киа сефия
(FB12) Генератор
  • 4010 сообщений
Отправлено 09 October 2012 - 15:10
Kia Sephia FB12 (1995-1998) - снятие и установка генератора
G 1.5 DOHC
G 1.6 DOHC
Прикрепленный файл  1.gif   65.34К   12 Количество загрузок:
Be sure the battery connections are not reversed, this will the rectifier.
Do not use of high-voltage testers such as a magger will damage the rectifier.
Remember that battery voltage is always applied to the generator B terminal.
Do not ground the L terminal while the engine is runing.
Do not start the engine while the connector is disconnected from the L and S terminals.
Remove in the order shown in the figure.
Inspect all parts and repair or replace as necessary. (Replace generator as one unit; do not disassemble.)
Install in the reverse order of removal.
Ещё обсуждения по киа сефия на MyKia.club:
