G 2.4 MPI > Head Lamp > Adaptive Front Lighting System
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1220 Vehicle Speed Sensor
B1301 Steering angle signal fault
B1302 Gearbox Signal Fault-CAN Signal
B1303 Accelerator Pedal Position Signal Error
B1304 Engine state signal fault
B1305 Yaw Rate Sensor Signal Fault
B1306 Brake pedal signal fault
B1308 Lamp Function Signal Fault
B1603 CAN Communication Bus Off
B1621 ECU Hardware Error
B1622 ECU Software Error
B1636 LIN Communication Error Fault
B1637 System Not Initialized
B1639 LIN communication error DBL left
B1661 Parameter Fault And Missing
B1953 AXLE Sensor Fault
B2200 LIN communication error DBL(Dynamic Bending Light) Right
B2201 LIN communication error HLL(Head Lamp Leveling) Left
B2202 LIN communication error HLL(Head Lamp Leveling) Right
B2325 Swivel module fault left
B2326 Swivel module fault right
B2400 Levelling motor fault left
B2401 Levelling motor fault right
G 2.4 MPI > Head Lamp > Auto Headlamp Leveling System
C1212 Vehicle Speed Sensor Failure
C1255 Rear Height Sensor
C1258 Magnet Setting Error
C1381 Sensor Internal Error
C1522 Head lamp Switch Fault
C1604 ECU Fault
C1606 ECU Software Error
C1620 First Setup Not Completed
C2226 Output Voltage Short to Battery or Short to Ground
#21
Отправлено 05 February 2021 - 15:14
Re: коды ошибок, расшифровка
G 2.4 MPI > Immobilizer > Immobilizer
P1675 Immobilizer-Transponder Programming Error
P169A Immobilizer-SMARTRA Authentication Fail
P1692 Immobilizer Indicator Lamp Error
G 2.4 MPI > LDWS > Blind Spot Detection
C1101XX Battery Voltage High
C1102XX Battery Voltage Low
C120AXX LED Right Circuit Short to Ground
C120BXX LED Right Circuit Short to Battery or Open
C120CXX LED Left Circuit Short to Ground
C120DXX LED Left Circuit Short to Battery or Open
C1501XX Switch Failure
C1611XX CAN Time-out EMS
C1613XX CAN signal error EMS
C1616XX CAN Bus OFF(C-CAN)
C1625XX CAN Time-out ABS/ESC(ESP)
C1628XX CAN Time-out Cluster
C1671XX Signal Yaw Rate or Acceleration AX or Acceleration AY or Brakepressure State not valid
C160AXX BSD Local CAN bus off
C170AXX Activation Switch LED Circuit short to ground
C170CXX ECU Hardware error (REAR LEFT)
C170DXX ECU Hardware error (REAR RIGHT)
C2702XX Control Module Master Missing Calibration
C2703XX Control Module Slave Missing Calibration
G 2.4 MPI > LDWS > Lane Departure Warning System
C1361 Camera H/W Failure
C1363 Camera Signal Error for Calibration
C1364 Not found Reference Point
C1365 Invalid Reference Point
C1604 ECU HW error
C1613 CAN Wrong Message
C1616 CAN Bus OFF
C1653 CAN Time-out Cluster for SCC
C1654 CAN Time-out Cluster for EPB
C1702 Variant Coding Error
C2710 In Line Test Failure-Not found Lane
C2711 In Line Test Failure-Not found Lane Change
C2721 Camera Not Calibrated
G 2.4 MPI > SPAS > Smart Parking Assist System
C1104 Ignition Voltage High
C1105 Ignition Voltage Low
C1112 Sensor Source Voltage
C1368 PAS Sensor - Rear Left Outer
C1369 PAS Sensor - Rear Left Inner
C1370 PAS Sensor - Rear Right Inner
C1371 PAS Sensor - Rear Right Outer
C1372 PAS Sensor - Front Right Outer
C1373 PAS Sensor - Front Right Inner
C1374 PAS Sensor - Front Left Inner
C1375 PAS Sensor - Front Left Outer
C1376 SPAS Sensor - Front Left
C1377 SPAS Sensor - Front Right
C1528 PAS Switch Indicator Failure
C1529 SPAS Switch Indicator Failure
C1530 PAS Switch Failure
C1531 SPAS Switch Failure
C1604 ECU Hardware Error
C1612 CAN Time-out TCU
C1616 CAN Bus Off
C1625 CAN Time-out ABS/ESP
C1628 CAN Timeout - Cluster
C1642 CAN Message Failure - ABS/ESC(ESP)
C1646 CAN Message Failure - TCU
C1656 CAN signal error Cluster
C1687 CAN Time-out MDPS
C1688 MDPS signal error
C1694 CAN Time out - FATC
C1695 CAN Message Failure - FATC
G 2.4 MPI > Smart Key > Smart Key Code Saving(Button)
G 2.4 MPI > Smart Key > Smart Key Unit
B160200 CAN Error
B160300 CAN Bus OFF
G 2.4 MPI > Steering > Motor driven Power Steering
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1109 IGN Signal Error
C1290 Torque Sensor Signal Error
C1603 MDPS Thermal Protection
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1616 CAN Bus Off
C1622 Vehicle Speed Signal Error
C1656 CAN Signal Error Cluster
C1692 CAN Time-out VSM
C1693 CAN Signal Error VSM
C1696 CAN time-out SPAS
C1697 CAN Message Failure - SPAS
C1700 Byte Coding Error
C1704 ECU Fail-Safe Relay Fault
C1705 EPS Module(pre-charge circuit) Malfunction
C2400 Motor Fault - Motor Not Running
C2401 Motor Position Sensor Error
C2412 Motor Short or Open
C2413 Motor Current Error
G 2.4 MPI > Tire Pressure Monitoring > Tire Pressure Monitoring
C1332 Front Left Sensor Fault
C1334 Left Rear Sensor Fault
C1335 Rear Right Sensor Fault
C1611 CAN Time-out EMS
C1616 CAN Bus OFF
C1642 CAN Message Failure - Brake
C1660 Receiver RF Circuit Fail
C1661 Receiver EEPROM Failure
C1662 Auto Learning failure
C1663 Auto Location Failure
G 2.4 MPI > Transmission > Automatic Transaxle
P0601 Internal Control Module Memory Check Sum Error
P0705 Transmission Range Sensor Circuit Malfunction
P0706 Transmission Range Sensor Circuit Range/Performance
P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input
P0717 Input/Turbine Speed Sensor "A" Circuit No Signal
P0722 Output Speed Sensor Circuit No Signal
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0729 Gear 6 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0748 Pressure Control Solenoid Valve(VFS) "A" Electrical
P0753 Shift Control Solenoid Valve "A" Electical (UD/B)
P0758 Shift Control Solenoid Valve "B" Electrical (2-6/B)
P0763 Shift Control Solenoid Valve "C" Electrical (35R/C)
P0768 Shift Control Solenoid Valve "D" Electrical (OD/C)
P0773 Shift Control Solenoid Valve "E" Electrical (SS-A)
P0880 TCM Power Signal Error Open/Short (GND)
P0955 Auto Shift Manual Mode Circuit
P2709 Shift Control Solenoid Valve "F" Electrical (SS-B)
U0100 Lost Communication With ECM/PCM "A"
Ещё обсуждения по Киа Соренто 2 XM на MyKia.club:
Киа Соренто 2 XM
Киа Соренто клуб →
Двигатель и КПП Kia Sorento →
замена АКППАвтор krionika, 22 Aug 2011 |
Киа Соренто 2 XM
Киа Соренто клуб →
ремонт двигателяАвтор *Дмитрий* , 20 Feb 2022 |
Киа Соренто 2 XM
Киа Соренто клуб →
кондиционерАвтор krionika, 29 Oct 2011 |
Киа Соренто 2 XM
Киа Соренто клуб →
схема проводки (жгутов)Автор krionika, 16 Sep 2011 |
Киа Соренто 2 XM
Киа Соренто клуб →
вентилятор печкиАвтор krionika, 02 Jun 2011 |
