Киа Соренто 2 XM
Сообщений в теме: 25
Отправлено 05 February 2021 - 15:12
D 2.2 TCI-R > Smart Key > Smart Key Code Saving(Button)
D 2.2 TCI-R > Smart Key > Smart Key Unit
B160200 CAN Error
B160300 CAN Bus OFF
D 2.2 TCI-R > Steering > Motor driven Power Steering
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1109 IGN Signal Error
C1290 Torque Sensor Signal Error
C1603 MDPS Thermal Protection
C1604 ECU Hardware Error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1616 CAN Bus Off
C1622 Vehicle Speed Signal Error
C1628 CAN Timeout - Cluster
C1646 CAN Message Failure - TCU
C1656 CAN Signal Error Cluster
C1692 CAN Time-out VSM
C1693 CAN Signal Error VSM
C1696 CAN time-out SPAS
C1697 CAN Message Failure - SPAS
C1700 Byte Coding Error
C1702 Variant Coding Error
C1704 ECU Fail-Safe Relay Fault
C1705 EPS Module(pre-charge circuit) Malfunction
C2400 Motor Fault - Motor Not Running
C2401 Motor Position Sensor Error
C2412 Motor Short or Open
C2413 Motor Current Error
Отправлено 05 February 2021 - 15:13
D 2.2 TCI-R > Tire Pressure Monitoring > Tire Pressure Monitoring
C1212 Vehicle Speed Sensor
C1332 Front Left Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1611 CAN Time-out EMS
C1616 CAN Bus OFF
C1642 CAN Message Failure - Brake
C1660 Receiver RF Circuit Fail
C1661 Receiver EEPROM Failure
C1662 Auto Learning failure
C1663 Auto Location Failure
D 2.2 TCI-R > Transmission > Automatic Transaxle
P0601 Internal Control Module Memory Check Sum Error
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range/Performance
P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input
P0717 Input/Turbine Speed Sensor "A" Circuit No Signal
P0722 Output Speed Sensor Circuit No Signal
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0729 Gear 6 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0748 Pressure Control Solenoid Valve(VFS) "A" Electrical
P0753 Shift Control Solenoid Valve "A" Electical (UD/B)
P0758 Shift Control Solenoid Valve "B" Electrical (2-6/B)
P0763 Shift Control Solenoid Valve "C" Electrical (35R/C)
P0768 Shift Control Solenoid Valve "D" Electrical (OD/C)
P0773 Shift Control Solenoid Valve "E" Electrical (SS-A)
P0880 TCM Power Signal Error Open/Short (GND)
P0955 Auto Shift Manual Mode Circuit
P2709 Shift Control Solenoid Valve "F" Electrical (SS-B)
U0100 Lost Communication With ECM/PCM "A"
G 2.4 MPI > Active Hood System > Active Hood System
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1602 CAN LINE ERROR
B1624 EEPROM Failure
B1809 Active Hood System Sensor Failure
B2343 Temperature Sensor Error
B2355 Active Hood System LH Actuator Failure
B2356 Active Hood System RH Actuator Failure
B2357 Fire Output
B2358 Active Hood System LH Actuator Fuse Failure
B2359 Active Hood System RH Actuator Fuse Failure
B2360 Exceeds Fire Counter
B2594 Active Hood System Warning Lamp Failure
G 2.4 MPI > Air Conditioner > Air Conditioner
B1204 Air Mix Potentiometer Open (Low)–Passenger
B1205 Air Mix Potentiometer Short (High)–Passenger
B1237 Ambient Temperature Sensor Short (Low)
B1238 Ambient Temperature Sensor Open (High)
B1245 Air Mix Potentiometer Open (Low)-Driver
B1246 Air Mix Potentiometer Short (High)-Driver
B1249 Direction Potentiometer Open (Low)-Driver
B1250 Direction Potentiometer Short (High)-Driver
B1281 Humidity Sensor Short (Low) – AUTO Defog
B1283 Direction Potentiometer Open (Low) - AUTO Defog
B1284 Direction Potentiometer Short (High) - Auto Defog
B1285 Direction Control Motor -AUTO Defog
B1672 APT Sensor Fault – CAN Signal
B1685 Engine RPM fault – CAN Signal
B1686 Vehicle Speed Sensor Fault – CAN Signal
B1687 Engine Coolant Temperature Sensor Circuit - CAN Signal
B1688 Cluster Ionizer Fault
B2406 Air Mix Motor-Driver
B2408 Intake Motor
B2409 Direction Control Motor-Driver
B2415 Air Mix Door Motor-Passenger
G 2.4 MPI > Airbag > Airbag(Event #1)
B110100 Battery Voltage High
B110200 Battery Voltage Low
B132800 FIS(Front Impact Sensor)-Driver Defect
B132900 FIS(Front Impact Sensor)-Driver Communication error
B133000 FIS(Front Impact Sensor)-Driver Wrong ID
B133300 FIS(Front Impact Sensor)-Passenger Defect
B133400 FIS(Front Impact Sensor)-Passenger Communication error
B133500 FIS(Front Impact Sensor)-Passenger Wrong ID
B134600 Driver Airbag Resistance too High (1st stage)
B134700 Driver Airbag Resistance too Low (1st stage)
B134800 Driver Airbag resistance circuit short to Ground (1st stage)
B134900 Driver Airbag resistance circuit short to Battery (1st stage)
B135200 Passenger Airbag Resistance too High (1st Stage)
B135300 Passenger Airbag Resistance too Low (1st stage)
B135400 Passenger Airbag Resistance Circuit Short to Ground (1st Stage)
B135500 Passenger Airbag Resistance Circuit Short to Battery (1st Stage)
B136100 Pretensioner Front-Driver Resistance too High
B136200 Pretensioner Front-Driver Resistance too Low
B136300 Pretensioner front-Driver resistance circuit short to Ground
B136400 Pretensioner front-Driver resistance circuit short to Battery
B136700 Pretensioner Front-Passenger Resistance too High
B136800 Pretensioner Front-Passenger Resistance too Low
B136900 Pretensioner Front-Passenger Resistance Circuit Short to Ground
B137000 Pretensioner Front-Passenger Resistance Circuit Short to Battery
B137800 Side Airbag Front-Driver Resistance too High
B137900 Side Airbag Front-Driver Resistance too Low
B138000 Side Airbag Front-Driver Resistance Circuit Short to Ground
B138100 Side Airbag Front-Driver Resistance Circuit Short to Battery
B138200 Side Airbag Front-Passenger Resistance too High
B138300 Side Airbag Front-Passenger Resistance too Low
B138400 Side Airbag Front-Passenger Resistance Circuit Short to Ground
B138500 Side Airbag Front-Passenger Resistance Circuit Short to Battery
B139500 Cross coupling
B141200 SIS(Side Impact Sensor)Rear-Driver Communication error
B141300 SIS(Side Impact Sensor)Rear-Passenger Communication error
B141600 SIS(Side Impact Sensor)Rear-Driver Wrong ID
B141700 SIS(Side Impact Sensor)Rear-Passenger Wrong ID
B141800 SIS(Side Impact Sensor)Rear-Driver Defect
B141900 SIS(Side Impact Sensor)Rear-Passenger Defect
B147300 Inflatable Curtain Airbag Driver Resistance too High
B147400 Inflatable Curtain Airbag Driver Resistance too Low
B147500 Inflatable Curtain Airbag Driver Resistance Circuit Short to Ground
B147600 Inflatable Curtain Airbag Driver Resistance Circuit Short to Battery
B147700 Inflatable Curtain Airbag Passenger Resistance too High
B147800 Inflatable Curtain Airbag Passenger Resistance too Low
B147900 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Ground
B148000 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Battery
B152700 Passenger airbag On/Off switch open or short to Battery
B152800 Passenger airbag On/Off switch short or short to Ground
B152900 Passenger airbag On/Off switch defect
B162000 Internal fault-Replace SRSCM
B164900 Crash Recorded - Rollover event (Replace SRSCM)
B165000 Crash Recorded in 1st Stage Only(Frontal-Replace SRSCM)
B165100 Crash Recorded in Driver Side Airbag(Replace SRSCM)
B165200 Crash Recorded in Passenger Side Airbag(Replace SRSCM)
B167800 Scrap Recorded(Replace SRSCM)
B168300 Exceed Maximum Coding Number
B168400 Not Configured Device is Detected
B173000 Anchor Pretensioner front-Driver resistance too High
B173100 Anchor Pretensioner front-Driver resistance too Low
B173200 Anchor Pretensioner front-Driver resistance circuit short to Ground
B173300 Anchor Pretensioner front-Driver resistance circuit short to Battery
B173800 P-SIS(Side Impact Sensor, Pressure) Front - Driver Wrong ID
B173900 P-SIS(Side Impact Sensor, Pressure) Front-Driver Defect
B174200 P-SIS(Side Impact Sensor, Pressure) Front-Driver Communication Error
B174400 P-SIS(Side Impact Sensor, Pressure) Front - Passenger Wrong ID
B174500 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Defect
B174800 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Communication Error
B176200 ACU Coding Error
B250000 Warning lamp Failure
B250500 Passenger Airbag on/off Warning Lamp Failure
G 2.4 MPI > Body Control > Body Control Module
B121000 Front Left Sensor Fault
B121100 Front Center Left Sensor Fault
B121200 Front Center Right Sensor Fault
B121300 Front Right Sensor Fault
B121400 Rear Left Sensor Fault
B121500 Rear Center Left Sensor Fault
B121600 Rear Center Right Sensor Fault
B121700 Rear Right Sensor Fault
B160200 CAN Line Error (B-CAN)
B160300 CAN Bus OFF (B-CAN)
G 2.4 MPI > Brake > Electronic Stability Program
C1112 Sensor source voltage
C1274 Longitudinal G sensor open/short
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yaw Rate & Lateral G Sensor-Electrical
C1285 Longitudinal G Sensor Not Calibrated
C1286 Yaw Rate & G Sensor Fail-Check SRSCM
C1503 TCS/ESC(ESP) Switch error
C1520 Clutch Signal Error
C1526 Down Hill Brake Control(DBC) Switch Error
C1605 CAN Hardware error
C1613 CAN Wrong Message
C1616 CAN Bus off
C1627 CAN Time-out 4WD
C1647 CAN Hardware Error - Sensor Channel
C1687 CAN Time-out VSM2 (MDPS)
C1688 VSM2 (MDPS) Signal Error
C2112 Valve Relay Error
C2130 Brake Lamp Relay Error
C2131 ESS Brake Lamp Relay Error
C2227 Excessive Temperature Of Brake Disc
C2380 ABS/TCS/ESC(ESP) valve error
C2402 Motor Failure
G 2.4 MPI > Driveshaft > 4WD Control
P0602 Control Module Programming Error
P1779 Supply Voltage Missing
P1780 Battery Voltage High
P1781 Battery Voltage Low
P1820 Pump for 4WD Motor High Overcurrent Detected
P1821 Pump for 4WD Motor Wire Short to Battery
P1822 Pump for 4WD Motor Wire Open Load
P1823 Pump for 4WD Motor Wire Short to GND
P1824 Pump for 4WD Slow Thermal Overload
P1825 Pressure Sensor for 4WD Supply Short to Battery
P1826 Pressure Sensor for 4WD Supply Short to Ground
P1827 Pressure Sensor for 4WD Signal Wire Short to Battery
P1828 Pressure Sensor for 4WD Signal Wire Short to Ground
P1829 Clutch Torque Tolerance Upper Limit
P1830 Clutch Torque Tolerance Lower Limit
P1831 Clutch Thermal Overstress Warning
P1832 Clutch Thermal Overstress Shutdown
P1833 Actuator Thermal Overstress Warning
P1834 Actuator Thermal Overstress Shutdown
P1835 Pressure Sensor for 4WD Supply Offset Failure
P1836 Bleed Pressure Line Test Error
P1837 Vehicle Variant Can Not Be Detected
U0101 Lost Communication with TCM (C-CAN)
U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0122 Lost Communication With Vehicle Dynamics Control Module
U0126 Lost Communication With Steering Angle Sensor Module
U1121 Lost Communication With Electric Stability Program Module
G 2.4 MPI > Engine > Engine Control
P0011 "A" Camshaft Position-Timing Over-Advanced or System Performance (Bank 1)
P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0016 Crankshaft Position–Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position – Camshaft Position Correlation (Bank 1 Sensor B)
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit-High (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0111 Intake Air Temperature Sensor 1 Circuit Range / Performance
P0119 Engine Coolant Temperature Circuit Intermittent
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0170 Fuel Trim (Bank 1)
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0261 Cylinder 1 Injector Circuit Low
P0264 Cylinder 2 Injector Circuit Low
P0267 Cylinder 3 Injector Circuit Low
P0270 Cylinder 4 Injector Circuit Low
P0301 Cylinder 1-Misfire detected
P0302 Cylinder 2-Misfire detected
P0303 Cylinder 3-Misfire detected
P0304 Cylinder 4-Misfire detected
P0315 Camshaft Position (CMP) Sensor Error
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0340 Camshaft Position Sensor "A" Circuit (Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1)
P0365 Camshaft Position Sensor B Circuit Malfunction (Bank 1)
P0366 Camshaft Position Sensor "B" Circuit Range/Performance (Bank 1)
P0444 Evaporative Emission System-Purge Control Valve Circuit Open
P0445 Evaporative Emission System-Purge Control Valve Circuit Shorted
P0501 Vehicle Speed Sensor "A" Range/Performance
P0504 Brake Switch "A" / "B" Correlation
P0560 System Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0620 Alternator Control Circuit
P0625 Generator Field/ F Terminal Circuit Low
P0626 Generator Field/F Terminal Circuit High
P0638 Throttle Actuator Control Range/Performance (Bank 1)
P0642 Sensor Reference Voltage "A" Circuit Low
P0643 Sensor Reference Voltage "A" Circuit High
P0652 Sensor Reference Voltage "B" Circuit Low
P0653 Sensor Reference Voltage "B" Circuit High
P0661 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
P0662 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
P0698 Sensor Reference Voltage "C" Circuit Low
P0699 Sensor Reference Voltage "C" Circuit High
P06A4 Sensor Reference Voltage "D" Circuit Low
P06A5 Sensor Reference Voltage "D" Circuit High
P0704 Clutch Switch Input Circuit Malfunction
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2104 Throttle Actuator Control System - Forced Idle
P2105 Throttle Actuator Control System-Force Engine Shutdown
P2106 Throttle Actuator Control System-Force Limited Power
P2110 Throttle Actuator Control System - Forced Limited RPM
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch "D" Circuit Low Input
P2123 Throttle/Pedal Position Sensor /Switch "D" Circuit High Input
P2127 Throttle/Pedal Position Sensor/Switch "E" Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch "E" Circuit-High Input
P2159 Vehicle Speed Sensor "B" Range / Performance(Wheel Speed Sensor)
P2187 System too Lean at Idle (←Additive) (Bank 1)
P2188 System too Rich at Idle (Bank 1)
P2191 System too Lean at Higher Load (Multiple) (Bank 1)
P2192 System too Rich at Higher Load (Bank 1)
P2195 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P2196 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
P2237 O2 Sensor Pumping Current Circuit/Open (Bank 1 Sensor 1)
P2243 O2 Sensor Reference Voltage Circuit/Open (Bank 1 Sensor 1)
P2251 O2 Sensor Reference Ground Circuit/Open (Bank 1 Sensor 1)
P2270 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 2)
P2271 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 2)
P2297 O2 Sensor Out of Range During Deceleration - (Bank 1 Sensor 1)
P2414 O2 Sensor Exhaust Sample Error (Bank 1 Sensor 1)
P2502 Battery Voltage Rationality
P2503 No Battery Charge
P2610 ECM/PCM Internal Engine Off Timer Performance
U0101 Lost Communication With TCM
U1111 Battery Sensor fault detected by ECU
U1112 LIN Communication Error
