Киа Спектра SD
Отправлено 16 March 2021 - 15:32
Коды ошибок Kia Spectra (SD)
G 1.6 DOHC > Engine > Unleaded(IMMO-)
P0100 Mass or Volume Air Flow Circuit
P0110 Intake Air Temperature Sensor 1 Circuit
P0111 Intake Air Temperature(IAT) Circuit Range/Performance
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0121 Throttle Position Sensor(TPS) Range/Performance
P0131 Heated O2 Sensor(HO2S) Circuit Low Input(B1/S1)
P0132 Heated O2 Sensor(HO2S) Circuit High Input(B1/S1)
P0135 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0137 Heated O2 Sensor(HO2S) Circuit Low Input(B1/S2)
P0138 Heated O2 Sensor(HO2S) Circuit High Input(B1/S2)
P0141 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0170 Fuel Trim (Bank 1)
P0172 System too Rich (Bank 1)
P0301 Cylinder 1 MISFIRE
P0302 Cylinder 2 MISFIRE
P0303 Cylinder 3 MISFIRE
P0304 Cylinder 4 MISFIRE
P0326 Knock Sensor Circuit Range/Performance(B1)
P0336 Crankshaft Position(CKP) Sensor Range/Performance
P0422 Main Catalyst System Efficiency below (Bank 1)
P0443 Evaporative Emission System-Purge Control Valve Circuit
P0507 Idle Control System RPM Higher Than Expected
P0562 System Voltage Low
P0563 System Voltage High
P0601 Internal Control Module Memory Check Sum Error
P1307 Acceleration Sensor-Range / Performance
P1308 Chassis Acceleration Sensor Low Input
P1309 Chassis Acceleration Sensor High Input
P1386 Knock Circuit Error
P1505 Idle Speed Control Actuator Circuit 1-Low
P1506 Idle Speed Control Actuator Circuit 1-High
P1507 Idle Speed Control Actuator Circuit 2-Low
P1508 Idle Speed Control Actuator Circuit 2-High
P1586 M/T-A/T Encoding Signal Malfunction
P1693 TCM Malfunction Indicator Lamp (MIL) Request Line Malfunction
P1610 Smartra Unit (No Answer or Invalid Message From Smartra)
P1801 Smartra Transponder Malfunction or Invalid Data
P1802 Smartra Unit(Antenna Malfunction)
P1803 Smartra Unit(Invalid Request)
P1805 Control Unit Deffective Or ECM Fault
P0105 Manifold Absolute Pressure (MAP) Sensor Circuit Malfunction
P1780 Torque Reduction Request Signal (TCU-ECU)
P1800 Engine Torque Signal Malfunction
