Киа Маджентис 2 MG
Сообщений в теме: 14
Отправлено 19 April 2021 - 14:19
G 2.0 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1208 Intake potentiometer open (Low)
B1209 Intake potentiometer short (High)
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B1257 AQS sensor open (High)
B1258 AQS sensor short (Low)
B1259 AQS sensor fault
B2406 Air mix motor (Driver)
B2408 Intake motor
B2409 Direction control motor (Driver)
Отправлено 19 April 2021 - 14:20
B1101 Battery voltage high
B1102 Battery voltage low
B1338 Front Impact Sensor (FIS) - Center Defect
B1339 Front Impact Sensor (FIS) - Center Communication Error
B1400 SIS front-Driver defect
B1412 SIS rear-Driver communication error
B1413 SIS rear-Passenger communication error
B1418 SIS rear-Driver defect
B1419 SIS rear-Passenger defect
B1527 Passenger airbag deactivation switch open or short to Battery
B1528 Passenger airbag deactivation switch short or short to Ground
B1529 Passenger airbag deactivation switch defect
B1530 Passenger airbag deactivation switch instability
B2503 Warning lamp open or short to ground
B2504 Warning lamp short or short to battery
B2507 Passenger airbag Telltale lamp open or short to ground
B2508 Passenger airbag Telltale lamp short or short to battery
G 2.0 DOHC > Brake > Anti-Lock Brake
C1101 (ABS) Battery voltage high
C1101 (ESP) Battery voltage high
C1102 (ABS) Battery voltage low
C1102 (ESP) Battery voltage low
C1112 (ESP) Sensor power voltage
C1200 (ABS) Wheel speed sensor front-LH open/short
C1200 (ESP) Wheel speed sensor front-LH open/short
C1201 (ABS) Wheel speed sensor front-LH range / performance / intermittent
C1201 (ESP) Wheel speed sensor front-LH range / performance / intermittent
C1202 (ABS) Wheel speed sensor front-LH invalid/no signal
C1202 (ESP) Wheel speed sensor front-LH invalid/no signal
C1203 (ABS) Wheel speed sensor front-RH open/short
C1203 (ESP) Wheel speed sensor front-RH open/short
C1204 (ABS) Wheel speed sensor front-RH range / performance / intermittent
C1204 (ESP) Wheel speed sensor front-RH range / performance / intermittent
C1205 (ABS) Wheel speed sensor front-RH invalid/no signal
C1205 (ESP) Wheel speed sensor front-RH invalid/no signal
C1206 (ABS) Wheel speed sensor rear-LH open/short
C1206 (ESP) Wheel speed sensor rear-LH open/short
C1207 (ABS) Wheel speed sensor rear-LH range / performance / intermittent
C1207 (ESP) Wheel speed sensor rear-LH range / performance / intermittent
C1208 (ABS) Wheel speed sensor rear-LH invalid/no signal
C1208 (ESP) Wheel speed sensor rear-LH invalid/no signal
C1209 (ABS) Wheel speed sensor rear-RH open/short
C1209 (ESP) Wheel speed sensor rear-RH open/short
C1210 (ABS) Wheel speed sensor rear-RH range / performance / intermittent
C1210 (ESP) Wheel speed sensor rear-RH range / performance / intermittent
C1211 (ABS) Wheel speed sensor rear-RH invalid/no signal
C1211 (ESP) Wheel speed sensor rear-RH invalid/no signal
C1235 (ESP) Primary pressure sensor - electrical
C1237 (ESP) Primary pressure sensor - signal
C1259 (ESP) Steering sensor - electrical
C1260 (ESP) Steering sensor circuit - signal
C1282 (ESP) Yaw rate and lateral G sensor - electrical
C1283 (ESP) Yaw rate and lateral G sensor - signal
C1503 (ESP) ESP switch error
C1513 (ESP) Brake switch error
C1604 (ABS) ECU Hardware Error
C1604 (ESP) ECU Hardware Error
C1605 (ESP) CAN Hardware Error
C1611 (ESP) CAN time-out EMS
C1612 (ESP) CAN time-out TCU
C1613 (ESP) CAN wrong message
C1616 (ESP) CAN bus off
C2112 (ABS) Valve relay error
C2112 (ESP) Valve relay error
C2227 (ESP) Excessive temperature of brake disc
C2380 (ABS) ABS/TCS/ESP valve error
C2380 (ESP) ABS/TCS/ESP valve error
C2402 (ABS) Motor electrical
C2402 (ESP) Motor electrical
G 2.0 DOHC > Engine > Unleaded EOBD
P0011 Camshaft Position-Timing Over-Advanced or System Performance(Bank 1)
P0016 Crankshaft Position-Camshaft Position Correlation(Bank 1)
P0030 O2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 1)
P0031 O2 Sensor Heater Circuit low (Bank 1 / Sensor 1)
P0032 O2 Sensor Heater Circuit high (Bank 1 / Sensor 1)
P0036 O2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 2)
P0037 O2 Sensor Heater Circuit low (Bank 1 / Sensor 2)
P0038 O2 Sensor Heater Circuit high (Bank 1 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low (Bank1)
P0077 Intake Valve Control Solenoid Circuit High (Bank1)
P0101 Mass or Volume Air Flow Circuit Range / Performance Problem
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0121 Throttle / Pedal Position Circuit Range/Performance Problem
P0122 Throttle / Pedal Position Circuit Low Input
P0123 Throttle / Pedal Position Circuit High Input
P0130 O2 Sensor Circuit (Bank 1 / Sensor 1)
P0131 O2 Sensor Circuit Low Input(Bank 1 / Sensor 1)
P0132 O2 Sensor Circuit High Input(Bank 1 / Sensor 1)
P0133 O2-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 / Sensor 2)
P0137 O2 Sensor Circuit Low Input (Bank 1 / Sensor 2)
P0138 O2 Sensor Circuit High Input (Bank 1 / Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 2)
P0170 O2 Sensor System - Lambda Controller at the Limit (Bank 1)
P0196 Engine Oil Temp. Sensor Range / Performance
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0230 Fuel Pump Circuit Malfunction
P0300 Multiple Cylinder Misfire Detected
P0315 Segment Time Acquisition Incorrect
P0325 Knock Sensor 1 Circuit Malfunction
P0335 Crankshaft Position Sensor Circuit Malfunction
P0336 Crankshaft Position Sensor Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Malfunction
P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted
P0506 Idle Control system- RPM lower than expected
P0507 Idle Control System RPM Higher than Expected
P0551 Power Steering Switch Circuit Malfunction
P0560 System Voltage Malfunction
P0562 System Voltage Low
P0563 System Voltage High
P0600 Serial Communication Link Malfunction
P0625 Generator Field/F Terminal Circuit Low Input
P0626 Generator Field/F Terminal Circuit High Input
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit Low
P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction
P0700 TCU Request for MIL On/Freeze Frame to ECU via CAN
P1505 Idle Charge Actuator Signal Low of Coil #1
P1506 Idle Charge Actuator Signal High of Coil #1
P1507 Idle Charge Actuator Signal Low of Coil #2
P1508 Idle Charge Actuator Signal High of Coil #2
P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
P2097 Post Catalyst Fuel Trim System Too Rich Bank 1
P2159 Vehicle Speed Sensor B Range/Performance
P2187 System Too Lean at Idle(Additive) (Bank1)
P2188 System Too Rich at Idle (Bank1)
P2191 System Too Lean at Higher Load(Multiple) (Bank1)
P2192 System Too Rich at Higher Load (Bank1)
G 2.0 DOHC > Immobilizer > Immobilizer
P1610 Non-Immobilizer-EMS connected to an Immobilizer
P1674 Transponder Status Error
P1675 Transponder Programming Error
P1676 SMARTRA Message Error
P1690 SMARTRA No Response
P1691 Antenna Coil Error
P1692 Immobilizer Lamp error
P1693 Transponder no Response Error / Invalid Response
P1694 EMS Message Error
P1695 EMS Memory Error
P1696 Authentication Fail
P1699 Twice Overtrial
P0703 Stop Lamp Switch(Brake SW) - Short(B+)
P0721 AT Output Speed Sensor Fail
P0722 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0770 Reduction Solenoid Valve Circuit - Open or Short(GND)
U0100 NO ID FROM ECU
U0001 NO ID FROM ECU
P0885 A/T Control Relay Malfunction
G 2.4 DOHC > Air Conditioner > Air Conditioner
B2408 Intake motor
G 2.4 DOHC > Airbag > Airbag Control
G 2.4 DOHC > Brake > Anti-Lock Brake
Отправлено 19 April 2021 - 14:21
G 2.4 DOHC > Engine > Engine Control
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0638 Throttle Actuator Control Range/Performance
P0652 Sensor Reference Voltage B Circuit Low
P0653 Sensor Reference Voltage B Circuit High
P0698 Sensor Reference Voltage C Circuit Low
P0699 Sensor Reference Voltage C Circuit High
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2104 Throttle Actuator Control System-Forced Idle
P2105 Throttle Actuator Control System-Forced Engine Shutdown
P2106 Throttle Actuator Control System-Forced Limited Power
P2110 Throttle Actuator Control System-Forced Limited RPM
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
G 2.4 DOHC > Immobilizer > Immobilizer
G 2.4 DOHC > Transmission > Automatic Transaxle
