Система охлаждения Kia Carnival 1 (GQ) 2.5L бензин
Система охлаждения Kia Carnival 1 (GQ) 2.5L бензин.gif 17.56К
5 Количество загрузок:
1 WATER PUMP ASSY 0K9BV15010 1
2 FAN COMPT.-ELECTRIC 0K55215025A 1
2 FAN COMPT.-ELECTRIC 0K55215025B 1
3 FAN ASSY-COOLING 0K55215140 1
3 FAN ASSY-COOLING 0K55215140A 1
4 MOTOR-RADIATOR COOLING FAN 0K55215150 1
4 MOTOR-RADIATOR COOLING FAN 0K55215150A 1
5 THERMO HOUSING.ASSY 0K5581507XA 1
5 THERMO HOUSING.ASSY 0K9BV1507XE 1
5 THERMO HOUSING.ASSY 0K9BV1507XF 1
6 PULLEY-COOLANT PUMP 0K9BV15131 1
7 HOSE-WATER,UP. 0K55815186C 1
7 HOSE-WATER,UP. 0K55815186D 1
8 HOSE-RADIATOR LOWER 0K55815187A 1
8 HOSE-RADIATOR LOWER 0K55C15187 1
8 HOSE-WATER, LWR 0K56P15187 1
9 PIPE ASSY-WATER,RH 0K55815190C 1
9 PIPE ASSY-WATER,UPR 254413Y200 1
9 PIPE ASSY-WATER,UPR 254413Y201 1
9 PIPE ASSY-WATER,RH 254413Y250 1
10 WATER HOSE, RH 0K55815191C 1
10 WATER HOSE, RH 0K55815191D 1
10 WATER HOSE, RH 0K55815191E 1
10 WATER HOSE, RH 254113Y200 1
11 RADIATOR ASSY 0K55815200 1
11 RADIATOR ASSY 0K55815200A 1
11 RADIATOR ASSY 0K55815200B 1
11 RADIATOR ASSY 0K55815200C 1
11 RADIATOR ASSY 0K55815200D 1
11 RADIATOR ASSY 0K55815200E 1
11 RADIATOR ASSY 0K55815200F 1
11 RADIATOR ASSY 0K55C15200 1
11 RADIATOR ASSY 0K55C15200A 1
11 RADIATOR ASSY 0K55C15200B 1
11 RADIATOR ASSY 0K55C15200C 1
11 RADIATOR ASSY 0K55C15200D 1
11 RADIATOR ASSY 0K55C15200E 1
12 RUBBER-MTG 0K93015202 2
13 GASKET-DRAIN COCK 0FE6515204 GSL 1
14 CAP ASSY-RADIATOR 0K20215205 GSL 1
14 CAP ASSY-RADIATOR 0K20215205A 1
15 GUIDE-DRAIN 0FE6515209 GSL 1
16 COWLING ASSY-FAN 0K55215210A 1
16 COWLING ASSY-FAN 0K55215210B 1
17 BRACKET ASSY-RADIATOR MTG UPR,LH 0K55215220B 1
17 BRACKET ASSY-RADIATOR MTG UPR,LH 0K55215220C 1
18 TANK ASSY-RESERVOIR 0K55815250 1
18 TANK ASSY-RESERVOIR 0K55815250A 1
18 TANK ASSY-RESERVOIR 0K55815250B 1
18 TANK ASSY-RESERVE 0K55815250C 1
19 HOSE ASSY-BYPASS 0K9BV15280 1
19 PIPE ASSY-WATER INLET 0K9BV15280A 1
20 CLIP 0K9BV15286 2
21 O-RING 0K9BV15287 3
21 O-RING 254623Y200 3
22 HOSE-WATER OUTLET 0K95K15290 1
22 PIPE-WATER OUTLET 0K95K15290A 1
22 PIPE ASSY-WATER OUTLET 0K9BV15290 1
23 COCK-WATER DRAIN 0FE6515203 GSL 1
24 BRACKET ASSY-RADIATOR MTG UPR,RH 0K55215330B 1
24 BRACKET ASSY-RADIATOR MTG UPR,RH 0K55215330C 1
25 CLIP-HOSE 0K86215388 2
26 CLIP-FAN 0K20115T56 1
27 PIPE & HOSE ASSY-HEATER 0K55861214A 1
27 PIPE & HOSE ASSY-HEATER 0K5661518X 1
27 PIPE & HOSE ASSY-HEATER 0K5661518XA 1
28 HOSE-RADIATOR RESERVOIR K9932507300 1
29 GASKET-WATER PUMP 0K9BV15116 1
30 BOLT K997960620B 7
31 NUT-FLANGE K999400602 ATM 4
32 CLAMP-HOSE K9WNCB3700 GSL 6
32 CLAMP K9WNCB3700B 6
33 BOLT 1141506203 2
33 SCREW K907860620 97MY 2
33 SCREW K907860620B 2
34 CLIP-HOSE K992831000 EXPORT 2
34 CLIP-HOSE K992831000B 2
35 SCREW K907860616B GSL 3
36 BOLT 1141506163 4
36 SCREW K907860616B GSL 4
36 BOLT K997940616B GSL 4
37 BOLT K997960610B GSL 2
38 CLIP-HOSE K992832200P 1
39 BOLT 1140308251 1
39 BOLT K997960825 10F 1
39 BOLT K997960825B 1
40 CAP 0K55215255 1
41 HOSE-BYPASS 0K56615282 1
42 CLIP-HOSE K992831200B GSL 2
43 BAND K997093200 DASHBOARD 1
44 HOSE ASSY-WATER 0K55W13690 1
40 CAP 0K55215255 1
Тема закрыта
