G 1.0 SOHC > Steering > MDPS
C1101 System Voltage high
C1102 System Voltage – low
C1112 Torque Sensor Supply voltage malfunction
C1212 Vehicle Speed Input Malfunction
C1272 Engine Speed Input Malfunction
C1290 Torque Sensor Main Signal-Open/Short
C1291 Torque Sensor Sub Signal-Open/Short
C1292 Torque Sensor Signal Mismatch-Main and Sub
C1604 EPS Module(pre-charge circuit) Malfunction
C1704 EPS Module(fail safe relay stuck)Malfunction
C2412 Motor circuit–Short to Battery or Ground
C2413 Motor current–Overflow
C2414 Motor current–Excessive Overflow
C2415 Motor current–Insufficient flow
#11
Отправлено 02 April 2021 - 16:59
Re: коды ошибок, расшифровка
G 1.0 SOHC > Transmission > Automatic Transaxle
P0712 Transaxle Fluid Temperature Sensor Circuit Low Circuit
P0713 Transaxle Fluid Temperature Sensor Circuit High Circuit
P0717 A/T Input speed Sensor Circuit Low Input
P0722 A/T Output speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0741 Damper Clutch Open Stuck
P0743 Damper Clutch Control Solenoid Valve : Open or Short(GND)
P0748 VF Solenoid Valve Circuit - Open or Short(GND)
P0750 Shift Control Solenoid Valve-A Circuit - Open or Short(GND)
P0755 Shift Control Solenoid Valve-B Circuit - Open or Short(GND)
P0760 Shift Control Solenoid Valve-C Circuit - Open or Short(GND)
P0765 PCSV-C(UD) Solenoid Valve Circuit - Open or Short(GND)
U0001 Can Communication BUS Off
U0100 No ID From ECU
Киа Пиканто клуб →
Двигатель и КПП Kia Picanto →
заливная горловина бакаАвтор krionika, 09 Feb 2007 |
Киа Пиканто клуб →
замена и ремонт двигателяАвтор krionika, 24 May 2004 |
Киа Пиканто клуб →
Киа Пиканто клуб →
Кузов и Салон Kia Picanto →
Киа Пиканто клуб →
