Киа Маджентис 2 MG
Сообщений в теме: 14
Отправлено 19 April 2021 - 14:21
G 2.7 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1208 Intake potentiometer open (Low)
B1209 Intake potentiometer short (High)
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B1257 AQS sensor open (High)
B1258 AQS sensor short (Low)
B1259 AQS sensor fault
B2406 Air mix motor (Driver)
B2408 Intake motor
B2409 Direction control motor (Driver)
G 2.7 DOHC > Airbag > Airbag Control
B1101 Battery voltage high
B1102 Battery voltage low
B1338 Front Impact Sensor (FIS) - Center Defect
B1339 Front Impact Sensor (FIS) - Center Communication Error
B1400 SIS front-Driver defect
B1412 SIS rear-Driver communication error
B1413 SIS rear-Passenger communication error
B1418 SIS rear-Driver defect
B1419 SIS rear-Passenger defect
B1527 Passenger airbag deactivation switch open or short to Battery
B1528 Passenger airbag deactivation switch short or short to Ground
B1529 Passenger airbag deactivation switch defect
B1530 Passenger airbag deactivation switch instability
B2503 Warning lamp open or short to ground
B2504 Warning lamp short or short to battery
B2507 Passenger airbag Telltale lamp open or short to ground
B2508 Passenger airbag Telltale lamp short or short to battery
G 2.7 DOHC > Brake > Anti-Lock Brake
C1101 (ABS) Battery voltage high
C1101 (ESP) Battery voltage high
C1102 (ABS) Battery voltage low
C1102 (ESP) Battery voltage low
C1112 (ESP) Sensor power voltage
C1200 (ABS) Wheel speed sensor front-LH open/short
C1200 (ESP) Wheel speed sensor front-LH open/short
C1201 (ABS) Wheel speed sensor front-LH range / performance / intermittent
C1201 (ESP) Wheel speed sensor front-LH range / performance / intermittent
C1202 (ABS) Wheel speed sensor front-LH invalid/no signal
C1202 (ESP) Wheel speed sensor front-LH invalid/no signal
C1203 (ABS) Wheel speed sensor front-RH open/short
C1203 (ESP) Wheel speed sensor front-RH open/short
C1204 (ABS) Wheel speed sensor front-RH range / performance / intermittent
C1204 (ESP) Wheel speed sensor front-RH range / performance / intermittent
C1205 (ABS) Wheel speed sensor front-RH invalid/no signal
C1205 (ESP) Wheel speed sensor front-RH invalid/no signal
C1206 (ABS) Wheel speed sensor rear-LH open/short
C1206 (ESP) Wheel speed sensor rear-LH open/short
C1207 (ABS) Wheel speed sensor rear-LH range / performance / intermittent
C1207 (ESP) Wheel speed sensor rear-LH range / performance / intermittent
C1208 (ABS) Wheel speed sensor rear-LH invalid/no signal
C1208 (ESP) Wheel speed sensor rear-LH invalid/no signal
C1209 (ABS) Wheel speed sensor rear-RH open/short
C1209 (ESP) Wheel speed sensor rear-RH open/short
C1210 (ABS) Wheel speed sensor rear-RH range / performance / intermittent
C1210 (ESP) Wheel speed sensor rear-RH range / performance / intermittent
C1211 (ABS) Wheel speed sensor rear-RH invalid/no signal
C1211 (ESP) Wheel speed sensor rear-RH invalid/no signal
C1235 (ESP) Primary pressure sensor - electrical
C1237 (ESP) Primary pressure sensor - signal
C1259 (ESP) Steering sensor - electrical
C1260 (ESP) Steering sensor circuit - signal
C1282 (ESP) Yaw rate and lateral G sensor - electrical
C1283 (ESP) Yaw rate and lateral G sensor - signal
C1503 (ESP) ESP switch error
C1513 (ESP) Brake switch error
C1604 (ABS) ECU Hardware Error
C1604 (ESP) ECU Hardware Error
C1605 (ESP) CAN Hardware Error
C1611 (ESP) CAN time-out EMS
C1612 (ESP) CAN time-out TCU
C1613 (ESP) CAN wrong message
C1616 (ESP) CAN bus off
C2112 (ABS) Valve relay error
C2112 (ESP) Valve relay error
C2227 (ESP) Excessive temperature of brake disc
C2380 (ABS) ABS/TCS/ESP valve error
C2380 (ESP) ABS/TCS/ESP valve error
C2402 (ABS) Motor electrical
C2402 (ESP) Motor electrical
G 2.7 DOHC > Engine > Unleaded EOBD
P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0037 HO2S Heater Circuit low (Bank 1 / Sensor 2)
P0038 HO2S Heater Circuit high (Bank 1 / Sensor 2)
P0051 HO2S Heater Circuit low (Bank 2 / Sensor 1)
P0052 HO2S Heater Circuit high (Bank 2 / Sensor 1)
P0057 HO2S Heater Circuit low (Bank 2 / Sensor 2)
P0058 HO2S Heater Circuit high (Bank 2 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High(Bank 1)
P0082 Intake Valve Control Solenoid Circuit Low(Bank 2)
P0083 Intake Valve Control Solenoid Circuit High(Bank 2)
P0110 Intake Air Temperature Sensor1 Circuit
P0111 Intake Air Temperature Sensor1 Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0133 O2-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
P0135 O2 Sensor Heater Circuit (Bank 1 / Sensor 1)
P0141 O2 Sensor Heater Circuit (Bank 1 / Sensor 2)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 1)
P0155 O2 Sensor Heater Circuit (Bank 2 / Sensor 1)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 / Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 / Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 2)
P0161 O2 Sensor Heater Circuit (Bank 2 / Sensor 2)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0196 Engine Oil Temp. Sensor Range / Performance
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0217 Engine Coolant Over Temperature Condition
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0273 Cylinder 5 - Injector Circuit Low
P0274 Cylinder 5 - Injector Circuit High
P0276 Cylinder 6 - Injector Circuit Low
P0277 Cylinder 6 - Injector Circuit High
P0305 Cylinder 5 - Misfire detected
P0306 Cylinder 6 - Misfire detected
P0315 Segment Time Acquisition Incorrect
P0325 Knock Sensor 1 Circuit
P0330 Knock Sensor 2 Circuit
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0340 Camshaft Position Sensor A Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or Single Sensor)
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0351 Ignition Coil A Primary / Secondary Circuit
P0352 Ignition Coil B Primary / Secondary Circuit
P0353 Ignition Coil C Primary / Secondary Circuit
P0354 Ignition Coil D Primary / Secondary Circuit
P0355 Ignition Coil E Primary / Secondary Circuit
P0356 Ignition Coil F Primary / Secondary Circuit
P0430 Catalyst System Efficiency below Threshold (Bank 2)
P0444 Evap. Emission System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission System - Purge Ctrl. Valve Circuit Shorted
P0506 Idle Air Control System - RPM lower than expected
P0507 Idle Air Control System - RPM higher than expected
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control ON Signal
P0566 Cruise Control CANCEL Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0571 Brake Switch A Circuit
P0601 EEPROM - Check Sum Error
P0602 EEPROM - Programing Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0606 ECM/PCM Processor(ECU-SELF TEST Failed)
P0638 Throttle Actuator Control Range/Performance
P0641 Sensor Reference Voltage A Circuit/Open
P0651 Sensor Reference Voltage B Circuit/Open
P0660 Intake Manifold Tuning Valve Control Circuit/Open (Bank 1)
P0661 Intake Manifold Tuning Valve Control Circuit/Open (Bank 2)
P1106 Manifold Absolute Pressure Sensor Circuit Short - Intermittent High Input
P1107 Manifold Absolute Pressure Sensor Circuit Short - Intermittent Low Input
P1111 Intake Air Temperature Sensor Circuit Intermittent Low Input
P1112 Intake Air Temperature Sensor Circuit Intermittent High Input
P1114 Engine Coolant Temperature Sensor Circuit Intermittent Low Input
P1115 Engine Coolant Temperature Sensor Circuit - Intermittent High Input
P1295 ETC (Electronic Throttle Control) System Malfunction - Power Management
P1523 ETC (Electronic Throttle Control) System Malfunction - Throttle Valve Stuck
P2104 ETC (Electronic Throttle Control) System Malfunction - Forced Idle
P2105 ETC (Electronic Throttle Control) System Malfunction - Forced Engine Shutdown
P2106 ETC (Electronic Throttle Control) System Malfunction - Forced Limited Power
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
P2135 Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
P2173 ETC (Electronic Throttle Control) System Malfunction - High Air flow Detected
P2187 System Too Lean at Idle (Bank 1)
P2188 System Too Rich at Idle (Bank 1)
P2189 System Too Lean at Idle (Bank 2)
P2190 System Too Rich at Idle (Bank 2)
P2195 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
P2196 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
P2197 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 1)
P2198 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 1)
P2270 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 2)
P2271 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 2)
P2272 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 2)
P2273 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 2)
P2610 ECM/PCM Internal Engine Off Timer Performance
U0001 CAN Communication BUS Off
Отправлено 19 April 2021 - 14:22
G 2.7 DOHC > Immobilizer > Immobilizer
P1610 Non-Immobilizer-EMS connected to an Immobilizer
P1674 Transponder Status Error
P1675 Transponder Programming Error
P1676 SMARTRA Message Error
P1690 SMARTRA No Response
P1691 Antenna Coil Error
P1692 Immobilizer Lamp error
P1693 Transponder no Response Error / Invalid Response
P1694 EMS Message Error
P1695 EMS Memory Error
P1696 Authentication Fail
P1699 Twice Overtrial
G 2.7 DOHC > Transmission > Automatic Transaxle
P0722 AT Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0742 Torque Converter Clutch Stuck On
P0748 VFS Solenoid Valve Circuit - Open or Short(GND)
P0770 Reduction Solenoid Valve Circuit - Open or Short(GND)
P0885 A/T Control Relay Malfalfunction
P0890 TCM Power Relay Sense Circuit Low
P0891 TCM Power Relay Sense Circuit High
