Коды ошибок Kia Carens 1 (FJ)
B1101 Battery Voltage Too High
B1102 Battery Voltage Too Low
B1345 Driver Air Bag Open
B1346 Driver Air Bag Resistance Too high
B1347 Driver Air Bag Resistance Too Low
B1351 Passenger Air Bag Open
B1352 Passenger Air Bag Resistance Too Low
B1353 Passenger Air Bag Resistance Too High
B1360 Pretensioner Froun-LH Open
B1361 Driver Seat Belt Pretensioner Resistance Too High or Open
B1362 Driver Seat Belt Pretensioner Resistance Too Low or Ghort
B1363 Pretensioner Front-Driver Resistance Circuit Short to Ground
B1364 Pretensioner Front-Driver Resistance Circuit Short to Battery
B1366 Pretensioner Front -RH Open
B1367 Pretensioner Front -RH Resistance Too High
B1368 Pretensioner Front -RH Resistance Too Low
B1369 Passenger Seat Belt Pretensioner Short To Ground
B1370 Passenger Seat Belt Pretensioner Short To Battery
B1377 Side Air Bag Front-LH Open
B1378 Side Air Bag Front-LH Resistance Too High
B1379 Side Air Bag Front-LH Resistance Too Low
B1382 Side Air Bag Front-RH Resistance to High
B1383 Side Air Bag Front-RH Resistance to Low
B1384 Side Air Bag Front-RH Resistance Circuit Shorted To Ground
B1385 Side Air Bag Front-RH Resistance Circuit Shorted To Battery
B1386 Side Air Bag Front-RH Open
B1395 Squib Interconnection Fault
B1400 SIS(Side Impact Sensor) Front-Driver Defect
B1401 SIS(Side Impact Sensor) Front-Driver Circuit Short to Ground
B1402 SIS(Side Impact Sensor) Front-Driver Circuit Short to Battery
B1403 Satellite Front-RH Defect
B1404 Satellite Front-RH Circuit Shorted to Ground
B1405 Satellite Front-RH Circuit Shorted to Battery
B1409 Satellite Front-LH Communication Error
B1410 Satellite Front-RH Communication Error
B1414 Wrong Satellite Front-LH
B1415 Wrong Satellite Front-RH
B1610 K-Line Fault
B1620 Internal Fault
B1623 Crash Output Error
B1624 Crash Output Short to Ground
B1625 Crash Output Short to Vbatt
B1650 Crash Recorded(Frontal - Replace ECU)
B1651 Crash Recorded Side Airbag Front-LH
B1652 Crash Recorded Side Airbag Front-RH
B1655 Crash Recorded(Side - Replace ECU)
B1656 Fault Memory Full
B1657 Crash Recorded - Belt Pretensioner Only
B1658 Belt Pretensioner 6 Times Deployment
B1660 Crash Recorded Driver Airbag
B1661 Parameter Fault Missing
B1662 Crash Recorded Driver Belt Pretensioner
B1663 Crash Recorded Passenger AirBag
B1664 Crash Recorded Passenger Belt Pretensioner
B1670 Crash Recorded - Full Stage
B2503 Warning Lamp Open or Short to Ground
B2504 Warning Lamp Short or Short to Battery
