Киа Спортейдж 1 AL
кондиционер
  • 4013 сообщений
Отправлено 02 October 2012 - 16:49
Kia Sportage AL (1993-2005) - снятие и установка радиатора кондиционера
Removal 1. Chock wheels. 2. Disconnect negative battery cable. 3. Discharge the air conditioning system. Refer to Discharging/Evacuating/Charging in this section. 4. Disconnect refrigerant hoses at the condenser. 5. Remove the three plastic retainers attaching the trim panel to the upper shroud panel. 6. Remove the screw retaining the radiator grille to the hood stay. 7. Carefully depress the four tabs on the radiator grille and remove the grille from the vehicle. 8. Remove the radiator grille retaining clips from the side shroud panels and attach them to the radiator grille. 9. Disconnect the condenser fan connector. 10. Remove the three condenser fan assembly bolts and remove the condenser fan assembly. 11. Remove the four hood latch mounting bolts. Carefully lay the center stay on the lower shroud panel to avoid damage to the radiator. Прикрепленный файл  62181 copy.jpg   30.97К   7 Количество загрузок: 12. Install a Snap-ON® Hood Prop Rod Tool #A4590 or equivalent to support the hood. 13. Remove the upper shroud panel and hood support rod. Прикрепленный файл  62182 copy.jpg   33.67К   7 Количество загрузок: 14. Disconnect the wire harness clips and separate the wire harness from the shroud panel. 15. Lift the wire harness out from under the right and left shroud panels. Прикрепленный файл  62183 copy.jpg   35.38К   6 Количество загрузок: 16. Place a piece of cardboard between the radiator and the condenser. 17. Remove the nuts retaining the condenser. 18. Remove the condenser by puling upward ; lifting the radiator off the mounting studs and pulling the condenser forward and out of the vehicle. Прикрепленный файл  62191 copy.jpg   32.21К   6 Количество загрузок:
#2 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 02 October 2012 - 16:50
Installation
Gently place the condenser into position on the mounting studs, in front of the radiator.
Place the radiator on the mounting studs.
Install the condenser retaining nuts.
Tightening torque : 0.9kg-m (80lb-ft, 9N·m).
4.
Remove the cardboard.
5.
Insert the wire harness under the right and left shroud panels.
6.
Place the wire harness in position and connect the wire harness clips.
7.
Install the upper shroud panel and hood support rod.
8.
Support the hood with the hood support rod and remove the hood prop rod tool.
9.
Install the center stay and the four mounting bolts.
Tightening torque : 0.9kg-m (80lb-in, 9N·m)
10.
Install the condenser fan assembly and the three condenser fan assembly bolts.
11.
Connect the condenser fan connector.
12.
Carefully snap the radiator grille into place in front of the condenser fan assembly.
13.
Install the one screw retaining the radiator grille to the hood stay.
14.
Install the three plastic retainers attaching the trim panel to the upper shroud panel.
15.
Connect the refrigerant hoses to the condenser.
Tightening torque : 1.3kg-m(10lb-in, 13N·m).
Tightening torque : 2.2kg-m(16lb-in, 22N·m).
16.
Evacuate the A/C system. Refer to Discharging/Evacuating/Charging in this section. Perform vacuum test.
17.
Charge the A/C system. Refer to Discharging/Evacuating/Charging in this section.
Add 1.0 oz (30 cc) of refrigerant oil if the condenser has been replaced with a new unit. Perform a leak test.
18.
Connect the negative battery cable.
19.
Start engine and run the A/C system. Check for leaks at the condenser.
#3 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 19 October 2012 - 15:51
Kia Sportage AL (1993-2005) - снятие и установка компрессора кондиционера
Removal 1. Disconnect the negative battery cable. 2. Discharge the air conditioning system. Refer to Discharging/Evacuating/Charging in this section. 3. Remove the air conditioner lines from the compressor. Immediately plug all open fittings to keep moisture out of system. 4. Disconnect the compressor clutch electrical connector. Прикрепленный файл  1 copy.jpg   29.84К   9 Количество загрузок: 5. Raise vehicle and support. 6. Remove the four engine undercover mounting bolts and remove the undercover. Прикрепленный файл  2 copy.jpg   29.21К   10 Количество загрузок: 7. Loosen the compressor drive belt tensioner pulley nut. 8. Turn the tensioner adjusting bolt counter-clockwise to relieve tension on the belt. 9. Remove the drive belt. Прикрепленный файл  3 copy.jpg   23.94К   10 Количество загрузок: 10. Lower vehicle. 11. Remove the four compressor mounting bolts and remove the compressor. Прикрепленный файл  4 copy.jpg   31.68К   17 Количество загрузок:
#4 getAway Re: кондиционер
  • 4013 сообщений
Отправлено 19 October 2012 - 15:53
Installation
Install the compressor using four bolts.
Tightening torque : 2.44kg-m (18lb-ft, 24N·m)
Raise and support the vehicle.
Install the drive belt.
4.
Adjust the air conditioner drive belt to specification.
Specification : 0.35 in (9.0 mm) at 22lb (98N) of pressure
5.
Tighten the compressor drive belt tensioner pulley nut.
Tightening torque : 3.2kg-m (24lb-ft, 32N·m)
Прикрепленный файл  1 copy.jpg   24.52К   9 Количество загрузок:
6.
Install the engine undercover using four bolts.
Tightening torque : 0.8kg-m (71lb-ft, 8N·m)
Прикрепленный файл  2 copy.jpg   29.01К   9 Количество загрузок:
7.
Lower the vehicle.
8.
Install the air conditioner lines to the compressor.
Tightening torque : 2.4kg-m (18lb-ft, 24N·m)
9.
Connect the compressor clutch electrical connector.
Прикрепленный файл  3 copy.jpg   28.87К   9 Количество загрузок:
10.
Evacuate and charge the air conditioner system.
11.
12.
Start engine and run A/C system. Check for leaks at compressor.
Ещё обсуждения по киа спортейдж 1 al на MyKia.club:
