G 1.8 DOHC > Immobilizer > Immobilizer
P1611 Communication Error(ECM - ICU)
P1612 Checksum message wrong
P1613 Implausible bytes from ICU
P1614 ECU status error
G 1.8 DOHC > Transmission > Automatic Transaxle
P0713 Fluid(Oil) Temperature Circuit High
P0717 Input/Turbine Speed Sensor No Signal
P0727 Eng. Speed Input Circuit No Signal
P0748 Pressure Control Solenoid "A" Electrical
P0753 Shift Control Solenoid Valve "A"-Electrical
P0758 Shift Control Solenoid Valve " B" Electrical
P0763 Shift Control Solenoid Valve "C" Electrical
P1121 Throttle Position Sensor (TPS) Signal Malfunction
P1500 Vehicle Speed Sensor Signal Circuit Malfunction
P1800 Engine Torque Signal(ECM)
P0703 Stop Lamp (Brake) Switch Circuit Malfunction
P0707 Transmission Range Sensor Circuit Low Input
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Gear Incorrect Ratio
P0741 Torque Converter Clutch Circuit Stuck Off
P0750 Shift Control Solenoid Valve "A"
P0716 Input/Turbine Speed Sensor "A" Circuit Range/Performance
P0726 Engine Speed Input Circuit Range/Performance
P1700 Over Drvier(O/D) Lamp / Hold Lamp Circuit Malfunction
P1780 Torque Reduction Request Signal (TCU-ECU)
P0605 Internal Control Module Read only Memory(ROM) Error
P0710 Transmission Fluid Temperature Sensor A Circuit
P0715 Input/Turbine Speed Sensor "A" Circuit
P0720 Output Speed Sensor (Pulse Generator B) Circuit
P1723 TCM Power Relay Control Circuit/Open
#11
Отправлено 10 February 2021 - 16:31
Re: коды ошибок, расшифровка
D 2.0 TCI > Airbag > Airbag Control
B1101 Battery Voltage Too High
B1102 Battery Voltage Too Low
B1345 Driver Air Bag Open
B1346 Driver Air Bag Resistance Too high
B1347 Driver Air Bag Resistance Too Low
B1351 Passenger Air Bag Open
B1352 Passenger Air Bag Resistance Too Low
B1353 Passenger Air Bag Resistance Too High
B1360 Pretensioner Froun-LH Open
B1361 Driver Seat Belt Pretensioner Resistance Too High or Open
B1362 Driver Seat Belt Pretensioner Resistance Too Low or Ghort
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1366 Pretensioner Front -RH Open
B1367 Pretensioner Front -RH Resistance Too High
B1368 Pretensioner Front -RH Resistance Too Low
B1369 Passenger Seat Belt Pretensioner Short To Ground
B1370 Passenger Seat Belt Pretensioner Short To Battery
B1377 Side Air Bag Front-LH Open
B1378 Side Air Bag Front-LH Resistance Too High
B1379 Side Air Bag Front-LH Resistance Too Low
B1382 Side Air Bag Front-RH Resistance to High
B1383 Side Air Bag Front-RH Resistance to Low
B1384 Side Air Bag Front-RH Resistance Circuit Shorted To Ground
B1385 Side Air Bag Front-RH Resistance Circuit Shorted To Battery
B1386 Side Air Bag Front-RH Open
B1395 Squib Interconnection Fault
B1400 SIS(Side Impact Sensor) Front-Driver Defect
B1401 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B1403 Satellite Front-RH Defect
B1404 Satellite Front-RH Circuit Shorted to Ground
B1405 Satellite Front-RH Circuit Shorted to Battery
B1409 Satellite Front-LH Communication Error
B1410 Satellite Front-RH Communication Error
B1414 Wrong Satellite Front-LH
B1415 Wrong Satellite Front-RH
B1610 K-Line Fault
B1620 Internal Fault
B1623 Crash Output Error
B1624 Crash Output Short to Ground
B1625 Crash Output Short to Vbatt
B1650 Crash Recorded(Frontal - Replace ECU)
B1651 Crash Recorded Side Airbag Front-LH
B1652 Crash Recorded Side Airbag Front-RH
B1655 Crash Recorded(Side - Replace ECU)
B1656 Fault Memory Full
B1657 Crash Recorded - Belt Pretensioner Only
B1658 Belt Pretensioner 6 Times Deployment
B1660 Crash Recorded Driver Airbag
B1661 Parameter Fault Missing
B1662 Crash Recorded Driver Belt Pretensioner
B1663 Crash Recorded Passenger AirBag
B1664 Crash Recorded Passenger Belt Pretensioner
B1670 Crash Recorded - Full Stage
B2503 Warning Lamp Open or Short to Ground
B2504 Warning Lamp Short or Short to Battery
D 2.0 TCI > Brake > Anti-Lock Brake
C1101 Battery Voltage High
C1102 Battery Voltage Low Volt
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/No Signal
C1203 FR Wheel Sensor - Open or Short to GND/Battery
C1204 FR Wheel Sensor - Range/Performance
C1205 FR Wheel Sensor - No Signal
C1206 RL Wheel Sensor - Open or Short to GND/Battery
C1207 RL Wheel Sensor - Range/Performance
C1208 RL Wheel Sensor - No Signal
C1209 RR Wheel Sensor - Open or Short to GND/Battery
C1210 RR Wheel Sensor Range/Performance
C1211 RR Wheel Sensor - No Signal
C1604 ECU(Brake System) Hardware error
C2112 Valve Relay Error
C2402 Motor Electrical
D 2.0 TCI > Engine > Engine Control
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0047 VGT Vacuum Modulator Circuit Low
P0048 VGT Vacuum Modulator Circuit High
P0069 Boost Pressure Sensor Circuit Malfunction
P0087 Rail Pressure Monitoring-Minimum Pressure at Engine Speed too Low
P0088 Rail Pressure Monitoring-Maximum Pressure Exceeded
P0089 Rail Pressure Regulator Valve Circuit Over Current
P0091 Rail Pressure Regulator Valve Circuit Low
P0092 Rail Pressure Regulator Valve Circuit High
P0097 Intake Air Temperature Sensor 2 Circuit Low Input
P0098 Intake Air Temperature Sensor 2 Circuit High Input
P0103 Mass or Volume Air Flow Circuit High Input
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0231 Fuel Pump Circuit-Low Input
P0232 Fuel Pump Circuit-High Input
P0234 Turbo/Super Charger Overboost Condition
P0237 Boost Pressure Sensor Circuit High Input
P0238 Boost Pressure Sensor Circuit Low Input
P0252 Fuel Pressure Regulator Valve Circuit Over Current
P0253 Fuel Pressure Regulator Valve Circuit Low
P0254 Fuel Pressure Regulator Valve Circuit High
P0299 Turbo/Super Charger Underboost
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1)
P0381 Glow Plug/Heater Indicator Circuit
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0472 Differential Pressure Sensor Low
P0473 Differential Pressure Sensor High
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0504 Brake Switch "A" / "B" Correlation
P0545 Exhaust Gas TEMP. Sensor Circuit Low (Bank 1 Sensor 1)
P0546 Exhaust Gas TEMP. Sensor Circuit High (Bank 1 Sensor 1)
P0562 System Voltage Low
P0563 System Voltage High
P0602 Control Module Programming Error
P0606 ECM/PCM Processor
P0611 Injector Circuit Malfunction (More than Two Injectors)
P0642 Sensor Reference Voltage "A" Circuit Low
P0643 Sensor Reference Voltage "A" Circuit High
P0652 Sensor Reference Voltage "A" Circuit Low
P0653 Sensor Reference Voltage "B" Circuit High
P0670 Glow Relay Circuit Malfunction
P0698 Sensor Reference Voltage C Circuit Low
P0699 Sensor Reference Voltage C Circuit High
P0820 Neutral S/W Malfunction
P0830 Clutch S/W Malfunction
P1145 Overrun Monitoring Error
P1171 Minimum Rail Pressure Exceeded (Diesel)
P1172 Maximum Rail Pressure Exceeded (Diesel)
P1173 Set Value of Rail Pressure Not In Plausibility Range (Diesel)
P1185 Fuel Pressure Monitoring - Excessive
P1186 Fuel Pressure Monitoring - too Low
P1403 Differential Pressure not Plausible (Hose Line Grozen) (Diesel)
P1405 CPF-Permanent Regeneration
P1406 Exhaust Gas Temperature not Plausible between Calculated and Simulated
P1407 Plausibility of Temperature Calculated and Simulated Upstream of Particulate Filter
P1586 M/T-A/T Encoding Signal Malfunction
P1587 CAN communication Error (MT/AT Recognition Error)
P1588 Signal Change through MT/AT Line (During Engine Running)
P1634 Auxiliary Heater Relay Short or Open
P1652 Ignition Switch Malfunction
P1670 Injector Classification-Invalid
P1671 Injector Classification-Write Error
P2002 Particulate Trap Efficiency below Threshold
P2009 Intake Manifold Runner Control Circuit Low(Bank 1)
P2010 Intake Manifold Runner Control Circuit High(Bank 1)
P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance(Bank 1)
P2016 Intake Manifold Runner Position Sensor/Switch Circuit Low(Bank 1)
P2017 Intake Manifold Runner Position Sensor/Switch Circuit High(Bank 1)
P2030 Exhaust Temperature Value not Plausible with Sensor 1 and 2
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 / Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 / Sensor 2)
P2111 Throttle Actuator Control Module Performance //Throttle Actuator Control System-Stuck Open
P2112 Throttle Actuator Control System Stuck Closed
P2113 Throttle/Pedal Position Sensor 'B' Minimum Stop Performance
P2123 Accelerator Pedal Position Sensor Circuit High Input
P2128 Accelerator Pedal Position Sensor (APS) 2 Circuit High Input
P2238 HO2Sensor Pumping Current Circuit Low (Bank 1 / Sensor 1)
P2239 HO2Sensor Pumping Current Circuit High (Bank 1 / Sensor 1)
P2251 HO2Sensor Reference Ground Circuit/Open (Bank 1 / Sensor 1)
P2264 Detected Water in Fuel Filter
P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
P1690 SMARTRA No Response
P1692 Immobilizer Lamp Error
P1693 Transponder No Reaponse Error/Invalid Response
P1695 EMS Memory Error
P1696 Immobilizer Authentication Error
P1697 HI-SCAN Message Error
P1698 Invalid TP(TP has different Vin)
Отправлено 10 February 2021 - 16:32
D 2.0 TCI > Transmission > Automatic Transaxle
Киа Каренс 1 FJ
Другие модели Киа →
Киа Каренс клуб →
Кузов и Салон Kia Carens →
потекла печкаАвтор Oleg60, 3 недель назад |
Киа Каренс 1 FJ
Другие модели Киа →
Киа Каренс клуб →
Электрика и Аудио Kia Carens →
сканерАвтор Oleg60, 31 Mar 2025 |
Киа Каренс 1 FJ
Другие модели Киа →
Киа Каренс клуб →
PTC HeaterАвтор Andrey 142, 23 Oct 2024 |
Киа Каренс 1 FJ
Другие модели Киа →
Киа Каренс клуб →
Двигатель и КПП Kia Carens →
радиатор кондиционераАвтор *dmi* , 11 May 2024 |
Киа Каренс 1 FJ
Другие модели Киа →
Киа Каренс клуб →
передняя панель (торпедо)Автор krionika, 12 May 2004 |
