Киа Маджентис 1 MS
сцепление (ремонт и замена)
Сообщений в теме: 5
  • 4009 сообщений
Отправлено 03 November 2012 - 16:15
Kia Magentis MS (2001-2006) - замена сцепления
REMOVAL 1. To remove the transaxle assembly firstly remove the air cleaner joint, mounting bracket, and wiring etc. 2. Remove the release lever. Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (1).jpg   22.7К   10 Количество загрузок: (1) Loosen the release lever nut and washer. (2) Remove the clevis pin and snap ring from the release cylinder. (3) Remove the release lever. It is impossible to remove transaxle assembly without doing this step. Because, clutch cover, release bearing and release fork are combined together. 3. Loosen the bolts attached to the release cylinder and remove the release cylinder. 4. Remove the transaxle assembly, after removing each bolt which connect the transaxle assembly and engine. Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (2).jpg   17.36К   9 Количество загрузок: 5. In the state that the clutch cover is attached to the flywheel remove the release bearing using appropriate tool as shown. (1) Rotate the release bearing in the easy direction in order to examine the snap ring. (2) Insert the tool under the wave washer as shown in the illustration and locate in the center of snap ring. (3) Widen the space of snap ring by pushing the bearing an shown in the illustration. Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (3).jpg   29.19К   11 Количество загрузок: (4) The snap ring-widen state is like as shown the figure. Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (4).jpg   27.79К   9 Количество загрузок: (5) In the snap ring-widen state pull out the release bearing and remove it. 6. Insert the special tool (09411-11000) in the clutch disc to prevent the disc from falling. 7. Loosen the bolts which attach the clutch cover to the flywheel in a star pattern. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover flange. Do not clean the clutch disc or release bearing with cleaning solvent. 8. Remove the release fork shaft and bushing. Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (5).jpg   29.19К   8 Количество загрузок:
#2 getAway Re: сцепление (ремонт и замена)
  • 4009 сообщений
Отправлено 03 November 2012 - 16:17
INSTALLATION
Apply multipurpose grease to the spline of disc.
Grease : CASMOLY L9508
When installing the clutch, apply grease to each part, but be careful not to apply excessive grease' It can cause clutch slippage and judder.
Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (1).jpg   34.15К   11 Количество загрузок:
Install the clutch disc assembly t the flywheel using special tool(09411-11000).
Install the clutch cove assembly to the flywheel and temporarily tighten the bolts one or two steps at a time in a star pattern.
Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (2).jpg   29.28К   9 Количество загрузок:
Tightening torque Clutch cover bolt : 2.0L - 15-22 Nm( 150-220 kg·cm, 11-16 lb·ft), 2.5L - 20-27 Nm(200-270 kg·cm, 15-20 lf·t)
4.
Align the bearing to the release fork and then install it to the sleeve of housing.
Apply multipurpose grease (CASMOLY L9508) to the grease home of bearing sleeve and contact point of release fork.
Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (3).jpg   29.27К   10 Количество загрузок:
5.
Install the release lever to the release fork.
If transaxle assembly is installed to engine without dong this step, release bearing can be separated according as the release fork rotates free.
Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (4).jpg   24.03К   8 Количество загрузок:
6.
Install the transaxle assembly to the engine.
7.
After finishing step 6, pushing the release lever to the release bearing and clutch cover are aligned correctly.
Release lever operating range : 3° or less
If the range is over 3° it is a symptom that the release bearing and clutch cover are not aligned correctly. So, push the release lever to the arrow mark one more time.
Прикрепленный файл  Kia Magentis MS 2001-2006 - замена сцепления (5).jpg   25.88К   9 Количество загрузок:
#3 krionika Re: сцепление (ремонт и замена)
Отправлено 17 January 2014 - 15:18
*Датый*
Надеюсь не сильно :n56:
Взял недавно мадж 2002 года Заметил что нажимаешь на газ, двигатель дает большие обороты, но машина едет не охотно, и медленно разгоняется. Думаю что что-то со сцеплением. Вопрос! Сцепление на мадже регулируется или однозначно менять?
Регулировать там можно было если бы педаль брала высоко или низко, а при таки симптомах - только замена. Вот кстати.. http://auto-texcente...ia-magentis-mg/
#4 *Датый* Re: сцепление (ремонт и замена)
*Датый*
Отправлено 20 January 2014 - 16:33
Вот кстати..
ПОнял
#5 *Гога* Re: сцепление (ремонт и замена)
*Гога*
Отправлено 30 May 2021 - 10:30
Привет всем, проблема такая -  даю газ, отпускаю сцепление и машина сначала не едет, хоть обороты и растут. Потом нехотя начинает ехать и затем все нормально. Правда при переключении тоже незначительно повышение оборотов есть при ускорении. Это куда смотреть надо?
#6 Архангел Михаил Re: сцепление (ремонт и замена)
Архангел Михаил
  • 37 сообщений
Отправлено 30 May 2021 - 10:51
на диск сцепления, ему хана
Ты дал ему то, что он просил, а я дал — то, чего он ждал... :aq:
Ещё обсуждения по киа маджентис 1 ms на MyKia.club:
