Киа Карнивал 2 VQ
Сообщений в теме: 28
#21 krionika
Отправлено 11 February 2021 - 10:28
G 2.7 DOHC > Airbag > Airbag Control
B1101 Battery voltage high
B1102 Battery voltage low
B1328 FIS-Driver defect
B1333 FIS-Passenger defect
B1395 Firing loops interconnection fault
B1400 SIS front-Driver defect
B1412 SIS rear-Driver communication error
B1413 SIS rear-Passenger communication error
B1418 SIS rear-Driver defect
B1419 SIS rear-Passenger defect
B1655 Crash recorded–Pass side with PAB inhibited
B1722 Inflatable curtain airbag rear-Driver resistance too High
B1723 Inflatable curtain airbag rear-Driver resistance too Low
B1724 Inflatable curtain airbag rear-Driver resistance circuit short to Ground
B1725 Inflatable curtain airbag rear-Driver resistance circuit short to Battery
B1726 Inflatable curtain airbag rear-Passenger resistance too High
B1727 Inflatable curtain airbag rear-Passenger resistance too Low
B1728 Inflatable curtain airbag rear-Passenger resistance circuit short to Ground
B1729 Inflatable curtain airbag rear-Passenger resistance circuit short to Battery
B2500 Warning Lamp
Отправлено 11 February 2021 - 10:29
G 2.7 DOHC > Instrument Panel Module > Instrument Panel Module
B1581 Ignition Switch Error
B1603 CAN BUSOFF
B1624 EEPROM Failure
B1627 EEPROM Corruption
B1628 Module Configuration Conflict
B1646 Software Rescue Mode
B1602 CAN Bus Physical Error, Bus Failure
B1611 Lost Communication With FAM, Bus Failure
B1612 Lost Communication With RAM, Bus Ffailure
B1613 Lost Communication With CLU, Bus Failure
B1605 Lost Communication With DDM, Bbus Failure
B1606 Lost Communication With ADM, Bus Failure
B1607 Lost Communication With IMS, Bus Failure
B1588 Front Wiper/Washer MF Switch Error
B1589 Rear Wiper/Washer MF Switch Error
B1590 Light MF Switch Error
B1591 Turn Signal MF Switch Error
B1647 VAS Error
B1102 Logic Battery Voltage Low
G 2.7 DOHC > Integrated Memory System > Integrated Memory System
B1954 Slide Motor or Sensor Error
B1955 Recline Motor or Sensor Error
B1956 Front Hight Motor or Sensor Error
B1957 Rear Hight Motor or Sensor Error
B1958 Pedal Motor or Sensor Error
B2456 Seat Motor Sensor Vcc Error
B2457 Pedal Motor Sensor Vcc Error
G 2.7 DOHC > Power Sliding Door > Power Sliding Door-Left
B1101 Logic Battery Voltage High
B1105 Reference Voltage Fault
B1223 VSS Failure
B1270 Optical Sensor 1 Stuck High
B1271 Optical Sensor 1 Stuck Low
B1272 Optical Sensor 2 Stuck High
B1273 Optical Sensor 2 Stuck Low
B1274 Broken Cable
B1580 Ignition Start Switch Short High
B1586 Chime Open or Short High
B1587 Chime Short Low
B1621 ECU Defective
B1645 Drive Unit Failure
B2420 Drive Motor Open
B2421 Drive Motor Short High
B2422 Drive Motor Short Low
B2423 Clutch Open or Short High
B2424 Clutch Short Low
B2425 Pinch Strip Open or Stuck High
B2426 Pinch Strip (PSD) Stuck Low
B2450 Unlatch Motor Short High
B2451 Unlatch Motor Short Low
G 2.7 DOHC > Power Sliding Door > Power Sliding Door-Right
B1223 VSS Failure
B1274 Broken Cable
B1621 ECU Defective
G 2.7 DOHC > Power Tail Gate > Power Tail Gate
B1223 VSS Failure
B1585 Latch Switch Failure
B1621 ECU Defective
B2425 Left Pinch Strip Open or Stuck High
B2426 Left Pinch Strip Stuck Low
B2427 Right Pinch Strip Open or Stuck High
B2428 Right Pinch Strip Stuck Low
B2452 Cinch Motor Open
G 2.7 DOHC > Rear Area Module > Rear Area Module
B2583 Left Tail License Side Marker Lamp Circuit Short to Ground Error
B2585 Left Tail License Side Marker Lamp Circuit Open Error
B2579 Right Tail License Side Marker Lamp Circuit Short to Ground Error
B2581 Right Tail License Side Marker Lamp Circuit Open Error
B2539 Left Turn Signal Lamp Circuit Short to Ground Error
B2541 Left Turn Signal Lamp Circuit Open Error
B2535 Right Turn Signal Lamp Circuit Short to Ground
B2537 Right Turn Signal Lamp Circuit Open Error
B2587 Back Up Lamps For Back Up Warning System Unit Circuit Short to Ground Error
B2589 Back Up Lamps For Back Up Warning System Unit Circuit Open Error
B2524 Stop Lamps Default Circuit Open Error
B2115 Rear Defog Relay Failure
B2441 Rear Wiper Park Position Detection Failure
B2598 Rear Blower Switch Illumination Circuit Open
B2599 Back Up Lamps For Back Up Warning System Unit Circuit Short to Ground Error
G 2.7 DOHC > Brake > ABS(MEB-2)
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1213 Wheel Speed Frequency Error
C1604 ECU Hardware Error
C1605 CAN Hardware Error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus Off
C1626 Implausible Control
C1643 CAN Time-out Yaw Rate & Lateral G Sensor
C1702 Variant Coding Error
C2112 Valve Relay Error
C2308 Front-LH Valve error (Inlet Valve)
C2312 Front-LH Valve error (Outlet Valve)
C2316 Front-RH Valve error (Inlet Valve)
C2320 Front-RH Valve error (Outlet Valve)
C2324 Rear-LH Valve error (Inlet Valve)
C2328 Rear-LH Valve error (Outlet Valve)
C2332 Rear-RH Valve error (Inlet Valve)
C2336 Rear-RH Valve error (Outlet Valve)
C2366 TC Valve Primary (USV1) Error
C2370 TC Valve Secondary (USV2) Error
C2372 Electronic Shuttle Valve Primary (HSV1) Error
C2374 Electronic Shuttle Valve Secondary (HSV2) Error
C2402 Motor Electrical
G 2.7 DOHC > Engine > Unleaded EOBD
P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Circuit (Bank 1 / Sensor 1)
P0036 HO2S Heater Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Circuit low (Bank 1 / Sensor 2)
P0038 HO2S Heater Circuit high (Bank 1 / Sensor 2)
P0050 HO2S Heater Circuit (Bank 2 / Sensor 1)
P0051 HO2S Heater Circuit low (Bank 2 / Sensor 1)
P0052 HO2S Heater Circuit high (Bank 2 / Sensor 1)
P0056 HO2S Heater Circuit (Bank 2 / Sensor 2)
P0057 HO2S Heater Circuit low (Bank 2 / Sensor 2)
P0058 HO2S Heater Circuit high (Bank 2 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High(Bank 1)
P0082 Intake Valve Control Solenoid Circuit Low(Bank 2)
P0083 Intake Valve Control Solenoid Circuit High(Bank 2)
P0105 Manifold ABSolute Pressure/Barometric Pressure Circuit
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Sensor1 Circuit
P0111 Intake Air Temperature Sensor1 Circuit Range/Performance
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0131 HO2S Circuit Low Voltage (Bank 1 / Sensor 1)
P0132 HO2S Circuit High Voltage (Bank 1 / Sensor 1)
P0133 HO2S Circuit Slow Response (Bank 1 / Sensor 1)
P0134 HO2S Circuit No Activity Detected (Bank 1 / Sensor 1)
P0137 HO2S Circuit Low Voltage (Bank 1 / Sensor 2)
P0138 HO2S Circuit High Voltage (Bank 1 / Sensor 2)
P0140 HO2S Circuit No Activity Detected (Bank 1 / Sensor 2)
P0151 HO2S Circuit Low Voltage (Bank 2 / Sensor 1)
P0152 HO2S Circuit High Voltage (Bank2 / Sensor 1)
P0153 HO2S Circuit Slow Response (Bank 2 / Sensor 1)
P0154 HO2S Circuit No Activity Detected (Bank 2 / Sensor 1)
P0157 HO2S Circuit Low Voltage (Bank 2 / Sensor 2)
P0158 HO2S Circuit High Voltage (Bank 2 / Sensor 2)
P0160 HO2S Circuit No Activity Detected (Bank 2 / Sensor 2)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0217 Engine Coolant Over Temperature Condition
P0222 Throttle Position Sensor 2 Signal Circuit Low Input
P0223 Throttle Position Sensor 2 Signal Circuit High Input
P0273 Cylinder 5 - Injector Circuit Low
P0274 Cylinder 5 - Injector Circuit High
P0276 Cylinder 6 - Injector Circuit Low
P0277 Cylinder 6 - Injector Circuit High
P0305 Cylinder 5 - Misfire detected
P0306 Cylinder 6 - Misfire detected
P0315 Segment Time Acquisition Incorrect
P0325 Knock Sensor 1 Circuit
P0330 Knock Sensor 2 Circuit
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0340 Camshaft Position Sensor "A" Circuit (Bank1)
P0341 Camshaft Position Sensor "A" Circuit Range/ Performace (Bank 1)
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0351 Ignition Coil A Primary / Secondary Circuit
P0352 Ignition Coil B Primary / Secondary Circuit
P0353 Ignition Coil C Primary / Secondary Circuit
P0354 Ignition Coil D Primary / Secondary Circuit
P0355 Ignition Coil E Primary / Secondary Circuit
P0356 Ignition Coil F Primary / Secondary Circuit
P0430 Catalyst System Efficiency below Threshold (Bank 2)
P0444 Evap. Emission System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission System - Purge Ctrl. Valve Circuit Shorted
P0506 Idle Air Control System - RPM lower than expected
P0507 Idle Air Control System - RPM higher than expected
P0551 Power Steering Pressure Sensor/Switch Circuit Range/Performance
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control ON Signal
P0566 Cruise Control CANCEL Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0571 Brake Switch A Circuit
P0601 EEPROM - Check Sum Error
P0602 EEPROM - Programing Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0606 ECM/PCM Processor(ECU-SELF TEST Failed)
P0638 Throttle Actuator Control Range/Performance
P0641 Sensor Reference Voltage A Circuit/Open
P0651 Sensor Reference Voltage B Circuit/Open
P0660 Intake Manifold Tuning Valve Control Circuit/Open (Bank 1)
P0663 Intake Manifold Tuning Valve Control Circuit/Open (Bank 2)
P1106 Manifold Absolute Pressure Sensor Circuit Short - Intermittent High Input
P1107 Manifold Absolute Pressure Sensor Circuit Short - Intermittent Low Input
P1111 Intake Air Temperature Sensor Circuit Intermittent Low Input
P1112 Intake Air Temperature Sensor Circuit Intermittent High Input
P1114 Engine Coolant Temperature Sensor Circuit Intermittent Low Input
P1115 Engine Coolant Temperature Sensor Circuit - Intermittent High Input
P1295 ETC (Electronic Throttle Control) System Malfunction - Power Management
P1523 ETC (Electronic Throttle Control) System Malfunction - Throttle Valve Stuck
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2098 Post Catalyst Fuel Trim System Too Lean (Bank 2)
P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
P2104 Lime Home Mode - Forced Idle
P2105 Lime Home Mode - Forced Engine Shutdown
P2106 Lime Home Mode - Forced Limited Power
P2122 Accelerator Position Sensor 1 Signal Circuit Low Input
P2123 Accelerator Position Sensor 1 Signal Circuit High Input
P2127 Accelerator Position Sensor 2 Signal Circuit Low Input
P2128 Accelerator Position Sensor 2 Signal Circuit High Input
P2135 Throttle Position Sensor 1 & 2 Signal Voltage Correlation
P2138 Accelerator Position Sensor 1 & 2 Signal Voltage Correlation
P2173 ETC (Electronic Throttle Control) System Malfunction - High Air flow Detected
P2187 System Too Lean at Idle (Bank 1)
P2188 System Too Rich at Idle (Bank 1)
P2189 System Too Lean at Idle (Bank 2)
P2190 System Too Rich at Idle (Bank 2)
P2195 HO2S Signal Stuck Lean (Bank 1 / Sensor 1)
P2196 HO2S Signal Stuck Rich (Bank 1 / Sensor 1)
P2197 HO2S Signal Stuck Lean (Bank 2 / Sensor 1)
P2198 HO2S Signal Stuck Rich (Bank 2 / Sensor 1)
P2270 HO2S Signal Stuck Lean (Bank 1 / Sensor 2)
P2271 HO2S Signal Stuck Rich (Bank 1 / Sensor 2)
P2272 HO2S Signal Stuck Lean (Bank 2 / Sensor 2)
P2273 HO2S Signal Stuck Rich (Bank 2 / Sensor 2)
P2507 ECM/PCM power Input Signal Low
P2610 ECM/PCM Internal Engine Off Timer Performance
U0001 CAN Communication BUS Off
G 2.7 DOHC > Transmission > Automatic Transaxle
P0722 AT Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0742 Torque Converter Clutch Stuck On
P0746 VFS Solenoid Valve Malfunction
P0748 VFS Solenoid Valve Circuit - Open or Short(GND)
P0770 Reduction Solenoid Valve Circuit - Open or Short(GND)
P0885 A/T Control Relay Malfalfunction
P0890 TCM Power Relay Sense Circuit Low
P0891 TCM Power Relay Sense Circuit High
Ещё обсуждения по Киа Карнивал 2 VQ на MyKia.club:
