Киа Маджентис 1 MS
Сообщений в теме: 15
Отправлено 14 April 2021 - 18:36
G 2.0 DOHC > Immobilizer > Immobilizer
ECM Request Signal Error
EEPROM Communication Error
Transponder Communication Error
ECM Communication Link Malfunction
G 2.0 DOHC > Engine > A/T(Unleaded)
P0105 Manifold Absolute Pressure (MAP) Sensor Circuit Malfunction
P0110 Intake Air Temperature Sensor 1 Circuit
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0202 Injector Circuit-Cylinder 2
P0203 Injector Circuit-Cylinder 3
P0204 Injector Circuit-Cylinder 4
P0350 Ignition Coil Primary / Secondary Circuit
P0500 Vehicle Speed Sensor
P1330 Spark Timing Adjust Signal
P1520 Alternator FL signal malfunction
P0100 Mass or Volume Air Flow Circuit
P0135 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0141 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0172 System too Rich (Bank 1)
P0421 Warm Up Catalyst Efficiency below Threshold (Bank 1)
P0441 Evaporative Emission System Incorrect Purge Flow
P0443 Evaporative Emission System-Purge Control Valve Circuit
Отправлено 14 April 2021 - 18:37
P0703 Stop Lamp (Brake) Switch Circuit Malfunction
P0707 Transaxle range switch open circuit
P0708 Transaxle range switch short circuit
P0712 Fluid(Oil) Temperature Circuit Low
P0713 Fluid(Oil) Temperature Circuit High
P0715 Input/Turbine Speed Sensor "A" Circuit
P0720 Output Speed Sensor (Pulse Generator B) Circuit
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Gear Incorrect Ratio
P0741 Torque Converter Clutch(TCC) system defect/stuck onl
P0742 Torque Converter Clutch(TCC) system defect/stuck onl
P0750 Shift Control Solenoid Valve "A" (Low-Reverse Brake Control Solenoid)-Open or Short
P0755 UD solenoid valve line
P0760 2nd solenoid valve line
P0765 OD solenoid valve line
P1723 TCM Power Relay Open or Short (Ground)
G 2.4 DOHC > Airbag > Airbag Control
B1111 Ignition Voltage High
B1112 Battery Voltage Too Low
B1347 DAB Resistance Too Low or Short
B1353 PAB Resistance Too Low or Short
B1362 Driver Seat Belt Pretensioner Resistance Too Low or Short
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1367 Passenger Seat Belt Pretensioner Resistane Too High or Open
B1368 Passenger Seat Belt Pretensioner Resistane Too Low or Short
B1369 Passenger Seat Belt Pretensioner Short To GND
B1370 Passenger Seat Belt Pretensioner Short To Battery
B1379 Driver Side Air Bag, Resistance Too Low or Short
B1382 Passenger Side Air Bag, Resistance too High or Open
B1383 Passenger Side Air Bag, Resistance too Low or Short
B1384 Passenger Side Air Bag, Short to GND
B1385 Passenger Side Air Bag, Short to Battery
B1400 SIS(Side Impact Sensor) Front-Driver Defect
B1401 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B1403 Satellite Right Side Defect
B1404 Satellite Right Side Short to GND or Short
B1405 Satellite Right Side Short to Battery or Open
B1406 Passenger Presence Detection Front-Passenger Defect
B1407 PPD Communication Error
B1408 Satellite Left Communication Error
B1410 Satellite Right Communication Error
B1511 Buckle Switch Driver Open or Short to Battery
B1512 Driver Seat-Belt Buckle Switch Short to GND or Short
B1513 Passenger Seat-Belt Buckle Switch short to Battery or Open
B1514 Passenger Seat-Belt Buckle Switch short to GND or Short
B1620 SRSCM Internal Failure
B1650 Crash Recorded Front Airbag
B1655 Crash Recorded Side Airbag
B1657 Ignition Recorded Belt Pretensioner
B1661 ECU Mismatching
B2500 Warning Lamp Failure
G 2.4 DOHC > Brake > Anti-Lock Brake(Mando)
C1103 Battery Voltage Out of Range
C1161 Brake Switch Circuit
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1203 Wheel speed sensor(FR)-open or short to GND circuit
C1204 Wheel speed sensor (FR)-Plausibility fault
C1206 Wheel speed sensor(RL)-open or short to GND circuit
C1207 Wheel speed sensor(RL)-Plausibility fault
C1209 Wheel speed sensor(RR)-open or short to GND circuit
C1210 Wheel speed sensor(RR)-Plausibility fault
C1245 Wheel Speed Frequency Error
C1604 ECU(Brake System) Hardware error
C2112 Main Relay Circuit
C2114 Disturbance(Including Valve failures)
C2402 Motor Electrical
C1605 CAN Bus Off
C1611 Lost Communication with ECM
G 2.4 DOHC > Immobilizer > Immobilizer
G 2.4 DOHC > Engine > Engine Control
P0107 Manifold Absolute Pressure Circuit Low Input
P0108 Manifold Absolute Pressure Circuit High Input
P0112 Intake Air Temperature(IAT) Circuit Low Input
P0113 Intake Air Temperature(IAT) Circuit High Input
P0125 Insufficient Coolant Temp. for Closed Loop Fuel Control
P0122 Throttle Position Sensor(TPS) Circuit Low Input
P0123 Throttle Position Sensor(TPS) Circuit High Input
P0132 Heated O2 Sensor(HO2S) Circuit High Input(B1/S1)
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0140 Heated O2 Sensor(HO2S) Circuit No Activity(B1/S2)
P0141 O2 Sensor Heater Circuit(Bank 1 / Sensor 2)
P0202 Injector Circuit -Cylinder 2
P0203 Injector Circuit -Cylinder 3
P0204 Injector Circuit -Cylinder 4
P0301 Cylinder 1 MISFIRE
P0302 Cylinder 2 MISFIRE
P0303 Cylinder 3 MISFIRE
P0304 Cylinder 4 MISFIRE
P0335 Crankshaft Position (CKP) Sensor Circuit-Malfunction
P1609 Immobilizer System Malfunction
G 2.4 DOHC > Transmission > Automatic Transaxle
Ещё обсуждения по Киа Маджентис 1 MS на MyKia.club:
