Киа Карнивал 2 VQ
Сообщений в теме: 28
Отправлено 11 February 2021 - 10:27
D 2.9 VGT > Airbag > Airbag Control
B1101 Battery voltage high
B1102 Battery voltage low
B1328 FIS-Driver defect
B1333 FIS-Passenger defect
B1395 Firing loops interconnection fault
B1400 SIS front-Driver defect
B1412 SIS rear-Driver communication error
B1413 SIS rear-Passenger communication error
B1418 SIS rear-Driver defect
B1419 SIS rear-Passenger defect
B1655 Crash recorded–Pass side with PAB inhibited
B1722 Inflatable curtain airbag rear-Driver resistance too High
B1723 Inflatable curtain airbag rear-Driver resistance too Low
B1724 Inflatable curtain airbag rear-Driver resistance circuit short to Ground
B1725 Inflatable curtain airbag rear-Driver resistance circuit short to Battery
B1726 Inflatable curtain airbag rear-Passenger resistance too High
B1727 Inflatable curtain airbag rear-Passenger resistance too Low
B1728 Inflatable curtain airbag rear-Passenger resistance circuit short to Ground
B1729 Inflatable curtain airbag rear-Passenger resistance circuit short to Battery
B2500 Warning Lamp
D 2.9 VGT > Instrument Panel Module > Instrument Panel Module
B1581 Ignition Switch Error
B1603 CAN BUSOFF
B1624 EEPROM Failure
B1627 EEPROM Corruption
B1628 Module Configuration Conflict
B1646 Software Rescue Mode
B1602 CAN Bus Physical Error, Bus Failure
B1611 Lost Communication With FAM, Bus Failure
B1612 Lost Communication With RAM, Bus Ffailure
B1613 Lost Communication With CLU, Bus Failure
B1605 Lost Communication With DDM, Bbus Failure
B1606 Lost Communication With ADM, Bus Failure
B1607 Lost Communication With IMS, Bus Failure
B1588 Front Wiper/Washer MF Switch Error
B1589 Rear Wiper/Washer MF Switch Error
B1590 Light MF Switch Error
B1591 Turn Signal MF Switch Error
B1647 VAS Error
B1102 Logic Battery Voltage Low
Отправлено 11 February 2021 - 10:28
D 2.9 VGT > Integrated Memory System > Integrated Memory System
B1954 Slide Motor or Sensor Error
B1955 Recline Motor or Sensor Error
B1956 Front Hight Motor or Sensor Error
B1957 Rear Hight Motor or Sensor Error
B1958 Pedal Motor or Sensor Error
B2456 Seat Motor Sensor Vcc Error
B2457 Pedal Motor Sensor Vcc Error
D 2.9 VGT > Power Sliding Door > Power Sliding Door-Left
B1101 Logic Battery Voltage High
B1105 Reference Voltage Fault
B1223 VSS Failure
B1270 Optical Sensor 1 Stuck High
B1271 Optical Sensor 1 Stuck Low
B1272 Optical Sensor 2 Stuck High
B1273 Optical Sensor 2 Stuck Low
B1274 Broken Cable
B1580 Ignition Start Switch Short High
B1586 Chime Open or Short High
B1587 Chime Short Low
B1621 ECU Defective
B1645 Drive Unit Failure
B2420 Drive Motor Open
B2421 Drive Motor Short High
B2422 Drive Motor Short Low
B2423 Clutch Open or Short High
B2424 Clutch Short Low
B2425 Pinch Strip Open or Stuck High
B2426 Pinch Strip (PSD) Stuck Low
B2450 Unlatch Motor Short High
B2451 Unlatch Motor Short Low
D 2.9 VGT > Power Sliding Door > Power Sliding Door-Right
B1223 VSS Failure
B1274 Broken Cable
B1621 ECU Defective
D 2.9 VGT > Power Tail Gate > Power Tail Gate
B1223 VSS Failure
B1585 Latch Switch Failure
B1621 ECU Defective
B2425 Left Pinch Strip Open or Stuck High
B2426 Left Pinch Strip Stuck Low
B2427 Right Pinch Strip Open or Stuck High
B2428 Right Pinch Strip Stuck Low
B2452 Cinch Motor Open
D 2.9 VGT > Rear Area Module > Rear Area Module
B2583 Left Tail License Side Marker Lamp Circuit Short to Ground Error
B2585 Left Tail License Side Marker Lamp Circuit Open Error
B2579 Right Tail License Side Marker Lamp Circuit Short to Ground Error
B2581 Right Tail License Side Marker Lamp Circuit Open Error
B2539 Left Turn Signal Lamp Circuit Short to Ground Error
B2541 Left Turn Signal Lamp Circuit Open Error
B2535 Right Turn Signal Lamp Circuit Short to Ground
B2537 Right Turn Signal Lamp Circuit Open Error
B2587 Back Up Lamps For Back Up Warning System Unit Circuit Short to Ground Error
B2589 Back Up Lamps For Back Up Warning System Unit Circuit Open Error
B2524 Stop Lamps Default Circuit Open Error
B2115 Rear Defog Relay Failure
B2441 Rear Wiper Park Position Detection Failure
B2598 Rear Blower Switch Illumination Circuit Open
B2599 Back Up Lamps For Back Up Warning System Unit Circuit Short to Ground Error
D 2.9 VGT > Brake > ABS(MEB-2)
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1213 Wheel Speed Frequency Error
C1604 ECU Hardware Error
C1605 CAN Hardware Error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus Off
C1626 Implausible Control
C1643 CAN Time-out Yaw Rate & Lateral G Sensor
C1702 Variant Coding Error
C2112 Valve Relay Error
C2308 Front-LH Valve error (Inlet Valve)
C2312 Front-LH Valve error (Outlet Valve)
C2316 Front-RH Valve error (Inlet Valve)
C2320 Front-RH Valve error (Outlet Valve)
C2324 Rear-LH Valve error (Inlet Valve)
C2328 Rear-LH Valve error (Outlet Valve)
C2332 Rear-RH Valve error (Inlet Valve)
C2336 Rear-RH Valve error (Outlet Valve)
C2366 TC Valve Primary (USV1) Error
C2370 TC Valve Secondary (USV2) Error
C2372 Electronic Shuttle Valve Primary (HSV1) Error
C2374 Electronic Shuttle Valve Secondary (HSV2) Error
C2402 Motor Electrical
D 2.9 VGT > Engine > Engine Control
P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0069 Manifold Absolute Pressure-Barometric Pressure Correlaton
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0097 Intake Air temperature Sensor 2 circuit low
P0098 Intake Air temperature Sensor 2 circuit high
P0101 Mass or Volume Air Flow A Circuit Range/Performance
P0102 Mass or Volume Air Flow A Circuit Low
P0103 Mass or Volume Air Flow A Circuit High
P0112 Intake Air TEMP. Sensor 1 Circuit Low
P0113 Intake Air TEMP. Sensor 1 Circuit High
P0116 Engine Coolant Temperature Circuit Range/Performance
P0117 Engine Coolant TEMP. Sensor 1 Circuit Low
P0118 Engine Coolant TEMP. Sensor 1 Circuit High
P0182 Fuel TEMP. Sensor A Circuit Low
P0183 Fuel TEMP. Sensor A Circuit High
P0191 Fuel Rail Pressure Sensor A Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor A Circuit Low
P0193 Fuel Rail Pressure Sensor A Circuit High
P0194 Fuel Rail Pressure Sensor A Circuit Intermittent/Erratic
P0201 Cylinder 1 Injector Circuit/Open
P0202 Cylinder 2 Injector Circuit/Open
P0203 Cylinder 3 Injector Circuit/Open
P0204 Cylinder 4 Injector Circuit/Open
P0237 Turbo/Super Charger Boost Sensor "A" Circuit Low
P0238 Turbo/Super Charger Boost Sensor "A" Circuit High
P0253 Injection Pump Fuel Metering Control A Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control A High (Cam/Rotor/Injector)
P0263 Cylinder 1 Contribution/Balance
P0266 Cylinder 2 Contribution/Balance
P0269 Cylinder 3 Contribution/Balance
P0272 Cylinder 4 Contribution/Balance
P0325 Accelleometer ACC Engine Noise 0
P0330 Accelleometer ACC Engine Noise 1
P0340 Camshaft Position Sensor A Circuit (Bank 1)
P0381 Glow Plug/Heater Indicator Circuit
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0532 A/C Refrigerant Pressure Sensor "A" Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor "A" Circuit High Input
P0562 System Voltage Low
P0563 System Voltage High
P0603 Control Module Performance
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 ECM/PCM Processor
P0607 ECM/PCM Internal Error(Watch-dog)
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit High
P0670 Glow Plug Module Control Circuit
P0700 Transmission Control System(MIL Request)
P0830 Clutch Pedal Switch "A" Circuit
P0692 Cooling Fan Relay #1 Circuit High
P0693 Cooling Fan Relay #2 Circuit Low
P0694 Cooling Fan Relay #2 Circuit High
P1588 MT/AT autorecognition signal error
P1634 Auxiliary Heater Malfunction
P1655 Tacho Output Fault
P1670 Injector Classification Error (Diesel 1) / Injector Specific Data Error (Diesel 2)
P1674 Transponder Status Error
P1675 Transponder Programming Error
P1676 SMARTRA Message Error
P1690 SMARTRA No Response
P1691 Antenna Coil Error
P1693 Transponder No response Error / Invalid response
P1694 EMS message error
P2009 Intake Manifold Runner Control Circuit High
P2010 Intake Manifold Runner Control Circuit High
P2015 Manifold Runner Position Sensor/Switch Circuit Range/Performance
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low
P2123 Throttle/Pedal Position Sensor/Switch D Circuit High
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High
P2147 Injector Power Supply Circuit A Low
P2148 Injector Power Supply Circuit A High
P2228 Barometric Pressure Circuit Low
P2229 Barometric Pressure Circuit High
P2264 Water in Fuel Sensor Circuit
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
U0001 High Speed CAN Communication Bus
U0101 Lost Communication with TCM
U0122 Lost Communication With Vehicle Dynamics Control Module
D 2.9 VGT > Transmission > Automatic Transaxle
P0722 AT Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0742 Torque Converter Clutch Stuck On
P0746 VFS Solenoid Valve Malfunction
P0748 VFS Solenoid Valve Circuit - Open or Short(GND)
P0770 Reduction Solenoid Valve Circuit - Open or Short(GND)
P0885 A/T Control Relay Malfalfunction
P0890 TCM Power Relay Sense Circuit Low
P0891 TCM Power Relay Sense Circuit High
G 2.7 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1204 Air mix potentiometer open (Low) - Passenger
B1205 Air mix potentiometer short (High) - Passenger
B1206 Direction potentiometer open (Low) - Passenger
B1207 Direction potentiometer short (High) - Passenger
B1208 Intake potentiometer open (Low)
B1209 Intake potentiometer short (High)
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B1260 Air mix potentiometer open (Low) - Rear
B1261 AIR MIX POTENTIO OPEN (LOW) RE
B1262 Direction potentiometer open (Low) - Rear
B1263 Direction potentiometer short (High) - Rear
B2405 AIR MIX MOTOR (REAR)
B2406 Air mix motor (Driver)
B2408 Intake motor
B2409 Direction control motor (Driver)
B2411 Direction control motor (Rear)
B2415 Air mix motor (Driver)
B2416 Direction control motor (Passengr)
Ещё обсуждения по Киа Карнивал 2 VQ на MyKia.club:
