Киа Мохав HM
кондиционер
  • 3845 сообщений
Отправлено 11 October 2012 - 11:58
Kia Mohave HM (2008+) - снятие и установка радиатора кондиционера
Replacement 1. Recover the refrigerant with a recovery/ recycling/ charging station . 2. Disconnect the negative (-) battery terminal. 3. Remove the front bumper(Refer to BD group-front bumper) 4. 4. Remove the radiator assembly(Refer to EM group-radiator) 5. Remove the condenser(A) from radiator. Прикрепленный файл  1 copy.jpg   45.29К   11 Количество загрузок: 6. Install in the reverse order of removal, and note these items : A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Be sure to install the lower mount cushions of condenser securely into the holes. E. Charge the system, and test its performance. Desiccant Replacement 1. Remove the condenser, and then remove the bottom cap (B) with L wrench (A) from the condenser. Прикрепленный файл  2 copy.jpg   22.75К   9 Количество загрузок: TORQUE : 22.5~32.3N.m (2.3~3.3kgf•m, 16.6~23.8lb-ft) 2. Remove the desiccant (A) from condenser using a long nose plier. Check for crumbled desiccant and clogged bottom cap filter. Прикрепленный файл  3 copy.jpg   22.28К   10 Количество загрузок: 3. Apply air conditioning compressor oil along the O-rings and threads of the new bottom cap. 4. Insert the new desiccant into the receiver drier tank. The desiccant must be sealed in vacuum before it is exposed to air for use. 5. Install the new bottom cap to the condenser. - Always replace the desiccant and bottom cap at the same time. - Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. - Be careful not to damage the radiator and condenser fins when installing the condenser. - Be sure to install the lower mount cushions of condenser securely into the holes. - Charge the system, and test its performance.
#2 getAway Re: кондиционер
  • 3845 сообщений
Отправлено 18 October 2012 - 17:09
Kia Mohave HM (2008+) - снятие и установка компрессора кондиционера
Replacement 1. Remove the spare tire. 2. Remove the connector (A) & air tube. Прикрепленный файл  1 copy.jpg   37.61К   9 Количество загрузок: 3. Disconnect the connector (A) and then loosen the bolts. Прикрепленный файл  2 copy.jpg   40.16К   9 Количество загрузок: 4. Installation is the reverse of removal. • Do not damage the connector (A). Прикрепленный файл  3 copy.jpg   37.61К   8 Количество загрузок: • Do not use the connector (A) again. • Confirm that whether the tube is escaped a not by puling it. • Avoid suffering excessive impact. • Do not pile up the parts. • When connecting, make sure each tube goes into the hole upto specified area.
