G 3.5 GDI LAMBDA III > Integrated Body Control Unit-TPMS > Integrated Body Control Unit-TPMS
C112100 Front Left Sensor Battery Voltage Low
C112200 Front Right Sensor Battery Voltage Low
C112300 Rear Left Sensor Battery Voltage Low
C112400 Rear Right Sensor Battery Voltage Low
C112600 TPMS ECU Battery Voltage Low
C112700 TPMS ECU Battery Voltage High
C121200 Vehicle Speed Sensor
C131200 Front Left Sensor RF Channel Failure
C131300 Front Right Sensor RF Channel Failure
C131400 Rear Left Sensor RF Channel Failure
C131500 Rear Right Sensor RF Channel Failure
C132200 Front Left Sensor Over Temperature
C132300 Front Right Sensor Over Temperature
C132400 Rear Left Sensor Over Temperature
C132500 Rear Right Sensor Over Temperature
C133200 Front Left Sensor Fault
C133300 Front Right Sensor Fault
C133400 Rear Left Sensor Fault
C133500 Rear Right Sensor Fault
C160E00 CAN Bus Off P-CAN
C161100 CAN Time-out EMS
C161600 CAN Bus OFF(C-CAN)
C162500 CAN Time-out ABS/ESC
C164200 CAN Message Failure - Brake
C166000 Receiver RF Circuit Fail
C166200 Auto Learning failure
C166300 Auto Location Failure
G 3.5 GDI LAMBDA III > Integrated Central Control Unit > Integrated Central Control Unit
B110100 Battery Voltage High
B110200 Battery Voltage Low
B160300 CAN Bus OFF
B160500 CAN Time-Out DDM
B160700 CAN Time-Out P/SEAT
B162100 ECU hardware
B163600 LIN Error
B164400 CAN Time-Out ACU
B164C00 CAN time-out IBU
B164D00 CAN Time-Out WPC
B168E00 CAN Time-Out PTGM
B169800 CAN Time-Out SWRC
B169900 CAN Time-Out AV/AVN(HU)
B235200 Dedicated DRL LH SCG
B235300 Dedicated DRL RH SCG
B247300 Haptic Warning System Open CirCuit
B247400 Haptic Warning System Short to Ground
B251000 Head Lamp High RH SCG
B251100 Head Lamp High LH SCG
B251200 Head Lamp Low RH SCG
B251300 Head Lamp Low LH SCG
B251400 External Tail Lamp RH Circuit Short to Ground
B251500 External Tail Lamp LH Circuit Short to Ground
B251700 Internal Lamp Circuit Short to Ground
B251D00 Stop Lamp Right Short to Ground
B251E00 Stop Lamp Left Short to Ground
B251F00 High Mounted Stop Lamp Short to Ground
B252200 Turn Signal LH Front Short to Ground
B252300 Turn Signal LH Rear Short to Ground
B252400 Turn Signal RH Front Short to Ground
B252500 Turn Signal RH Rear Short to Ground
B258A00 External Lamp Front Right Circuit Short to Ground
B258B00 External Tail Lamp Front Left Circuit Short to Ground
B258C00 External Tail Lamp Rear Right Circuit Short to Ground
B258D00 External Tail Lamp Rear Left Circuit Short to Ground
B259E00 Rear Fog Lamp RH SCG
B259F00 Rear Fog Lamp LH SCG
B261000 Backup Lamp Short to Ground
B261900 CAN Time-Out SHVU FR
B262000 CAN Time-Out SHVU RR
B262100 CAN Time-Out MLM
B267200 CAN Time-Out DPSS
B267300 CAN Time-Out DLBCU
B267800 CAN Time-Out ROA
B268100 Parasitic Current Forced Power Off State(PROTO stage only)
B280000 MM CAN Bus Off Error
B280100 MM CAN Signal Line Error
B280300 Timeout Multimedia CAN Message (AMP)
B280400 Timeout Multimedia CAN Message(DATC)
B280900 Timeout Multimedia CAN Message (RRC)
B280C00 Timeout Multimedia CAN Message (MKBD)
B281700 I-CAN Bus Off Error
C160E00 P-CAN Bus OFF
C161200 CAN Time-out TCU
C161600 C-CAN Bus OFF
C161E00 E-CAN Bus OFF (E-CAN Bus Off Error)
C162500 CAN Time-Out ABS/ESP
C162800 CAN Time-out Cluster
C165100 CAN Time-Out EPB
C165900 CAN Time-Out SAS
C166D00 CAN Time-out HUD
C168700 CAN Time-Out VSM2 (MDPS)
C169800 CAN Time-Out ECS
C182D00 CAN Time-Out SCU
C184B00 CAN Time-Out SBW
C184D00 CAN Time-Out RLHV
C184F00 CAN Time-Out RRHV
C186600 CAN Time-Out ICSC
C200E00 CAN Time-Out ADAS PRK
C28AA00 CAN Time-Out FR_CMR
C28AB00 CAN Time-Out FR_RDR
C28B300 CAN Time-Out RR_C_RDR
C28B500 CAN Time-Out ADAS_DRV
#11
Отправлено 11 March 2023 - 08:12
Re: коды ошибок, расшифровка
Отправлено 11 March 2023 - 08:13
G 3.5 GDI LAMBDA III > Mood Lamp Module > Mood Lamp Module
B262200 Passenger Mood Lamp Malfunction Error
B262300 Passenger Mood Lamp LIN Communication Error
B262A00 Driver Door Garnish Inner Mood Lamp Malfunction Error
B262B00 Driver Door Garnish Inner Mood Lamp LIN Communication Error
B262C00 Driver Door Power Handle Mood Lamp Malfunction Error
B262D00 Driver Door Power Handle Mood Lamp LIN Communication Error
B262E00 Passenger Door Garnish Inner Mood Lamp Malfunction Error
B262F00 Passenger Door Garnish Inner Mood Lamp LIN Communication Error
B263000 Passenger Door Power Handle Mood Lamp Malfunction Error
B263100 Passenger Door Power Handle Mood Lamp LIN Communication Error
B263200 Rear Door Garnish Inner Mood Lamp LH Malfunction Error
B263300 Rear Door Garnish Inner Mood Lamp LH LIN Communication Error
B263600 Rear Door Garnish Inner Mood Lamp RH Malfunction Error
B263700 Rear Door Garnish Inner Mood Lamp RH LIN Communication Error
B263A00 Front Console Mood Lamp Malfunction Error
B263B00 Front Console Mood Lamp LIN Communication Error
B269300 Driver Door Garnish Mood Lamp Malfunction Error
B269400 Driver Door Garnish Mood Lamp LIN Communication Error
B269500 Passenger Door Garnish Mood Lamp Malfunction Error
B269600 Passenger Door Garnish Mood Lamp LIN Communication Error
G 3.5 GDI LAMBDA III > Power Seat Module > Power Seat Module
B160200 CAN Line Error (B-CAN)
B160300 CAN Bus OFF (B-CAN)
B163700 System Not Initialized
G 3.5 GDI LAMBDA III > Power Trunk Module > Power Trunk Module
B24D000 Power Trunk Module Inline Mode Not Deactivated
B24D100 PTL Unlatch Error
B24D200 PTL Hall Sensor Error
G 3.5 GDI LAMBDA III > Rear Corner Radar > Rear Corner Radar
C110117 Battery Voltage High
C110216 Battery Voltage Low
C120A11 Right Warning Indicator Circuit short to ground
C120B15 Right Warning Indicator Circuit short to battery or open
C120C11 Left Warning Indicator Circuit short to ground
C120D15 Left Warning Indicator Circuit Short to battery or open
C160A88 Local CAN Bus OFF
C161187 CAN Time-out EMS
C161287 CAN Time-out TCU
C161381 CAN Signal Error EMS
C161688 C-CAN Bus OFF
C161E88 E-CAN Bus OFF (E-CAN Bus Off Error)
C162387 CAN Time-out Steering Angle Sensor
C162587 CAN Time-Out ABS/ESP
C162887 CAN Time-out Cluster
C163381 Cluster invalid displayed speed
C164281 CAN Message Failure - Brake
C164681 CAN Message Failure - TCU
C164A87 Local CAN Time-Out (Front Left)
C164B87 Local CAN Time-Out (Front Right)
C164C87 Local CAN Time-Out (Rear Left)
C164D87 Local CAN Time-Out (Rear Right)
C165787 CAN time-Out TCS
C166987 CAN Time-Out ACU
C167181 Signal Yaw Rate or Acceleration AX or Acceleration AY or Brake Pressure State not valid
C167281 SAS Message Counter Error
C167581 Signal WHEEL FL or WHEEL FR or WHEEL RL or WHEEL RR not Valid
C168787 CAN Time-out VSM2 (MDPS)
C168881 VSM2 (MDPS) Signal Error
C169381 ESC Signal Error
C16B687 CAN Time-Out AEB
C170255 Variant Coding Error
C170C04 ECU Hardware error (REAR RIGHT)
C170D04 ECU Hardware error (REAR LEFT)
C170E04 ECU Hardware Error (Front Right)
C170F04 ECU Hardware Error (Front Left)
C17354B Over Temperature Detected
C174305 Software Mis-Match
C181287 CAN Time-Out Gateway
C181687 CAN Time-Out SJB
C183E81 Invalid Signal of ICU
C183E83 Invalid Signal of ICU
C184881 Invalid Signal of IBU
C225387 CAN Time-Out IBU
C270654 Control Module Missing Calibration (Front Left)
C270754 Control Module Missing Calibration (Front Right)
C270854 Control Module Missing Calibration (Rear Left)
C270954 Control Module Missing Calibration (Rear Right)
C28AA87 CAN Time-Out FR_CMR
Отправлено 11 March 2023 - 08:14
G 3.5 GDI LAMBDA III > Rear Left Heater Ventilation Unit > Rear Left Heater Ventilation Unit
B160300 CAN BUS OFF
G 3.5 GDI LAMBDA III > Rear Occupant Alert > Rear Occupant Alert
B267700 ECU Internal Error
B267900 ROA CAN Bus OFF
B268000 Sensor Blockage
G 3.5 GDI LAMBDA III > Rear Remote Controller > Rear Remote Controller
G 3.5 GDI LAMBDA III > Rear Right Heater Ventilation Unit > Rear Right Heater Ventilation Unit
B160300 CAN BUS OFF
G 3.5 GDI LAMBDA III > Rear View Monitor > Rear View Monitor
B161F00 Camera Input Error
B16A700 Camera Video Output Error
G 3.5 GDI LAMBDA III > SBW Control Unit (SCU) > SBW Control Unit (SCU)
P060141 Internal Control Module Memory Check Sum Error
P060147 Functional Safety Level 3 S/W Fail
P060148 Functional Safety Level 2 S/W Fail
P065713 SBW Actuator Power Circuit short to Ground or Open
P06B011 SBW Actuator Encoder Power – Circuit Short to Ground
P06B012 SBW Actuator Encoder Power – Circuit Short to Battery
P06B013 SBW Actuator Encoder Power – Circuit Open
P070512 Transmission Range Sensor Circuit Malfunction - Circuit Short to Battery
P070514 Transmission Range Sensor Circuit Malfunction - Circuit Short to Ground or Open
P070516 Transmission Range Sensor Circuit Malfunction - Sensor Power Circuit Short to Ground or Open
P070517 Transmission Range Sensor Circuit Malfunction - Sensor Power Circuit Short to Battery
P070661 Transmission Range Sensor Circuit Range/Performance - Signal Calculation Failure
P070696 Transmission Range Sensor Circuit Range/Performance - Component Internal Failure
P106114 SBW Actuator Power Circuit Short to Ground or Open
P106212 SBW Actuator Error - U/V/W Circuit Short to Battery
P106400 SBW Over Current Detection
P106800 SBW Actuator Assy Error
P106900 SBW Actuator Running Error
P106B00 SBW Actuator Driver Error
P106C12 P Output Signal Error - Circuit Short to Battery
P106C14 P Output Signal Error - Circuit Short to Ground or Open
P106D00 SBW Actuator Stuck - Initial Drive Error
P106D14 SBW Actuator Stuck - U/V/W Circuit Short to Ground or Open
P106D71 SBW Actuator Stuck
P171400 IMMO Window Timeout
P171500 IMMO Data Timing Error
P171600 IMMO Wrong VIN/MIN/RPM
P28E211 Shift Motor Phase U-V-W Circuit/Open
P28E212 Shift Motor Phase U-V-W Circuit/Open
P28E213 Shift Motor Phase U-V-W Circuit/Open
P28E21D Shift Motor Phase U-V-W Circuit/Open
P28E302 Shift Motor Phase U-V-W Performance
P28E419 Shift Motor Driver Current/Temperature Too High
P28E507 Shift Motor Performance
P28E577 SBW Actuator Commanded Position Not Reachable
P28E592 Shift Motor Performance
P28E594 Shift Motor Performance
P28E711 SBW Actuator Encoder Error – Circuit Short to Ground
P28E715 SBW Actuator Encoder Error – Circuit Short to Battery
P28E764 SBW Actuator Encoder Error – Signal Plausibility Failure
P28EA71 Shift Motor Position Sensor Circuit Range/Performance
U000100 High Speed CAN Communication Bus
U010000 Lost Communication With ECM/PCM "A"
U010082 Lost Communication With ECM/PCM "A"
U010083 Lost Communication With ECM/PCM "A"
U010100 Lost Communication With TCM
U010182 Lost Communication With TCM
U010183 Lost Communication With TCM
U012100 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U012182 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U012183 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U014600 Lost Communication with GateWay "A"
U015500 Lost Communication with Instrument Panel Cluster (IPC) Control Module
U110100 Lost Communication with TCM "B"
U110182 TCU CAN2 Alive Counter Error
U110183 TCU CAN2 CRC Error
U110300 Lost Communication With TGS Lever
U110382 TGS Lever Alive Counter Error
U110383 Lost Communication with TGS Lever
U110400 Lost Communication with TGS Lever "B"
U111700 High Speed CAN2 Communication (EMS-DCT)
U116000 Lost Communication with ACU
U133882 Lost Communication With RSPA
U133883 Lost Communication With RSPA
U133887 Lost Communication With RSPA
U133900 Lost Communication With Electronic Parking Brake Control Module
G 3.5 GDI LAMBDA III > Seat heater Ventilation control Unit-Front > Seat heater Ventilation control Unit-Front
B160300 CAN BUS OFF
G 3.5 GDI LAMBDA III > Seat heater Ventilation control Unit-Rear > Seat heater Ventilation control Unit-Rear
B160300 CAN BUS OFF
G 3.5 GDI LAMBDA III > Smart Key > Smart Key Code Saving
P167600 Smartra Message Error
P169000 Smartra No Response
P169500 Immobilizer-EMS Memory Error
P169600 Immobilizer-Authentication Fail
P169900 Immobilizer-Twice Overtrial
G 3.5 GDI LAMBDA III > Steering > Motor Driven Power Steering
C110921 IG1 Open - MDPS Fail Safe
C111201 Sensor Source Voltage
C120286 Wheel Speed Sensor Front-LH Invalid/No Signal
C120586 Wheel Speed Sensor Front-RH Invalid/no Signal
C120886 Wheel Speed Sensor Rear-LH Invalid/no Signal
C121186 Wheel Speed Sensor Rear-RH Invalid/no Signal
C125901 Steering Angle Sensor-Electrical
C125929 Steering Angle Sensor-Electrical
C125938 Steering Angle Sensor - Electrical
C126154 Steering Angle Sensor is not Calibrated
C126204 Temperature Sensor Failure
C129002 Torque Sensor Signal Fail
C16034B ECU thermal protection
C160404 ECU Hardware Error
C160604 ECU Software Error
C161386 CAN Signal Error EMS
C161F86 Invalid Vehicle Speed
C162986 Cluster Invalid Counter
C166B87 CAN time-out Wheel Speed Sensor
C169287 CAN Time-out ESC
C169386 ESC Signal Error
C169687 CAN Time-Out SPAS/PA
C169786 CAN Message Failure - SPAS
C16B286 WHL_SPD Checksum/Alive Counter Error
C16BF64 WHL_SPD Monitoring logic Error
C170004 Byte Coding Error
C170401 ECU Fail-Safe Relay Fail
C170504 ECU Pre-Charge Circuit Fail
C171101 Improper program termination
C180487 CAN time out LKAS
C180586 LKAS CAN Signal Error
C186687 CAN Time-Out ICSC
C240162 Motor Circuit
C241216 Motor Short or Open
C241262 Motor Short or Open
C241319 Motor Current Fail (Current Over)
C241328 Motor Current Fail (Current Over)
C241396 Motor Current Fail (Current Over)
Отправлено 11 March 2023 - 08:15
G 3.5 GDI LAMBDA III > Steering Wheel Remote Control > Steering Wheel Remote Control
G 3.5 GDI LAMBDA III > Suspension > Electronic Control Suspension
C127429 G Sensor Error
C160444 ECU Hardware Error
C160445 ECU Hardware Error
C160446 ECU Hardware Error
C160447 ECU Hardware Error
C160451 ECU Hardware Error
C160454 ECU Hardware Error
C164286 CAN Message Failure - Brake
C167186 Signal Yaw Rate or Acceleration AX or Acceleration AY or Brakepressure State not Valid
C181486 CAN Message Failure - SAS
C186087 CAN Time-Out IVSS
C186186 CAN Signal Error IVSS
C221213 Front-LH Actuator
C221219 Front-LH Actuator
C221613 Front-RH (or Front) Actuator
C221619 Front-RH (or Front) Actuator
C222013 Rear-LH Actuator
C222019 Rear-LH Actuator
C222413 Rear-RH (or rear) Actuator
C222419 Rear-RH (or rear) Actuator
G 3.5 GDI LAMBDA III > Wireless Power Charger > Wireless Power Charger
B160300 CAN BUS OFF
G 3.5 GDI LAMBDA III > Engine > Engine Control
P000A00 "A" Camshaft Position Slow Response Bank 1
P000B00 "B" Camshaft Position Slow Response Bank 1
P000C00 "A" Camshaft Position Slow Response Bank 2
P000D00 "B" Camshaft Position Slow Response Bank 2
P001100 "A(Intake)" Camshaft Position-Timing Over-Advanced or System Performance (Bank1)
P001400 "B(Exhaust)" Camshaft Position - Timing Over-Advanced or System Performance (Bank1)
P001600 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A(Intake))
P001700 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B(Exhaust))
P001800 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P001900 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
P002100 "A" Camshaft Position-Timing Over-Advanced or System Performance
P002400 "B" Camshaft Position-Timing Over-Advanced or System Performance
P003000 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P003100 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P003200 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P003600 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P003700 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P003800 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P005000 HO2S Heater Control Circuit (Bank 2 / Sensor 1)
P005100 HO2S Heater Circuit low (Bank 2 Sensor 1)
P005200 HO2S Heater Circuit high (Bank 2 Sensor 1)
P005600 HO2S Heater Control Circuit (Bank 2 / Sensor 2)
P005700 HO2S Heater Circuit low (Bank 2 Sensor 2)
P005800 HO2S Heater Circuit high (Bank 2 Sensor 2)
P006800 MAP(MAF)-Throttle Position Sensor Correlation
P007000 Ambient Air Temperature Sensor Circuit
P007100 Ambient Air Temperature Circuit Range / Performance
P007500 Intake Valve Control Solenoid Circuit (Bank 1)
P007600 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P007700 Intake Valve Control Solenoid Circuit-High (Bank 1)
P007800 Exhaust Valve Control Solenoid Circuit (Bank1)
P007900 Exhaust Valve Control Solenoid Circuit Low (Bank1)
P008000 Exhaust Valve Control Solenoid Circuit High (Bank1)
P008100 Intake Valve Control Solenoid Circuit (Bank 2)
P008200 Intake Valve Control Solenoid Circuit Low (Bank 2)
P008300 Intake Valve Control Solenoid Circuit High (Bank 2)
P008400 Exhaust Valve Control Solenoid Circuit (Bank 2)
P008500 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P008600 Exhaust Valve Control Solenoid Circuit High (Bank 2)
P008700 Fuel Rail/System Pressure - Too Low
P008800 Fuel Rail/System Pressure - Too High
P009000 Fuel Pressure Regulator 1 Control Circuit/Open
P009100 Fuel Pressure Regulator 1 Control Circuit Low
P009200 Fuel Pressure Regulator 1 Control Circuit High
P00B700 Engine Coolant Flow Low/Performance
P00BC00 Mass or Volume Air Flow "A" Circuit Range/Performance - Air Flow Too Low
P00BD00 Mass or Volume Air Flow "A" Circuit Range/Performance - Air Flow Too High
P00CE00 Intake Air Temperature Measurement System - Multiple Sensor Correlation Bank 1
P00D100 HO2S Heater Control Circuit Range/Performance Bank 1 Sensor 1
P00D200 HO2S Heater Control Circuit Range/Performance Bank 1 Sensor 2
P00D300 HO2S Heater Control Circuit Range/Performance Bank 2 Sensor 1
P00D400 HO2S Heater Control Circuit Range/Performance Bank 2 Sensor 2
P010100 Mass or Volume Air Flow Circuit Range / Performance
P010600 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P010700 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P010800 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P011100 Intake Air Temperature Sensor 1 Circuit
P011200 Intake Air Temperature Sensor 1 Circuit Low Input
P011300 Intake Air Temperature Sensor 1 Circuit High Input
P011600 Engine Coolant Temperature Circuit Range / Performance
P011700 Engine Coolant Temperature Circuit Low Input
P011800 Engine Coolant Temperature Circuit High Input
P011900 Engine Coolant Temperature Circuit Intermittent
P012100 Throttle Position Sensor 1 Signal Circuit Range/Performance
P012200 Throttle Position Sensor 1 Signal Circuit Low Input
P012300 Throttle Position Sensor 1 Signal Circuit High Input
P012800 Coolant Thermostat (Coolant Temperature below Thermostat Regulating Temperature)
P012F00 Engine Coolant Temperature / Engine Oil Temperature Correlation
P013100 O2 Sensor Circuit Low Voltage(Bank 1 / Sensor 1)
P013200 O2 Sensor Circuit High Voltage(Bank 1 / Sensor 1)
P013300 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P013600 O2 Sensor Circuit(Bank 1 / Sensor 2)
P013700 O2 Sensor Circuit Low Voltage (Bank 1 / Sensor 2)
P013800 O2 Sensor Circuit High Voltage (Bank 1 / Sensor 2)
P013A00 O2 Sensor Slow Response - Rich to Lean Bank 1 Sensor 2
P013B00 O2 Sensor Slow Response - Lean to Rich Bank 1 Sensor 2
P013C00 O2 Sensor Slow Response - Rich to Lean Bank 2 Sensor 2
P013D00 O2 Sensor Slow Response - Lean to Rich Bank 2 Sensor 2
P013E00 O2 Sensor Deleyed Response - Rich to Lean Bank 1 Sensor 2
P013F00 O2 Sensor Deleyed Response - Lean to Rich Bank 1 Sensor 2
P014000 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P014A00 O2 Sensor Delayed Response - Rich to Lean Bank 2 Sensor 2
P014B00 O2 Sensor Delayed Response - Lean to Rich Bank 2 Sensor 2
P015100 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 1)
P015200 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 1)
P015300 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 1)
P015600 O2 Sensor Circuit (Bank 2 / Sensor 2)
P015700 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 2)
P015800 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 2)
P016000 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 2)
P016E00 Closed Loop Fuel Pressure Control At Limit - Pressure Too High
P016F00 Closed Loop Fuel Pressure Control At Limit - Pressure Too Low
P017100 System too Lean (Bank 1)
P017200 System too Rich (Bank 1)
P017400 System too Lean (Bank 2)
P017500 System too Rich (Bank 2)
P019100 Fuel Rail Pressure Sensor Circuit Range/Performance
P019200 Fuel Rail Pressure Sensor Circuit Low Input
P019300 Fuel Rail Pressure Sensor Circuit High Input
P019600 Engine Oil Temperature Sensor-Range / Performance
P019700 Engine Oil Temperature Sensor Low Input
P019800 Engine Oil Temperature Sensor High Input
P020000 Injector Circuit/Open
P020100 Injector Circuit/Open - Cylinder 1
P020200 Injector Circuit/Open - Cylinder 2
P020300 Injector Circuit/Open - Cylinder 3
P020400 Injector Circuit/Open - Cylinder 4
P020500 Injector Circuit/Open - Cylinder 5
P020600 Injector Circuit/Open - Cylinder 6
P022100 Throttle Position Sensor 2 Signal Circuit Range/Performance
P022200 Throttle Position Sensor 2 Signal Circuit Low Input
P022300 Throttle Position Sensor 2 Signal Circuit High Input
P023000 Fuel Pump Primary Circuit
P026100 Cylinder 1 Injector Circuit Low
P026200 Cylinder 1 Injector Circuit High
P026400 Cylinder 2 Injector Circuit Low
P026500 Cylinder 2 Injector Circuit High
P026700 Cylinder 3 Injector Circuit Low
P026800 Cylinder 3 Injector Circuit High
P026B00 Injection Timing Performance
P027000 Cylinder 4 Injector Circuit Low
P027100 Cylinder 4 Injector Circuit High
P027300 Cylinder 5 Injector Circuit Low
P027400 Cylinder 5 Injector Circuit High
P027600 Cylinder 6 Injector Circuit Low
P027700 Cylinder 6 Injector Circuit High
P02CC00 Cylinder 1 Fuel Injector Offset Learning At Min Limit
P02CD00 Cylinder 1 Fuel Injector Offset Learning At Max Limit
P02CE00 Cylinder 2 Fuel Injector Offset Learning At Min Limit
P02CF00 Cylinder 2 Fuel Injector Offset Learning At Max Limit
P02D000 Cylinder 3 Fuel Injector Offset Learning At Min Limit
P02D100 Cylinder 3 Fuel Injector Offset Learning At Max Limit
P02D200 Cylinder 4 Fuel Injector Offset Learning at Min Limit
P02D300 Cylinder 4 Fuel Injector Offset Learning at Max Limit
P02D400 Cylinder 5 Fuel Injector Offset Learning at Min Limit
P02D500 Cylinder 5 Fuel Injector Offset Learning at Max Limit
P02D600 Cylinder 6 Fuel Injector Offset Learning at Min Limit
P02D700 Cylinder 6 Fuel Injector Offset Learning at Max Limit
P030000 Random/Multiple Cylinder Misfire Detected
P030100 Cylinder 1-Misfire detected
P030200 Cylinder 2-Misfire detected
P030300 Cylinder 3-Misfire detected
P030400 Cylinder 4-Misfire detected
P030500 Cylinder 5-Misfire detected
P030600 Cylinder 6-Misfire detected
P032600 Knock Sensor 1 Circuit Range/Performance (Bank 1)
P033100 Knock Sensor 2 Circuit Range/Performance
P033500 Crankshaft Position Sensor "A" Circuit
P033600 Crankshaft Position Sensor "A" Circuit Range/Performance
P034100 Camshaft Position Sensor "A"(Intake) Circuit Range/Performance (Bank1)
P034200 Camshaft Position Sensor "A"(Intake) Circuit Low Input
P034300 Camshaft Position Sensor "A"(Intake) Circuit High Input
P034600 Camshaft Position Sensor "A"(Intake) Circuit Range/Performance (Bank 2)
P034700 Camshaft Position Sensor "A"(Intake) Circuit Low Input
P034800 Camshaft Position Sensor "A"(Intake) Circuit High Input
P036500 Camshaft Position Sensor "B(Exhaust)" Circuit Malfunction (Bank 1)
P036600 Camshaft Position Sensor 'B'(Exhaust) Circuit Range/Performance (Bank1)
P036700 Camshaft Position Sensor "B"(Exhaust) Circuit Low
P036800 Camshaft Position Sensor "B"(Exhaust) Circuit High
P039000 Camshaft Position Sensor "B" Circuit
P039100 Camshaft Position Sensor "B" Circuit Range/Performance
P039200 Camshaft Position Sensor "B"(Exhaust) Circuit Low
P039300 Camshaft Position Sensor "B"(Exhaust) Circuit High
P040200 Exhaust Gas Recirculation Flow Excessive Detected
P040500 Exhaust Gas Recirculation Sensor A Circuit Low
P040700 Exhaust Gas Recirculation Sensor B Circuit Low
P040800 Exhaust Gas Recirculation Sensor B Circuit High
P042000 Catalyst System Efficiency Below Threshold (Bank1)
P043000 Catalyst System Efficiency Below Threshold (Bank 2)
P044200 Evaporative Emission System-Leak detected (small leak)
P044400 Evaporative Emission System-Purge Control Valve Circuit Open
P044500 Evaporative Emission System-Purge Control Valve Circuit Shorted
P045A00 Exhaust Gas Recirculation "B" Control Circuit
P045B00 Exhaust Gas Recirculation "B" Control Circuit Range/Performance
P046100 Fuel Level Sensor "A" Circuit Range/Performance
P046200 Fuel Level Sensor "A" Circuit Low Input
P046300 Fuel Level Sensor "A" Circuit High Input
P046E00 Exhaust Gas Recirculation Sensor "B" Circuit Range/Performance
P049B00 EGR "B" Flow Insufficient Detected
P049D00 EGR "A" Control Position Exceeded Learning Limit
P049E00 Exhaust Gas Recirculation B Control Position Exceeded Learning Limit
P04DF00 EVAP System Purge Control Valve "A" Performance/Stuck Open
P04E000 EVAP System Purge Control Valve "A" Stuck Closed
P04F000 EVAP System High Load Purge Line "A" Performance
P050400 Brake Switch "A" / "B" Correlation
P050600 Idle Air Control System-RPM Lower than Expected
P050700 Idle Air Control System-RPM Higher than Expected
P050A00 Cold Start Idle Air Control System Performance
P050B00 Cold Start Ignition Timing Performance
P050C00 Cold Start Engine Coolant Temperature Performance
P052100 Engine Oil Pressure Sensor/Switch "A" Range/Performance
P052200 Engine Oil Pressure Sensor/Switch "A" Low
P052300 Engine Oil Pressure Sensor/Switch "A" High
P052400 Engine Oil Pressure Too Low
P053200 A/C Refrigerant Pressure Sensor "A" Circuit Low Input
P053300 A/C Refrigerant Pressure Sensor "A" Circuit High Input
P053F00 Cold Start Fuel Pressure Performance
P055F00 Engine Oil Pressure Out of Range
P056000 System Voltage
P056200 System Voltage Low
P056300 System Voltage High
P060500 Internal Control Module Read Only Memory(ROM) Error
P060600 ECM/PCM Processor
P060700 Control Module Performance
P061000 Control Module Vehicle Option Error
P061600 Starter Relay Circuit Low
P061700 Starter Relay Circuit High
P061A00 Internal Control Module Torque Performance
P061B00 Internal Control Module Torque Calculation Performance
P062B00 Internal Control Module Fuel Injector Control Performance
P063000 VIN Not Programmed or Incompatible-ECM/PCM
P063800 Throttle Actuator Control Range / Performance
P064100 Sensor Reference Voltage "A" Circuit/Open
P064200 Sensor Reference Voltage "A" Circuit Low
P064300 Sensor Reference Voltage "A" Circuit High
P064D00 Internal Control Module O2 Sensor Processor Performance Bank 1
P064E00 Internal Control Module O2 Sensor Processor Performance Bank 2
P065100 Sensor Reference Voltage "B" Circuit/Open
P065200 Sensor Reference Voltage "B" Circuit Low
P065300 Sensor Reference Voltage "B" Circuit High
P066000 Intake Manifold Tuning Valve Control Circuit/Open / Bank 1
P066100 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
P066200 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
P069700 Sensor Reference Voltage "C" Circuit/Open
P069800 Sensor Reference Voltage "C" Circuit Low
P069900 Sensor Reference Voltage "C" Circuit High
P06DA00 Engine Oil Pressure Control Circuit/Open
P06DB00 Engine Oil Pressure Control Circuit Low
P06DC00 Engine Oil Pressure Control Circuit High
P0A1A00 Generator Control Module
P122000 Engine Oil Pressure Control Circuit/Open
P122200 Engine Oil Pressure Control Circuit Low
P122300 Engine Oil Pressure Control Circuit High
P123000 Fuel Pump malfunction
P123300 Low Pressure Fuel System - High deviation between target and current pressure
P132600 Knock Signal Range/Performance
P209600 Post Catalyst Fuel Trim System too Lean (Bank1)
P209700 Post Catalyst Fuel Trim System too Rich (Bank1)
P209800 Post Catalyst Fuel Trim System Too Lean (Bank 2)
P209900 Post Catalyst Fuel Trim System Too Rich (Bank 2)
P210100 Throttle Actuator Control Motor Circuit Range/Performance
P211800 Throttle Actuator Control Motor Current Range/Performance
P212200 Accelerator Position Sensor 1 Signal Circuit Low Input
P212300 Accelerator Position Sensor 1 Signal Circuit High Input
P212700 Accelerator Position Sensor 2 Signal Circuit Low Input
P212800 Accelerator Position Sensor 2 Signal Circuit-High Input
P213800 Accelerator Position Sensor 1 & 2 Signal Voltage Correlation
P215900 Vehicle Speed Sensor "B" Range / Performance(Wheel Speed Sensor)
P217700 System Too Lean Off Idle Bank 1
P217800 System Too Rich Off Idle Bank 1
P217900 System Too Lean Off Idle Bank 2
P218000 System Too Rich Off Idle Bank 2
P218100 Cooling System Performance
P218300 Engine Coolant Temperature Sensor 2 Circuit Range/Performance
P218400 Engine Coolant Temperature Sensor 2 Circuit Low
P218500 Engine Coolant Temperature Sensor 2 Circuit High
P218600 Engine Coolant Temperature Sensor 2 Circuit Intermittent/Erratic
P219500 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P219600 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
P219700 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 1)
P219800 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 1)
P219C00 Cylinder 1 Air-Fuel Ratio Imbalance
P219D00 Cylinder 2 Air-Fuel Ratio Imbalance
P219E00 Cylinder 3 Air-Fuel Ratio Imbalance
P219F00 Cylinder 4 Air-Fuel Ratio Imbalance
P21A000 Cylinder 5 Air-Fuel Ratio Imbalance
P21A100 Cylinder 6 Air-Fuel Ratio Imbalance
P21CF00 Cylinder 1 Injector "B" Circuit/Open
P21D000 Cylinder 2 Injector "B" Circuit/Open
P21D100 Cylinder 3 Injector "B" Circuit/Open
P21D200 Cylinder 4 Injector "B" Circuit/Open
P21D300 Cylinder 5 Injector "B" Circuit/Open
P21D400 Cylinder 6 Injector "B" Circuit/Open
P21DB00 Cylinder 1 Injector "B" Circuit Low
P21DC00 Cylinder 1 Injector "B" Circuit High
P21DE00 Cylinder 2 Injector "B" Circuit Low
P21DF00 Cylinder 2 Injector "B" Circuit High
P21E000 Cylinder 3 Injector "B" Circuit Low
P21E100 Cylinder 3 Injector "B" Circuit High
P21E200 Cylinder 4 Injector "B" Circuit Low
P21E300 Cylinder 4 Injector "B" Circuit High
P21E400 Cylinder 5 Injector "B" Circuit Low
P21E500 Cylinder 5 Injector "B" Circuit High
P21E600 Cylinder 6 Injector "B" Circuit Low
P21E700 Cylinder 6 Injector "B" Circuit High
P222700 Barometric Pressure Circuit Range/Performance
P222800 Barometric Pressure Circuit Low Input
P222900 Barometric Pressure Circuit High Input
P223700 O2 Sensor Pumping Current Circuit/Open (Bank 1 Sensor 1)
P224000 O2 Sensor Pumping Current Circuit/Open (Bank 2 Sensor 1)
P224300 O2 Sensor Reference Voltage Circuit/Open (Bank 1 Sensor 1)
P224700 O2 Sensor Reference Voltage Circuit/Open (Bank 2 Sensor 1)
P225100 O2 Sensor Reference Ground Circuit/Open (Bank 1 Sensor 1)
P225400 O2 Sensor Reference Ground Circuit/Open (Bank 2 Sensor 1)
P227000 O2 Sensor Stuck Lean - Bank1 Sensor 2
P227100 O2 Sensor Stuck Rich - Bank1 Sensor 2
P227200 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 2)
P227300 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 2)
P227900 Intake Air System Leak
P230000 Ignition Coil "A" Primary Control Circuit Low
P230100 Ignition Coil "A" Primary Control Circuit High
P230300 Ignition Coil "B" Primary Control Circuit Low
P230400 Ignition Coil "B" Primary Control Circuit High
P230600 Ignition Coil "C" Primary Control Circuit Low
P230700 Ignition Coil "C" Primary Control Circuit High
P230900 Ignition Coil "D" Primary Control Circuit Low
P231000 Ignition Coil "D" Primary Control Circuit High
P231200 Ignition Coil "E" Primary Control Circuit Low
P231300 Ignition Coil "E" Primary Control Circuit High
P231500 Ignition Coil "F" Primary Control Circuit Low
P231600 Ignition Coil "F" Primary Control Circuit High
P23F200 Cylinder 1 Injector "B" Air-Fuel Ratio Imbalance
P23F300 Cylinder 2 Injector "B" Air-Fuel Ratio Imbalance
P23F400 Cylinder 3 Injector "B" Air-Fuel Ratio Imbalance
P23F500 Cylinder 4 Injector "B" Air-Fuel Ratio Imbalance
P23F600 Cylinder 5 Injector "B" Air-Fuel Ratio Imbalance
P23F700 Cylinder 6 Injector "B" Air-Fuel Ratio Imbalance
P241400 O2 Sensor Exhaust Sample Error (Bank 1 Sensor 1)
P241500 O2 Sensor Exhaust Sample Error (Bank 2 Sensor 1)
P250100 AMS Voltage Rationality
P250200 Charging System Voltage
P250300 Charging System Voltage Low
P250400 Charging System Voltage High
P25B000 Fuel Level Sensor "A" Stuck
P261000 ECM/PCM Internal Engine Off Timer Performance
P262600 O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
P262900 O2 Sensor Pumping Current Trim Circuit/Open (Bank 2 Sensor 1)
P262B00 Control Module Power Off Timer Performance
P2B5800 Engine Coolant Flow Control Valve Motor Current High
P2B5900 Engine Coolant Flow Control Valve Control Circuit/Open
P2B5A00 Engine Coolant Flow Control Valve Control Circuit Low
P2B5B00 Engine Coolant Flow Control Valve Control Circuit High
P2B6000 Engine Coolant Flow Control Valve Position Sensor Circuit Range/Performance
P2B9500 Cold Start Injection Pulse Performance
P2BEC00 Fuel Control System "A" Too Lean Bank 1
P2BED00 Fuel Control System "A" Too Rich Bank 1
P2BEE00 Fuel Control System "A" Too Lean Bank2
P2BEF00 Fuel Control System "A" Too Rich Bank2
P2BF000 Fuel Control System "B" Too Lean Bank 1
P2BF100 Fuel Control System "B" Too Rich Bank 1
P2BF200 Fuel Control System "B" Too Lean Bank2
P2BF300 Fuel Control System "B" Too Rich Bank2
U000100 High Speed CAN Communication Bus off
U003700 Vehicle Communication Bus "B"
U010100 Lost Communication with TCM
U010400 Lost Communication With Cruise Control Module
U012300 Lost Communication With Yaw Rate Sensor Module
U012600 Lost Communication With Steering Angle Sensor Module
U012800 Lost Communication With Park Brake Control Module
U012A00 Lost Communication With ICSC Module
U012D00 Lost Communication With Generator Control Module
U013100 Lost Communication With Power Steering Control Module
U014000 Lost Communication With Body Control Module
U015500 Lost Communication With Instrument Panel Cluster (IPC) Control Module
U015C00 Lost Communication With Automated Driving System Control Module "A"
U016400 Lost Communication With HVAC Control Module(FATC CAN Time Out)
U01B000 Lost Communication with Battery Monitor Module
U01B400 Lost Communication With Brake System Control Module "B"
U040200 Invalid Data Received From TCM
U042B00 Invalid Data Received From Chassis Control Module "A"
U04B100 Invalid Data Received From Battery Monitor Module
U060900 Lost Communication With Manifold Absolute Pressure/Barometric Pressure Sensor
U060F00 Lost Communication With Mass or Volume Air Flow Sensor "A"
U061100 Lost Communication With Intake Air Temperature Sensor1 Bank1
U063F00 Lost Communication With Engine Coolant Flow Control Valve Position Sensor
U111200 LIN Communication Error
G 3.5 GDI LAMBDA III > Transmission > Automatic Transaxle
P060100 Internal Control Module Memory Check Sum Error
P070512 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P070514 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P07051C Transmission Range Sensor Circuit Malfunction (PRNDL Input)
P071200 Transmission Fluid Temperature Sensor "A" Circuit Low Input
P071300 Transmission Fluid Temperature Sensor "A" Circuit High Input
P071700 Input/Turbine Speed Sensor "A" Circuit No Signal
P072100 Output Speed Sensor Circuit Range/Performance
P072200 Output Speed Sensor Circuit No Signal
P072900 Gear 6 Incorrect Ratio
P073000 Gear 8 Incorrect Ratio
P073100 Gear 1 Incorrect Ratio
P073200 Gear 2 Incorrect Ratio
P073300 Gear 3 Incorrect Ratio
P073400 Gear 4 Incorrect Ratio
P073500 Gear 5 Incorrect Ratio
P074100 Torque Converter Clutch Circuit Performance or Stuck Off
P074300 Torque Converter Clutch Circuit Electrical
P074800 Pressure Control Solenoid Valve(VFS) "A" Electrical
P075300 Shift Control Solenoid Valve "A" Electrical (UD/C)
P075800 Shift Control Solenoid Valve "B" Electrical (46/C)
P076300 Shift Control Solenoid Valve "C" Electrical (37R/C)
P076800 Shift Control Solenoid Valve "D" Electrical (OD&LR)
P076F00 Gear 7 Incorrect Ratio
P077300 Shift Control Solenoid Valve "E" Electrical (28/B)
P079100 Intermediate Shaft Speed Sensor "A" Circuit
P088000 TCM Power Input Signal
P160200 No EOL Data
P270900 Shift Control Solenoid Valve "F" Electrical
U000100 High Speed CAN Communication Bus Off (P-CAN)
U010000 Lost Communication with ECM/PCM 'A'
U010300 Lost Communication With Gear Shift Control Module "A"
U010308 Lost Communication With Gear Shift Control Module "A"
U111700 Hhigh Speed CAN2 Communication (EMS-DCT)
U111788 Hhigh Speed CAN2 Communication (EMS-DCT)
Ещё обсуждения по Киа K8 GL3 на MyKia.club:
Киа K8 GL3
Другие модели Киа →
Киа K8 клуб →
передний бамперАвтор krionika, 04 Dec 2022 |
Киа K8 GL3
Другие модели Киа →
Киа K8 клуб →
задний бамперАвтор krionika, 27 May 2023 |
Киа K8 GL3
Другие модели Киа →
Киа K8 клуб →
инструкция по эксплуатацииАвтор krionika, 07 Sep 2021 |
Киа K8 GL3
Другие модели Киа →
Киа K8 клуб →
масло и фильтр для двигателяАвтор krionika, 16 Sep 2021 |
Киа K8 GL3
Другие модели Киа →
Киа K8 клуб →
сход развалАвтор krionika, 18 Nov 2022 |
