Киа Маджентис 1 MS
Сообщений в теме: 15
  • 24955 сообщений
Отправлено 14 April 2021 - 18:35
G 2.7 DOHC > Airbag > Airbag Control
B1111 Ignition Voltage High
B1112 Ignition voltage too Low
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1400 SIS(Side Impact Sensor) Front-Driver Defect
B1401 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1406 Passenger Presence Detection Front-Passenger Defect
B1407 PPD front-Passenger communication error
B1408 SIS front-Driver communication error
B1511 Buckle Switch Driver Open or Short to Battery
B1512 Buckle Switch Driver short or short to Ground
B1513 Buckle Switch Passanger open or short to Battery
B1514 Buckle Switch Passenger short or short to Ground
B1620 SRSCM Internal Failure
B1655 Crash recorded (Side - Replace ECU)
B1661 Parameter fault And missing
B2500 Warning Lamp Failure
  • 24955 сообщений
G 2.7 DOHC > Brake > Anti-Lock Brake(Mando)
C1103 Battery Voltage Out of Range
C1161 Brake Switch Circuit
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1203 Wheel speed sensor(FR)-open or short to GND circuit
C1204 Wheel speed sensor (FR)-Plausibility fault
C1206 Wheel speed sensor(RL)-open or short to GND circuit
C1207 Wheel speed sensor(RL)-Plausibility fault
C1209 Wheel speed sensor(RR)-open or short to GND circuit
C1210 Wheel speed sensor(RR)-Plausibility fault
C1245 Wheel Speed Frequency Error
C1604 ECU(Brake System) Hardware error
C2112 Main Relay Circuit
C2114 Disturbance(Including Valve failures)
C2402 Motor Electrical
C1605 CAN Bus Off
C1611 Lost Communication with ECM
  • 24955 сообщений
G 2.7 DOHC > Immobilizer > Immobilizer
ECM Request Signal Error
EEPROM Communication Error
Transponder Communication Error
ECM Communication Link Malfunction
G 2.7 DOHC > Engine > Engine Control
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0037 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P0051 HO2S Heater Control Circuit Low (Bank 2 / Sensor 1)
P0057 HO2S Heater Control Circuit Low (Bank 2 / Sensor 2)
P0121 Throttle Position Sensor (TPS)-Malfunction Adjustment
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0136 O2 Sensor Circuit(Bank 1 / Sensor 1)
P0150 O2 Sensor Circuit(Bank 2 / Sensor 1)
P0156 O2 Sensor Circuit (Bank 2 / Sensor 2)
P0172 System too Rich (Bank 1)
P0261 Cylinder 1 Injector Circuit Low
P0335 Crankshaft Position (CKP) Sensor Circuit-Malfunction
P0350 Ignition Coil Primary / Secondary Circuit
P0420 Warm Up Catalyst Efficiency below Threshold (Bank 1)
P0430 Catalyst System Efficiency below Threshold (Bank 2)
P0444 Evaporative Emission System-Purge Control Valve Circuit Open
P0560 System Voltage
P0605 Internal Control Module Read only Memory(ROM) Error
P1134 HO2S Circuit-Transition Switch Time Malfunction / Slope (Bank 1 / Sensor 1)
P1166 Fuel Trim(Bank 1)
P1505 Idle Speed Control Actuator Circuit 1-Low
P1506 Idle Speed Control Actuator Circuit 1-High
P1507 Idle Speed Control Actuator Circuit 2-Low
P1508 Idle Speed Control Actuator Circuit 2-High
P1529 TCM Request For Malfunction Indicator Lamp (MIL) On Signal
P1602 Serial Communication Problem With TCM
  • 24955 сообщений
G 2.7 DOHC > Transmission > Automatic Transaxle
P0560 Back-Up Line For Power
P0605 Eeprom Abnormal
P0703 Stop Lamp (Brake) Switch Circuit Malfunction
P0715 Input/Turbine Speed Sensor "A" Circuit
P0720 Output Speed Sensor (Pulse Generator B) Circuit
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Gear Incorrect Ratio
P0742 Torque Converter Clutch Stuck On
P0750 Shift Control Solenoid Valve "A" (Low-Reverse Brake Control Solenoid)-Open or Short
P1603 CAN-BUS-OFF
P1604 CAN-TIME OUT ECU
P1723 TCM Power Relay Open or Short (Ground)
P1764 TCU CAN MI-COM MALFUNCTION
P0500 Vehicle Speed Sensor
  • 24955 сообщений
Отправлено 14 April 2021 - 18:36
G 2.5 DOHC > Airbag > Airbag Control
  • 24955 сообщений
G 2.5 DOHC > Brake > Anti-Lock Brake(Mando)
C1605 CAN Bus Off
G 2.5 DOHC > Immobilizer > Immobilizer
  • 24955 сообщений
G 2.5 DOHC > Engine > Unleaded GEN
P0031 O2 Sensor Heater Circuit low (Bank 1/Sensor 1)
P0032 O2 Sensor Heater Circuit high (Bank 1/Sensor 1)
P0037 O2 Sensor Heater Circuit low (Bank 1/Sensor 2)
P0038 O2 Sensor Heater Circuit high (Bank 1/Sensor 2)
P0051 O2 Sensor Heater Circuit low (Bank 2/Sensor 1)
P0052 O2 Sensor Heater Circuit high (Bank 2/Sensor 1)
P0057 O2 Sensor Heater Circuit low (Bank 2/Sensor 2)
P0058 O2 Sensor Heater Circuit high (Bank 2/Sensor 2)
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle/Pedal Position Circuit Low Input
P0123 Throttle/Pedal Position Circuit High Input
P0131 O2 Sensor Circuit Low Input(Bank 1/Sensor 1)
P0132 O2 Sensor Circuit High Input(Bank 1/Sensor 1)
P0137 O2 Sensor Circuit Low Input (Bank 1/Sensor 2)
P0138 O2 Sensor Circuit High Input (Bank 1/Sensor 2)
P0151 O2 Sensor Circuit Low Input (Bank 2/Sensor 1)
P0152 O2 Sensor Circuit High Input (Bank 2/Sensor 1)
P0153 O2-Sensor Circuit Slow Response (Bank 2/Sensor 1)
P0157 O2 Sensor Circuit Low Input (Bank 2/Sensor 2)
P0158 O2 Sensor Circuit High Input (Bank 2/Sensor 2)
P0171 Fuel Trim Malfunction - System Too Lean (Bank 1)
P0172 Fuel Trim Malfunction - System Too Rich (Bank 1)
P0174 Fuel Trim Malfunction - System Too Lean (Bank 2)
P0175 Fuel Trim Malfunction - System Too Rich (Bank 2)
P0273 Cylinder 5 - Injector Circuit Low
P0274 Cylinder 5 - Injector Circuit High
P0276 Cylinder 6 - Injector Circuit Low
P0277 Cylinder 6 - Injector Circuit High
P0300 Multiple Cylinder Misfire Detected
P0305 Cylinder 5 - Misfire detected
P0306 Cylinder 6 - Misfire detected
P0330 Knock Sensor 2 Circuit Malfunction
P0351 Ignition Coil(A) Primary / Secondary Circuit Malfunction
P0352 Ignition Coil(B) Primary / Secondary Circuit Malfunction
P0353 Ignition Coil© Primary / Secondary Circuit Malfunction
P0354 Ignition Coil(D) Primary / Secondary Circuit Malfunction
P0355 Ignition Coil(E) Primary / Secondary Circuit Malfunction
P0356 Ignition Coil(F) Primary / Secondary Circuit Malfunction
P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted
P0501 Wheel Speed Malfunction
P0551 Power Steering Pressure Sensor/Switch Circuit Range/Performance
P0560 System Voltage malfunction
P0605 Internal Control Module ROM error
P0650 Malfunction Indication Lamp(MIL) Control Circuit Malfunction
P1167 O2 Sensor System - Lambda Controller at the Limit (Bank 2)
P1372 Segment Time Acquisition Incorrect
  • 24955 сообщений
G 2.5 DOHC > Transmission > Automatic Transaxle
P1603 CAN-BUS-OFF
  • 24955 сообщений
B1112 Battery Voltage Too Low
B1347 DAB Resistance Too Low or Short
B1353 PAB Resistance Too Low or Short
B1362 Driver Seat Belt Pretensioner Resistance Too Low or Short
B1367 Passenger Seat Belt Pretensioner Resistane Too High or Open
B1368 Passenger Seat Belt Pretensioner Resistane Too Low or Short
B1369 Passenger Seat Belt Pretensioner Short To GND
B1370 Passenger Seat Belt Pretensioner Short To Battery
B1379 Driver Side Air Bag, Resistance Too Low or Short
B1382 Passenger Side Air Bag, Resistance too High or Open
B1383 Passenger Side Air Bag, Resistance too Low or Short
B1384 Passenger Side Air Bag, Short to GND
B1385 Passenger Side Air Bag, Short to Battery
B1403 Satellite Right Side Defect
B1404 Satellite Right Side Short to GND or Short
B1405 Satellite Right Side Short to Battery or Open
B1407 PPD Communication Error
B1408 Satellite Left Communication Error
B1410 Satellite Right Communication Error
B1512 Driver Seat-Belt Buckle Switch Short to GND or Short
B1513 Passenger Seat-Belt Buckle Switch short to Battery or Open
B1514 Passenger Seat-Belt Buckle Switch short to GND or Short
B1650 Crash Recorded Front Airbag
B1655 Crash Recorded Side Airbag
B1657 Ignition Recorded Belt Pretensioner
B1661 ECU Mismatching
  • 24955 сообщений
G 2.0 DOHC > Brake > Anti-Lock Brake(Mando)
C1605 CAN Bus Off
Ещё обсуждения по Киа Маджентис 1 MS на MyKia.club:
