расшифровка VIN Kia, Hyundai
Сообщений в теме: 1887
#871 krionika
Отправлено 24 November 2014 - 15:05
Добрый день! Помогите расшифровать ВИН корейский- KNAFZ417BF5311372
На машинке КИА Церато
⊙ KNAFZ417BF5311372 - 2014/07/19 (RUSSIA) KEURPA712  K3 12         ENGINE : B24T(G4NAEH517694) T/M : U48P(EJERBH833520) SEAT : INTERIOR : WK (SATURN BLACK) EXTERIOR : MST (METAL STREAM) LEFT HAND DRIVE WEATHER - THE FRIGID ZONE SEDAN - 4DR 5P 2000 CC - NU DOHC - MPI GASOLINE - UNLEADED AUTO - 6 SPEED 2WD ALL AUDIO   S 0091A3  ENGINE PACKAGE - LOW POWER ENG S 0101B4  MODEL YEAR PACKAGE - 15MY S 2531A1  RAD CORE MATERIAL - RESISTANT CACL2 S 2841B6  EMISSION REGULATION - EURO 4 S 2843A3  EVAP. GAS CONTROL - ULEV S 2862A1  MUFFLER TAIL TRIM - SINGLE S 2911A1  UNDER COVER - W/ NOISE PAD S 2921A4  ENGINE COVER - FULL S 3111B1  FUEL TANK-CAPACITY - 50 LITER S 3116B3  FILLER NECK LABEL - RUSSIA S 3281A3  PEDAL TYPE - METAL PAD S 3283A1  FLOOR MTG TYPE S 371CA1  BATTERY SAVER S 3711A8  BATTERY CAPACITY - 60AH (20HR) S 4371B3  AT KNOB - LEATHER WRAPPED S 4503A2  SHIFT LOCK SYSTEM - ELECTRONIC TYPE S 4509A1  H-MATIC S 529AB1  TIRE PRESSURE LABEL - EUROPE S 529TA7  TOOL SET & JACK LABEL - EUROPE S 5291VA  AL WHEEL 7.0J * 17 - A TYPE S 5293G1  215 TIRE - 215/45 R17 S 5295A2  TIRE MATERIAL - SILICA S 5297A3  FULL SIZE 1EA - AL WHEEL & TIRE S 5411A1  FR SUSP TYPE - MACPH. W/COIL SPRING S 5412A2  S/ABSORBER TYPE - GAS S 5511A9  RR SUSP TYPE - TORSION AXLE S 5512A2  S/ABSORBER TYPE - GAS S 5611B3  3-SPOKE - LEATHER S 5631A4  STEER G COLUMN-MANUAL TILT & TELESCOPIC S 569BE1  AIR BAG LABEL(PASS S) - PICTOGRAM S 569EA1  PAB ON/OFF SWITCH S 5691A3  DRIVER SIDE - DEPOWERED S 5692A3  PASSENGER SIDE - DEPOWERED S 5711A6  MDPS S 5719A1  FLEX STEER S 5811A4  FR BRAKE - DISC-15 INCH S 5812A7  RR BRAKE - DISC-14 INCH S 589GA1  VSM (VEHICLE STABILITY MANAGEMENT) S 589HA1  HAC (HILLSTART ASSIST CONTROL) S 5891A2  ABS (ANTI LOCK BRK SYS) S 5894A1  ESC (ELECTRONIC STABILITY CONTROL) S 5896A1  ESS (EMERGENCY STOP SIGNAL) S 5911A3  SINGLE BOOSTER - 10 INCH S 5972A1  P/BRAKE KNOB TRIM - SOFT PVC S 5973A3  P/BRAKE PUSH BUTTON TRIM - CR COAT G S 6501A1  HIGH GRADE S 6921D1  LICENCE PLATE - EUROPE TYPE S 811AA1  HOOD INSULATOR S 8123A2  TRUNK LID RELEASE TYPE - CABLE S 8124A1  TRUNK LID TRIM - FULL COVER S 8125A2  T/LID INSIDE HANDLE - HOOK TYPE S 813AA1  SPEED SENS G AUTO DR LOCK S 813BA1  IMPACT SENS G AUTO DR UNLOCKG S 813DA1  IGN KEY REMINDER S 813MA1  SECURITY INDICATE S 813XA1  IGN KEY REMOVG AT DR UNLOCK S 8131A1  CENTRAL DR LOCK/UNLOCK - DR S CONTROL S 8135A2  INSIDE HNDL OVER RIDE - DR S & PA'S SIDE S 8136A1  CHILD SAFETY RR DR LOCK G S 8152A3  FUEL FILLER DR REL TYPE - CABLE S 819AA1  KEYLESS ENTRY-B/ALARM S 819CA1  KEYLESS ENTRY-T/OPEN S 819LA1  MIRROR FOLDING S 819PA1  TAIL INNER LIGHTING S 8195A1  IGNITION ILLUMINATED - BULB TYPE S 82A5A1  MAP POCKET-FR DR S 82A7A1  MAP POCKET-RR DR S 822AA1  DR BLACK OUT MATERIAL - TAPE S 8221A1  DR FRAME MLDG - BLACK S 8223A3  DR BELT LINE MLD G - BRIGHT S 8232A3  UPR TRIM FINISH G - PVC S 8233C1  CENTER TRIM - PVC S 8235A1  MAP POCKET FINISH G - W/O T/C PILE S 8236A3  ARM REST COVER G - ARTIFICIAL LEATHER S 8237A1  ARM REST HANDLE - PULL TYPE S 824FC1  P/WINDOW SW - ILLUMINATION(ALL) S 8241A2  FR DR GLASS - TINTED S 8245A2  RR DR GLASS - TINTED S 8261A4  FINISH G - CR COAT'G S 8262A2  LEVER FINISH G - CR COAT'G S 834CA4  SAFETY WINDOW - FR DR(DRIVER S+PASS'S) S 8341A2  POWER WINDOW(FR+RR) S 84D6A1  LWR S 84D9A1  MULTI BOX - W/ COVER S 84Q1A1  CLUSTER FACIA PNL S 842BA4  FOOT REST - AL TYPE S 8421D1  N/PUNCH - FLAT TYPE S 845BA1  W/ ILLUM S 8451A1  W/O LOCK S 8452A2  W/ DAMPER S 846BA4  W/ STORAGE BOX ARM REST - DLX(SLID G) S 846EA1  POWER OUTLET S 8461B1  DLX - PVC S 8462A1  CUP HOLDER - FR(W/O ILL) S 8481A9  GRAIN - HYDRO GRAPHICS S 8492A1  CONSOLE UPR COVER S 8499A1  DOOR TRIM GARNISH S 85APA1  TOOL CASE(OVM TOOL) S 852AA1  TICKET HOLDER S 852BA1  VANITY MIRROR COVER S 852DA1  ILLUMINATED S 852EA1  SUNVISOR TYPE - EXTENSION S 852GA1  VANITY MIRROR - GLASS TYPE S 852HA1  VANITY MIRROR COVER S 852KA1  ILLUMINATED S 852LA1  SUNVISOR TYPE - EXTENSION S 8521A1  MATERIAL - VINYL S 8522A1  VANITY MIRROR - GLASS TYPE S 8523A1  MATERIAL - VINYL S 853AA2  RR - 2 EA S 853JA1  RR - 1 EA S 8531A2  ROOF TRIM MATERIAL - FABRIC S 8532A1  FR - 1 EA S 8561A2  RR P/TRAY MATERIAL - W/PAPER S 8571C1  LUGGAGE SIDE - W/PAPER S 8572A2  RR - PLASTIC S 8573A2  FLOOR - WALL PAPER S 858AA7  A PILLAR - CLOTH-LOOKING(TEXTILE) S 858BA7  B PILLAR - CLOTH-LOOKING(TEXTILE) S 858RA1  DR SCUFF - STD S 858SA1  STEP PLATE S 8612A1  MLD G-WINDSHIELD - BLACK S 863AC4  CAR NAME - CERAT0 S 8631B5  B TYPE - SILVER S 864EA1  VIN LABEL - VIN S 8641A1  TOWING HOOK S 8649B6  ID PLATE - GEN+MES TYPE(ID) S 865HA1  RR UNDER COVER S 8651B1  TYPE - 2.5 MILE S 8652B1  COLOR - BODY COLOR S 871BA1  RR HEATED W/ TIMER S 8712B4  BACK LITE GLASS TYPE -TINTED(W/ HEATED) S 8723A2  LENS TYPE - LED S 876MA1  ELECTRIC FOLD G CONTROL S 876NA1  SIDE REPEATER LAMP (O/S MRR) S 8762C4  PASS S SIDE - ELECTRIC HTD-CONV S 8763C4  DRIVER S SIDE - ELECTRIC HTD-CONV S 8765A2  COLOR - BODY COLOR S 878AB1  FR QTR GLASS TYPE - TINTED S 8811C3  CLOTH - CLOTH3 S 8823A1  SLIDING S 8824A2  DOUBLE RECLIN G S 8825A4  ADJUSTER - PUMP G DEVICE S 885DA1  SLIDING S 885EA2  DOUBLE RECLIN G S 886BA1  SEAT BACK - SEAT BACK POCKET S 888AA2  PRE TENSIONER - ELECTRICAL TYPE S 888DA1  SEAT BELT REMINDER S 888KA2  S/BELT ANCHOR - ADJUSTABLE S 888RA2  S/BELT ANCHOR - ADJUSTABLE S 8881B1  DRIVER S SIDE - ELR S 8884D1  PASSENGER S SIDE - ELR S 8885A2  RETRACTOR PRETENSIONER - ELECTRICAL TYPE S 89F1A1  W/ CUP HOLDER S 8912D1  6:4 SPLIT BACK FOLD G - BACK S 8913A1  LH S 8914A1  RH S 8915A1  CTR S 892DA1  HOLDER - UPR ANCHOR S 892GA1  LWR ANCHOR S 8981A4  SIDE - ELR S 8982A4  CTR - ELR S 921BA1  LEVELING DEVICE - MANUAL S 921JA1  ESCORT S 921LA1  LED POSITION TYPE S 9211F1  PROJECTION-LOW BEAM-A TYPE S 9213A4  DRL - DEDICATED LED TYPE S 9221F1  SPORTY TYPE - MFR S 9222A1  RR - CONVENTIONAL S 9241A3  RR COMBI LAMP - LED TYPE S 928FA1  CTR - GLOW LAMP S 928HA2  FR - REFLECTOR S 9282A1  FR - W/ SUNGLASSES S 9287A1  LUGGAGE LAMP S 94C1A1  A/T POSITION INDICATOR S 94C6A1  DIRECTION INDICATOR S 94C7A1  OIL PRESSURE S 94C8A1  BRAKE OIL S 94C9A1  PARK G BRAKE S 94D0A1  DR AJAR - DR AJAR S 94D1A1  BATTERY CHARGE S 94D2A1  HIGH BEAM S 94D3A1  LOW BEAM S 94D4A1  LOW FUEL S 94D5A1  RR FOG LAMP S 94D7A1  TRUNK LID(T/GATE) OPEN S 94D9A1  CHECK ENGINE S 94E3A1  SEAT BELT S 94E5A1  A.B.S S 94E6A1  A/BAG S 94F3A1  CRUISE CONTROL S 94G0A1  LOW WASHER FLUID S 94G4A1  FR FOG LAMP S 94H6A1  IMMOBILIZER S 94H9A1  E.S.C S 94M0A1  SPEEDOMETER TYPE - KMPH S 94N0A1  TEMPERATURE UNIT - C S 94S0A8  CLUSTER TYPE - G TYPE(RUSSIA) S 940AA3  TRIP ODOMETER - LCD S 940BA1  TACHOMETER S 940CA1  FUEL S 940DA1  WATER TEMP. S 9402A1  SPEEDOMETER S 9451A1  TYPE - DIGITAL S 9491A1  RHEOSTAT S 9511A1  AUTO LIGHT CONTROL SYSTEM - 1 STAGE S 9541A1  BODY CONTROL MODULE - BCM(ETACS) S 9542A1  IMMOBILIZER S 9545A3  FREQUENCY-SMART KEY - GENERAL S 9571A2  PARK G ASSIST SYSTEM S 9614B1  COMPONENT- 2 DIN S 9615A3  FREQUENCY VIBRATION - AM9K/FM50K S 9618A1  USB+AUX S 9621E1  GLASS ANTENNA - RADIO S 963CA1  SPEAKER LOCATION FR DR - GENERAL S 963KA1  SPEAKER LOCATION TWEETER-FR DR UPR S 963ZA1  SPEAKER LOCATION RR DR LOW-GENERAL S 9641A1  AUTO CRUISE CONTROL - CONVENTIONAL S 965QA1  O/SIDE TEMPERATURE DISPLAY S 9651A1  TYPE - SEPARATED TYPE S 9661A1  SINGLE HORN S 967AA1  AUDIO REMO. S 967BA1  ACC REMO. S 967KA1  PADDLE SHIFTER - LEVER TYPE S 9681A1  SEAT BELT S 9711A2  BLOWER - 4 SPEED FAN S 9714A1  FUNCTION - AIR FILTER S 974AA1  CONSOLE A/VENT S 9741A1  RR HEATING DUCTS - 2ND SEAT S 981AA1  FR WIPER-2 SPEED S 981BA1  FR WIPER-TIME ADJUSTER S 9811A2  FR WIPER - INTERMITTENT(VARIABLE) S 9817A1  MIST FUNCTION S 9819A2  BLADE TYPE - AERO S 9852A1  FUNCTION - WASHER FLUID LEVEL SENSOR S 9911A9  REGULATION & UNIQUE SPEC - RUSSIA SPEC O 561AA1  W/ HEATED O 5693A3  SIDE AIR BAG-FR - FR(THORAX & PELVIS) O 5695A1  CURTAIN A/BAG O 819HA1  SMART KEY-FR DR O 8196A2  BUTTON START - BUTTON W/ ILLUMINATED O 8198A3  STEER G LOCK TYPE - ESCL O 826DA1  POCKET LIGHTING - FRT DOOR - W/ILLUM O 8441A5  FR - PORTABLE O 8445A2  CIGAR LIGHTER - W/ ILLUM O 845DA1  GLOVE BOX-COOLING O 8511C1  ECM (ELECTRIC CHROMIC MIRROR) O 86A1A1  W/ WIPER DEICER O 8611C1  W/S GLASS TYPE-UV CUT O 8681A1  MUD GUARD-FR O 8682A1  MUD GUARD-RR O 87A1A1  W/ PUDDLE LAMP O 8721A1  RR SPOILER - W/O HMSL O 8821A5  HEAD REST - UP/DOWN & SLIDING O 8828A2  LUMBAR SUPPORT - ELECTRIC O 8838A1  SEAT WARMER(HEATER) O 8854A5  HEAD REST - UP/DOWN & SLIDING O 8873A1  SEAT WARMER O 892WA1  SEAT WARMER O 9216C1  HID (25W) O 94U1A3  WARNG SOUND TYPE - MONO SPEAKER + SOUND O 9401D1  CLUSTER TYPE - SUPER VISION+TFT LCD INFO O 9552A2  BLUE TOOTH (AUDIO)-W/ VOICE RECOGNITION O 9611NL  RADIO+CD+MP3+RDS - PA30B R O 9652A1  BACK WARN G CAMERA O 967FA1  VOICE RECOGNITION SYSTEM REMO O 971DA1  PTC HEATER_INT TYPE (GASOLINE) O 9717A1  CLUSTER IONIZER O 972MA1  AUTO DEFOG SYSTEM O 9761A6  FR COOLER - DUAL FULL AUTO A/CON O 979EA1  EXTERNAL CONTROL COMPRESSOR
#872 *Гость* Re: расшифровка VIN Kia, Hyundai
Отправлено 25 November 2014 - 18:23
Доброго времени суток! Стала твладельцем недавно Киа Соренто 05 года. Расшифруйте пожалуйста vin KNEJC522555430407. Заранее благодарю
Сообщение отредактировал krionika: 25 November 2014 - 20:21
#873 *Гость* Re: расшифровка VIN Kia, Hyundai
Отправлено 25 November 2014 - 18:25
Заранее благодарю
не разобралась еще как писать на форумен так что сорри за предидущее...
#874 *Юлия* Re: расшифровка VIN Kia, Hyundai
*Юлия*
Отправлено 25 November 2014 - 18:36
Спасибо!!!!
#875 krionika Re: расшифровка VIN Kia, Hyundai
Отправлено 25 November 2014 - 20:20
Держи :)
KNEJC522555430407 - 2004/12/29 (RUSSIA) EURK3E002A  SORENTO 02         ENGINE : HG41(G4JS4169175) T/M : U04G(FYW 430407) SEAT : INTERIOR : CY (KEY COLOR(GRAY)) EXTERIOR : YC-EB/V9 (EBONY BLACK/PEWTER GREY) LEFT HAND DRIVE 5 DR WAGON HIGH GRADE 2400 CC MPI-DOHC 5 SPEED MT 4WD ALL AUDIO   S ALL0  ALL MODEL S K0N0  BL S W20  THE FROZEN ZONE S 0910  UNLEADED S 2831  EVAP. GAS CONTROL S 2838  EMISSION EC 2000 S 3114  FUEL CUT SYSTEM S 5002  LSD S 52BO  TIRE-245/70 R 16 S 5274  HANKOOK S 529E  15 (AL) S 5291  EMBLEM CENTER CAP S 53WP  WHL-7.0JJ*16(AL) A'TYPE S 5619  STRG-ELECTRIC POWER S 5691  A/BAG(D/S) S 5832  DISC S 6501  HIGH GRADE S 8131  ANTI THEFT SYSTEM(W/O BURGLAR) S 8165  O/H CONSOLE-STD S 8197  KEYLESS(433.9MHZ) S 824A  GLASS-RR DR(TNTD) S 8241  TNTD S 8512  MIRROR-I/S(DAY & NIGHT) S 852C  MRR-VANITY(ILL) D/S S 8524  MRR-VANITY(ILL) P/S S 857U  LUGGAGE NET S 8639  RAD. GRILLE-B TYPE S 864C  MUD GUARD-RR(W/O LETTER) S 8647  MUD GUARD-FRT(W/O LETTER) S 8672  ROOF RACK S 8713  TNTD W/O HTD S 8718  HEATED S 8734  MLDG-BACK PNL(CR COATG) S 8742  MRR-O/SIDE(BODY COLOR) S 875D  MRR-PA S ELEC:HTR CONV S 8761  MRR-DR S ELEC:HTD CONV S 877F  GARNISH S 8776  MLDG-DRIP RAIL(BLACK) S 8792  GLASS-QTR SWIVELG(TINTED) S 8817  B/PANEL S 8819  UNDER TRAY(P/S) S 8875  H/R TILT S 888D  S/BELT DRIVE PRETENSION S 888F  SEAT BELT-FR DR S LOAD LIMITER S 889D  S/BELT PASS. PRETENSION S 898C  SEAT BELT-RR CTR(ELR) S 9211  HLLD S 9215  BULB-12V P43T(H4 HALOGEN) S 9231  REPEATER-SIDE S 9241  LAMP-FOG(FR) S 9242  LAMP-FOG(RR) S 9275  LAMP-HMS S 9403  KMH S 9406  LAMP-S/BELT WARN G S 9416  MULTI METER S 9542  IMMOBILIZER S 96SB  SPEAKER-IP. S 9601  ANTENNA-POWER S 9619  AM9K/FM50K S 9631  AUDIO BLANK G COVER-GERMANY S 970A  TEMPERATURE UNIT C' S 9711  RR HEAT(STD) S 9726  HEATER CONTROL(ROTARY TYPE) S 9862  CHIME BELL O 2924  ENGINE COVER O 4751  AUTO TRANSFER(ELECTRONIC) O 5615  LEATHER O 5692  A/BAG(P/S) O 5695  AIR BAG-SIDE O 5891  ABS O 8234  LEATHER O 826A  HANDLE-DR I/S-CR COATG O 8268  CR COATG O 8477  WOOD GRAIN O 8561  PACKAGE TRAY-RR(WALL PAPER) O 8587  DR SCUFF-DLX O 8626  SOLAR O 8629  GLASS-W/S WITH WIPER DEICER O 876C  MRR-ELEC FOLD O 8800  LEATHER O 8805  SEAT-POWER O 8810  SEAT-FR(WITH HEATED) O 976A  S.A.T.C O 9768  AIR CON-FULL AUTO O 9836  WASHER FLUID LEVEL SENSOR O 9867  WASHER-HEAD LAMP
#876 *Гость* Re: расшифровка VIN Kia, Hyundai
Отправлено 26 November 2014 - 09:20
Добрый день! Помогите расшифровать плиз, Kia Cerato VIN KNAFX417BF5275127
#877 krionika Re: расшифровка VIN Kia, Hyundai
Отправлено 26 November 2014 - 12:17
Держи )
⊙ KNAFX417BF5275127 - 2014/05/19 (RUSSIA) KEURPA712  K3 12         ENGINE : B24T(G4NAEH516215) T/M : U48P(EJERBH868303) SEAT : INTERIOR : WK (SATURN BLACK) EXTERIOR : MST (METAL STREAM) LEFT HAND DRIVE WEATHER - THE FRIGID ZONE SEDAN - 4DR 5P 2000 CC - NU DOHC - MPI GASOLINE - UNLEADED AUTO - 6 SPEED 2WD ALL AUDIO   S 0091A3  ENGINE PACKAGE - LOW POWER ENG S 0101B4  MODEL YEAR PACKAGE - 15MY S 2531A1  RAD CORE MATERIAL - RESISTANT CACL2 S 2841B6  EMISSION REGULATION - EURO 4 S 2843A3  EVAP. GAS CONTROL - ULEV S 2911A1  UNDER COVER - W/ NOISE PAD S 2921A4  ENGINE COVER - FULL S 3111B1  FUEL TANK-CAPACITY - 50 LITER S 3116B3  FILLER NECK LABEL - RUSSIA S 3281A1  PEDAL TYPE - RUBBER PAD S 3283A1  FLOOR MTG TYPE S 371CA1  BATTERY SAVER S 3711A8  BATTERY CAPACITY - 60AH (20HR) S 4503A2  SHIFT LOCK SYSTEM - ELECTRONIC TYPE S 4509A1  H-MATIC S 529AB1  TIRE PRESSURE LABEL - EUROPE S 529TA7  TOOL SET & JACK LABEL - EUROPE S 5295A2  TIRE MATERIAL - SILICA S 5411A1  FR SUSP TYPE - MACPH. W/COIL SPRING S 5412A2  S/ABSORBER TYPE - GAS S 5511A9  RR SUSP TYPE - TORSION AXLE S 5512A2  S/ABSORBER TYPE - GAS S 5631A4  STEER G COLUMN-MANUAL TILT & TELESCOPIC S 569BE1  AIR BAG LABEL(PASS S) - PICTOGRAM S 569EA1  PAB ON/OFF SWITCH S 5691A3  DRIVER SIDE - DEPOWERED S 5692A3  PASSENGER SIDE - DEPOWERED S 5711A6  MDPS S 5811A4  FR BRAKE - DISC-15 INCH S 5891A2  ABS (ANTI LOCK BRK SYS) S 5896A1  ESS (EMERGENCY STOP SIGNAL) S 5911A3  SINGLE BOOSTER - 10 INCH S 5972A1  P/BRAKE KNOB TRIM - SOFT PVC S 6501A1  HIGH GRADE S 6921D1  LICENCE PLATE - EUROPE TYPE S 8123A2  TRUNK LID RELEASE TYPE - CABLE S 8124A1  TRUNK LID TRIM - FULL COVER S 8125A2  T/LID INSIDE HANDLE - HOOK TYPE S 813AA1  SPEED SENS G AUTO DR LOCK S 813BA1  IMPACT SENS G AUTO DR UNLOCKG S 813DA1  IGN KEY REMINDER S 813MA1  SECURITY INDICATE S 813XA1  IGN KEY REMOVG AT DR UNLOCK S 8131A1  CENTRAL DR LOCK/UNLOCK - DR S CONTROL S 8135A2  INSIDE HNDL OVER RIDE - DR S & PA'S SIDE S 8136A1  CHILD SAFETY RR DR LOCK G S 8152A3  FUEL FILLER DR REL TYPE - CABLE S 819AA1  KEYLESS ENTRY-B/ALARM S 819CA1  KEYLESS ENTRY-T/OPEN S 819PA1  TAIL INNER LIGHTING S 8194B3  TYPE - FOLDING S 8195A1  IGNITION ILLUMINATED - BULB TYPE S 82A5A1  MAP POCKET-FR DR S 82A7A1  MAP POCKET-RR DR S 822AA1  DR BLACK OUT MATERIAL - TAPE S 8221A1  DR FRAME MLDG - BLACK S 8223A2  DR BELT LINE MLD G - BLACK-SUS+PVC TYPE S 8235A1  MAP POCKET FINISH G - W/O T/C PILE S 8236A3  ARM REST COVER G - ARTIFICIAL LEATHER S 8237A1  ARM REST HANDLE - PULL TYPE S 824FC1  P/WINDOW SW - ILLUMINATION(ALL) S 8241A2  FR DR GLASS - TINTED S 8245A2  RR DR GLASS - TINTED S 8261A2  FINISH G - BODY COLOR S 8262A2  LEVER FINISH G - CR COAT'G S 8341A2  POWER WINDOW(FR+RR) S 84D6A1  LWR S 84D9A1  MULTI BOX - W/ COVER S 842BA2  FOOT REST - PLASTIC S 8421D1  N/PUNCH - FLAT TYPE S 8446A1  POWER OUTLET(FR) S 845BA1  W/ ILLUM S 8451A1  W/O LOCK S 8452A2  W/ DAMPER S 846BA4  W/ STORAGE BOX ARM REST - DLX(SLID G) S 846EA1  POWER OUTLET S 8461B1  DLX - PVC S 8462A1  CUP HOLDER - FR(W/O ILL) S 8481A9  GRAIN - HYDRO GRAPHICS S 8492A1  CONSOLE UPR COVER S 8499A1  DOOR TRIM GARNISH S 85APA1  TOOL CASE(OVM TOOL) S 852AA1  TICKET HOLDER S 852BA1  VANITY MIRROR COVER S 852EA1  SUNVISOR TYPE - EXTENSION S 852GA1  VANITY MIRROR - GLASS TYPE S 852HA1  VANITY MIRROR COVER S 852LA1  SUNVISOR TYPE - EXTENSION S 8521A1  MATERIAL - VINYL S 8522A1  VANITY MIRROR - GLASS TYPE S 8523A1  MATERIAL - VINYL S 853AA2  RR - 2 EA S 853JA1  RR - 1 EA S 8531A2  ROOF TRIM MATERIAL - FABRIC S 8532A1  FR - 1 EA S 8561A2  RR P/TRAY MATERIAL - W/PAPER S 8571C1  LUGGAGE SIDE - W/PAPER S 8572A2  RR - PLASTIC S 8573A2  FLOOR - WALL PAPER S 858AA7  A PILLAR - CLOTH-LOOKING(TEXTILE) S 858BA7  B PILLAR - CLOTH-LOOKING(TEXTILE) S 858RA1  DR SCUFF - STD S 858SA1  STEP PLATE S 8612A1  MLD G-WINDSHIELD - BLACK S 863AC4  CAR NAME - CERAT0 S 8631B5  B TYPE - SILVER S 864EA1  VIN LABEL - VIN S 8641A1  TOWING HOOK S 8649B6  ID PLATE - GEN+MES TYPE(ID) S 865HA1  RR UNDER COVER S 8651B1  TYPE - 2.5 MILE S 8652B1  COLOR - BODY COLOR S 871BA1  RR HEATED W/ TIMER S 8712B4  BACK LITE GLASS TYPE -TINTED(W/ HEATED) S 8722A3  H.M.S.L - RR P/TRAY S 876MA2  MANUAL FOLD G S 876NA1  SIDE REPEATER LAMP (O/S MRR) S 8762C4  PASS S SIDE - ELECTRIC HTD-CONV S 8763C4  DRIVER S SIDE - ELECTRIC HTD-CONV S 8765A2  COLOR - BODY COLOR S 878AB1  FR QTR GLASS TYPE - TINTED S 8811C2  CLOTH - CLOTH2 S 8823A1  SLIDING S 8824A2  DOUBLE RECLIN G S 8825A4  ADJUSTER - PUMP G DEVICE S 885DA1  SLIDING S 885EA2  DOUBLE RECLIN G S 886BA1  SEAT BACK - SEAT BACK POCKET S 888AA2  PRE TENSIONER - ELECTRICAL TYPE S 888DA1  SEAT BELT REMINDER S 888KA2  S/BELT ANCHOR - ADJUSTABLE S 888RA2  S/BELT ANCHOR - ADJUSTABLE S 8881B1  DRIVER S SIDE - ELR S 8884D1  PASSENGER S SIDE - ELR S 8885A2  RETRACTOR PRETENSIONER - ELECTRICAL TYPE S 89F1A1  W/ CUP HOLDER S 8912D1  6:4 SPLIT BACK FOLD G - BACK S 8913A1  LH S 8914A1  RH S 8915A1  CTR S 892DA1  HOLDER - UPR ANCHOR S 892GA1  LWR ANCHOR S 8981A4  SIDE - ELR S 8982A4  CTR - ELR S 921BA1  LEVELING DEVICE - MANUAL S 921JA1  ESCORT S 9211F1  PROJECTION-LOW BEAM-A TYPE S 9221F1  SPORTY TYPE - MFR S 9222A1  RR - CONVENTIONAL S 9241A2  RR COMBI LAMP - NON LED TYPE S 928FA1  CTR - GLOW LAMP S 928HA2  FR - REFLECTOR S 9282A1  FR - W/ SUNGLASSES S 9287A1  LUGGAGE LAMP S 94C1A1  A/T POSITION INDICATOR S 94C6A1  DIRECTION INDICATOR S 94C7A1  OIL PRESSURE S 94C8A1  BRAKE OIL S 94C9A1  PARK G BRAKE S 94D0A1  DR AJAR - DR AJAR S 94D1A1  BATTERY CHARGE S 94D2A1  HIGH BEAM S 94D3A1  LOW BEAM S 94D4A1  LOW FUEL S 94D5A1  RR FOG LAMP S 94D7A1  TRUNK LID(T/GATE) OPEN S 94D9A1  CHECK ENGINE S 94E3A1  SEAT BELT S 94E5A1  A.B.S S 94E6A1  A/BAG S 94F3A1  CRUISE CONTROL S 94G0A1  LOW WASHER FLUID S 94G4A1  FR FOG LAMP S 94H6A1  IMMOBILIZER S 94M0A1  SPEEDOMETER TYPE - KMPH S 94N0A1  TEMPERATURE UNIT - C S 94S0A8  CLUSTER TYPE - G TYPE(RUSSIA) S 940AA3  TRIP ODOMETER - LCD S 940BA1  TACHOMETER S 940CA1  FUEL S 940DA1  WATER TEMP. S 9402A1  SPEEDOMETER S 9451A1  TYPE - DIGITAL S 9491A1  RHEOSTAT S 9541A1  BODY CONTROL MODULE - BCM(ETACS) S 9542A1  IMMOBILIZER S 9545A3  FREQUENCY-SMART KEY - GENERAL S 9611NK  RADIO+CD+MP3+RDS - PA30A R S 9614B1  COMPONENT- 2 DIN S 9615A3  FREQUENCY VIBRATION - AM9K/FM50K S 9618A1  USB+AUX S 9621E1  GLASS ANTENNA - RADIO S 963CA1  SPEAKER LOCATION FR DR - GENERAL S 963KA1  SPEAKER LOCATION TWEETER-FR DR UPR S 963ZA1  SPEAKER LOCATION RR DR LOW-GENERAL S 9641A1  AUTO CRUISE CONTROL - CONVENTIONAL S 965QA1  O/SIDE TEMPERATURE DISPLAY S 9651A1  TYPE - SEPARATED TYPE S 9661A1  SINGLE HORN S 967AA1  AUDIO REMO. S 967BA1  ACC REMO. S 9681A1  SEAT BELT S 9711A2  BLOWER - 4 SPEED FAN S 9714A1  FUNCTION - AIR FILTER S 974AA1  CONSOLE A/VENT S 9741A1  RR HEATING DUCTS - 2ND SEAT S 981AA1  FR WIPER-2 SPEED S 981BA1  FR WIPER-TIME ADJUSTER S 9811A2  FR WIPER - INTERMITTENT(VARIABLE) S 9817A1  MIST FUNCTION S 9819A2  BLADE TYPE - AERO S 9852A1  FUNCTION - WASHER FLUID LEVEL SENSOR S 9911A9  REGULATION & UNIQUE SPEC - RUSSIA SPEC O 4371B3  AT KNOB - LEATHER WRAPPED O 5291MA  AL WHEEL 6.5J * 16 - A TYPE O 5293F7  205 TIRE - 205/55 R16 O 5297A3  FULL SIZE 1EA - AL WHEEL & TIRE O 561AA1  W/ HEATED O 5611B3  3-SPOKE - LEATHER O 5693A3  SIDE AIR BAG-FR - FR(THORAX & PELVIS) O 5695A1  CURTAIN A/BAG O 5719A1  FLEX STEER O 5812A7  RR BRAKE - DISC-14 INCH O 589GA1  VSM (VEHICLE STABILITY MANAGEMENT) O 589HA1  HAC (HILLSTART ASSIST CONTROL) O 5894A1  ESC (ELECTRONIC STABILITY CONTROL) O 5973A3  P/BRAKE PUSH BUTTON TRIM - CR COAT G O 811AA1  HOOD INSULATOR O 8232A3  UPR TRIM FINISH G - PVC O 8233C1  CENTER TRIM - PVC O 834CA4  SAFETY WINDOW - FR DR(DRIVER S+PASS'S) O 84Q1A1  CLUSTER FACIA PNL O 845DA1  GLOVE BOX-COOLING O 8511C1  ECM (ELECTRIC CHROMIC MIRROR) O 852DA1  ILLUMINATED O 852KA1  ILLUMINATED O 86A1A1  W/ WIPER DEICER O 8611C1  W/S GLASS TYPE-UV CUT O 8681A1  MUD GUARD-FR O 8682A1  MUD GUARD-RR O 8721A1  RR SPOILER - W/O HMSL O 8821A5  HEAD REST - UP/DOWN & SLIDING O 8838A1  SEAT WARMER(HEATER) O 8854A5  HEAD REST - UP/DOWN & SLIDING O 8873A1  SEAT WARMER O 892WA1  SEAT WARMER O 94H9A1  E.S.C O 9401B1  CLUSTER TYPE - SUPER VISION O 9552A2  BLUE TOOTH (AUDIO)-W/ VOICE RECOGNITION O 9571A2  PARK G ASSIST SYSTEM O 967FA1  VOICE RECOGNITION SYSTEM REMO O 967KA1  PADDLE SHIFTER - LEVER TYPE O 971DA1  PTC HEATER_INT TYPE (GASOLINE) O 9717A1  CLUSTER IONIZER O 972MA1  AUTO DEFOG SYSTEM O 9761A6  FR COOLER - DUAL FULL AUTO A/CON O 979EA1  EXTERNAL CONTROL COMPRESSOR
#878 *Гость* Re: расшифровка VIN Kia, Hyundai
Отправлено 27 November 2014 - 11:27
Огромное спасибо!!!
#879 *Гость* Re: расшифровка VIN Kia, Hyundai
Отправлено 29 November 2014 - 10:16
krionika, спасибо!  может еще можете подсказать где найти на кузове выбитый рос вин? -)
#880 krionika Re: расшифровка VIN Kia, Hyundai
Отправлено 29 November 2014 - 11:56
где
https://mykia.club/forum/408-vin-kia/
