Киа Опирус GH
Сообщений в теме: 25
#21 krionika
Отправлено 13 February 2021 - 11:36
G 3.5 DOHC > Power Seat Module > Power Seat Module
1 [BCM] Brake Lamp Malfunction
2 [BCM] Brake Fuse Open
3 [BCM] Direction Lamp Malfunction
4 [BCM] Rain Sensor Malfunction 1
5 [BCM] Rain Sensor Malfunction 2
6 [BCM] Rain Sensor Malfunction 3
7 [BCM] Can Error
8 [BCM] Can Bus Off
9 [BCM] Low Voltage/LIN Communication Line(RX) Error
10 [BCM] Low Voltage/LIN Communication Line(TX) Error
11 Driver Safety Power Window LIN Communication Error
12 Rear Driver Safety Power Window LIN Communication Error
13 Switch Module LIN Communication Error
14 LH Outside Mirror Horizontal Motor or Sensor Error
15 LH Outside Mirror Vertical Motor or Sensor Error
16 Driver Safety Power Window Motor Hall Sensor 1 Error
17 Driver Safety Power Window Motor Hall Sensor 2 Error
18 Driver Safety Power Window Normalization Error
19 Driver Safety Power Window Unit Error
20 Driver Motor Hall Sensor Count Direction Error
21 Driver Motor Thermal Protection Error
22 Driver Motor Hall Sensor Power Line Short
23 Driver Safety Power Window Input Voltage Low
24 Driver Safety Power Window Input Voltage High
25 Driver Safety Power Window Low Speed Error
26 Rear Driver Safety Power Window Motor Hall Sensor 1 Error
27 Rear Driver Safety Power Window Motor Hall Sensor 2 Error
28 Rear Driver Safety Power Window Normalization Error
29 Rear Driver Safety Power Window Unit Error
30 Rear Driver Motor Hall Sensor Count Direction Error
31 Rear Driver Motor Thermal Protection Error
32 Rear Driver Motor Hall Sensor Power Line Short
33 Rear Driver Safety Power Window Input Voltage Low
34 Rear Driver Safety Power Window Input Voltage High
35 Rear Driver Safety Power Window Low Speed Error
36 Passenger Safety Power Window LIN Communication Error
37 Rear Passenger Safety Power Window LIN Communication Error
38 RH Outside Mirror Horizontal Motor or Sensor Error
39 RH Outside Mirror Vertical Motor or Sensor Error
40 Passenger Safety Power Window Motor Hall Sensor 1 Error
41 Passenger Safety Power Window Motor Hall Sensor 2 Error
42 Passenger Safety Power Window Normalization Error
43 Passenger Safety Power Window Unit Error
44 Passenger Motor Hall Sensor Count Direction Error
45 Passenger Motor Thermal Protection Error
46 Passenger Driver Motor Hall Sensor Power Line Short
47 Passenger Driver Safety Power Window Input Voltage Low
48 Passenger Driver Safety Power Window Input Voltage High
49 Passenger Safety Power Window Low Speed Error
50 Rear Passenger Safety Power Window Motor Hall Sensor 1 Error
51 Rear Passenger Safety Power Window Motor Hall Sennsor 2 Error
52 Rear Passenger Safety Power Window Normalization Error
53 Rear Passenger Safety Power Window Unit Error
54 Rear Passenger Motor Hall Sensor Count Direction Error
55 Rear Passenger Motor Thermal Protection Error
56 Rear Passenger Driver Motor Hall Sensor Power Line Short
57 Rear Passenger Driver Safety Power Window Input Voltage Low
58 Rear Passenger Driver Safety Power Window Input Voltage High
59 Rear Passenger Safety Power Window Low Speed Error
60 Seat Slide Motor or Sensor Error
61 Seat Recline Motor or Sensor Error
62 Tilt Motor or Sensor Error
63 Telescope Motor or Sensor Error
G 3.5 DOHC > Power Window Assist > Power Window Assist
7 [BCM] Can Error
8 [BCM] Can Bus Off
G 3.5 DOHC > Power Window Main > Power Window Main
7 [BCM] Can Error
8 [BCM] Can Bus Off
G 3.5 DOHC > Steering > Electronic Power Steering
C1101 Battery Voltage High
C1102 Battery Voltage Under
C1212 Vehicle Speed Sensor
C1604 Internal Control Module Read only Memory(ROM) Error
C2230 Solenoid Current Error
G 3.5 DOHC > Suspension > Electronic Control Suspension
C1107 Alternator "L"Voltage High
C1108 Alternator"L" Voltage Low
C1112 Sensor Source Voltage
C1259 Steering Angle Sensor-Electrical
C1278 Acceleration Sensor Front-LH
C1279 Acceleration Sensor Front-RH
C1281 Acceleration Sensor Front-RH
C2124 Actuator Relay
C2212 Front-LH Actuator
C2216 Front-RH Actuator
C2220 Rear-LH Actuator
C2224 Rear-RH Actuator
G 3.5 DOHC > Engine > Engine Control
P0100(General) Mass Air Flow(MAF) Sensor Circuit Malfunction
P0101 Mass Air Flow Sensor (AFS) Circuit Malfunction
P0102 Mass Air Flow Sensor (AFS) Circuit Low Voltage
P0103 Mass Air Flow Sensor (AFS) Circuit High Voltage
P0105(General) Manifold Absolute Pressure(MAP) Sensor Circuit Malfunction
P0107 Manifold Absolute Pressure Sensor (MAP) Circuit Low Voltage
P0108 Manifold Absolute Pressure Sensor (MAP) Circuit High Voltage
P0110(General) Intake Air Temperature (IAT) Sensor Circuit Malfunction
P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0115(General) Engine Coolant Temperature(ECT) Circuit Malfunction
P0116 Engine Coolant Temperature(ECT) Circuit Malfunction - Range/Performance
P0117 Engine Coolant Temperature(ECT) Circuit Low
P0118 Engine Coolant Temperature(ECT) Circuit High
P0120 Throttle/Pedal Position Sensor/Switch "B" Circuit
P0120(General) Throttle Position Sensor(TPS) Property Malfunction
P0121 Throttle Position Sensor(TPS) Circuit Malfunction
P0122 Throttle Position Sensor(TPS) Circuit Low Input
P0122(General) Throttle Position Sensor(TPS) Circuit Low Input
P0123 Throttle Position Sensor(TPS) Circuit High Input
P0123(General) Throttle Position Sensor(TPS) Circuit High Input
P0125 Insufficient Water Temperature for Closed Loop Fuel Control
P0130(General) Heated O2 Sensor(HO2S) Circuit Malfunction(B1/S1)
P0131 HO2S Circuit Low Voltage (Bank 1 / Sensor 1)
P0132 Heated O2 Sensor(HO2S) Circuit High Input(B1/S1)
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0136 Heated O2 Sensor(HO2S) Circuit Malfunction(B1/S2)
P0137 Heated O2 Sensor(HO2S) Circuit Low Input(B1/S2)
P0138 Heated O2 Sensor(HO2S) Circuit High Input(B1/S2)
P0141 Heated O2 Sensor(HO2S) Heater Malfunction(B1/S2)
P0150 Heated O2 Sensor(HO2S) Circuit Malfunction(B2/S1)
P0150(General) Heated O2 Sensor(HO2S) Circuit Malfunction(B2/S1)
P0151 Heated O2 Sensor(HO2S) Circuit Low Input(B2/S1)
P0152 Heated O2 Sensor(HO2S) Circuit High Input(B2/S1)
P0153 HO2S Slow Response(B2/S1)
P0154 HO2S No Activity(B2/S1)
P0155 Heated O2 Sensor(HO2S) Heater Malfunction(B2/S1)
P0156 Heated O2 Sensor(HO2S) Circuit Malfunction(B2/S2)
P0157 Heated O2 Sensor(HO2S) Circuit Low Input(B2/S2)
P0158 Heated O2 Sensor(HO2S) Circuit High Input(B2/S2)
P0160 Heated O2 Sensor(HO2S) Circuit Malfunction(B1/S2)
P0161 Heated O2 Sensor(HO2S) Heater Malfunction(B2/S2)
P0172 Fuel System (Bank 1) Too Rich
P0174 Fuel System (Bank 2) Too Lean
P0175 Fuel System (Bank 2) Too Rich
P0201(General) Injector Circuit-Cylinder 1
P0202 Injector Circuit-Cylinder 2
P0202(General) Injector Circuit-Cylinder 2
P0203 Injector Circuit-Cylinder 3
P0203(General) Injector Circuit-Cylinder 3
P0204 Injector Circuit-Cylinder 4
P0204(General) Injector Circuit-Cylinder 4
P0205 Injector Circuit-Cylinder 5
P0205(General) Injector Circuit-Cylinder 5
P0206 Injector Circuit-Cylinder 6
P0206(General) Injector Circuit-Cylinder 6
P0220 Throttle Position Sensor(TPS) Property Malfunction
P0220(General) Throttle Position Sensor(TPS) Property Malfunction
P0221 Throttle Position Sensor(TPS) Circuit Malfunction
P0221(General) Throttle Position Sensor(TPS) Circuit Malfunction
P0222 Throttle Position Sensor(TPS) Circuit Low Input
P0222(General) Throttle Position Sensor(TPS) Circuit Low Input
P0223 Throttle Position Sensor(TPS) Circuit High Input
P0223(General) Throttle Position Sensor(TPS) Circuit High Input
P0224 Throttle Position Sensor(TPS #1 MAIN) Linearity
P0224(General) Throttle Position Sensor(TPS #1 MAIN) Linearity
P0225 Accelerator Position Senosr (APS) Property Malfunction
P0225(General) Accelerator Position Senosr (APS) Property Malfunction
P0227 Accelerator Position Senosr (APS #1 SUB) Circuit Low Voltage
P0227(General) Accelerator Position Senosr (APS #1 SUB) Circuit Low Voltage
P0228 Accelerator Position Senosr (APS #1 SUB) Circuit High Voltage
P0228(General) Accelerator Position Senosr (APS #1 SUB) Circuit High Voltage
P0301 Misfire Detected (Sylinder #1)
P0302 Misfire Detected (Sylinder #2)
P0303 Misfire Detected (Sylinder #3)
P0304 Misfire Detected (Sylinder #4)
P0305 Misfire Detected (Sylinder #5)
P0306 Misfire Detected (Sylinder #6)
P0320 Ignition Failure Sensor-Malfunction
P0325(General) Knock Sensor Circuit Malfunction
P0335(General) Crankshaft Position Sensor (CKP) Circuit Malfunction
P0340(General) Camshaft Position Sensor Circuit Malfunction
P0350 Ignition Coil Primary / Secondary Circuit
P0403 Exhaust Gas Recirculation Control Circuit
P0421 Warm Up Catalyst Efficiency below Threshold (Bank 1)
P0431 Catalyst (Bank 2) - MCC Deterioration
P0441 Evaporative Emission System Incorrect Purge Flow
P0441(General) Evaporative Emission Control System (PCSV) - Purge Control Sol. Valve Stuck
P0443 Evaporative Emission Control System (PCSV) - Purge Control Sol. Valve Malfunction
P0443(General) Evaporative Emission Control System (PCSV) - Purge Control Sol. Valve Malfunction
P0500 Vehicle Speed Sensor
P0510 Closed Throttle Position Switch
P0510(General) IDLE S/W Circuit Malfunction
P1151 Accelerator Position Sensor (APS #2 MAIN) Circuit Malfunction
P1151(General) Accelerator Position Sensor (APS #2 MAIN) Circuit Malfunction
P1152 Accelerator Position Sensor (APS #2 MAIN) Circuit Low Voltage
P1152(General) Accelerator Position Sensor (APS #2 MAIN) Circuit Low Voltage
P1153 Accelerator Position Sensor (APS #2 MAIN) Circuit High Voltage
P1153(General) Accelerator Position Sensor (APS #2 MAIN) Circuit High Voltage
P1159 Variable Intake Motor Rotation System- Malfunction
P1159(General) Variable intake mainifold Circuit Malfunction
P1330 Spark Timing Adjust Malfunction
P1330(General) Spark Timing Adjust Malfunction
P1632 CAN BUS OFF
P1632(General) CAN BUS OFF
G 3.5 DOHC > Transmission > Automatic Transaxle
P0703 Stop Lamp (Brake) Switch Circuit Malfunction
P0707 Transaxle range switch open circuit
P0708 Transaxle range switch short circuit
P0713 Fluid(Oil) Temperature Circuit High
P0715 Input/Turbine Speed Sensor "A" Circuit No Signal
P0720 Output Speed Sensor (Pulse Generator B) Circuit
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Gear Incorrect Ratio
P0741 Torque Converter Clutch(TCC) system defect/stuck onl
P0742 Torque Converter Clutch(TCC) system defect/stuck onl
P0750 Shift Control Solenoid Valve "A" (Low-Reverse Brake Control Solenoid)-Open or Short
P0755 UD solenoid valve line
P0760 2nd solenoid valve line
P0765 OD solenoid valve line
P0770 Reduction brake solenoid
P1630 CAN-BUS Off
P1631 CAN-TIME Out ECM
P1723 TCM Power Relay Open or Short (Ground)
P1764 CAN MI_COM Circuit
Ещё обсуждения по Киа Опирус GH на MyKia.club:
