Киа Церато 1 LD
Сообщений в теме: 7
  • 24088 сообщений
Отправлено 22 March 2021 - 12:43
Коды ошибок Kia Cerato 1 (LD)
B1111 Battery voltage high
B1112 Battery voltage low
B1383 Side airbag front-Passenser resistance too Low
B1384 Side airbag front-Passenser resistance short to Ground
B1400 SIS front-Driver defect
B1412 SIS rear-Driver communication error
B1413 SIS rear-Passenger communication error
B1418 SIS rear-Driver defect
B1419 SIS rear-Passenger defect
B1527 Passenger airbag deactivation switch open or short to Battery
B1528 Passenger airbag deactivation switch short or short to Ground
B1529 Passenger airbag deactivation switch defect
B1530 Passenger airbag deactivation switch instability
B2503 Warning lamp open or short to ground
B2504 Warning lamp short or short to battery
B2507 PAD Indicator or Telltale lamp open or short to ground
B2508 PAD Indicator or Telltale lamp short or short to battery
  • 24088 сообщений
G 2.0 DOHC > Brake > Anti-Lock Brake
C1101 Battery voltage over volt
C1102 Battery voltage low volt
C1200 Wheel speed sensor front-LH open/short
C1201 Wheel speed sensor front-LH range/performance/intermittent
C1202 Wheel speed sensor front-LH invalid/no signal
C1203 Wheel speed sensor front-RH open/short
C1204 Wheel speed sensor front-RH range/performance/intermittent
C1205 Wheel speed sensor front-RH invalid/no signal
C1206 Wheel speed sensor rear-LH open/short
C1207 Wheel speed sensor rear-LH range/performance/intermittent
C1208 Wheel speed sensor rear-LH invalid/no signal
C1209 Wheel speed sensor rear-RH open/short
C1210 Wheel speed sensor rear-RH range/performance/intermittent
C1211 Wheel speed sensor rear-RH invalid/no signal
C1503 TCS Switch Failure
C1604 ECU Hardware Error
C1605 ECU Hardware Error
C1611 ECU Hardware Error
C1612 ECU Hardware Error
C1613 ECU Hardware Error
C1616 CAN Bus off failure
C2112 Valve relay error
C2227 Brake disc overheat
C2380 ABS valve error
C2402 Motor electrical
  • 24088 сообщений
Отправлено 22 March 2021 - 12:44
G 2.0 DOHC > Engine > Unleaded GEN
P0011 Camshaft Position-Timing Over-Advanced or System Performance(Bank 1)
P0016 Crankshaft Position-Camshaft Position Correlation(Bank 1)
P0030 O2 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Circuit low (Bank 1 Sensor 1)
P0032 HO2S Heater Circuit high (Bank 1 Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Circuit low (Bank 1 Sensor 2)
P0038 HO2S Heater Circuit high (Bank 1 Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low
P0077 Intake Valve Control Solenoid Circuit High
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0121 Throttle / Pedal Position Circuit Range/Performance Problem
P0122 Throttle / Pedal Position Circuit Low Input
P0123 Throttle / Pedal Position Circuit High Input
P0130 HO2S Sensor Circuit (Bank 1 / Sensor 1)
P0131 HO2S Sensor Circuit Low Input(Bank 1 / Sensor 1)
P0132 HO2S Sensor Circuit High Input(Bank 1 / Sensor 1)
P0133 HO2S-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 HO2S Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
P0136 HO2S Sensor Circuit Malfunction (Bank 1 / Sensor 2)
P0137 HO2S Sensor Circuit Low Input (Bank 1 / Sensor 2)
P0138 HO2S Sensor Circuit High Input (Bank 1 / Sensor 2)
P0139 HO2S Sensor Circuit Slow Response (Bank 1 / Sensor 2)
P0140 HO2S Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P0170 HO2S Sensor System - Lambda Controller at the Limit (Bank 1)
P0171 System Too Rich (Bank 1)
P0172 System Too Rich (Bank 1)
P0196 Engine Oil Temp. Sensor Range / Performance
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0230 Fuel Pump Circuit Malfunction
P0300 Multiple Cylinder Misfire Detected
P0315 Segment Time Acquisition Incorrect
P0325 Knock Sensor 1 Circuit Malfunction
P0335 Crankshaft Position Sensor Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction
P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted
P0501 Vehicle Speed Sensor B Range/Performance
P0506 Idle Control system- RPM lower than expected
P0507 Idle Control System RPM Higher than Expected
P0560 System Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0625 Generator Field/F Terminal Circuit Low Input
P0626 Generator Field/F Terminal Circuit High Input
P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction
P0700 TCU Request for MIL On/Freeze Frame to ECU via CAN
P1505 Idle Charge Actuator Signal Low of Coil #1
P1506 Idle Charge Actuator Signal High of Coil #1
P1507 Idle Charge Actuator Signal Low of Coil #2
P1508 Idle Charge Actuator Signal High of Coil #2
U0001 High Speed CAN Communication Bus
U0101 Lost Communication with TCM
  • 24088 сообщений
G 2.0 DOHC > Immobilizer > Immobilizer
P1610 Non-Immobilizer-EMS connected to an Immobilizer
P1674 Transponder status error
P1675 Transponder programming error
P1676 SMARTRA message error
P1690 SMARTRA no response
P1691 Antenna coil error
P1692 Lamp error
P1693 Transponder no response error / Invalid response
P1694 EMS message error
P1695 EMS message error
P1696 Authentication fail
P1697 HI-SCAN MESSAGE ERROR
P1699 Twice overtrial
P0712 Transaxle Fluid Temperature Sensor Circuit Low Circuit
P0713 Transaxle Fluid Temperature Sensor Circuit High Circuit
P0716 A/T Input Speed Sensor Rationality
P0717 A/T Input speed Sensor Circuit Low Input
P0722 A/T Output speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0741 Damper Clutch Open Stuck
P0742 Damper Clutch Close Stuck
P0743 Damper Clutch Control Solenoid Valve : Open or Short(GND)
P0748 VF Solenoid Valve Circuit - Open or Short(GND)
P0750 Shift Control Solenoid Valve-A Circuit - Open or Short(GND)
P0755 Shift Control Solenoid Valve-B Circuit - Open or Short(GND)
P0760 Shift Control Solenoid Valve-C Circuit - Open or Short(GND)
P0765 PCSV-C(UD) Solenoid Valve Circuit - Open or Short(GND)
P0880 TCM Power Signal Error
U0001 Can Communication BUS Off
U0100 No ID From ECU
P0605 Check SUM Error
  • 24088 сообщений
G 1.6 DOHC > Airbag > Airbag Control
  • 24088 сообщений
G 1.6 DOHC > Brake > Anti-Lock Brake
  • 24088 сообщений
G 1.6 DOHC > Engine > Unleaded GEN
P0011 A Camshaft Position-Timing Over-Advanced or System Performance
P0012 A Camshaft Position-Timing Over-Retarded
P0016 Crankshaft Position-Camshaft Position Correlatioin
P0030 HO2S Heater Control Circuit (Sensor 1)
P0031 HO2S Heater Circuit Low (Sensor1)
P0032 HO2S Heater Circuit High (Sensor1)
P0036 HO2S Heater Control Circuit (Sensor2)
P0037 HO2S Heater Circuit Low(Sensor2)
P0038 HO2S Heater Circuit High(Sensor2)
P0068 MAP/MAF-Throttle Position Correlation
P0075 Intake Valve Control Solenoid Circuit
P0116 Engine Coolant Temperature Circuit Range/Performance
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittant
P0130 O2 Sensor Circuit(Sensor1)
P0131 O2 Sensor Circuit Low Voltage (Sensor1)
P0132 O2 Sensor Circuit High Voltage (Sensor1)
P0133 O2 Sensor Circuit Slow Response (Sensor1)
P0134 O2 Sensor Circuit No Activity Detected (Sensor 1)
P0135 HO2S Heater Control Circuit (Sensor 1)
P0136 O2 Sensor Circuit (Sensor 2)
P0137 O2 Sensor Circuit Low Voltage(Sensor 2)
P0138 O2 Sensor Circuit High Voltage(Sensor 2)
P0139 O2 Sensor Circuit Slow Response(Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Sensor 2)
P0141 O2 Sensor Heater Circuit (Sensor 2)
P0171 System Too Lean
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0261 Cylinder 1-Injector Circuit Low
P0262 Cylinder 1-Injector Circuit High
P0264 Cylinder 2-Injector Circuit Low
P0265 Cylinder 2-Injector Circuit High
P0267 Cylinder 3-Injector Circuit Low
P0268 Cylinder 3-Injector Circuit High
P0270 Cylinder 4-Injector Circuit Low
P0271 Cylinder 4-Injector Circuit High
P0301 Cylinder 1-Misfire Detected
P0302 Cylinder 2-Misfire Detected
P0303 Cylinder 3-Misfire Detected
P0304 Cylinder 4-Misfire Detected
P0326 Knock Sensor 1 Circuit Range/Performance
P0327 Knock Sensor 1 Circuit Low Input
P0328 Knock Sensor 1 Circuit High Input
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit
P0340 Camshaft Position Sensor A Circuit Malfunction (Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance(Single Sensor)
P0342 Camshaft Position Sensor A Circuit Low Input
P0343 Camshaft Position Sensor A Circuit High Input
P0420 Catalyst System Efficiency below Threshold (Bank1)
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0506 Idle Air Control System - RPM lower than expected
P0507 Idle Air Control System - RPM higher than expected
P0561 System Voltage Unstable
P0605 Internal Control Module Read Only Memory (ROM) Error
P1550 Knock sensor evaluation IC
P1560 Knock control SPI check
P2096 Post Catalyst Fuel Trim System Too Lean
P2097 Post Catalyst Fuel Trim System Too Rich
P2232 O2 Sensor Signal Circuit Shorted to Heater Circuit (Sensor 2)
U0001 CAN Communication Malfunction
U0101 ECM-TCM CAN Error
  • 24088 сообщений
Отправлено 22 March 2021 - 12:45
G 1.6 DOHC > Immobilizer > Immobilizer
P1692 Lamp error
G 1.6 DOHC > Transmission > Automatic Transaxle
