D 2.9 TCI-J3 > Airbag > Airbag Control
B1111 Ignition Voltage High
B1112 Battery Voltage Too Low
B1347 Driver Air Bag Resistance Too Low or Short
B1353 Passenger Air Bag Resistance Too Low or Short
B1354 Passenger Air Bag Short To Ground
B1355 Passenger Air Bag Short To Battery
B1361 Driver Seat Belt Pretensioner Resistance Too High or Open
B1362 Driver Seat Belt Pretensioner Resistance Too Low or Ghort
B1363 Driver Seat Belt Pretensioner Short To Ground
B1364 Driver Seat Belt Pretensioner Short To Battery
B1367 Passenger Seat Belt Pretensioner Resistane Too High or Open
B1368 Passenger Seat Belt Pretensioner Resistane Too Low or Short
B1369 Passenger Seat Belt Pretensioner Short To Ground
B1370 Passenger Seat Belt Pretensioner Short To Battery
B1511 Driver Seat Belt Buckle Switch Short to Battery or Open
B1512 Driver Seat Belt Buckle Switch Short to GND or Short
B1513 Passenger Seat Belt Buckle Switch short to Battery or Open
B1514 Passenger Seat Belt Buckle Switch short to GND or Short
B1620 Internal Fault
B1650 Crash Recorded Front Airbag
B1655 Crash Recorded Side Airbag
B1657 Ignition Recorded Belt Pretensioner
B1661 SRSCM Unmatching
B2500 Warning Lamp Failure
					#1
			Отправлено 14 May 2021 - 19:19
					 Re: коды ошибок, расшифровка
D 2.9 TCI-J3 > Brake > ABS(EURO-3)
C1101 Battery Voltage High
C1102 Battery Voltage Low Volt
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/No Signal
C1203 FR Wheel Sensor - Open or Short to GND/Battery
C1204 FR Wheel Sensor - Range/Performance
C1205 FR Wheel Sensor - No Signal
C1206 RL Wheel Sensor - Open or Short to GND/Battery
C1207 RL Wheel Sensor - Range/Performance
C1208 RL Wheel Sensor - No Signal
C1209 RR Wheel Sensor - Open or Short to GND/Battery
C1210 RR Wheel Sensor Range/Performance
C1211 RR Wheel Sensor - No Signal
C1604 ECU(Brake System) Hardware error
C2112 Main Relay Circuit
C2402 Motor Electrical
D 2.9 TCI-J3 > Engine > Engine(J3-TCI)
P0100 Exhaust Gas Recirculation (EGR) or Air Intake System
P0110 Intake Air Temperature Sensor 1 Circuit
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0180 Fuel Temperature Sensor Circuit Malfunction
P0190 Rail Pressure Sensor Circuit
P0202 Injector Circuit -Cylinder 2
P0203 Injector Circuit -Cylinder 3
P0204 Injector Circuit -Cylinder 4
P0220 Accelerator Pedal Sensor 2 Circuit Malfunction
P0226 Accelerator Pedal Malfunction
P0325 Knock Sensor Circuit Malfunction
P0335 Crankshaft Position Sensor A Circuit Range/Performance
P0380 Air Heater Relay 1 Malfunction
P0381 Glow Indicator Lamp Control Circuit Malfunction
P0382 Air Heater Relay 2 Malfunction
P0400 EGR Circuit Malfunction
P0560 System Voltage Malfunction
P0650 Malfunction Indicator Lamp Control Circuit Malfunction
P1119 Inlet Metering Valve Control Malfunction
P1120 Inlet Metering Valve Circuit Malfunction
P1140 Intake Air Temperature Circuit Malfunction
P1150 Atmospheric Pressure Sensor Circuit Malfunction
P1300 Injector Control Circuit Malfunction
P1310 Injector Control Circuit Malfunction
P1458 A/C Signal Malfunction
P1500 Vehicle Speed Sensor Malfunction
P1543 Brake Switch Malfunction
P1608 Engine Control Module Malfunction
P1610 Sensor Reference Voltage Malfunction
P1611 Immobilizer-Transponder Malfunction
P1612 Immobilizer-SMARTRA Malfunction
P1613 Immobilizer-Communication Malfunction
P1614 Engine Control Module Software Malfunction
P1620 A/C Relay Malfunction
P1626 Immobilizer Indicator Lamp Control Circuit Malfunction
P1640 Main Relay Malfunction
P1672 Fan Relay Malfunction-Low Speed
P1673 Fan Relay Malfunction-High Speed
P1674 A/C Fan Relay Malfunction
P1690 Water Heater Relay Malfunction
P1780 Torque Reduction Signal Malfunction
P1786 Engine RPM Output Circuit Malfunction
P0150 O2 Sensor Circuit(Bank 2 / Sensor 1)
P0443 Evaporative Emission System-Purge Control Valve Circuit
P1166 Fuel Trim(Bank 1)
P1505 Idle Speed Control Actuator Circuit 1-Low
P1507 Idle Speed Control Actuator Circuit 2-Low
P1624 Cooling Fan Relay(Low) Circuit Malfunction
D 2.9 TCI-J3 > Transmission > Automatic Transaxle
P0717 Input/Turbine Speed Sensor No Signal
P0722 Output Speed Sensor No Signal
P0743 Torque Converter Clutch(Lock-Up Sol.) Circuit Electrical
P0748 Pressure Control Solenoid Electrical
P0753 Shift Solenoid 1(A) Electrical
P0758 Shift Solenoid 2(B) Electrical
P1780 Torque Reduction Signal(TCM to ECM)
P1121 TPS Signal(ECM To TCM)-PWM
P0500 Vehicle Speed Sensor
G 2.5 DOHC > Airbag > Airbag Control
G 2.5 DOHC > Brake > Anti-Lock Brake
G 2.5 DOHC > Engine > Gasoline KV6
P0100(General) Mass Air Flow(MAF)Sensor Malfunction
P0100 Mass or Volume Air Flow Circuit
P0110(General) Intake Air Temperature(IAT) Circuit Malfunction
P0115(General) Engine Coolant Temperature(ECT) Circuit Malfunction
P0120(General) Throttle Position Sensor(TPS) Malfunction
P0130(General) Heated O2 Sensor(HO2S) Circuit Malfunction(B1/S1)
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0135(General) Heated O2 Sensor(HO2S) Heater Malfunction(B1S1)
P0150(General) Heated O2 Sensor(HO2S) Circuit Malfunction(B2/S1)
P0155 O2 Sensor Circuit Heater Circuit (Bank 2 / Sensor 1)
P0155(General) Heated O2 Sensor(HO2S) Heater Malfunction(B2S1)
P0170 Fuel Trim (Bank 1)
P0173(General) FUEL TRIM MALFUNCTION(B2)
P0201(General) Injector Circuit -Cylinder 1
P0202 Injector Circuit-Cylinder 2
P0202(General) Injector Circuit -Cylinder 2
P0203 Injector Circuit-Cylinder 3
P0203(General) Injector Circuit -Cylinder 3
P0204 Injector Circuit-Cylinder 4
P0204(General) Injector Circuit -Cylinder 4
P0205 Injector Circuit-Cylinder 5
P0205(General) Injector Circuit -Cylinder 5
P0206 Injector Circuit-Cylinder 6
P0206(General) Injector Circuit -Cylinder 6
P0230(General) Fuel Pump Circuit Malfunction
P0335(General) Crankshaft Position(CKP) Sensor Circuit Malfunction
P0340(General) Camshaft Position Sensor Circuit Malfunction
P0443(General) Evaporative Emission(EVAP) System Purge Control Valve
P0500 Vehicle Speed Sensor Signal Circuit Malfunction
P0500(General) Vehicle Speed Sensor(VSS) Malfunction
P0505 Idle Air Control System
P0606 ECM/PCM Processor
P0606(General) ECM Malfunction(Processor)
P1121(General) TPS SIGNAL(ECU TO TCU)-PWM
P1166(General) Feedback System(B1)
P1167 Fuel System Malfunction (Bank 1)
P1167(General) Feedback System(B2)
P1505(General) Idle Air Control(IAC)Valve Opening Coil Signal Malfunction
P1507(General) Idle Air Control(IAC)Valve Closing Coil Signal Malfunction
P1523(General) VICS Solenoid Valve 1 Circuit
P1623 Serial Communication Problem with TCU (Timeout)
P1642(General) No Answer From Immobilizer
P1672(General) Cooling Fan Relay Circuit-Low
P1673(General) Cooling Fan Relay Circuit-High
P1699 Main Relay Circuit
P1699(General) Main Relay Malfunction
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0050 HO2S Heater Control Circuit (Bank 2 / Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 / Sensor 2)
P0111 Intake Air Temperature Sensor 1 Circuit Range / Performance
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0153 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 1)
P0156 O2 Sensor Circuit (Bank 2 / Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 / Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 / Sensor 2)
P0172 System too Rich (Bank 1)
P0430 Catalyst System Efficiency below Threshold (Bank 2)
P0605 Internal Control Module Read only Memory(ROM) Error
P1307 Acceleration Sensor-Range / Performance
P1308 Acceleration Sensor - Low Input
P1309 Acceleration Sensor - High Input
P1506 Idle Speed Control Actuator Circuit 1-High
P1508 Idle Speed Control Actuator Circuit 2-High
P1529 TCM MIL On Request Signal
P1602 ECU-TCU Communication Line Malfunction
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
			Отправлено 14 May 2021 - 19:20
G 2.5 DOHC > Transmission > Automatic Transaxle
P0705 Transaxle range signal (P, R, N, D, 2, L) malfunction
P0710 ATF Sensor Open or Short
P0727 Engine Revolution Sensor Malfunction
P1115 Water Temperature Sensor
P0703 Stop Lamp (Brake) Switch Circuit Malfunction
P0713 Transmission Fluid Temperature Sensor "A" Circuit High Input
P0715 Input/Turbine Speed Sensor "A" Circuit
P0720 Output Speed Sensor (Pulse Generator B) Circuit
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Gear Incorrect Ratio
P0750 Shift Control Solenoid Valve "A" (Low-Reverse Brake Control Solenoid)-Open or Short
P1699 Main Relay Control Circuit Malfunction
P1723 TCM Power Relay Open or Short (Ground)
P0741 Torque Converter Clutch Circuit Stuck Off
Ещё обсуждения по Киа Карнивал 1 GQ на MyKia.club:
| Киа Карнивал 1 GQ
				Киа Карнивал клуб →
				Двигатель и КПП Kia Carnival → замена АКППАвтор krionika, 29 Oct 2011 |
| Киа Карнивал 1 GQ
				Киа Карнивал клуб →
				Электрика и Аудио Kia Carnival → подогреватель антифризаАвтор Сергей 09, 11 Dec 2024 |
|  | Киа Карнивал 1 GQ
				Киа Карнивал клуб →
				Двигатель и КПП Kia Carnival → момент затяжки двигателяАвтор krionika, 13 Jul 2011 |
| Киа Карнивал 1 GQ
				Киа Карнивал клуб →
				Электрика и Аудио Kia Carnival → задние фонариАвтор krionika, 12 Nov 2009 |
| Киа Карнивал 1 GQ
				Киа Карнивал клуб →
				Электрика и Аудио Kia Carnival → передние фарыАвтор krionika, 31 Oct 2009 |
