS
P0602 EEPROM error - programing error
P0603 EEPROM communication error
P0606 ECM/PCM Processor
P0642 Sensor Reference Voltage “A” Circuit Low
P0643 Sensor Reference Voltage “A” Circuit High
P0652 Sensor Reference Voltage “B” Circuit Low
P0653 Sensor Reference Voltage “B” Circuit High
P0704 Clutch S/W Malfunction
P1183 Fuel Pressure Regulator-Open or Short Circuit
P1185 Maximum Pressure Exceeded
P1186 Minimum Pressure at Engine Speed Too Low
P1187 Fuel Pressure Monitoring-Regulator Valve Stick
P1188 Fuel Pressure Monitoring-Leakage
P1300 CMP/Engine Speed Sensor-Synchronization Error (CKP/CMP plausibility)
P1321 Glow Indicator Lamp-Short Circuit
P1326 Glow Relay-Short Circuit
P1327 Glow Relay-Open or Short Circuit
P1522 Sensor Supply Voltage 1-Low Input
P1523 Sensor Supply Voltage 1-High Input
P1524 Sensor Supply Voltage 2-Low Input
P1525 Sensor Supply Voltage 2-High Input
P1540 Neutral Switch-Short Circuit
P1541 Neutral Switch-Open or Short Circuit
P1603 CAN Communication BUS OFF
P1616 Main Relay Malfunction
P1634 Minimum fault
P1636 Voltage regulator for injector
P1638 ECM (CPU Error)
P1639 ECM (ADC Error)
P1646 Capacitor 1 voltage-High Input
P1647 Capacitor 1 voltage-Low Input
P1652 IG S/W Malfunction
P1653 After-Rrun Check Error
P1670 Invalid Injector IQA/C2I(read or write error)
P2135 Accelerator Position Sensor-Range/Performance
P2138 Throttle/Pedal Position Sensor/Switch “D” / “E” Voltage Correlation
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
#11
Отправлено 22 April 2021 - 18:10
Re: коды ошибок, расшифровка
Отправлено 22 April 2021 - 18:11
D 2.5 WGT > Fuel Fired Heater > Fuel Fired Heater
1001 Control Unit Erroneous or Wrong Checksum
2001 Control Unit Erroneous or Wrong Checksum
1002 No Start
2002 No Start
1003 Fame-Out During Operation with no Further Flame-up
2003 Flame-Out During Operation with no Further Flame-up
1013 3Time Flame-Out During Heating Cycle
2013 3Time Flame-Out During Heating Cycle
1C04 Overvoltage
2C04 Overvoltage
1A05 Undervoltage
2A05 Undervoltage
1006 Flame Prior to Combustion Opeation
2006 Flame Prior to Combustion Operaton
1C07 Overheating(Water Temperature>125°C)
2C07 Overheating(Water Temperature>125°C)
1608 Dosing Pump:Short Circuit Against Ground
2608 Dosing Pump:Short Circuit Against Ground
1818 Dosing Pump:Open Circuit Against Ground+UB
2818 Dosing Pump:Open Circuit Against Ground+UB
1609 Combustion Air Fan:Short Circuit Against Ground
2609 Combustion Air Fan: Short Circuit Against Ground
1819 Combustion Air Fan:Open Circuit or Short Circuit Against+UB
2819 Combustion Air Fan:Open Circuit or Short Circuit Against+UB
160A Glow Plug:Short Circuit Against Ground
260A Glow Plug:Short Circuit Against Ground
181A Glow Plug:Open Circuit
281A Glow Plug:Open Circuit
160B Water Pump:Short Circuit Against Ground
260B Water Pump:Short Circuit Against Ground
181B Water Pump:Open Circuit
281B Water Pump:Open Circuit
D 2.5 WGT > Immobilizer > Immobilizer
P1690 SMARTRA no response
P1692 Immobilizer Lamp error
P1693 Transponder no response error/Invalid response
P1695 EMS memory error
P1696 Authentication fail
P1697 Hi-Scan message error
P1698 TRANSPONDER INVALID
D 2.5 WGT > Transmission > Automatic Transaxle
P0705 Transmission Range Sensor Circuit Malfunction (PRND Input)
P0711 Transmission Fluid Temperature Sensor a Rationality
P0712 Transmission Fluid Temperature Sensor a Stuck Off(High Input)
P0713 Transmission Fluid Temperature Sensor a Stuck On(Low Input)
P0716 A/T Input Speed Sensor Circuit - Open or Short(GND)
P0721 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0743 TCC Control Solenoid Valve Circuit - Open or Short(GND)
P0748 Pressure Control Solenoid Valve-A Circuit - Open or Short(GND)
P0751 Shift Solenoid "A(I/C Solenoid)" Performance or Stuck Off
P0752 Shift Solenoid "A(I/C Solenoid)" Performance or Stuck On
P0753 Shift Solenoid "A(I/C Solenoid)" Circuit - Open or Short(GND)
P0756 Shift Solenoid "B(Fr/B Solenoid)" Performance or Stuck Off
P0757 Shift Solenoid "B(Fr/B SOLENOID)" Performance or Stuck On
P0758 Shift Solenoid "B(Fr/B SOLENOID)" Circuit - Open or Short(GND)
P0761 Shift Solenoid "C(D/C Solenoid)" Performance or Stuck Off
P0762 Shift Solenoid "C(D/C Solenoid)" Performance or Stick On
P0763 Shift Solenoid "C(D/C Solenoid)" Circuit - Open or Short(GND)
P0766 Shift Solenoid "D(H and LR/C Solenoid)" Performance or Stuck Off
P0767 Shift Solenoid "D(H and LR/C Solenoid)" Performance or Stuck On
P0768 Shift Solenoid "D(H and LR/C Solenoid)" Circuit - Open or Short(GND)
P0772 Shift Solenoid "D(LC/B Solenoid)" Performance or Stuck On
P0773 Shift Solenoid "E(LC/B Solenoid)" Circuit - Open or Short(GND)
P0863 CAN Communication Bus Off
P0893 Multiple Gears Engaged
D 2.5 VGT > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1204 Air mix potentiometer open (Low) - Passenger
B1205 Air mix potentiometer short (High) - Passenger
B1208 Intake potentiometer open (Low)
B1209 Intake potentiometer short (High)
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B2406 Air mix motor (Driver)
B2408 Intake motor
B2409 Direction control motor (Driver)
B2415 Air mix motor (Driver)
D 2.5 VGT > Airbag > Airbag Control
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1103 Communication Voltage too Low
B1326 FIS-Driver short to Ground
B1327 FIS-Driver short to Battery
B1328 FIS-Driver defect
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger short to Ground
B1332 FIS-Passenger short to Battery
B1333 FIS-Passenger defect
B1335 FIS-Passenger Wrong ID
B1395 Firing loops interconnection fault
B1400 SIS front-Driver defect
B1401 SIS front-Driver circuit short to Ground
B1402 SIS front-Driver circuit short to Battery
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1414 SIS front-Driver Wrong ID
B1415 SIS front-Passenger Wrong ID
B1527 Passenger Airbag on-off switch open or leakage to Battery
B1528 Passenger Airbag on-off switch short or leakage to Ground
B1530 Passenger Airbag on-off switch instability
B1650 Crash recorded in 1st stage only (Frontal - Replace ECU)
B1651 Crash recorded in front-Driver side airbag (Replace ECU)
B1652 Crash recorded in front-Passenger side airbag (Replace ECU)
B2500 Warning lamp
B2507 PAB OFF W/LAMP FAILURE
D 2.5 VGT > Brake > ABS/ESP
C1101 Battery voltage high
C1101 Battery voltage high (ESP)
C1102 Battery voltage low
C1102 Battery voltage low (ESP)
C1200 Wheel speed sensor front-LH open/short
C1200 Wheel speed sensor front-LH open/short (ESP)
C1201 Wheel speed sensor front-LH range/performance/intermittent
C1201 Wheel speed sensor front-LH range/performance/intermittent (ESP)
C1202 Wheel speed sensor front-LH invalid/no signal
C1202 Wheel speed sensor front-LH invalid/no signal (ESP)
C1203 Wheel speed sensor front-RH open /short
C1203 Wheel speed sensor front-RH open/short (ESP)
C1204 Wheel speed sensor front-RH range/performance/intermittent
C1204 Wheel speed sensor front-RH range/performance/intermittent (ESP)
C1205 Wheel speed sensor front-RH invalid/no signal
C1205 Wheel speed sensor front-RH invalid/no signal (ESP)
C1206 Wheel speed sensor rear-LH open/short
C1206 Wheel speed sensor rear-LH open/short (ESP)
C1207 Wheel speed sensor rear-LH range/performance/intermittent
C1207 Wheel speed sensor rear-LH range/performance/intermittent (ESP)
C1208 Wheel speed sensor rear-LH invalid/no signal
C1208 Wheel speed sensor rear-LH invalid/no signal (ESP)
C1209 Wheel speed sensor rear-RH open/short
C1209 Wheel speed sensor rear-RH open/short (ESP)
C1210 Wheel speed sensor rear-RH range/performance/intermittent
C1210 Wheel speed sensor rear-RH range/performance/intermittent (ESP)
C1211 Wheel speed sensor rear-RH invalid/no signal
C1211 Wheel speed sensor rear-RH invalid/no signal (ESP)
C1213 Wheel speed frequency error
C1213 Wheel speed frequency error (ESP)
C1235 Primary Pressure Sensor- Electrical (ESP)
C1237 Pressure Sensor - Other (ESP)
C1260 Steering sensor circuit - signal (ESP)
C1261 Steering angle sensor not calibrated (ESP)
C1274 Longitudinal G sensor error
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yawrate and Lateral G Sensor - Electrical (ESP)
C1283 Yawrate and Lateral G Sensor - Signal / Other (ESP)
C1503 ESP switch error (ESP)
C1513 Brake switch error (ESP)
C1604 ECU Hardware Error
C1604 ECU Hardware Error (ESP)
C1605 CAN Hardware Error (ESP)
C1611 CAN time-out EMS (ESP)
C1612 CAN time-out TCU (ESP)
C1616 CAN bus off (ESP)
C1623 CAN time-out SAS (ESP)
C1625 CAN time-out ESP (ESP)
C1626 Implausible Control
C1626 Implausible Control (ESP)
C1627 CAN time-out 4WD (ESP)
C1702 Variant Coding (ESP)
C2112 Valve relay error
C2112 Valve relay error (ESP)
C2308 FL(IN) Valve error
C2308 FL(IN) Valve error (ESP)
C2312 FL(OUT) Valve error
C2312 FL(OUT) Valve error (ESP)
C2316 FR(IN) Valve error
C2316 FR(IN) Valve error (ESP)
C2320 FR(OUT) Valve error
C2320 FR(OUT) Valve error (ESP)
C2324 RL(IN) Valve error
C2324 RL(IN) Valve error (ESP)
C2328 RL(OUT) Valve error
C2328 RL(OUT) Valve error (ESP)
C2332 RR(IN) Valve error
C2332 RR(IN) Valve error (ESP)
C2336 RR(OUT) Valve error
C2336 RR(OUT) Valve error (ESP)
C2366 USV1 error (ESP)
C2370 USV2 error (ESP)
C2372 HSV1 error (ESP)
C2374 HSV2 error (ESP)
C2402 Motor electrical
C2402 Motor electrical (ESP)
D 2.5 VGT > Driveshaft > 4WD Control
P1739 General position encorder error
P1728 EMC-open/short to battery
P1729 EMC-shorted to ground
P1730 Front speed sensor voltage Low
P1731 Front speed sensor voltage High
P1732 Rear speed sensor voltage Low
P1733 Rear Speed sensor voltage High
P1734 Vehicle speed sensor reference Voltage Low
P1735 Vehicle speed sensor reference Voltage High
P1736 motor open/short to battery
P1737 Motor open/shorted to ground
P1738 Shift system timeout
P1740 Position 1 shorted to ground
P1741 Position 2 shorted to ground
P1742 Position 3 shorted to ground
P1743 Position 4 shorted to ground
P1781 Invalid TQ_STND signal
U0001 High Speed CAN Communication Bus
U0100 Lost Communication With ECM/PCM "A"
U0101 Lost Communication with TCM
U0122 Lost Communication With Vehicle Dynamics Control Module
D 2.5 VGT > Driveshaft > 4WD FULLTIME(FR)
P0836 Four Wheel Drive (4WD) Switch Circuit
P1759 Hubs Control Circuit Fault
Отправлено 22 April 2021 - 18:12
D 2.5 VGT > Steering > Electronic Power Steering
D 2.5 VGT > Engine > Engine Control
P0031 HO2S Heater Circuit low (Bank 1 Sensor 1)
P0032 HO2S Heater Circuit high (Bank 1 Sensor 1)
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0069 Manifold Absolute Pressure – Barometric Pressure Correlation
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0091 Fuel Pressure Regulator 1 Control Circuit Low
P0092 Fuel Pressure Regulator 1 Control Circuit High
P0097 Intake Air Temperature Sensor 2 Circuit Low
P0098 Intake Air Temperature Sensor 2 Circuit High
P0101 Mass or Volume Air Flow Circuit Range / Performance Problem
P0201 Injector Circuit/Open – Cylinder 1
P0202 Injector Circuit/Open – Cylinder 2
P0203 Injector Circuit/Open – Cylinder 3
P0204 Injector Circuit/Open – Cylinder 4
P0237 Turbo/Super Charger Boost Sensor "A" Circuit Low
P0238 Turbo/Super Charger Boost Sensor "A" Circuit High
P0252 Injection Pump Fuel Metering Control "A" Range/Performance
P0253 Injection Pump Fuel Metering Control "A" Low
P0254 Injection Pump Fuel Metering Control "A" High
P0340 Camshaft Position Sensor "A" Circuit
P0381 Glow Plug/Heater Indicator Circuit
P0401 Exhaust Gas Recirculation Flow Insufficent Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0611 Fuel Injector Control Module Performance
P062D Fuel Injector Driver Circuit Performance Bank 1
P062E Fuel Injector Driver Circuit Performance Bank 2
P0670 Glow Plug Module Control Circuit
P0700 Error path for OBD relevant error in TCU
P0701 Error path for TCU fault status
P0820 Gear Lever X-Y Position Sensor Circuit
P0830 Clutch Pedal Switch "A" Circuit
P1145 Overrun Monitoring Error
P1586 Variant dataset switching
P1587 GearbxMTAT
P1588 GearbxMTATVal
P1610 Non-Immobilizer-EMS connected to an Immobilizer
P1630 Short Circuit Battery
P1634 Minimum fault
P1671 Injector IQA checksum error
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit High Input
P2238 O2 Sensor Pumping Current Circuit Low (Bank 1 Sensor 1)
P2239 O2 Sensor Pumping Current Circuit High (Bank 1 Sensor 1)
P2251 O2 Sensor Reference Ground Circuit/Open (Bank 1 Sensor 1)
P2264 Water in Fuel Sensor Circuit
D 2.5 VGT > Fuel Fired Heater > Fuel Fired Heater
1002 No Start
2002 No Start
1C04 Overvoltage
2C04 Overvoltage
1A05 Undervoltage
2A05 Undervoltage
Киа Соренто 1 BL
Киа Соренто клуб →
блок ETACS дает команду на аварийное релеАвтор Alexander737, 03 Feb 2025 |
Киа Соренто 1 BL
Киа Соренто клуб →
Двигатель и КПП Kia Sorento →
замена АКППАвтор krionika, 14 Jul 2011 |
Киа Соренто 1 BL
Киа Соренто клуб →
характеристики двигателяАвтор krionika, 01 Aug 2011 |
Киа Соренто 1 BL
Киа Соренто клуб →
момент затяжки двигателяАвтор krionika, 12 Oct 2011 |
Киа Соренто 1 BL
Киа Соренто клуб →
самодиагностикаАвтор rus tam, 05 Feb 2024 |
