Kia Cadenza VG (2010+) - замена шруса
Replacement
Loosen the wheel nuts slightly.
Raise the vehicle, and make sure it is securely supported.
Remove the front wheel and tire(A) from front hub.
Tightening torque:
88.2 ~ 107.8N.m (9.0 ~ 11.0kgf.m, 65.0 ~ 79.5lb-ft)
Be careful not to damage to the hub bolts when removing the front wheel and tire (A).
Remove the brake caliper mounting bolts , and then place the brake caliper assembly (B) with wire.
Tightening torque:
78.4 ~ 98.0N.m (8.0 ~ 10.0kgf.m, 57.8 ~ 72.3lb-ft)
4.
Remove the tie rod end ball joint(A) from the knuckle.
(1)
Remove the split pin(B).
(2)
Remove the castle nut©.
Tightening torque:
34.3 ~ 44.1N.m (3.5 ~ 4.5kgf.m, 25.3 ~ 32.5lb-ft)
5.
Loosen the mount bolt and then remove the wheel speed sensor(B) from knuckle(A).
Tightening torque:
6.8 ~ 10.7N.m (0.7 ~ 1.1kgf.m, 5.0 ~ 7.9lb-ft)
6.
Remove driveshaft coking nut(A) from the front hub under applying the break.
Tightening torque:
196.1 ~ 254.9N.m (20.0 ~ 26.0kgf.m, 144.6 ~ 188.0lb-ft)
