Киа K8 GL3
Сообщений в теме: 19
  • 24970 сообщений
Отправлено 11 March 2023 - 08:09
Коды ошибок Kia K8 (GL3)
G 3.5 GDI LAMBDA III > ADAS Driving ECU > ADAS Driving ECU
B160487 CAN Time-Out BCM
B169887 CAN Time-Out SWRC
C110117 Battery Voltage High
C110216 Battery Voltage Low
C136081 ESP Irreversible Error
C160404 ECU Hardware Error
C160604 ECU Software Error
C160A88 Local CAN Bus Off
C161187 CAN Time-out EMS
C161287 CAN Time-out TCU
C161386 CAN Signal Error EMS
C161E88 CAN Bus OFF
C162387 CAN Time-out Steering Angle Sensor
C162887 CAN Time-out Cluster
C163881 SCC Communication Error
C164281 CAN Message Failure - Brake
C164282 CAN Message Failure - Brake
C164286 CAN Message Failure - Brake
C164686 CAN Message Failure - TCU
C165686 CAN Signal Error - Cluster
C165B87 CAN Time-Out ESC
C165C87 CAN Time-out YRS
C167A87 CAN Time-Out NAVI
C168787 CAN Time-out VSM2 (MDPS)
C168886 VSM2 (MDPS) Signal Error
C16B881 AEB Communication Error
C170255 Variant Coding Error
C181287 CAN Time-out Gateway
C181486 CAN Message Failure - SAS
C181786 CAN Signal Error Gateway
C183186 CAN Signal Error - Navigation
C183D82 CAN Message Failure - SWRC
C183E86 Invalid Signal of ICU
C184286 Yaw rate, Lateral Acceleration or Logngitudinal Acceleration Not valid
C184881 Invalid Signal of IBU
C185187 CAN Time-out SBCM
C185287 CAN Time-out SBCM
C185381 Invalid Signal of SBCM
C185481 Invalid Signal of SBCM
C186387 CAN Time-out NAVI for HDA
C186687 CAN Time-Out ICSC
C187002 CAN Signal Error ICSC
C188087 CAN Time-Out FR_C_RDR
C188186 CAN Signal Error FR_C_RDR
C223986 MDPS Steering Control Failure for LKAS
C28AA87 CAN Time-Out FR_CMR
C28AB87 CAN Time-Out FR_RDR
C28B086 CAN Signal Error FR_CMR
C28B186 CAN Signal Error FR_RDR
  • 24970 сообщений
Отправлено 11 March 2023 - 08:10
G 3.5 GDI LAMBDA III > Advanced Driver Assistance System_Parking > Advanced Driver Assistance System_Parking
B103000 No Camera Tolerance Correction
B162100 ECU hardware
B162C00 Camera Power Line Short
B16B700 Front Camera Input Error
B16B800 Rear Camera Input Error
B16B900 Left Camera Input Error
B16BA00 Right Camera Input Error
C110417 Ignition Voltage High
C110516 Ignition Voltage Low
C112811 PAS Front Sensor source Voltage
C112911 PAS Rear Sensor Source Voltage
C11311C Camera Power Supply Fail
C136231 Camera Signal Failure
C136887 PAS Sensor - Rear Left Outer
C136896 PAS Sensor - Rear Left Outer
C136987 PAS Sensor - Rear Left Inner
C136996 PAS Sensor - Rear Left Inner
C136A87 SPAS Sensor - Rear Left
C136A96 SPAS Sensor - Rear Left
C136B87 SPAS Sensor - Rear Right
C136B96 SPAS Sensor - Rear Right
C136C10 PAS Sensor LIN Short
C136D10 SPAS Sensor LIN2 Short
C137087 PAS Sensor - Rear Right Inner
C137096 PAS Sensor - Rear Right Inner
C137187 PAS Sensor - Rear Right Outer
C137196 PAS Sensor - Rear Right Outer
C137287 PAS Sensor - Front Right Outer
C137296 PAS Sensor - Front Right Outer
C137387 PAS Sensor - Front Right Inner
C137396 PAS Sensor - Front Right Inner
C137487 PAS Sensor - Front Left Inner
C137496 PAS Sensor - Front Left Inner
C137587 PAS Sensor - Front Left Outer
C137596 PAS Sensor - Front Left Outer
C137687 SPAS Sensor - Front Left
C137696 SPAS Sensor - Front Left
C137787 SPAS Sensor - Front Right
C137796 SPAS Sensor - Front Right
C152811 PAS Switch Indicator Failure
C152812 PAS Switch Indicator Failure
C152911 PA Switch Indicator Failure
C152912 PA Switch Indicator Failure
C153011 PAS Switch Failure
C153111 PA Switch Failure
C160449 ECU Hardware Error
C161187 CAN Time-Out EMS
C161287 CAN Time-Out TCU
C161688 C-CAN Bus OFF
C162587 CAN Time-Out ABS/ESP
C162887 CAN Time-Out Cluster
C164387 CAN Time-Out Yaw Rate & G Sensor
C165187 CAN Time-Out EPB
C165286 CAN Signal Error EPB
C165987 CAN Time-Out SAS
C166B87 CAN time-out Wheel Speed Sensor
C167186 Signal LAT_ACCEL or LONG_ACCEL or YAW_RATE or YL_PRES_STAT not Valid
C168787 CAN Time-Out VSM2 (MDPS)
C169487 CAN Time-Out FATC
C169586 CAN Message Failure - FATC
C16B286 WHL_SPD Checksum/Alive Counter Error
C170246 Variant Coding Error
C181287 CAN Time-Out Gateway
C181C87 CAN Time-Out LVR
C182D87 CAN Time-Out SCU
C183487 CAN Time-Out IEB
C183586 CAN Signal Error IEB
C183686 CAN Signal Error LVR
C183A86 CAN Message Failure - SCU
C224786 PA failure for MDPS Steering Control
C224986 RSPA Failure for iEB Control
C225086 RSPA Failure for PT Assist
C225186 RSPA Failure for IBU Control
C225286 CAN Message Failure IBU
C225387 CAN Time-Out IBU
  • 24970 сообщений
G 3.5 GDI LAMBDA III > Air Conditioner > Air Conditioner
B120413 Air Mix Potentiometer Open (Low)-Passenger
B120511 Air Mix Potentiometer Short (High)-Passenger
B120813 Intake Potentiometer Open (Low)
B120911 Intake Potentiometer Short (High)
B123311 Incar Temp Sensor Short (Low) - Front
B123413 Incar Temp Sensor Open (High) - Front
B123711 Ambient Temperature Sensor Short (Low)
B123813 Ambient Temperature Sensor Open (High)
B124111 Evaporator Sensor Short (Low)
B124213 Evaporator Sensor Open (High)
B124513 Air Mix Potentiometer Open (Low) - Driver
B124611 Air Mix Potentiometer Short (High) - Driver
B124913 Direction Potentiometer Open (Low) - Driver
B125011 Direction Potentiometer Short (High) - Driver
B127513 Air Direction Potentiometer- Open (Low) - Console
B127611 Air Direction Potentiometer - Short (High) - Console
B127713 Air Mix Potentiometer-TEMP Open (Low)-Console
B127811 Air Mix Potentiometer-TEMP Short (High)-Console
B128111 Humidity Sensor Short (Low) - AUTO Defog
B128313 Direction Potentiometer Open (Low) - AUTO Defog
B128411 Direction Potentiometer Short (High) - Auto Defog
B128577 Direction Control Motor -AUTO Defog
B167288 APT Sensor Fault - CAN Signal
B168588 Engine RPM fault - CAN Signal
B168688 Vehicle Speed Sensor Fault - CAN Signal
B168788 Engine Coolant Temperature Sensor Fault - CAN Signal
B16A413 ECV Fault
B177388 Climate CAN Communication Fail (Rear)
B177688 Climate LIN Communication Fail (Panel)
B240677 Air Mix Motor - Driver
B240877 Intake Motor
B240977 Direction Control Motor - Driver
B241577 Air Mix Motor-Passenger
B244777 Air Direction Motor (Console)
B244877 Air Mix Motor TEMP-Console
  • 24970 сообщений
G 3.5 GDI LAMBDA III > Airbag > Airbag(Event #1)
B110100 Battery Voltage High
B110200 Battery Voltage Low
B111600 Battery Voltage Unstable
B111700 B+ Line Disconnected
B132800 FIS(Front Impact Sensor)-Driver Defect
B132900 FIS(Front Impact Sensor)-Driver Communication Error
B133000 FIS(Front Impact Sensor)-Driver Wrong ID
B133300 FIS(Front Impact Sensor)-Passenger Defect
B133400 FIS(Front Impact Sensor)-Passenger Communication Error
B133500 FIS(Front Impact Sensor)-Passenger Wrong ID
B134600 Driver Airbag Resistance too High (1st Stage)
B134700 Driver Airbag Resistance too Low (1st Stage)
B134800 Driver Airbag Resistance Circuit Short to Ground (1st Stage)
B134900 Driver Airbag Resistance Circuit Short to Battery (1st Stage)
B135200 Passenger Airbag Resistance too High (1st Stage)
B135300 Passenger Airbag Resistance too Low (1st Stage)
B135400 Passenger Airbag Resistance Circuit Short to Ground (1st Stage)
B135500 Passenger Airbag Resistance Circuit Short to Battery (1st Stage)
B136100 Pretensioner Front-Driver Resistance too High
B136200 Pretensioner Front-Driver Resistance too Low
B136300 Pretensioner Front-Driver Resistance Circuit Short to Ground
B136400 Pretensioner Front-Driver Resistance Circuit Short to Battery
B136700 Pretensioner Front-Passenger Resistance too High
B136800 Pretensioner Front-Passenger Resistance too Low
B136900 Pretensioner Front-Passenger Resistance Circuit Short to Ground
B137000 Pretensioner Front-Passenger Resistance Circuit Short to Battery
B137800 Side Airbag Front-Driver Resistance too High
B137900 Side Airbag Front-Driver Resistance too Low
B138000 Side Airbag Front-Driver Resistance Circuit Short to Ground
B138100 Side Airbag Front-Driver Resistance Circuit Short to Battery
B138200 Side Airbag Front-Passenger Resistance too High
B138300 Side Airbag Front-Passenger Resistance too Low
B138400 Side Airbag Front-Passenger Resistance Circuit Short to Ground
B138500 Side Airbag Front-Passenger Resistance Circuit Short to Battery
B139500 Cross Coupling
B140000 SIS(Side Impact Sensor) Front-Driver Defect
B140300 SIS(Side Impact Sensor) Front-Passenger Defect
B140900 SIS(Side Impact Sensor) Front-Driver Communication Error
B141000 SIS(Side Impact Sensor) Front-Passenger Communication Error
B141200 SIS(Side Impact Sensor)Rear-Driver Communication error
B141300 SIS(Side Impact Sensor)Rear-Passenger Communication error
B141400 SIS(Side Impact Sensor) Front-Driver Wrong ID
B141500 SIS(Side Impact Sensor) Front-Passenger Wrong ID
B141600 SIS(Side Impact Sensor)Rear-Driver Wrong ID
B141700 SIS(Side Impact Sensor)Rear-Passenger Wrong ID
B141800 SIS(Side Impact Sensor)Rear-Driver Defect
B141900 SIS(Side Impact Sensor)Rear-Passenger Defect
B142900 Side Airbag Rear-Driver Resistance too High
B143000 Side Airbag Rear-Driver Resistance too Low
B143100 Side Airbag Rear-Driver Resistance Circuit Short to Ground
B143200 Side Airbag Rear-Driver Resistance Circuit Short to Battery
B143300 Side Airbag Rear-Passenger Resistance too High
B143400 Side Airbag Rear-Passenger Resistance too Low
B143500 Side Airbag Rear-Passenger Resistance Circuit Short to Ground
B143600 Side Airbag Rear-Passenger Resistance Circuit Short to Battery
B147300 Inflatable Curtain Airbag Driver Resistance too High
B147400 Inflatable Curtain Airbag Driver Resistance too Low
B147500 Inflatable Curtain Airbag Driver Resistance Circuit Short to Ground
B147600 Inflatable Curtain Airbag Driver Resistance Circuit Short to Battery
B147700 Inflatable Curtain Airbag Passenger Resistance too High
B147800 Inflatable Curtain Airbag Passenger Resistance too Low
B147900 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Ground
B148000 Inflatable Curtain Airbag Passenger Resistance Circuit Short to Battery
B162000 Internal Fault - Replace SRSCM
B164900 Crash Recorded-Rollover Event (Replace SRSCM)
B165000 Crash Recorded in 1st Stage Only (Frontal-Replace SRSCM)
B165100 Crash Recorded in Driver Side Airbag (Replace SRSCM)
B165200 Crash Recorded in Passenger Side Airbag (Replace SRSCM)
B167000 Crash Recorded in Full Stage (Frontal-Replace SRSCM)
B167600 Crash Recorded in Driver Side Restraint System With Frontal Crash (Replace ECU)
B167700 Crash Recorded in Passenger Side Restraint System With Frontal Crash (Replace ECU)
B167800 Scrap Recorded (Replace ECU)
B168300 Exceed Maximum Coding Number
B168400 Not Configured Device is Detected
B16D000 Internal Fault - Main Sensor
B16D100 Internal Fault - Safing Sensor
B16D200 Internal Fault - Roll Sensor (Gyro)
B16D300 Internal Fault - Roll Sensor (Low-g)
B16D400 Internal Fault – ESC Sensor (Gyro)
B16D500 Internal Fault – ESC Sensor (Low-g)
B16D600 Internal Fault - MCU (Except Memory)
B16D700 Internal Fault - ROM/RAM/EEPROM
B16D800 Internal Fault - Safing FET
B16D900 Internal Fault - System ASIC
B16DA00 Internal Fault – Squib ASIC (if equipped)
B16DB00 Internal Fault – Sensor I/F ASIC (if equipped)
B16DC00 Internal Fault - Energy Reserve
B171100 Knee airbag - Driver resistance too High
B171200 Knee airbag - Driver resistance too Low
B171300 Knee airbag - Driver resistance circuit short to Ground
B171400 Knee airbag - Driver resistance circuit short to Battery
B173800 P-SIS(Side Impact Sensor, Pressure) Front-Driver Wrong ID
B173900 P-SIS(Side Impact Sensor, Pressure) Front-Driver Defect
B174200 P-SIS(Side Impact Sensor, Pressure) Front-Driver Communication Error
B174400 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Wrong ID
B174500 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Defect
B174800 P-SIS(Side Impact Sensor, Pressure) Front-Passenger Communication Error
B176200 ACU Coding Error
B261300 ACU Airbag Warning Lamp CAN Message Error
B261400 Cluster Airbag Warning Lamp Circuit Failure
B261500 ACU and Cluster Airbag Lamp CAN Message Mismatch
B261600 Cluster Airbag Warning Lamp CAN Message Invaild
B261700 Cluster Airbag Warning Lamp CAN Message Timeout
B261800 Cluster Airbag Warning Lamp CAN Message Timeout by CAN Bus
  • 24970 сообщений
G 3.5 GDI LAMBDA III > Amplifier > Amplifier
B280100 MM CAN Signal Line Error
B291500 Front Left Woofer Open Load
B291600 Front Right Woofer Open Load
B291700 Front Left Mid/TWT Open Load
B291800 Front Right Mid/TWT Open Load
B291900 Front Center Open Load
B291A00 Rear Left Woofer Open Load
B291B00 Rear Right Woofer Open Load
B291C00 Rear Left Mid/TWT Open Load
B291D00 Rear Right Mid/TWT Open Load
B291E00 Left Surround Open Load
B291F00 Right Surround Open Load
B292000 Subwoofer 1 Open Load
B292100 Subwoofer 2 Open Load
G 3.5 GDI LAMBDA III > Audio Video Navigation > Audio Video Navigation
B282400 FRT MIC Connection Error
B282600 GPS Antenna Short State
B282700 GPS Antenna Open State
B284100 USB Communication Error
B284300 Multimedia Terminal Connection Error
B28C000 Am/Fm1 Radio Antenna Short State
B28C100 Am/Fm1 Radio Antenna Open State
B28C200 FM2 Radio Antenna Short State
B28C300 FM2 Radio Antenna Open State
B294300 FL Speaker Connection Error
B294400 FR Speaker Connection Error
B294500 RL Speaker Connection Error
B294600 RR Speaker Connection Error
B294900 Radio Antenna Connection & Receive Quality
  • 24970 сообщений
G 3.5 GDI LAMBDA III > Brake > ABS/ESP
C110101 Battery Voltage High
C110113 Battery Voltage High
C110201 Battery Voltage Low
C110213 Ignition Voltage
C110362 Ignition Voltage
C110913 IG1 Open
C120001 Wheel Speed Sensor Front-LH Open/Short
C120102 Wheel Speed Sensor Front-LH Range / Performance / Intermittent
C120202 Wheel Speed Sensor Front-LH Invalid/No Signal
C120301 Wheel Speed Sensor Front-RH Open/Short
C120402 Wheel Speed Sensor Front-RH Range / Performance / Intermittent
C120502 Wheel Speed Sensor Front-RH Invalid/no Signal
C120601 Wheel Speed Sensor Rear-LH Open/Short
C120702 Wheel Speed Sensor Rear-LH Range / Performance / Intermittent
C120802 Wheel Speed Sensor Rear-LH Invalid/no Signal
C120901 Wheel Speed Sensor Rear-RH Open/Short
C121002 Wheel Speed Sensor Rear-RH Range / Performance / Intermittent
C121102 Wheel Speed Sensor Rear-RH Invalid/no Signal
C121302 Wheel Speed Frequency Error (Generic Wheel Speed Error)
C123501 Pressure Sensor(Primary) - Open/Short
C123702 Pressure Sensor - Other
C128354 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C128364 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C128382 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C128383 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C128386 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C128387 Lateral G Sensor/Longitudinal G Sensor/Yaw Rate Sensor - Signal Error
C135801 AVH Switch Circuit Error
C150113 Switch Failure
C15011F Switch Failure
C150193 Switch Failure
C150301 TCS/ESC(ESP) Switch Circuit Error
C154201 Brake Circuit Error
C160496 ECU Hardware Error
C160648 ECU Software Error
C16064A ECU Software Error
C160662 ECU Software Error
C160696 ECU Software Error
C160E88 P-CAN Bus OFF
C161382 CAN Signal Error EMS
C161383 CAN Signal Error EMS
C161387 CAN Signal Error EMS
C162604 Implausible Control
C163882 SCC/FCA Communication Error
C163883 SCC/FCA Communication Error
C163886 SCC/FCA Communication Error
C163887 SCC/FCA Communication Error
C164682 CAN Message Failure - TCU
C164683 CAN Message Failure - TCU
C164687 CAN Message Failure - TCU
C165682 CAN Signal Error - Cluster
C165683 CAN Signal Error - Cluster
C165687 CAN Signal Error - Cluster
C166982 CAN Time-Out ACU
C166983 CAN Time-Out ACU
C166987 CAN Time-Out ACU
C168883 VSM2 (MDPS) Signal Error
C168887 VSM2 (MDPS) Signal Error
C16B882 FCA Communication Error
C16B883 FCA Communication Error
C16B887 FCA Communication Error
C17024A Variant Coding Error
C181454 CAN Message Failure - SAS
C181464 CAN Message Failure - SAS
C181482 CAN Message Failure - SAS
C181483 CAN Message Failure - SAS
C181487 CAN Message Failure - SAS
C181787 CAN Signal Error Gateway
C181887 CAN Time-Out LCA/BSD/BCW
C183782 CAN Signal Error BCA/BCW
C183783 CAN Signal Error BCA/BCW
C183982 CAN Signal Error RSPA
C183983 CAN Signal Error RSPA
C183987 CAN Signal Error RSPA
C184082 Communication Error - RR_C_RDR
C184083 Communication Error - RR_C_RDR
C184087 Communication Error - RR_C_RDR
C184782 Communication Error - PCA
C184783 Communication Error - PCA
C184787 Communication Error - PCA
C211201 Valve Relay Error
C213001 Brake Lamp Relay Error
C220277 Latching Failure / Mechanics
C222071 Rear-LH Actuator
C222074 Rear-LH Actuator
C222077 Rear-LH Actuator
C222094 Rear-LH Actuator
C222471 Rear-RH (or rear) Actuator
C222474 Rear-RH (or rear) Actuator
C222477 Rear-RH (or rear) Actuator
C222494 Rear-RH (or rear) Actuator
C222798 Excessive Temperature Of Brake Disc
C238001 ABS/TCS/ESP valve error
C240201 Motor Electrical
C241611 Motor Short or Open - LH
C241612 Motor Short or Open - LH
C241613 Motor Short or Open - LH
C241711 Motor Short or Open - RH
C241712 Motor Short or Open - RH
C241713 Motor Short or Open - RH
  • 24970 сообщений
Отправлено 11 March 2023 - 08:11
G 3.5 GDI LAMBDA III > Cluster Module > Cluster Module(4inch)
B100051 Cluster Coding Not Programmed
B100152 SCC Missing Error - without SCC unit or connector fault
B100155 SCC Present Error - Coding code error
B100252 EPB Missing Error - without EPB unit or connector fault
B100255 EPB Present Error - Coding code error
B100552 Airbag Missing Error - without Airbag unit or connector fault
B100555 Airbag Present Error - Coding code error
B100852 MDPS Missing Error - without MDPS unit or connector fault
B100855 MDPS Present Error - Coding code error
B101052 ESC Missing Error - without ESC unit or connector fault
B101055 ESC Present Error - Coding code error
B102052 TPMS Missing Error - without TPMS unit or connector fault
B102055 TPMS Present Error - Coding code error
B108052 ECS Missing Error - without ECS unit or connector fault
B108055 ECC Present Error - Coding code error
B109052 TCU Missing Error
B109055 TCU Present Error
B109352 eCall Missing Error
B109355 eCall Present Error
B280000 MM CAN Bus Off Error
G 3.5 GDI LAMBDA III > Driver Door Module > Driver Door Module
B160300 CAN Bus OFF (B-CAN)
B161C00 LIN Error RH Outside Mirror Unit
B169B00 LIN Error LH Outside Mirror Unit
G 3.5 GDI LAMBDA III > Driver Lumbar Bolster Cushion Unit > Driver Lumbar Bolster Cushion Unit
B160300 CAN BUS OFF (B-CAN)
G 3.5 GDI LAMBDA III > Driver Power Seat Switch > Driver Power Seat Switch
  • 24970 сообщений
G 3.5 GDI LAMBDA III > E-Shifter > E-Shifter
C138201 Lever Hall Sensor Fault
C153364 Park Switch Fault
C154893 Shift Button Indicator Failure
C160C87 CAN Time-out SCU_Back up
C161187 CAN Time-out ECM
C162887 CAN Time-out CLU
C172144 Data from EEPROM Not Valid or Hardware Defects
C181287 CAN Time-out ICU
C182D87 CAN Time-out SCU_Main
C183A82 CAN Message Failure - SCU
C183A83 CAN Message Failure - SCU
C225387 CAN Time-out IBU
G 3.5 GDI LAMBDA III > Front Radar > Front Radar
C120281 Wheel Speed Sensor Front-LH Invalid/no Signal
C120581 Wheel Speed Sensor Front-RH Invalid/no Signal
C120881 Wheel Speed Sensor Rear-LH Invalid/no Signal
C121181 Wheel Speed Sensor Rear-RH Invalid/no Signal
C160A88 Local CAN Bus OFF
C160C87 Local CAN Time-out
C161381 CAN Signal Error EMS
C161E88 E-CAN Bus OFF (E-CAN Bus Off Error)
C162078 Alignment Failed
C163881 ACC/SCC communication error
C164283 CAN Message Failure - Brake
C164681 CAN Message Failure - TCU
C165681 CAN Signal Error - Cluster
C167281 SAS Message Counter Error
C167282 SAS1 Message Counter Error
C167283 SAS Message Counter Error
C174181 ESC-not available VSM (Check ESC)
C174281 Variant Error - ESC (Check ESC)
C174455 SCC Coding & AVN/Navi Option Mismatch
C180487 CAN time-out LKAS
C180581 LKAS CAN Signal Error
C180582 LKAS CAN Signal Error
C180583 LKAS CAN Signal Error
C183C83 CAN Message Failure - ICU
C183D83 CAN Message Failure - SWRC
C184281 YRS_YawRate or YRS_LatAccel or YRS LongAccel Not valid
C184282 YRS_YawRate or YRS_LatAccel or YRS LongAccel Not valid
C184283 YRS_YawRate or YRS_LatAccel or YRS LongAccel Not valid
  • 24970 сообщений
G 3.5 GDI LAMBDA III > Front View Camera > Front View Camera
C160649 ECU Software Error
C160A87 Local CAN Bus Off
C160C87 Local CAN Time-Out
C161E87 E-CAN Bus OFF (E-CAN Bus Off Error)
C162385 CAN Time-out Steering Angle Sensor
C162585 CAN Time-Out ABS/ESP
C166787 CAN Time-Out SCC
C167286 SAS Message Counter Error
C168785 CAN Time-out VSM2 (MDPS)
C16B687 CAN Time-Out FCA
C16B802 FCA Communication Error
C170262 Variant Coding Error
C174686 HDA Coding & AVN / Navi Option Mismatch
C184286 YRS_YawRate or YRS_LatAccel or YRS LongAccel Not valid
C184987 CAN Time-Out H_U
C186286 Invalid Signal of SCC
C272146 System Calibration Required
C272246 System Out of Calibration
G 3.5 GDI LAMBDA III > Head Up Display > Head Up Display
B160300 CAN Bus OFF (C-CAN)
B285300 No HUD Flection Correction(HUD Not Warped)
  • 24970 сообщений
Отправлено 11 March 2023 - 08:12
G 3.5 GDI LAMBDA III > Integrated Body Control Unit-BCM > Integrated Body Control Unit-BCM
B100052 EOL Not Programmed
B121000 Front Left Sensor Fault
B121100 Front Center Left Sensor Fault
B121200 Front Center Right Sensor Fault
B121300 Front Right Sensor Fault
B121400 Rear Left Sensor Fault
B121500 Rear Center Left Sensor Fault
B121600 Rear Center Right Sensor Fault
B121700 Rear Right Sensor Fault
B160200 CAN Line Error (B-CAN)
B163100 LIN Communication Error - FL SPW
B163200 LIN Communication Error - FR SPW
B163300 LIN Communication Error - RL SPW
B163400 LIN Communication Error - RR SPW
B163E00 Rain Sensor Module LIN Fault
B165E00 LIN communication Error - Glass
B165F00 LIN communication Error - Blind
B181000 UIP/ROA Sensor Error
B187000 ROA Sensor Error (Slave)
C160E00 P-CAN Bus OFF
C161600 C-CAN Bus OFF
G 3.5 GDI LAMBDA III > Integrated Body Control Unit-SMK > Integrated Body Control Unit-SMK
B160200 CAN Error
B160300 CAN Bus OFF
B16A800 Interior Antenna #1 Failure
B16A900 Interior Antenna #2 Failure
B16AA00 Interior Antenna #3 Failure
B16AB00 Rear Bumper Antenna Failure
B16AC00 Driver Side Door Handle Antenna Failure
B16AD00 Passenger Side Door Handle Antenna Failure
Ещё обсуждения по Киа K8 GL3 на MyKia.club:
