Передние амортизаторы и пружины Kia Shuma (SD)
передние амортизаторы и пружины Kia Shuma (SD) (1).gif 12.94К
5 Количество загрузок:
передние амортизаторы и пружины Kia Shuma (SD) (2).gif 16.24К
1 NUT-FLANG 0H26628091A 98MY,99MY 4
2 SPRING-COIL 0K2A134011A 2
2 SPRING-COIL,FRT 0K2A234011 2
2 SPRING-COIL 0K2A334011 2
2 SPRING-COIL 0K2A534011A 2
2 SPRING-COIL 0K2AC34011 2
2 SPRING-COIL 0K2AD34011 2
2 SPRING-COIL,FRT 0K2NC34011 2
2 SPRING-COIL,FRT 0K2SA34011 2
3 RUBBER SEAT 0K24134012 2
4 SEAT 0K20134013B 2
5 BOOT-DUST 0K24434015 2
6 CAP 0K20134019 2
6 CAP M101134019 2000CC 2
7 NUT-FLANGE 0GJ2134031 8
7 NUT-FLANGE 0K2A134031 8
7 NUT-FLANGE KH38034034 8
8 NUT-FLANGE K9YB041201 2
8 NUT-FLANGE KGA2A34091 2
8 NUT-FLANGE M9YB041201 2
9 NUT-FLANGE LOCK 0K20134091 4
10 BOLT 0G03034098 2
11 STOPPER-BUMPER 0K20134111 2
11 SPACER 0K20134111A 2
11 STOPPER-BUMPER 0K2SA34111 2
12 BOLT-FLANGE 0K2A134116 4
13 ARM ASSY-LWR, RH 0K2A134300B 1
13 ARM ASSY-LWR, RH 0K2C034300 1
13 ARM ASSY-LWR, RH 0K2N134300 1
13 ARM ASSY-LWR, RH 0K2N134300A 1
13 ARM ASSY-LWR, RH 0K2NA34300 1
13 ARM ASSY-LWR, RH 0K2NA34300A 1
13 ARM ASSY-LWR, RH 0K2NA34300B 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2A134900D 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2A134900E 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2A334900D 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2A334900E 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2A334900F 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2N134900C 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2N134900D 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2N134900F W/O ABS 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2N334900C 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2N334900D 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2N334900F W/ABS 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2SA34900 1
14 SHOCK ABSORBER ASSY-FRONT,LH 0K2SB34900 1
15 SEAT-SPRING 0K2A134340A 2
15 SEAT-SPRING 0K2NA34340A 2
16 BOLT 0K20134349 4
17 ARM ASSY-LWR, LH 0K2A134350B 1
17 ARM ASSY-LWR, LH 0K2C034350 1
17 ARM ASSY-LWR, LH 0K2N134350 1
17 ARM ASSY-LWR, LH 0K2N134350A 1
17 ARM ASSY-LWR, LH 0K2NA34350 1
17 ARM ASSY-LWR, LH 0K2NA34350A 1
17 ARM ASSY-LWR, LH 0K2NA34350B 1
18 SHEET KGA2A34003 2
19 RUBBER-STRUT MTG,FRT 0K2A134380 2
19 RUBBER-STRUT MTG,FRT 0K2A134380A 2
19 RUBBER-STRUT MTG,FRT 0K2NA34380 2
20 BEARING-STRUT 0K2A13438XA 2
21 WASHER 0K20134405 2
22 WASHER-PLAIN 0K2A134409 2
23 BUSH-RUBBER 0K2A134460 2
23 BUSH-RUBBER 0K2C034460 2
24 BRACKET-LOWER ARM BUSH,RH 0K2A13446X 1
25 BRACKET-LOWER ARM BUSH,LH 0K2A13446Y 1
26 JOINT-BALL 0K2A134550A 2
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2A134700D 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2A134700E 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2A334700D 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2A334700E 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2A334700F 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2N134700C 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2N134700D 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2N134700F W/O ABS 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2N334700C 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2N334700D 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2N334700F W/ABS 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2SA34700 1
27 SHOCK ABSORBER ASSY-FRONT,RH 0K2SB34700 1
28 NUT K999211400 SOFT TOP 2
29 WASHER-SPRING K999711400 DSL 2
30 NUT-FLANGE K999401001 GSL 2
6 CAP 0K20134019 2
Задние амортизаторы и пружины Kia Shuma (SD)
Задние амортизаторы и пружины Kia Shuma (SD).gif 15.63К
4 Количество загрузок:
1 SPRING-COIL 0K2A128011A 2
1 SPRING-COIL 0K2A228011 2
1 SPRING-COIL 0K2AC28011 2
1 SPRING-RR 0K2NC28011 2
1 SPRING-RR 0K2SA28011 2
2 RUBBER SEAT 0K2A128012 2
3 RUBBER-SEAT BOOT 0G03028015B 2
4 CAP 0G03028019 2
5 NUT 0B03728091 2
6 NUT-FLANG 0H26628091A 98MY,99MY 4
7 SEAT 0K201280A3 2
8 STOPPER-BUMPER 0K2SA28111 2
8 STOPPER-BUMPER 0K90028111 2
8 STOPPER-BUMPER 0K90028111A 2
9 BOLT 0K2A128112 4
10 BOLT 0K2A128113 2
11 LINK ASSY-TRAILING,RH 0K2A128300C 1
11 LINK ASSY-TRAILING,RH 0K2NA28300 1
11 LINK ASSY-TRAILING,RH 0K2NA28300A 1
12 BOLT 0K24T28313 2
13 WASHER 0K2A128340 2
13 WASHER 0K2C028340 2
13 WASHER 0K2C028340A 2
13 WASHER 0K2NA28340 2
13 WASHER 0K2NA28340A 2
14 LINK ASSY-TRAILING,LH 0K2A128350C 1
14 LINK ASSY-TRAILING,LH 0K2NA28350 1
14 LINK ASSY-TRAILING,LH 0K2NA28350A 1
15 RUBBER-MTG,RH 0K20128380A 1
15 RUBBER-MTG,RH 0K20128380B 1
15 RUBBER-MTG,RH 0K2NA28380 1
15 RUBBER-MTG,RH 0K2NA28380A 1
16 RUBBER-MTG,LH 0K20128390A 1
16 RUBBER-MTG,LH 0K20128390B 1
16 RUBBER-MTG,LH 0K2NA28390 1
16 RUBBER-MTG,LH 0K2NA28390A 1
17 LINK ASSY-LATERAL,FRT 0K2AA28500 2
18 LINK-LATERAL REAR,RH 0K2A128600B 2
18 LINK-LATERAL REAR,RH 0K2A128600C 2
19 SHOCK ABSORBER ASSY-REAR,RH 0K2A128700B 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2A128700D 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2A328700B 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2A328700C 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2A328700E 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2NA28700 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2NB28700 1
19 DAMPER ASSY-REAR 0K2SA28700 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2SA28700A 1
19 DAMPER ASSY-REAR 0K2SB28700 1
19 SHOCK ABSORBER ASSY-REAR,RH 0K2SB28700A 1
20 MEMBER ASSY-REAR CROSS 0K2A128800E 1
20 MEMBER ASSY-REAR CROSS 0K2A128800G 1
20 MEMBER ASSY-REAR CROSS 0K2A128800H 1
21 BOLT 0K2A128890 FOR C/MEMBER 8
22 SHOCK ABSORBER ASSY-REAR,LH 0K2A128900B 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2A128900D 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2A328900B 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2A328900E 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2NA28900 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2NB28900 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2SA28900 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2SA28900A 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2SB28900 1
22 SHOCK ABSORBER ASSY-REAR,LH 0K2SB28900A 1
23 WASHER KGA2A28662A 2
24 BOLT-FLANGE 0K2A134116 4
25 WASHER 0B00134402A 2
26 WASHER-LWR SPINDLE 0019334662 2
27 SHEET 0G03028013A 2
27 SHEET 0G03028013B 2
27 SHEET 0K2NA28013 1
28 BRACKET-STABILIZER,RH 0K2A12815XA 1
28 BRACKET-STABILIZER,RH 0K2A12815XB 1
29 BRACKET-STABILIZER,LH 0K2A12815YA 1
29 BRACKET-STABILIZER,LH 0K2A12815YC 1
30 NUT-FLANGE K999401401 GSL 2
30 NUT-FLANGE K9YB041201 2
31 BOLT K997940816 GSL 2
32 NUT-FLANGE 0K2A128081 6
32 NUT K999400802 DSL 4
33 WASHER-SPRING K999711400 DSL 2
34 WASHER-SPRING K999711000 D/TIRE 4
35 WASHER-SPRING K999711200 WHEEL PARKING S 2
36 BOLT K997961016 GSL 2
37 SHEET,LH 0K2NA28014 1
38 BOLT 0K41313646 FOR LINK 4
4 CAP 0G03028019 2
5 NUT 0B03728091 2
7 SEAT 0K201280A3 2
9 BOLT 0K2A128112 4
