D 1.5 TCI-U2 (RDE) > Intelligent Manual Transmission > Intelligent Manual Transmission
P060141 Internal Control Module Memory Check Sum Error
P060147 Internal Control Module Memory Check Sum Error
P060148 Internal Control Module Memory Check Sum Error
P06B011 Sensor Power Supply "A" Circuit/Open
P06B012 Sensor Power Supply "A" Circuit/Open
P06B013 Sensor Power Supply "A" Circuit/Open
P071512 Input/Turbine Speed Sensor "A" Circuit
P071513 Input/Turbine Speed Sensor "A" Circuit
P071514 Input/Turbine Speed Sensor "A" Circuit
P071531 Input/Turbine Speed Sensor "A" Circuit
P0715A2 Input/Turbine Speed Sensor "A" Circuit
P073000 Incorrect Gear Ratio
P080512 Clutch Position Sensor "A" Circuit
P080564 Clutch Position Sensor "A" Circuit
P0805A2 Clutch Position Sensor "A" Circuit
P0805A3 Clutch Position Sensor "A" Circuit
P082212 Gear Lever Y Position Sensor 1
P082214 Gear Lever Y Position Sensor 1
P082261 Gear Lever Y Position Sensor 1
P0822A2 Gear Lever Y Position Sensor 1
P0822A3 Gear Lever Y Position Sensor 1
P08A600 Gear Lever Position Sensor System - Multiple Sensor Correlation
P090012 Clutch Actuator Circuit/open
P090014 Clutch Actuator Circuit/open
P090019 Clutch Actuator Circuit/open
P09001C Clutch Actuator Circuit/open
P090171 Clutch "A" Actuator Control Circuit Range/Performance
P090173 Clutch "A" Actuator Control Circuit Range/Performance
P090178 Clutch "A" Actuator Control Circuit Range/Performance
P090412 Gate Select Position "A"
P090414 Gate Select Position "A"
P090461 Gate Select Position Circuit
P091412 Gear Shift Position Circuit
P091414 Gear Shift Position Circuit
P091461 Gear Shift Position Circuit
U000188 High Speed CAN Communication Bus
U010087 Lost Communication With ECM/PCM "A"
U012187 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U110087 High Speed CAN2 Lost Communication (EMS-DCT)
U111788 High Speed CAN2 Communication (EMS-DCT)
#11
Отправлено 14 July 2023 - 14:54
Re: коды ошибок, расшифровка
D 1.5 TCI-U2 (RDE) > Selective Catalytic Reduction > Selective Catalytic Reduction
P007000 Ambient Air Temperature Sensor Circuit "A"
P05F400 Exhaust Aftertreatment Power Relay Control Circuit Low
P05F500 Exhaust Aftertreatment Power Relay Control Circuit high
P060600 ECM/PCM Processor
P062F00 Internal Control Module EEPROM Error
P063400 Control Module Internal Temperature "A" Too High
P06F200 Reductant Control Module Internal Temperature Sensor Circuit Low
P06F300 Reductant Control Module Internal Temperature Sensor Circuit High
P1F0100 Not Plausible MT Autorecognition for DCU
P1F0200 Not Plausible AT Autorecognition for DCU
P1F0300 Failure of Pressure Preparation Test
P1F0400 Not Plausible Autorecognition PIN for DCU
P1F3200 Exhaust Gas Temperature Sensor Circuit Low/High
P202A00 Reductant Tank Heater Control Circuit/Open
P202B00 Reductant Tank Heater Control Circuit Low
P202C00 Reductant Tank Heater Control Circuit High
P202E00 Reductant Injection Valve Circuit Range/Performance Bank 1 Unit 1
P203A00 Reductant Level Sensor "A" Circuit
P203B00 Reductant Level Sensor "A" Circuit Range/Performance
P203C00 Reductant Level Sensor "A" Circuit Low
P203D00 Reductant Level Sensor "A" Circuit High
P203E00 Reductant Level Sensor "A" Circuit Intermittent/Erratic
P204300 Reductant Temperature Sensor "A" Circuit Range/Performance
P204400 Reductant Temperature Sensor Circuit Low
P204500 Reductant Temperature Sensor Circuit High
P204700 Reductant Injection Valve Circuit/Open Bank 1 Unit 1
P204800 Reductant Injection Valve Circuit Low Bank 1 Unit 1
P204900 Reductant Injection Valve Circuit High Bank 1 Unit 1
P204A00 Reductant Pressure Sensor Circuit
P204B00 Reductant Pressure Sensor Circuit Range/Performance
P204C00 Reductant Pressure Sensor Circuit Low
P204D00 Reductant Pressure Sensor Circuit High
P204E00 Reductant Pressure Sensor Circuit Intermittent/Erratic
P204F00 Reductant System Performance Bank 1
P205B00 Reductant Tank Temperature Sensor Circuit Range/Performance
P205C00 Reductant Tank Temperature Sensor Circuit Low
P205D00 Reductant Tank Temperature Sensor Circuit High
P206B00 Reductant Quality Sensor Circuit Range/Performance
P207F00 Reductant Quality Performance
P208A00 Reductant Pump "A" Control Circuit/Open
P208B00 Reductant Pump "A" Control Performance/Stuck Off
P208C00 Reductant Pump "A" Control Circuit Low
P208D00 Reductant Pump "A" Control Circuit High
P208E00 Reductant Injection Valve Stuck Closed Bank 1 Unit 1
P209F00 Reductant Tank Heater Control Circuit Performance
P20A000 Reductant Purge Control Valve "A" Circuit /Open
P20A100 Reductant Purge Control Valve "A" Performance
P20A200 Reductant Purge Control Valve "A" Circuit Low
P20A300 Reductant Purge Control Valve "A" Circuit High
P20B900 Reductant Heater "A" Control Circuit/Open
P20BA00 Reductant Heater "A" Control Circuit Performance
P20BB00 Reductant Heater "A" Control Circuit Low
P20BC00 Reductant Heater "A" Control Circuit High
P20BE00 Reductant Heater "B" Control Circuit Performance
P20C900 Reductant Control Module Requested MIL Illumination
P20E800 Reductant Pressure Too Low
P20E900 Reductant Pressure Too High
P20EA00 Reductant Control Module Power Relay De-Energized Performance - Too Early
P20EE00 SCR NOx Catalyst Efficiency Below Threshold Bank 1
P20F400 Reductant Consumption Too Low
P20F500 Reductant Consumption Too High
P20FA00 Reductant Pump "B" Control Circuit/Open
P20FB00 Reductant Pump "B" Control Performance/Stuck Off
P20FC00 Reductant Pump "B" Control Circuit Low
P20FD00 Reductant Pump "B" Control Circuit High
P21C900 Reductant Control Module Power Relay/Relays Control Circuit High
P21CB00 Reductant Control Module Supply Voltage Low
P21CC00 Reductant Control Module Supply Voltage High
P220000 NOx Sensor Circuit Bank 1 Sensor 1
P220100 NOx Sensor Circuit Range/Performance Bank 1 Sensor 1
P220200 NOx Sensor Circuit Low Bank 1 Sensor 1
P220300 NOx Sensor Circuit High Bank 1 Sensor 1
P220B00 NOx Sensor Supply Voltage Circuit Bank 1 Sensor 2
P220E00 NOx Sensor Heater Control Circuit Range/Performance Bank 1 Sensor 1
P220F00 NOx Sensor Heater Control Circuit Range/Performance Bank 1 Sensor 2
P225C00 NOx Sensor Performance - Signal Biased/Stuck High Bank 1 Sensor 1
P225D00 NOx Sensor Performance - Signal Stuck Low Bank 1 Sensor 1
P225E00 NOx Sensor Performance - Signal Biased/Stuck High Bank 1 Sensor 2
P225F00 NOx Sensor Performance - Signal Stuck Low Bank 1 Sensor 2
P229E00 NOx Sensor Circuit Bank 1 Sensor 2
P229F00 NOx Sensor Circuit Range/Performance Bank 1 Sensor 2
P22A000 NOx Sensor Circuit Low Bank 1 Sensor 2
P22A100 NOx Sensor Circuit High Bank 1 Sensor 2
P22FB00 NOx Sensor Performance - Sensing Element Bank 1 Sensor 1
P22FE00 NOx Sensor Performance - Sensing Element Bank 1 Sensor 2
P249E00 Closed Loop Reductant Injection Control At Limit - Flow Too High
P2BA600 NOx Exceedence - SCR NOx Catalyst Performance
P2BA700 NOx Exceedence - Empty Reagent Tank
P2BA800 NOx Exceedence - Interruption of Reagent Dosing Activity
P2BA900 NOx Exceedence - Insufficient Reagent Quality
P2BAA00 NOx Exceedence - Low Reagent Consumption
P2C7A00 SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 2
U007400 Control Module Communication Bus "B" Off
U010000 Lost Communication with ECM/PCM 'A'
U029D00 Lost Communication With NOX Sensor "A"
U029E00 Lost Communication With NOX Sensor "B"
D 1.5 TCI-U2 (RDE) > Transmission > Automatic Transaxle
P060100 Internal Control Module Memory Check Sum Error
P070500 Transmission Range Sensor Circuit Malfunction
P070592 Transmission Range Sensor Circuit Malfunction
P070600 Shift Cable alignment error between TGS Lever and Transmission Range Sensor
P070629 Shift Cable alignment error between TGS Lever and Transmission Range Sensor
P071100 Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
P071102 Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
P071123 Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
P071124 Transmission Fluid Temperature Sensor "A" Circuit Range/Performance
P071200 Transmission Fluid Temperature Sensor "A" Circuit Low Input
P071211 Transmission Fluid Temperature Sensor "A" Circuit Low Input
P071300 Transmission Fluid Temperature Sensor "A" Circuit High Input
P071315 Transmission Fluid Temperature Sensor "A" Circuit High Input
P071700 Input/Turbine Speed Sensor "A" Circuit No Signal
P071711 Input/Turbine Speed Sensor "A" Circuit No Signal
P071712 Input/Turbine Speed Sensor "A" Circuit No Signal
P071714 Input/Turbine Speed Sensor "A" Circuit No Signal
P071729 Input/Turbine Speed Sensor "A" Circuit No Signal
P071731 Input/Turbine Speed Sensor "A" Circuit No Signal
P072100 Output Speed Sensor Circuit Range/Performance
P072162 Output Speed Sensor Circuit Range/Performance
P072200 Output Speed Sensor Circuit No Signal
P072211 Output Speed Sensor Circuit No Signal
P072212 Output Speed Sensor Circuit No Signal
P072214 Output Speed Sensor Circuit No Signal
P072229 Output Speed Sensor Circuit No Signal
P072231 Output Speed Sensor Circuit No Signal
P072900 Gear 6 Incorrect Ratio
P072962 Gear 6 Incorrect Ratio
P073100 Gear 1 Incorrect Ratio
P073162 Gear 1 Incorrect Ratio
P073200 Gear 2 Incorrect Ratio
P073262 Gear 2 Incorrect Ratio
P073300 Gear 3 Incorrect Ratio
P073362 Gear 3 Incorrect Ratio
P073400 Gear 4 Incorrect Ratio
P073462 Gear 4 Incorrect Ratio
P073500 Gear 5 Incorrect Ratio
P073562 Gear 5 Incorrect Ratio
P074100 Torque Converter Clutch Circuit Performance or Stuck Off
P074177 Torque Converter Clutch Circuit Performance or Stuck Off
P074300 Torque Converter Clutch Circuit Electrical
P074311 Torque Converter Clutch Circuit Electrical
P074312 Torque Converter Clutch Circuit Electrical
P074313 Torque Converter Clutch Circuit Electrical
P074800 Pressure Control Solenoid Valve(VFS) "A" Electrical
P074811 Pressure Control Solenoid Valve(VFS) "A" Electrical
P074812 Pressure Control Solenoid Valve(VFS) "A" Electrical
P074813 Pressure Control Solenoid Valve(VFS) "A" Electrical
P075300 Shift Control Solenoid Valve "A" Electrical (UD/B)
P075311 Shift Control Solenoid Valve "A" Electrical (UD/B)
P075312 Shift Control Solenoid Valve "A" Electrical (UD/B)
P075313 Shift Control Solenoid Valve "A" Electrical (UD/B)
P075800 Shift Control Solenoid Valve "B" Electrical (2-6/B)
P075811 Shift Control Solenoid Valve "B" Electrical (2-6/B)
P075812 Shift Control Solenoid Valve "B" Electrical (2-6/B)
P075813 Shift Control Solenoid Valve "B" Electrical (2-6/B)
P076300 Shift Control Solenoid Valve "C" Electrical (35R/C)
P076311 Shift Control Solenoid Valve "C" Electrical (35R/C)
P076312 Shift Control Solenoid Valve "C" Electrical (37R/C)
P076313 Shift Control Solenoid Valve "C" Electrical (35R/C)
P076800 Shift Control Solenoid Valve "D" Electrical (OD/C)
P076811 Shift Control Solenoid Valve "D" Electrical (OD/C)
P076812 Shift Control Solenoid Valve "D" Electrical (OD/C)
P076813 Shift Control Solenoid Valve "D" Electrical (OD/C)
P077300 Shift Control Solenoid Valve "E" Electrical (SS-A)
P077311 Shift Control Solenoid Valve "E" Electrical (SS-A)
P077312 Shift Control Solenoid Valve "E" Electrical (SS-A)
P077313 Shift Control Solenoid Valve "E" Electrical (SS-A)
P088000 TCM Power Input Signal
P088013 TCM Power Input Signal
P270900 Shift Control Solenoid Valve "F" Electrical (SS-B)
P270911 Shift Control Solenoid Valve "F" Electrical (SS-B)
P270912 Shift Control Solenoid Valve "F" Electrical (SS-B)
P270913 Shift Control Solenoid Valve "F" Electrical (SS-B)
U000100 High Speed CAN Communication Bus
U010087 Lost Communication with ECM/PCM 'A'
Ещё обсуждения по Киа Каренс 4 KY на MyKia.club:
Киа Каренс 4 KY
Другие модели Киа →
Киа Каренс клуб →
Двигатель и КПП Kia Carens →
кондиционерАвтор krionika, 26 Feb 2024 |
