Kia Rio JB (2006-2009) - замена сцепления
REMOVAL
To remove the transaxle assembly, first drain the clutch fluid and transaxle gear oil, then remove the air cleaner joint and the mounting bracket etc.
Remove the transaxle assembly, after removing each bolt which connects the transaxle assembly and engine.
Loosen the bolts attached to the release cylinder and remove the release cylinder.
4.
Remove the clutch release fork(A) and bearing(B).
It is impossible to remove the transaxle assembly without performing this step because the clutch cover assembly, release bearing and release fork are held together.
To reduce rattling noise from the gear, a new dual mass flywheel has been used. Due to the application of the dual mass flywheel, the clutch assembly has also been changed. When replacing the flywheel with the dual mass flywheel, the clutch disc and cover should be replaced with the new parts at the same time.
Kia Rio JB 2006-2009 - замена сцепления (1).jpg 35.29К
8 Количество загрузок:
5.
Remove the shift fork boot(A).
Kia Rio JB 2006-2009 - замена сцепления (2).jpg 29.65К
7 Количество загрузок:
6.
Insert the special tool (09411-25000) in the clutch disc to prevent the disc from shifting.
7.
Loosen the bolts which attach the clutch cover to the flywheel in a star pattern. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover.
Do not clean the clutch disc or the release bearing with cleaning solvent.
#1
Отправлено 03 November 2012 - 16:53
#2
Re: сцепление
Отправлено 03 November 2012 - 16:55
Installation
Apply multipurpose grease to the spline of the disc.
Grease: CASMOLY L 9508
When installing the clutch, apply grease to each part, but be careful not to apply excessive grease.
It can cause clutch slippage and vibration (shudder).
Kia Rio JB 2006-2009 - замена сцепления (1).jpg 27.41К
Install the clutch disc assembly to the flywheel using the special tool (09411-25000).
Install the clutch cover assembly to the flywheel and temporarily tighten the bolts one or two steps at a time in a star pattern.
TORQUE
Clutch cover bolt :
15 ~ 22 Nm (150 ~ 220 kgf.cm, 11 ~ 16 lb-ft)
Kia Rio JB 2006-2009 - замена сцепления (2).jpg 34.37К
5 Количество загрузок:
4.
Install the clutch release fork boot(A).
Kia Rio JB 2006-2009 - замена сцепления (3).jpg 39.04К
5.
Install the release bearing(A) and shift fork(B).
Kia Rio JB 2006-2009 - замена сцепления (4).jpg 35.23К
6 Количество загрузок:
6.
Install the release cylinder(A) to the transaxle
TORQUE
Release cylinder bolt :
Kia Rio JB 2006-2009 - замена сцепления (5).jpg 30.56К
7.
Install the transaxle assembly to the engine.
#3
Re: сцепление
Отправлено 23 June 2014 - 15:10
Прошу совета, на этих выходных приговорили к замене сцепление. Вопрос такой - менять на оригинал или нет? Машина 2008 года. Если на неоригинал то на какой?
И не испортит ли сцепление неоригинальное саму коробку?
А как сцепление может испортить коробкуто? я вот о таком не слышал. По оригиналу и не ему - если стоимость оригинала сильно дороже чем у неоригинала - то брать неоригинал.
#4
Re: сцепление
Отправлено 23 June 2014 - 15:55
Rio-Grande, разница между оригинальным сцеплением и неоригинальным составляет примерно 1500 руб. Поэтому тут каждый для себя сам принимает решение. Разница по цене может быть конечно намного больше, если ставить китайское г*авно, только потом вся эта разница уйдет на еще одну замену сцепления
Re: сцепление
Отправлено 11 March 2005 - 16:48
[color=#0000ff;]Сцепление 1.4 / 1.6[/color]
Сцепление Киа Рио JB.gif 17.39К
0 Количество загрузок:
Ещё обсуждения по киа рио 2 jb на MyKia.club:
Киа Рио 2 JB
Киа Рио клуб →
Двигатель и КПП Kia Rio →
момент затяжки МКППАвтор krionika, 11 Nov 2011 |
Киа Рио 2 JB
Киа Рио клуб →
Кузов и Салон Kia Rio →
подрамникАвтор krionika, 20 Nov 2011 |
Киа Рио 2 JB
Киа Рио клуб →
момент затяжки АКППАвтор krionika, 19 Oct 2011 |
Киа Рио 2 JB
Киа Рио клуб →
замена АКППАвтор krionika, 19 Oct 2011 |
Киа Рио 2 JB
Киа Рио клуб →
Электрика и Аудио Kia Rio →
схема проводки (жгутов)Автор krionika, 28 Feb 2023 |
