G 3.0 DOHC > Power Seat Module > Power Seat Module
1 [BCM] Brake Lamp Malfunction
2 [BCM] Brake Fuse Open
3 [BCM] Direction Lamp Malfunction
4 [BCM] Rain Sensor Malfunction 1
5 [BCM] Rain Sensor Malfunction 2
6 [BCM] Rain Sensor Malfunction 3
7 [BCM] Can Error
8 [BCM] Can Bus Off
9 [BCM] Low Voltage/LIN Communication Line(RX) Error
10 [BCM] Low Voltage/LIN Communication Line(TX) Error
11 Driver Safety Power Window LIN Communication Error
12 Rear Driver Safety Power Window LIN Communication Error
13 Switch Module LIN Communication Error
14 LH Outside Mirror Horizontal Motor or Sensor Error
15 LH Outside Mirror Vertical Motor or Sensor Error
16 Driver Safety Power Window Motor Hall Sensor 1 Error
17 Driver Safety Power Window Motor Hall Sensor 2 Error
18 Driver Safety Power Window Normalization Error
19 Driver Safety Power Window Unit Error
20 Driver Motor Hall Sensor Count Direction Error
21 Driver Motor Thermal Protection Error
22 Driver Motor Hall Sensor Power Line Short
23 Driver Safety Power Window Input Voltage Low
24 Driver Safety Power Window Input Voltage High
25 Driver Safety Power Window Low Speed Error
26 Rear Driver Safety Power Window Motor Hall Sensor 1 Error
27 Rear Driver Safety Power Window Motor Hall Sensor 2 Error
28 Rear Driver Safety Power Window Normalization Error
29 Rear Driver Safety Power Window Unit Error
30 Rear Driver Motor Hall Sensor Count Direction Error
31 Rear Driver Motor Thermal Protection Error
32 Rear Driver Motor Hall Sensor Power Line Short
33 Rear Driver Safety Power Window Input Voltage Low
34 Rear Driver Safety Power Window Input Voltage High
35 Rear Driver Safety Power Window Low Speed Error
36 Passenger Safety Power Window LIN Communication Error
37 Rear Passenger Safety Power Window LIN Communication Error
38 RH Outside Mirror Horizontal Motor or Sensor Error
39 RH Outside Mirror Vertical Motor or Sensor Error
40 Passenger Safety Power Window Motor Hall Sensor 1 Error
41 Passenger Safety Power Window Motor Hall Sensor 2 Error
42 Passenger Safety Power Window Normalization Error
43 Passenger Safety Power Window Unit Error
44 Passenger Motor Hall Sensor Count Direction Error
45 Passenger Motor Thermal Protection Error
46 Passenger Driver Motor Hall Sensor Power Line Short
47 Passenger Driver Safety Power Window Input Voltage Low
48 Passenger Driver Safety Power Window Input Voltage High
49 Passenger Safety Power Window Low Speed Error
50 Rear Passenger Safety Power Window Motor Hall Sensor 1 Error
51 Rear Passenger Safety Power Window Motor Hall Sennsor 2 Error
52 Rear Passenger Safety Power Window Normalization Error
53 Rear Passenger Safety Power Window Unit Error
54 Rear Passenger Motor Hall Sensor Count Direction Error
55 Rear Passenger Motor Thermal Protection Error
56 Rear Passenger Driver Motor Hall Sensor Power Line Short
57 Rear Passenger Driver Safety Power Window Input Voltage Low
58 Rear Passenger Driver Safety Power Window Input Voltage High
59 Rear Passenger Safety Power Window Low Speed Error
60 Seat Slide Motor or Sensor Error
61 Seat Recline Motor or Sensor Error
62 Tilt Motor or Sensor Error
63 Telescope Motor or Sensor Error
#11
Отправлено 13 February 2021 - 11:33
Re: коды ошибок, расшифровка
G 3.0 DOHC > Power Window Assist > Power Window Assist
7 [BCM] Can Error
8 [BCM] Can Bus Off
Отправлено 13 February 2021 - 11:34
G 3.0 DOHC > Power Window Main > Power Window Main
7 [BCM] Can Error
8 [BCM] Can Bus Off
G 3.0 DOHC > Steering > Electronic Power Steering
C1101 Battery Voltage High
C1102 Battery Voltage Under
C1212 Vehicle Speed Sensor
C1604 Internal Control Module Read only Memory(ROM) Error
C2230 Solenoid Current Error
G 3.0 DOHC > Suspension > Electronic Control Suspension
C1107 Alternator "L"Voltage High
C1108 Alternator"L" Voltage Low
C1112 Sensor Source Voltage
C1259 Steering Angle Sensor-Electrical
C1278 Acceleration Sensor Front-LH
C1279 Acceleration Sensor Front-RH
C1281 Acceleration Sensor Front-RH
C2124 Actuator Relay
C2212 Front-LH Actuator
C2216 Front-RH Actuator
C2220 Rear-LH Actuator
C2224 Rear-RH Actuator
G 3.0 DOHC > Transmission > Automatic Transaxle
P0703 Stop Lamp (Brake) Switch Circuit Malfunction
P0707 Transaxle range switch open circuit
P0708 Transaxle range switch short circuit
P0713 Fluid(Oil) Temperature Circuit High
P0715 Input/Turbine Speed Sensor "A" Circuit No Signal
P0720 Output Speed Sensor (Pulse Generator B) Circuit
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Gear Incorrect Ratio
P0741 Torque Converter Clutch(TCC) system defect/stuck onl
P0742 Torque Converter Clutch(TCC) system defect/stuck onl
P0750 Shift Control Solenoid Valve "A" (Low-Reverse Brake Control Solenoid)-Open or Short
P0755 UD solenoid valve line
P0760 2nd solenoid valve line
P0765 OD solenoid valve line
P0770 Reduction brake solenoid
P1630 CAN-BUS Off
P1631 CAN-TIME Out ECM
P1723 TCM Power Relay Open or Short (Ground)
P1764 CAN MI_COM Circuit
P0500 Vehicle Speed Sensor
G 3.5 DOHC > Air Conditioner > Air Conditioner
B1233 Incar Temperature Sensor Short(Low)
B1234 Incar Temperature Sensor Open(High)
B1237 Ambient Temperature Sensor Short(Low)
B1238 Ambient Temperature Sensor Open(High)
B1241 Evaporator Temperature Sensor Short(Low)
B1242 Evaporator Temperature Sensor Open(High)
B1245 DR Air Mix Potentiometer Open(Low)
B1246 DR Air Mix Potentiometer Short(High)
B1249 DR Direction Air Mix Potentiometer Open(Low)
B1250 DR Direction Air Mix Potentiometer Short(High)
B1417 Humidity Sensor Open(Low)
B1410 Humidity Sensor Short(High)
B1413 PS Air Mix Potentiometer Open(Low)
B1414 Passenger Air Mix Feedback-Short
B1415 Passenger Direction Potentiometer Open
B1416 PS Direction Potentiometer Short(High)
B2406 DR Air Mix Motor
B2409 DR Direction Motor
B2415 PS Air Mix Motor
B2416 PS Direction Motor
B2417 RR Vent Temperature Potentiometer Open(Low)
B2418 RR Vent Temperature Potentiometer SHort(High)
Отправлено 13 February 2021 - 11:35
G 3.5 DOHC > Airbag > Airbag Control
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1326 FIS(Front Impact Sensor)-Driver Short to Ground
B1327 FIS(Front Impact Sensor)-Driver Short to Battery
B1328 FIS(Front Impact Sensor)-Driver Defect
B1329 FIS(Front Impact Sensor)-Driver Communication error
B1330 FIS(Front Impact Sensor)-Driver Wrong ID
B1331 FIS(Front Impact Sensor)-Passenger Short to Ground
B1332 FIS(Front Impact Sensor)-Passenger Short to Battery
B1333 FIS(Front Impact Sensor)-Passenger Defect
B1334 FIS(Front Impact Sensor)-Passenger Communication error
B1335 FIS(Front Impact Sensor)-Passenger Wrong ID
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1383 Side Airbag Front-Passenger Resistance too Low
B1395 Firing Loops Interconnection Fault
B1401 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B1403 SIS(Side Impact Sensor) Front-Passenger Defect
B1404 SIS(Side Impact Sensor) Front-Passenger Circuit Short to Ground
B1405 SIS(Side Impact Sensor) Front-Passenger Circuit Short to Battery
B1409 SIS(Side Impact Sensor) Front-Driver Communication Error
B1410 SIS(Side Impact Sensor) Front-Passenger Communication Error
B1414 SIS(Side Impact Sensor) Front-Driver Wrong ID
B1415 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B1429 Side Airbag Rear-Driver Resistance too High
B1430 Side Airbag Rear-Driver Resistance too Low
B1431 Side Airbag Rear-Driver Resistance Circuit Short to Ground
B1432 Side Airbag Rear-Driver Resistance Circuit Short to Battery
B1433 Side Airbag Rear-Passenger Resistance too High
B1434 Side Airbag Rear-Passenger Resistance too Low
B1435 Side Airbag Rear-Passenger Resistance Circuit Short to Ground
B1436 Side Airbag Rear-Passenger Resistance Circuit Short to Battery
B1473 Inflatable Curtain Airbag Front-Driver Resistance too High
B1474 Inflatable Curtain Airbag Front-Driver Resistance too Low
B1475 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Ground
B1476 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Battery
B1477 Inflatable Curtain Airbag Front-Passenger Resistance too High
B1478 Inflatable Curtain Airbag Front-Passenger Resistance too Low
B1479 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Ground
B1480 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Battery
B1511 Buckle Switch Driver Short or Short to Battery
B1512 Buckle Switch Driver Short or Short to Ground
B1513 Buckle Switch Passenger Open or Short to Battery
B1514 Buckle Switch Passenger Short or Short to Ground
B1515 Buckle Switch Driver Defect
B1516 Buckle Switch Passenger Defect
B1620 Internal fault-Replace SRSCM
B1651 Crash Recorded in Front-Driver Side Airbag(Replace SRSCM)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace SRSCM)
B1657 Crash Recorded in Belt Pretensioner only
B2500 Warning Lamp Failure
G 3.5 DOHC > Body Control > Body Control Module
7 [BCM] Can Error
8 [BCM] Can Bus Off
G 3.5 DOHC > Brake > Electronic Stability Program
C1102 Battery Under Voltage
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/No Signal
C1203 Wheel Speed Sensor Front Right - Electrical
C1204 Wheel Speed Sensor Front Right - Extrapolate
C1205 Wheel Speed Sensor Front Right - Other
C1206 Wheel Speed Sensor Rear Left - Electrical
C1207 Wheel Speed Sensor Rear Left - Extrapolate
C1208 Wheel Speed Sensor Rear Left - Other
C1209 Wheel Speed Sensor Rear Right - Electrical
C1210 Wheel Speed Sensor Rear Right - Extrapolate
C1211 Wheel Speed Sensor Rear Right - Other
C1604 ECU Hardware error
C1700 Byte Coding Error
C2112 Valve Relay Error
C2402 Motor Electrical
G 3.5 DOHC > Head Lamp > Auto Headlamp Leveling
C1212 Vehicle Speed Sensor Mal.
C1255 RR Height Sensor Clrcuit
C1522 H/LAMP Light Sig. Line Open
C1606 ECM Software
C1620 First Setup Not Completed
C1621 Excessive Operating Temp.
C2226 Output Volt. Short To BAT/GND
G 3.5 DOHC > Immobilizer > Immobilizer
1 [IMM] ECU-BCM Communication Line Data Error
2 IMMO Power Short to Ground
3 IMMO Power Short to Battery
4 IMMO Output Signal Open/Short to Ground
5 IMMO Output Signal Short to Battery
6 IMMO Input Signal Short to Ground
7 IMMO Input Signal Open/Short to Battery
8 IMMO Antenna Coil Malfunction
Ещё обсуждения по Киа Опирус GH на MyKia.club:
Киа Опирус GH
Другие модели Киа →
Киа Опирус клуб →
Прочие вопросы по Kia Opirus →
пропуски в работе двигателяАвтор шева, 15 May 2025 |
Киа Опирус GH
Другие модели Киа →
Киа Опирус клуб →
Двигатель и КПП Kia Opirus →
момент затяжки двигателяАвтор krionika, 22 Sep 2011 |
Киа Опирус GH
Другие модели Киа →
Киа Опирус клуб →
Ходовая, тормоза, шины, диски Kia Opirus →
момент затяжки подвескиАвтор krionika, 21 Jan 2012 |
Киа Опирус GH
Другие модели Киа →
Киа Опирус клуб →
Электрика и Аудио Kia Opirus →
штатный усилительАвтор krionika, 03 Feb 2022 |
Киа Опирус GH
Другие модели Киа →
Киа Опирус клуб →
Кузов и Салон Kia Opirus →
передняя панель (торпедо)Автор krionika, 18 Aug 2011 |
