Киа Маджентис 2 MG
(MS) Передняя (приборная) панель
Сообщений в теме: 12
Отправлено 30 October 2015 - 16:21
11. Remove center panel. Прикрепленный файл  Untitled-1 copy.jpg   30.73К   0 Количество загрузок: (1) Remove five screws from center panel. (2) Disconnect electrical connector from rear of center panel.
#12 krionika Re: (MS) Передняя (приборная) панель
Отправлено 30 October 2015 - 16:22
12. Remove instrument panel. Прикрепленный файл  Untitled-1 copy.jpg   29.52К   0 Количество загрузок: (1) Remove two bolts from left side of instrument panel. (2) Remove two bolts from right side of instrument panel. (3) Remove two bolts from center of instrument panel. (4) Remove two mounting bolts from passenger airbag. (5) Disconnect electrical connector.
#13 krionika Re: (MS) Передняя (приборная) панель
Отправлено 30 October 2015 - 16:23
Installation 1. Install instrument panel. Прикрепленный файл  Untitled-1 copy.jpg   29.52К   0 Количество загрузок: (1) Mount instrument panel into position. Make sure steering column is mounted correctly through T-bar with electrical wire harness in position before attempting to position instrument panel in place. If this is not done, column cannot be positioned correctly. (2) Connect linking connectors between vehicle electrical wire harness and instrument panel. Each connector is keyed so an electrical harness connector mates with correct instrument panel connector. (3) Install two mounting bolts to passenger airbag. (4) Install two mounting bolts on center of instrument panel. (5) Install two mounting bolts on right side of instrument panel. (6) Install two bolts on left side of instrument panel.
