Коды ошибок Kia Picanto 1 (SA)
G 1.1 SOHC > Airbag > Airbag Control
B1111 Ignition voltage High
B1112 Ignition voltage Low
B1352 Passenger Airbag Resistance too High (1st stage)
B1354 Passenger Airbag Resistance Circuit Short to Ground (1st stage)
B1355 Passenger Airbag Resistance Circuit Short to Battery (1st stage)
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1383 Side Airbag front-Passenger Resistance too Low
B1400 SIS Front-Driver Defect
B1403 SIS Front-Passenger Defect
B1409 SIS Front-Driver Communication Error
B1410 SIS Front-Passenger Communication Error
B1527 Passenger airbag deactivation switch open or short to Battery
B1528 Passenger airbag deactivation switch short or short to Ground
B1529 Passenger Airbag on-off switch defect
B1530 Passenger airbag deactivation switch-Instability
B1650 Crash Recorded in 1st stage Only(Frontal - Replace ECU)
B1651 Crash Recorded in Front-Driver Side Airbag(Replace ECU)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace ECU)
B2503 Warning lamp open or short to ground
B2504 Warning lamp short or short to battery
B2505 Passenger airbag off warning lamp failure
