Kia Picanto SA (2004-2011) - снятие и установка радиатора кондиционера
REPLACEMENT
Recover the refrigerant with a recovery/recycling/charging station.
Remove the radiator fan and the radiator (Refer to the EM group).
Remove the nuts (A), then disconnect the discharge line and condenser line from the condenser.
Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination.
1 copy.jpg 32.72К
8 Количество загрузок:
4.
Remove the bolts, and then remove the condenser (A) by lifting it up. Be careful not to damage the radiator and condenser fins when removing the condenser.
2 copy.jpg 29.9К
7 Количество загрузок:
5.
Install in the reverse order of removal, and note these items :
A.
If you're installing a new condenser, add refrigerant oil FD46XG.
B.
Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage.
C.
Be careful not to damage the radiator and condenser fins when installing the condenser.
D.
Be sure to install the lower mount cushions of condenser securely into the holes.
E.
Charge the system, and test its performance.
