Киа Маджентис 2 MG
(MG) Передняя (приборная) панель
Сообщений в теме: 21
#21 krionika
  • 24998 сообщений
Отправлено 29 October 2015 - 16:03
4. Installation is the reverse of removal. SHROUD REPLACEMENT 1. Loosen the screws, then remove the shroud assembly (A). Прикрепленный файл  Untitled-1 copy.jpg   45.38К   0 Количество загрузок:
#22 krionika Re: (MG) Передняя (приборная) панель
  • 24998 сообщений
Отправлено 29 October 2015 - 16:05
2. Installation is the reverse of removal. CRASH PAD REPLACEMENT – When prying with a flat-tipped screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damaged. – Put on gloves to protect your hands. 1. Remove the following items. – Front seat. – Cluster facia panel, cluster. – Audio assembly. – Glove box. – Side cover, center under cover. – Front pillar trim. 2. Remove the photo sensor (A). 3. Disconnect the passenger`s air bag connector. Loosen the bolts and nuts, then remove the crash pad (B). 4. Installation is the reverse of removal. – Make sure the crash pad fits onto the guide pins correctly. – Before tightening the bolts, make sure the crash pad wire harnesses are not pinched. – Make sure the connectors are plugged in properly, and the antenna lead is connected properly, – Enter the anti-theft code for the radio, then enter the customer`s radio station presets. [LHD] Прикрепленный файл  Untitled-1 copy.jpg   58.36К   0 Количество загрузок:
