INSTALLATION
<table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 1.</td> <td style="padding-left:3px;" valign="top">
Coat gear oil to the drive shaft splines and differential case sliding surface. </td> </tr> </tbody></table><table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 2.</td> <td style="padding-left:3px;" valign="top">
Before installing the drive shaft, set the opening side of circlip facing downward. </td> </tr> </tbody></table><table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 3.</td> <td style="padding-left:3px;" valign="top">
After installation, check that the drive shaft cannot be removed by hand. </td> </tr> </tbody></table><table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 4.</td> <td style="padding-left:3px;" valign="top">
Install the washer under the drive shaft nut with facing the convex side outward as shown in the illustration. </td> </tr> </tbody></table><table border="0" cellpadding="0" cellspacing="0" style="width:100%;padding-bottom:6;"> <tbody> <tr> <td style="padding-left:3px;" valign="top" width="12"> 5.</td> <td style="padding-left:3px;" valign="top">
Tighten the following parts to the specified torque. <table border="1" cellpadding="3" cellspacing="0" style="border:solid 1pt gray;BORDER-COLLAPSE: collapse;bgcolor=#ccffff;width:100%;MARGIN-top: 5px;"> <tbody> <tr> <td align="left" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="50%%"> </td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="50%%"> Nm(kg·cm, lb·ft)</td> </tr> <tr> <td align="left" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="50%%"> Drive shaft nut</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="50%%"> 200-260(2000-2600, 148-192)</td> </tr> <tr> <td align="left" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="50%%"> Lower arm ball joint to knuckle</td> <td align="center" colspan="1" rowspan="1" style="border:solid 1pt gray;" valign="middle" width="50%%"> 100-120(1000-1200, 74-88)</td> </tr> </tbody> </table> </td> </tr> </tbody></table>
Kia Magentis MS 2001-2006 - замена шруса.jpg 19.72К
8 Количество загрузок:
