Киа Соренто 2 XM
Сообщений в теме: 25
Отправлено 05 February 2021 - 15:11
Коды ошибок Kia Sorento 2 (XM)
D 2.2 TCI-R > Active Hood System > Active Hood System
B1101 Battery Voltage High
B1102 Battery Voltage Low
B1602 CAN LINE ERROR
B1624 EEPROM Failure
B1809 Active Hood System Sensor Failure
B2343 Temperature Sensor Error
B2355 Active Hood System LH Actuator Failure
B2356 Active Hood System RH Actuator Failure
B2357 Fire Output
B2358 Active Hood System LH Actuator Fuse Failure
B2359 Active Hood System RH Actuator Fuse Failure
B2360 Exceeds Fire Counter
B2594 Active Hood System Warning Lamp Failure
D 2.2 TCI-R > Air Conditioner > Air Conditioner
B1204 Air Mix Potentiometer Open (Low)–Passenger
B1205 Air Mix Potentiometer Short (High)–Passenger
B1237 Ambient Temperature Sensor Short (Low)
B1238 Ambient Temperature Sensor Open (High)
B1245 Air Mix Potentiometer Open (Low)-Driver
B1246 Air Mix Potentiometer Short (High)-Driver
B1249 Direction Potentiometer Open (Low)-Driver
B1250 Direction Potentiometer Short (High)-Driver
B1281 Humidity Sensor Short (Low) – AUTO Defog
B1283 Direction Potentiometer Open (Low) - AUTO Defog
B1284 Direction Potentiometer Short (High) - Auto Defog
B1285 Direction Control Motor -AUTO Defog
B1672 APT Sensor Fault – CAN Signal
B1685 Engine RPM fault – CAN Signal
B1686 Vehicle Speed Sensor Fault – CAN Signal
B1687 Engine Coolant Temperature Sensor Circuit - CAN Signal
B1688 Cluster Ionizer Fault
B2406 Air Mix Motor-Driver
B2408 Intake Motor
B2409 Direction Control Motor-Driver
B2415 Air Mix Door Motor-Passenger
D 2.2 TCI-R > Airbag > Airbag(Event #1)
B110100 Battery Voltage High
B110200 Battery Voltage Low
B132800 FIS(Front Impact Sensor)-Driver Defect
B132900 FIS(Front Impact Sensor)-Driver Communication error
B133000 FIS(Front Impact Sensor)-Driver Wrong ID
B133300 FIS(Front Impact Sensor)-Passenger Defect
B133400 FIS(Front Impact Sensor)-Passenger Communication error
B133500 FIS(Front Impact Sensor)-Passenger Wrong ID
B134600 Driver Airbag Resistance too High (1st stage)
B134700 Driver Airbag Resistance too Low (1st stage)
B134800 Driver Airbag resistance circuit short to Ground (1st stage)
B134900 Driver Airbag resistance circuit short to Battery (1st stage)
B135200 Passenger Airbag Resistance too High (1st Stage)
B135300 Passenger Airbag Resistance too Low (1st stage)
B135400 Passenger Airbag Resistance Circuit Short to Ground (1st Stage)
B135500 Passenger Airbag Resistance Circuit Short to Battery (1st Stage)
B136100 Pretensioner Front-Driver Resistance too High
B136200 Pretensioner Front-Driver Resistance too Low
B136300 Pretensioner front-Driver resistance circuit short to Ground
B136400 Pretensioner front-Driver resistance circuit short to Battery
B136700 Pretensioner Front-Passenger Resistance too High
B136800 Pretensioner Front-Passenger Resistance too Low
B136900 Pretensioner Front-Passenger Resistance Circuit Short to Ground
B137000 Pretensioner Front-Passenger Resistance Circuit Short to Battery
B137800 Side Airbag Front-Driver Resistance too High
B137900 Side Airbag Front-Driver Resistance too Low
B138000 Side Airbag Front-Driver Resistance Circuit Short to Ground
B138100 Side Airbag Front-Driver Resistance Circuit Short to Battery
B138200 Side Airbag Front-Passenger Resistance too High
B138300 Side Airbag Front-Passenger Resistance too Low
B138400 Side Airbag Front-Passenger Resistance Circuit Short to Ground
B138500 Side Airbag Front-Passenger Resistance Circuit Short to Battery
B139500 Cross coupling
B141200 SIS(Side Impact Sensor)Rear-Driver Communication error
B141300 SIS(Side Impact Sensor)Rear-Passenger Communication error
B141600 SIS(Side Impact Sensor)Rear-Driver Wrong ID
B141700 SIS(Side Impact Sensor)Rear-Passenger Wrong ID
B141800 SIS(Side Impact Sensor)Rear-Driver Defect
B141900 SIS(Side Impact Sensor)Rear-Passenger Defect
B147300 Inflatable Curtain Airbag Driver Resistance too High
B147400 Inflatable Curtain Airbag Driver Resistance too Low
B147500 Inflatable Curtain Airbag Driver Resistance Circuit Short to Ground
B147600 Inflatable Curtain Airbag Driver Resistance Circuit Short to Battery
B147700 Inflatable Curtain Airbag Passenger Resistance too High
B147800 Inflatable Curtain Airbag Passenger Resistance too Low
B147900 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Ground
B148000 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Battery
B152700 Passenger airbag On/Off switch open or short to Battery
B152800 Passenger airbag On/Off switch short or short to Ground
B152900 Passenger airbag On/Off switch defect
B162000 Internal fault-Replace SRSCM
B164900 Crash Recorded - Rollover event (Replace SRSCM)
B165000 Crash Recorded in 1st Stage Only(Frontal-Replace SRSCM)
B165100 Crash Recorded in Driver Side Airbag(Replace SRSCM)
B165200 Crash Recorded in Passenger Side Airbag(Replace SRSCM)
B167800 Scrap Recorded(Replace SRSCM)
B168300 Exceed Maximum Coding Number
B168400 Not Configured Device is Detected
B173000 Anchor Pretensioner front-Driver resistance too High
B173100 Anchor Pretensioner front-Driver resistance too Low
B173200 Anchor Pretensioner front-Driver resistance circuit short to Ground
B173300 Anchor Pretensioner front-Driver resistance circuit short to Battery
B173800 P-SIS(Side Impact Sensor, Pressure) Front - Driver Wrong ID
B173900 P-SIS(Side Impact Sensor, Pressure) Front-Driver Defect
B174200 P-SIS(Side Impact Sensor, Pressure) Front-Driver Communication Error
B174400 P-SIS(Side Impact Sensor, Pressure) Front - Passenger Wrong ID
B174500 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Defect
B174800 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Communication Error
B176200 ACU Coding Error
B250000 Warning lamp Failure
B250500 Passenger Airbag on/off Warning Lamp Failure
D 2.2 TCI-R > Body Control > Body Control Module
B121000 Front Left Sensor Fault
B121100 Front Center Left Sensor Fault
B121200 Front Center Right Sensor Fault
B121300 Front Right Sensor Fault
B121400 Rear Left Sensor Fault
B121500 Rear Center Left Sensor Fault
B121600 Rear Center Right Sensor Fault
B121700 Rear Right Sensor Fault
B160200 CAN Line Error (B-CAN)
B160300 CAN Bus OFF (B-CAN)
D 2.2 TCI-R > Brake > Electronic Stability Program
C1101 Battery Voltage High
C1102 Battery Voltage Low
C1112 Sensor source voltage
C1274 Longitudinal G sensor open/short
C1275 Longitudinal G Sensor Range/Performance error
C1282 Yaw Rate & Lateral G Sensor-Electrical
C1285 Longitudinal G Sensor Not Calibrated
C1286 Yaw Rate & G Sensor Fail-Check SRSCM
C1503 TCS/ESC(ESP) Switch error
C1520 Clutch Signal Error
C1526 Down Hill Brake Control(DBC) Switch Error
C1604 ECU Hardware Error
C1605 CAN Hardware error
C1611 CAN Time-out ECM
C1612 CAN Time-out TCM
C1613 CAN Wrong Message
C1616 CAN Bus off
C1627 CAN Time-out 4WD
C1647 CAN Hardware Error - Sensor Channel
C1687 CAN Time-out VSM2 (MDPS)
C1688 VSM2 (MDPS) Signal Error
C1702 Variant Coding Error
C2112 Valve Relay Error
C2130 Brake Lamp Relay Error
C2131 ESS Brake Lamp Relay Error
C2227 Excessive Temperature Of Brake Disc
C2380 ABS/TCS/ESC(ESP) valve error
C2402 Motor Failure
D 2.2 TCI-R > Driveshaft > 4WD Control
P0602 Control Module Programming Error
P1779 Supply Voltage Missing
P1780 Battery Voltage High
P1781 Battery Voltage Low
P1820 Pump for 4WD Motor High Overcurrent Detected
P1821 Pump for 4WD Motor Wire Short to Battery
P1822 Pump for 4WD Motor Wire Open Load
P1823 Pump for 4WD Motor Wire Short to GND
P1824 Pump for 4WD Slow Thermal Overload
P1825 Pressure Sensor for 4WD Supply Short to Battery
P1826 Pressure Sensor for 4WD Supply Short to Ground
P1827 Pressure Sensor for 4WD Signal Wire Short to Battery
P1828 Pressure Sensor for 4WD Signal Wire Short to Ground
P1829 Clutch Torque Tolerance Upper Limit
P1830 Clutch Torque Tolerance Lower Limit
P1831 Clutch Thermal Overstress Warning
P1832 Clutch Thermal Overstress Shutdown
P1833 Actuator Thermal Overstress Warning
P1834 Actuator Thermal Overstress Shutdown
P1835 Pressure Sensor for 4WD Supply Offset Failure
P1836 Bleed Pressure Line Test Error
P1837 Vehicle Variant Can Not Be Detected
U0100 Lost Communication With ECM/PCM "A"
U0101 Lost Communication with TCM (C-CAN)
U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0122 Lost Communication With Vehicle Dynamics Control Module
U0126 Lost Communication With Steering Angle Sensor Module
U1121 Lost Communication With Electric Stability Program Module
Отправлено 05 February 2021 - 15:12
D 2.2 TCI-R > Engine > Engine Control
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0047 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit Low
P0048 Turbocharger/Supercharger Boost Control Solenoid "A" Circuit High
P0069 Manifold Absolute Pressure – Barometric Pressure Correlation
P0071 Ambient Air Temperature Sensor Range/Performance
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0091 Fuel Pressure Regulator 1 Control Circuit Low
P0092 Fuel Pressure Regulator 1 Control Circuit High
P0097 Intake Air Temperature Sensor 2 Circuit Low Input
P0098 Intake Air Temperature Sensor 2 Circuit High Input
P0101 Mass or Volume Air Flow "A" Circuit Range / Performance
P0102 Mass or Volume Air Flow "A" Circuit Low Input
P0103 Mass or Volume Air Flow "A" Circuit High Input
P0107 Barometric Pressure Circuit Low Input
P0108 Barometric Pressure Circuit High Input
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0192 Fuel Rail Pressure Sensor "A" Circuit Low
P0193 Fuel Rail Pressure Sensor "A" Circuit High
P0219 Engine Overspeed Condition
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0234 Turbocharger/Supercharger Overboost Condition
P0237 Turbocharger/Supercharger Boost Sensor "A" Circuit Low
P0238 Turbocharger/Supercharger Boost Sensor "A" Circuit High
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0299 Turbocharger/Supercharger Underboost
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1)
P0383 Glow Plug Control Module-Control Circuit Low
P0384 Glow Plug Control Module-Control Circuit High
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Control Circuit(R2.2)
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low(R2.2)
P0406 Exhaust Gas Recirculation Sensor A Circuit High(R2.2)
P0407 Exhaust Gas Recirculation Sensor B Circuit Low(LP EGR)
P0408 Exhaust Gas Recirculation Sensor B Circuit High(LP EGR)
P0471 Exhaust Pressure Sensor "A" Circuit Range/Performance
P0473 CPF/DPF Differential Pressure Sensor "A" Circuit High Input
P0475 Exhaust Pressure Control Valve(LP EGR)
P0476 Exhaust Pressure Control Valve Range/Performance(LP EGR)
P0477 Exhaust Pressure Control Valve Low(LP EGR)
P0478 Exhaust Pressure Control Valve High(LP EGR)
P0479 Exhaust Pressure Control Valve intermittent(LP EGR)
P047C Exhaust Pressure Sensor "B" Circuit Low(LP EGR)
P047D Exhaust Pressure Sensor "B" Circuit High(LP EGR)
P0487 Exhaust Gas Recirculation Throttle Position Control Circuit(LP EGR)
P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance(LP EGR)
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0501 Vehicle Speed Sensor "A" Range/Performance
P0504 Brake Switch "A" / "B" Correlation
P0532 A/C Refrigerant Pressure Sensor "A" Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor "A" Circuit High Input
P0562 System Voltage Low
P0563 System Voltage High
P0606 ECM/PCM Processor
P060B Internal Control Module NO Processing Performance
P0611 Fuel Injector Control Module Performance
P0620 Generator Control Circuit
P0625 Generator Field/ F Terminal Circuit Low
P0626 Generator Field/F Terminal Circuit High
P062D Fuel Injector Driver Circuit Performance (Bank 1)
P062E Fuel Injector Driver Circuit Performance (Bank 2)
P0643 Sensor Reference Voltage "A" Circuit High
P0653 Sensor Reference Voltage "B" Circuit High
P0670 Glow Plug Control Module Control Circuit / Open
P0684 Glow Plug Control Module to PCM Communication Circuit Range/Performance
P0699 Sensor Reference Voltage "C" Circuit High
P0820 Neutral S/W Malfunction
P0830 Clutch S/W Malfunction
P1171 CPC Mode Monitoring - Low Input
P1172 CPC Mode Monitoring - High Input
P1173 CPC Mode Monitoring - maximum PCV pressure exceeded
P1185 Maximum Pressure Exceeded
P1186 Minimum Pressure at Engine Speed Too Low
P12BF ECU Torque Monitoring - Not Plausible Signal
P1302 ECU Torque Monitoring - ADC Error
P1405 CPF-Permanent Regeneration
P1575 Wiper Motor Signal High
P1586 MT/AT Encoding Signal Malfunction
P1587 CAN Communication Error (MT/AT Recognition Error)
P1588 Signal Change Through MT/AT Line (During Engine Running)
P1591 Not Plausible DPF Auto Recognition
P1592 Changed Signal of DPF Auto Recognition
P1593 Not Plausible 2WD/4WD Auto Recognition
P1594 Changed Signal of 2WD/4WD Auto Recognition
P1670 Invalid Injector IQA/C2I
P1815 ESP Auto Recognition Fail
P2002 Diesel Particulate Filter Efficiency Below Threshold(Bank1)
P2009 Intake Manifold Runner Control Circuit Low (Bank 1)
P2010 Intake Manifold Runner Control Circuit High(Bank 1)
P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance(Bank 1)
P2016 Intake Manifold Runner Position Sensor/Switch Circuit Low(Bank 1)
P2017 Intake Manifold Runner Position Sensor/Switch Circuit High(Bank 1)
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 / Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 / Sensor 2) T5
P2101 Throttle actuator Control Motor Circuit Range/Performance
P2102 Throttle Actuator Control Motor Circuit Low
P2103 Throttle Actuator Control Motor Circuit High
P2107 Under Voltage Error For H-bridge
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
P2122 Accelerator Position Sensor 1 Signal Circuit Low Input
P2123 Accelerator Position Sensor 1 Signal Circuit High Input
P2127 Accelerator Position Sensor 2 Signal Circuit Low Input
P2128 Accelerator Position Sensor 2 Signal Circuit-High Input
P2138 Accelerator Position Sensor 1 & 2 Signal Voltage Correlation
P2141 Exhaust Gas Recirculation Throttle Position Circuit Low (LP EGR)
P2142 Exhaust Gas Recirculation Throttle Position Circuit High (LP EGR)
P2228 Barometric Pressure Circuit Low Input
P2229 Barometric Pressure Circuit High Input
P2238 O2 Sensor Pumping Current Circuit Low (Bank 1 Sensor 1)
P2239 O2 Sensor Pumping Current Circuit High (Bank 1 Sensor 1)
P2251 O2 Sensor Reference Ground Circuit/Open (Bank 1 Sensor 1)
P2263 Output Range Error Of VGT Actuator(R2.2)
P2264 Water in Fuel Sensor Circuit
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
P242F Diesel Particulate Filter Restriction - Ash Accumulation
P244A Diesel Particulate Filter Differential Pressure Too Low
P245A Exhaust Gas Recirculation Cooler Bypass Control Circuit Low
P245D Exhaust Gas Recirculation Cooler Bypass Control Circuit High
P2454 CPF differential Pressure Sensor "A" Low Input
P2455 CPF Differential Pressure Sensor "A" High Input
P2501 Generator Lamp/L-Terminal Circuit High
P2502 Charging System Voltage
P2503 Charging System Voltage Low
P2504 Charging System Voltage High
P250B Engine Oil Level Sensor Circuit Range/Performance
P250C Engine Oil Level Sensor Circuit Low
P250D Engine Oil Level Sensor Circuit High
P250F Engine Oil Level Too Low
P252F Engine Oil Level Too High
P2563 Turbocharger Boost Control Position Sensor "A" Circuit Range/Performance
U0101 Lost Communication With TCM
U1111 Battery Sensor fault detected by ECU
U1112 LIN Communication Error
D 2.2 TCI-R > Head Lamp > Adaptive Front Lighting System
B1220 Vehicle Speed Sensor
B1301 Steering angle signal fault
B1302 Gearbox Signal Fault-CAN Signal
B1303 Accelerator Pedal Position Signal Error
B1304 Engine state signal fault
B1305 Yaw Rate Sensor Signal Fault
B1306 Brake pedal signal fault
B1308 Lamp Function Signal Fault
B1603 CAN Communication Bus Off
B1621 ECU Hardware Error
B1622 ECU Software Error
B1636 LIN Communication Error Fault
B1637 System Not Initialized
B1639 LIN communication error DBL left
B1661 Parameter Fault And Missing
B1953 AXLE Sensor Fault
B2200 LIN communication error DBL(Dynamic Bending Light) Right
B2201 LIN communication error HLL(Head Lamp Leveling) Left
B2202 LIN communication error HLL(Head Lamp Leveling) Right
B2325 Swivel module fault left
B2326 Swivel module fault right
B2400 Levelling motor fault left
B2401 Levelling motor fault right
D 2.2 TCI-R > Head Lamp > Auto Headlamp Leveling System
C1212 Vehicle Speed Sensor Failure
C1255 Rear Height Sensor
C1258 Magnet Setting Error
C1381 Sensor Internal Error
C1522 Head lamp Switch Fault
C1604 ECU Fault
C1606 ECU Software Error
C1620 First Setup Not Completed
C2226 Output Voltage Short to Battery or Short to Ground
D 2.2 TCI-R > Immobilizer > Immobilizer
P1675 Immobilizer-Transponder Programming Error
P169A Immobilizer-SMARTRA Authentication Fail
P1692 Immobilizer Indicator Lamp Error
D 2.2 TCI-R > LDWS > Blind Spot Detection
C1101XX Battery Voltage High
C1102XX Battery Voltage Low
C120AXX LED Right Circuit Short to Ground
C120BXX LED Right Circuit Short to Battery or Open
C120CXX LED Left Circuit Short to Ground
C120DXX LED Left Circuit Short to Battery or Open
C1501XX Switch Failure
C1611XX CAN Time-out EMS
C1613XX CAN signal error EMS
C1616XX CAN Bus OFF(C-CAN)
C1625XX CAN Time-out ABS/ESC(ESP)
C1628XX CAN Time-out Cluster
C1671XX Signal Yaw Rate or Acceleration AX or Acceleration AY or Brakepressure State not valid
C160AXX BSD Local CAN bus off
C170AXX Activation Switch LED Circuit short to ground
C170CXX ECU Hardware error (REAR LEFT)
C170DXX ECU Hardware error (REAR RIGHT)
C2702XX Control Module Master Missing Calibration
C2703XX Control Module Slave Missing Calibration
D 2.2 TCI-R > LDWS > Lane Departure Warning System
C1361 Camera H/W Failure
C1363 Camera Signal Error for Calibration
C1364 Not found Reference Point
C1365 Invalid Reference Point
C1604 ECU HW error
C1616 CAN Bus OFF
C1653 CAN Time-out Cluster for SCC
C1654 CAN Time-out Cluster for EPB
C2710 In Line Test Failure-Not found Lane
C2711 In Line Test Failure-Not found Lane Change
C2721 Camera Not Calibrated
D 2.2 TCI-R > SPAS > Smart Parking Assist System
C1104 Ignition Voltage High
C1105 Ignition Voltage Low
C1112 Sensor Source Voltage
C1368 PAS Sensor - Rear Left Outer
C1369 PAS Sensor - Rear Left Inner
C1370 PAS Sensor - Rear Right Inner
C1371 PAS Sensor - Rear Right Outer
C1372 PAS Sensor - Front Right Outer
C1373 PAS Sensor - Front Right Inner
C1374 PAS Sensor - Front Left Inner
C1375 PAS Sensor - Front Left Outer
C1376 SPAS Sensor - Front Left
C1377 SPAS Sensor - Front Right
C1528 PAS Switch Indicator Failure
C1529 SPAS Switch Indicator Failure
C1530 PAS Switch Failure
C1531 SPAS Switch Failure
C1612 CAN Time-out TCU
C1616 CAN Bus Off
C1625 CAN Time-out ABS/ESP
C1628 CAN Timeout - Cluster
C1642 CAN Message Failure - ABS/ESC(ESP)
C1646 CAN Message Failure - TCU
C1656 CAN signal error Cluster
C1687 CAN Time-out MDPS
C1688 MDPS signal error
C1694 CAN Time out - FATC
C1695 CAN Message Failure - FATC
