Киа К7 1 VG
(VG) Кондиционер
  • 3850 сообщений
Отправлено 10 October 2012 - 14:49
Kia Cadenza VG (2010+) - снятие и установка радиатора кондиционера
Replacement 1. Recover the refrigerant with a recovery/ recycling/ charging station. 2. Disconnect the negative (-) battery terminal. 3. Remove the discharge line and liquid line (A) from the condenser. Прикрепленный файл  1 copy.jpg   35.56К   8 Количество загрузок: 4. Remove the radiator. (Refer to EM group-radiator). 5. Remove the condenser (A) by lifting it up. Be careful not to damage the radiator and condenser fins when removing the condenser. Прикрепленный файл  2 copy.jpg   38.02К   10 Количество загрузок: 6. Install in the reverse order of removal, and note these items : A. If you're installing a new condenser, add refrigerant oil ND-OIL8. B. Replace the O-rings with new ones at each fitting, and apply a thin coat of refrigerant oil before installing them. Be sure to use the right O-rings for R-134a to avoid leakage. C. Be careful not to damage the radiator and condenser fins when installing the condenser. D. Be sure to install the lower mount cushions of condenser securely into the holes. E. Charge the system, and test its performance.
#2 getAway Re: (VG) Кондиционер
  • 3850 сообщений
Отправлено 18 October 2012 - 16:26
Kia Cadenza VG (2010+) - снятие и установка компрессора кондиционера
Removal 1. If the compressor is marginally operable, run the engine at idle speed, and let the air conditioning work for a few minutes, then shut the engine off. 2. Disconnect the negative cable from the battery. 3. Recover the refrigerant with a recovery/charging station. 4. Loosen the drive belt.(Refer to EM group-Drive belt) 5. Remove the bolts, then disconnect the suction line (A) and discharge line (B) from the compressor. Plug or cap the lines immediately after disconnecting them to avoid moisture and dust contamination. Прикрепленный файл  1 copy.jpg   46.52К   9 Количество загрузок: 6. 6. Disconnect the compressor clutch connector (A), and then remove 4 mounting bolts and the compressor(B). Прикрепленный файл  2 copy.jpg   55.18К   10 Количество загрузок:
#3 getAway Re: (VG) Кондиционер
  • 3850 сообщений
Отправлено 18 October 2012 - 16:28
Installation
1.
Make sure of the length of compressor mounting bolts, and then tighten it A?B?C?D order.
Tightening torque :
20.0~32.9N.m (2.04~3.36kgf.m, 14.7~24.3 lb-ft)
Прикрепленный файл  1 copy.jpg   55.58К   9 Количество загрузок:
2.
A.
If you're installing a new compressor, drain all the refrigerant oil from the removed compressor, and measure its volume, Subtract the volume of drained oil from 120cc(4.20 oz.) the result is the amount of oil you should drain from the new compressor (through the suction fitting).
B.
C.
To avoid contamination, do not return the oil to the container once dispensed, and never mix it with other refrigerant oils.
D.
Immediately after using the oil, replace the cap
