Киа Опирус GH
Сообщений в теме: 25
Отправлено 13 February 2021 - 11:31
Коды ошибок Kia Opirus (GH)
G 3.8 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1204 Air mix potentiometer open (Low) - Passenger
B1205 Air mix potentiometer short (High) - Passenger
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B1257 AQS sensor open (High)
B1258 AQS sensor short (Low)
B1259 AQS sensor fault
B2406 Air mix motor (Driver)
B2409 Direction control motor (Driver)
B2415 Air mix motor (Driver)
B2416 PS Direction Motor
B2417 RR Vent Temperature Potentiometer Open(Low)
B2418 RR Vent Temperature Potentiometer SHort(High)
G 3.8 DOHC > Airbag > Airbag Control
B1101 Ignition Voltage High
B1102 Ignition Voltage Low
B1103 Communication Voltage too Low
B1326 FIS-Driver Short to Ground
B1327 FIS-Driver Short to Battery
B1328 FIS-Driver Defect
B1329 FIS-Driver Communication Error
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger Short to Ground
B1332 FIS-Passenger Short to Battery
B1333 FIS-Passenger Defect
B1334 FIS-Passenger Communication Error
B1335 FIS-Passenger Wrong ID
B1346 Driver Airbag Resistance too High (1st Stage)
B1347 Driver Airbag Resistance too Low (1st Stage)
B1348 Driver Airbag Resistance Circuit Short to Ground (1st Stage)
B1349 Driver Airbag Resistance Circuit Short to Battery (1st Stage)
B1353 Passenger Airbag Resistance too Low (1st Stage)
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1383 Side Airbag Front-Passenger Resistance too Low
B1384 Side Airbag Front-Passenger Resistance Ciruict Short to Ground
B1385 Side Airbag Front-Passenger Resistance Ciruict Short to Battery
B1395 Firing Loops Interconnection Fault
B1400 SIS Front-Driver Defect
B1401 SIS Front-Driver Circuit Short to Ground
B1402 SIS Front-Driver Circuit Short to Battery
B1403 SIS Front-Passenger Defect
B1404 SIS Front-Passenger Circuit Short to Ground
B1405 SIS Front-Passenger Circuit Short to Battery
B1409 SIS Front-Driver Communication Error
B1410 SIS Front-Passenger Communication Error
B1414 SIS Front-Driver Wrong ID
B1415 SIS Front-Passenger Wrong ID
B1429 Side Airbag Rear-Driver Resistance too High
B1430 Side Airbag Rear-Driver Resistance too Low
B1431 Side Airbag Rear-Driver Circuit Short to Ground
B1432 Side Airbag Rear-Driver Circuit Short to Battery
B1433 Side Airbag Rear-Passenger Resistance too High
B1434 Side Airbag Rear-Passenger Resistance too Low
B1435 Side Airbag Rear-Passenger Circuit Short to Ground
B1436 Side Airbag Rear-Passenger Circuit Short to Battery
B1473 Side Curtain Airbag Front-Driver Resistance too High
B1474 Side Curtain Airbag Front-Driver Resistance too Low
B1475 Side Curtain Airbag Front-Driver Resistance Circuit Short to Ground
B1476 Side Curtain Airbag Front-Driver Resistance Circuit Short to Battery
B1477 Side Curtain Airbag Front-Passenger Resistance too High
B1478 Side Curtain Airbag Front-Passenger Resistance too Low
B1479 Side Curtain Airbag Front-Passenger Resistance Circuit Short to Ground
B1480 Side Curtain Airbag Front-Passenger Resistance Circuit Short to Battery
B1527 PAB DEACT.SW OPEN/SHORT-B+
B1528 PAB DEACT.SW SHORT TO GND
B1530 PAB DEACT.SW INSTABILITY
B1620 Internal Fault - Replace ECU
B1650 Crash Recorded in 1st Stage only(Frontal - Replace ECU)
B1651 Crash Recorded in Front-Driver Side Airbag(Replace ECU)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace ECU)
B1657 Crash Recorded in Belt Pretensioner only
B2500 Warning lamp
B2505 PAB OFF WARN. LAMP FAILURE
G 3.8 DOHC > Body Control > Power Distribution Module
B1602 CAN Error
B1603 CAN Bus Off
B1987 Sub Micom Failed
B1988 ESCL Battery Short Circuit To Battery
B1989 ESCL Ground Short Circuit To Battery
B1990 ESCL Battery Short Circuit To Ground
B1991 Immobilizer TX Short Circuit To Ground
G 3.8 DOHC > Brake > Electronic Stability Program
C1101 Battery voltage high
C1102 Battery voltage low
C1200 Wheel speed sensor front-LH open/short
C1201 Wheel speed sensor front-LH range / performance / intermittent
C1202 Wheel speed sensor front-LH invalid/no signal
C1203 Wheel speed sensor front-RH open/short
C1204 Wheel speed sensor front-RH range / performance / intermittent
C1205 Wheel speed sensor front-RH invalid/no signal
C1206 Wheel speed sensor rear-LH open/short
C1207 Wheel speed sensor rear-LH range / performance / intermittent
C1208 Wheel speed sensor rear-LH invalid/no signal
C1209 Wheel speed sensor rear-RH open/short
C1210 Wheel speed sensor rear-RH range / performance / intermittent
C1211 Wheel speed sensor rear-RH invalid/no signal
C1604 ECU Hardware Error
C1700 Byte Coding Error
C2112 Valve relay error
C2402 Motor electrical
G 3.8 DOHC > Engine > Leaded All
P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Circuit (Bank 1 / Sensor 1)
P0036 HO2S Heater Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Circuit low (Bank 1 / Sensor 2)
P0038 HO2S Heater Circuit high (Bank 1 / Sensor 2)
P0050 HO2S Heater Circuit (Bank 2 / Sensor 1)
P0051 HO2S Heater Circuit low (Bank 2 / Sensor 1)
P0052 HO2S Heater Circuit high (Bank 2 / Sensor 1)
P0056 HO2S Heater Circuit (Bank 2 / Sensor 2)
P0057 HO2S Heater Circuit low (Bank 2 / Sensor 2)
P0058 HO2S Heater Circuit high (Bank 2 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High(Bank 1)
P0082 Intake Valve Control Solenoid Circuit Low(Bank 2)
P0083 Intake Valve Control Solenoid Circuit High(Bank 2)
P0105 MAP/Barometric Pressure Circuit
P0106 MAP/Barometric Pressure Circuit Range/Performance
P0107 MAP/Barometric Pressure Circuit Low
P0108 MAP/Barometric Pressure Circuit High
P0110 Intake Air Temperature Sensor1 Circuit
P0111 Intake Air Temperature Sensor1 Circuit Range/Performance
P0116 Engine Coolant Temperature Sensor 1 Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0131 HO2S Circuit Low Voltage(Bank 1 / Sensor 1)
P0132 HO2S Circuit High Voltage(Bank 1 / Sensor 1)
P0133 HO2S Circuit Slow Response (Bank 1 / Sensor 1)
P0134 HO2S Circuit No Activity Detected (Bank 1 / Sensor 1)
P0137 HO2S Circuit Low Voltage (Bank 1 / Sensor 2)
P0138 HO2S Circuit High Voltage (Bank 1 / Sensor 2)
P0140 HO2S Circuit No Activity Detected (Bank 1 / Sensor 2)
P0151 HO2S Circuit Low Voltage (Bank 2 / Sensor 1)
P0152 HO2S Circuit High Voltage (Bank 2 / Sensor 1)
P0153 HO2S Circuit Slow Response (Bank 2 / Sensor 1)
P0154 HO2S Circuit No Activity Detected (Bank 2 / Sensor 1)
P0157 HO2S Circuit Low Voltage (Bank 2 / Sensor 2)
P0158 HO2S Circuit High Voltage (Bank 2 / Sensor 2)
P0160 HO2S Circuit No Activity Detected (Bank 2 / Sensor 2)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0196 Engine Oil Temp. Sensor Range / Performance
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0217 Engine Coolant Over Temperature Condition
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High
P0273 Cylinder 5 - Injector Circuit Low
P0274 Cylinder 5 - Injector Circuit High
P0276 Cylinder 6 - Injector Circuit Low
P0277 Cylinder 6 - Injector Circuit High
P0305 Cylinder 5 - Misfire detected
P0306 Cylinder 6 - Misfire detected
P0315 Crankshaft Position System Variation Not Learned
P0325 Knock Sensor 1 Circuit (Bank 1)
P0330 Knock Sensor 2 Circuit (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0340 Camshaft Position Sensor A Circuit (Bank 1 )
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 )
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0351 Ignition Coil A Primary / Secondary Circuit
P0352 Ignition Coil B Primary / Secondary Circuit
P0353 Ignition Coil C Primary / Secondary Circuit
P0354 Ignition Coil D Primary / Secondary Circuit
P0355 Ignition Coil E Primary / Secondary Circuit
P0356 Ignition Coil F Primary / Secondary Circuit
P0430 Catalyst System Efficiency below Threshold (Bank 2)
P0444 Evap. Emission System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission System - Purge Ctrl. Valve Circuit Shorted
P0506 Idle Air Control System - RPM lower than expected
P0507 Idle Air Control System - RPM higher than expected
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control ON Signal
P0566 Cruise Control CANCEL Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0571 Brake Switch A Circuit
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0606 PCM/PCM Processor(PCM-SELF TEST Failed)
P0638 Throttle Actuator Control Range/Performance(Bank 1)
P0641 Sensor Reference Voltage A Circuit/Open
P0651 Sensor Reference Voltage B Circuit/Open
P0660 Intake Manifold Tuning Valve Control Circuit/Open (Bank 1)
P0685 PCM/PCM Power Relay Control Circuit /Open
P1106 MAP Sensor Circuit Intermittent High
P1107 MAP Sensor Circuit Intermittent Low
P1111 Intake Air Temperature Sensor Circuit Intermittent Low Input
P1112 Intake Air Temperature Sensor Circuit Intermittent High Input
P1114 Engine Coolant Temperature Sensor Circuit Intermittent Low
P1115 Engine Coolant Temperature Sensor Circuit - Intermittent High
P1295 Throttle Actuator Control System - Power Management
P1523 Throttle Actuator Control System - Throttle Valve Stuck
P2104 Throttle Actuator Control System - Forced Idle
P2105 Throttle Actuator Control System - Forced Engine Shutdown
P2106 Throttle Actuator Control System - Forced Limited Power
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low
P2123 Throttle/Pedal Position Sensor/Switch D Circuit High
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High
P2135 Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
P2173 Throttle Actuator Control System – High Airflow Detected
P2187 System Too Lean at Idle (Bank 1)
P2188 System Too Rich at Idle (Bank 1)
P2189 System Too Lean at Idle (Bank 2)
P2190 System Too Rich at Idle (Bank 2)
P2195 HO2S Signal Biased/Stuck Lean (Bank 1 Sensor 1)
P2196 HO2S Signal Biased/Stuck Rich (Bank 1 Sensor 1)
P2197 HO2S Signal Biased/Stuck Lean (Bank 2 Sensor 1)
P2198 HO2S Signal Biased/Stuck Rich (Bank 2 Sensor 1)
P2270 HO2S Signal Stuck Lean (Bank 1 Sensor 2)
P2271 HO2S Signal Stuck Rich (Bank 1 Sensor 2)
P2272 HO2S Signal Stuck Lean (Bank 2 Sensor 2)
P2273 HO2S Signal Stuck Rich (Bank 2 Sensor 2)
P2507 PCM/PCM Input Signal Low
P2610 PCM/PCM Internal Engine Off Timer Performance
U0001 High Speed CAN Communication Bus
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0551 Power Steering Pressure Sensor/Switch Circuit Range/Performance
P0552 Power Steering Pressure Sensor/Switch Circuit Low input
P0553 Power Steering Pressure Sensor/Switch Circuit High input
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2098 Post Catalyst Fuel Trim System Too Lean (Bank 2)
P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
Отправлено 13 February 2021 - 11:32
G 3.8 DOHC > Immobilizer > Immobilizer
G 3.8 DOHC > Smart Key > Interface Unit
B1602 CAN Error
B1603 CAN Bus Off
B1604 CAN Timeout between SMK and (IPM or BCM)
B1605 CAN Timeout Between SMK and DDM
B1606 CAN Timeout Between SMK and ADM
B1625 ECM Communication Data Failure
B1629 Lin Reception Error
B1689 CAN Time-out PDM
B1971 Parking Position Input Error
B1978 Electric Steering Column Lock Failure
G 3.8 DOHC > Steering > Electronic Power Steering
C1101 Battery Voltage Over
C1102 Battery Voltage Under
C1212 Vehicle Speed Sensor
C1604 ECU Error
C2230 Solenoid Current Error
G 3.8 DOHC > Suspension > Electronic Control Suspension
C1101 Battery Voltage High
C1107 Alternator "L"Voltage High
C1108 Alternator"L" Voltage Low
C1112 Sensor Source Voltage
C1259 Steering Angle Sensor-Electrical
C1278 Acceleration Sensor Front-LH
C1279 Acceleration Sensor Front-RH
C1281 Acceleration Sensor Front-RH
C2124 Actuator Relay
C2212 Front-LH Actuator
C2216 Front-RH Actuator
C2220 Rear-LH Actuator
C2224 Rear-RH Actuator
G 3.0 DOHC > Air Conditioner > Air Conditioner
B1233 Incar Temperature Sensor Short(Low)
B1234 Incar Temperature Sensor Open(High)
B1237 Ambient Temperature Sensor Short(Low)
B1238 Ambient Temperature Sensor Open(High)
B1241 Evaporator Temperature Sensor Short(Low)
B1242 Evaporator Temperature Sensor Open(High)
B1245 DR Air Mix Potentiometer Open(Low)
B1246 DR Air Mix Potentiometer Short(High)
B1249 DR Direction Air Mix Potentiometer Open(Low)
B1250 DR Direction Air Mix Potentiometer Short(High)
B1417 Humidity Sensor Open(Low)
B1410 Humidity Sensor Short(High)
B1413 PS Air Mix Potentiometer Open(Low)
B1414 Passenger Air Mix Feedback-Short
B1415 Passenger Direction Potentiometer Open
B1416 PS Direction Potentiometer Short(High)
B2406 DR Air Mix Motor
B2409 DR Direction Motor
B2415 PS Air Mix Motor
G 3.0 DOHC > Airbag > Airbag Control
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1326 FIS(Front Impact Sensor)-Driver Short to Ground
B1327 FIS(Front Impact Sensor)-Driver Short to Battery
B1328 FIS(Front Impact Sensor)-Driver Defect
B1329 FIS(Front Impact Sensor)-Driver Communication error
B1330 FIS(Front Impact Sensor)-Driver Wrong ID
B1331 FIS(Front Impact Sensor)-Passenger Short to Ground
B1332 FIS(Front Impact Sensor)-Passenger Short to Battery
B1333 FIS(Front Impact Sensor)-Passenger Defect
B1334 FIS(Front Impact Sensor)-Passenger Communication error
B1335 FIS(Front Impact Sensor)-Passenger Wrong ID
B1401 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B1403 SIS(Side Impact Sensor) Front-Passenger Defect
B1404 SIS(Side Impact Sensor) Front-Passenger Circuit Short to Ground
B1405 SIS(Side Impact Sensor) Front-Passenger Circuit Short to Battery
B1409 SIS(Side Impact Sensor) Front-Driver Communication Error
B1410 SIS(Side Impact Sensor) Front-Passenger Communication Error
B1414 SIS(Side Impact Sensor) Front-Driver Wrong ID
B1415 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B1431 Side Airbag Rear-Driver Resistance Circuit Short to Ground
B1432 Side Airbag Rear-Driver Resistance Circuit Short to Battery
B1435 Side Airbag Rear-Passenger Resistance Circuit Short to Ground
B1436 Side Airbag Rear-Passenger Resistance Circuit Short to Battery
B1473 Inflatable Curtain Airbag Front-Driver Resistance too High
B1474 Inflatable Curtain Airbag Front-Driver Resistance too Low
B1475 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Ground
B1476 Inflatable Curtain Airbag Front-Driver Resistance Circuit Short to Battery
B1477 Inflatable Curtain Airbag Front-Passenger Resistance too High
B1478 Inflatable Curtain Airbag Front-Passenger Resistance too Low
B1479 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Ground
B1480 Inflatable Curtain Airbag Front-Passenger Resistance Circuit Short to Battery
B1511 Buckle Switch Driver Short or Short to Battery
B1512 Buckle Switch Driver Short or Short to Ground
B1513 Buckle Switch Passenger Open or Short to Battery
B1514 Buckle Switch Passenger Short or Short to Ground
B1515 Buckle Switch Driver Defect
B1516 Buckle Switch Passenger Defect
B1620 Internal fault-Replace SRSCM
B1651 Crash Recorded in Front-Driver Side Airbag(Replace SRSCM)
B1652 Crash Recorded in Front-Passenger Side Airbag(Replace SRSCM)
B2500 Warning Lamp Failure
G 3.0 DOHC > Body Control > Body Control Module
1 [BCM] Brake Lamp Malfunction
2 [BCM] Brake Fuse Open
3 [BCM] Direction Lamp Malfunction
4 [BCM] Rain Sensor Malfunction 1
5 [BCM] Rain Sensor Malfunction 2
6 [BCM] Rain Sensor Malfunction 3
7 [BCM] Can Error
8 [BCM] Can Bus Off
9 [BCM] Low Voltage/LIN Communication Line(RX) Error
10 [BCM] Low Voltage/LIN Communication Line(TX) Error
11 Driver Safety Power Window LIN Communication Error
12 Rear Driver Safety Power Window LIN Communication Error
13 Switch Module LIN Communication Error
14 LH Outside Mirror Horizontal Motor or Sensor Error
15 LH Outside Mirror Vertical Motor or Sensor Error
16 Driver Safety Power Window Motor Hall Sensor 1 Error
17 Driver Safety Power Window Motor Hall Sensor 2 Error
18 Driver Safety Power Window Normalization Error
19 Driver Safety Power Window Unit Error
20 Driver Motor Hall Sensor Count Direction Error
21 Driver Motor Thermal Protection Error
22 Driver Motor Hall Sensor Power Line Short
23 Driver Safety Power Window Input Voltage Low
24 Driver Safety Power Window Input Voltage High
25 Driver Safety Power Window Low Speed Error
26 Rear Driver Safety Power Window Motor Hall Sensor 1 Error
27 Rear Driver Safety Power Window Motor Hall Sensor 2 Error
28 Rear Driver Safety Power Window Normalization Error
29 Rear Driver Safety Power Window Unit Error
30 Rear Driver Motor Hall Sensor Count Direction Error
31 Rear Driver Motor Thermal Protection Error
32 Rear Driver Motor Hall Sensor Power Line Short
33 Rear Driver Safety Power Window Input Voltage Low
34 Rear Driver Safety Power Window Input Voltage High
35 Rear Driver Safety Power Window Low Speed Error
36 Passenger Safety Power Window LIN Communication Error
37 Rear Passenger Safety Power Window LIN Communication Error
38 RH Outside Mirror Horizontal Motor or Sensor Error
39 RH Outside Mirror Vertical Motor or Sensor Error
40 Passenger Safety Power Window Motor Hall Sensor 1 Error
41 Passenger Safety Power Window Motor Hall Sensor 2 Error
42 Passenger Safety Power Window Normalization Error
43 Passenger Safety Power Window Unit Error
44 Passenger Motor Hall Sensor Count Direction Error
45 Passenger Motor Thermal Protection Error
46 Passenger Driver Motor Hall Sensor Power Line Short
47 Passenger Driver Safety Power Window Input Voltage Low
48 Passenger Driver Safety Power Window Input Voltage High
49 Passenger Safety Power Window Low Speed Error
50 Rear Passenger Safety Power Window Motor Hall Sensor 1 Error
51 Rear Passenger Safety Power Window Motor Hall Sennsor 2 Error
52 Rear Passenger Safety Power Window Normalization Error
53 Rear Passenger Safety Power Window Unit Error
54 Rear Passenger Motor Hall Sensor Count Direction Error
55 Rear Passenger Motor Thermal Protection Error
56 Rear Passenger Driver Motor Hall Sensor Power Line Short
57 Rear Passenger Driver Safety Power Window Input Voltage Low
58 Rear Passenger Driver Safety Power Window Input Voltage High
59 Rear Passenger Safety Power Window Low Speed Error
60 Seat Slide Motor or Sensor Error
61 Seat Recline Motor or Sensor Error
62 Tilt Motor or Sensor Error
63 Telescope Motor or Sensor Error
G 3.0 DOHC > Brake > Electronic Stability Program
C1102 Battery Under Voltage
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/No Signal
C1203 Wheel Speed Sensor Front Right - Electrical
C1204 Wheel Speed Sensor Front Right - Extrapolate
C1205 Wheel Speed Sensor Front Right - Other
C1206 Wheel Speed Sensor Rear Left - Electrical
C1207 Wheel Speed Sensor Rear Left - Extrapolate
C1208 Wheel Speed Sensor Rear Left - Other
C1209 Wheel Speed Sensor Rear Right - Electrical
C1210 Wheel Speed Sensor Rear Right - Extrapolate
C1211 Wheel Speed Sensor Rear Right - Other
C1604 ECU Hardware error
C2112 Valve Relay Error
C2402 Motor Electrical
Отправлено 13 February 2021 - 11:33
G 3.0 DOHC > Head Lamp > Auto Headlamp Leveling
C1212 Vehicle Speed Sensor Mal.
C1255 RR Height Sensor Clrcuit
C1522 H/LAMP Light Sig. Line Open
C1606 ECM Software
C1620 First Setup Not Completed
C1621 Excessive Operating Temp.
C2226 Output Volt. Short To BAT/GND
G 3.0 DOHC > Immobilizer > Immobilizer
1 [IMM] ECU-BCM Communication Line Data Error
2 IMMO Power Short to Ground
3 IMMO Power Short to Battery
4 IMMO Output Signal Open/Short to Ground
5 IMMO Output Signal Short to Battery
6 IMMO Input Signal Short to Ground
7 IMMO Input Signal Open/Short to Battery
8 IMMO Antenna Coil Malfunction
Ещё обсуждения по Киа Опирус GH на MyKia.club:
