Киа Спортейдж 1 AL
Сообщений в теме: 5
Отправлено 06 May 2021 - 11:54
Коды ошибок Kia Sportage 1 (AL)
00 Crash Occurred
10 Ignition Power Supply Circuit Low
11 Ignition Power Supply Circuit High
31 ADU Fault
37 Connector Fault
42 Warning Light Circuit Short to Ground
44 Warning Light Circuit Short to Battery
57 Passenger Air Bag Module Short to Ground
58 Passenger Air Bag Module Short to Battery
59 Passenger Air Bag Module Short
60 Passenger Air Bag Module Open
61 Driver Air Bag Module Short to Ground
63 Driver Air Bag Module Open
65 Driver Air Bag Module Short
67 Driver Air Bag Module Short to Battery
78 ADU Inconsistency (exclusive of PAB)
G 2.0 DOHC > Brake > Anti-Lock Brake
C1101 Battery voltage High
C1102 Battery voltage Low
C1200 Wheel speed sensor Front - LH open / short
C1201 Wheel speed sensor Front - LH Range/Performance/Intermittent
C1202 Wheel speed sensor Front - LH Invalid/No signal
C1203 Wheel speed sensor Front - RH open / short
C1204 Wheel speed sensor Front - RH Range/Performance/Intermittent
C1205 Wheel speed sensor Front - RH Invalid/No signal
C1206 Wheel speed sensor Rear - LH open / short
C1207 Wheel speed sensor Rear - LH Range/Performance/Intermittent
C1208 Wheel speed sensor Rear - LH Invalid/No signal
C1274 G-Sensor Error
C1275 G-Sensor Range/Performance Error
C1604 HECU Hardware Error
C2112 Valve Relay Error
C2402 Motor Electrical Error
G 2.0 DOHC > Engine > Unleaded
P0100 Mass or Volume Air Flow Circuit
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0403 Exhaust Gas Recirculation Control Circuit
P0443 Evaporative Emission System-Purge Control Valve Circuit
P0561 System Voltage Unstable
P0601 Internal Control Module Memory Check Sum Error
P1121 Throttle Position Sensor (TPS) Signal Malfunction
P1127 Fuel Trim too Lean at Higher Load (←Multiple) (Bank 1)
P1500 Vehicle Speed Sensor Signal Circuit Malfunction
P1505 Idle Speed Control Actuator Circuit 1-Low
P1506 Idle Speed Control Actuator Circuit 1-High
P1507 Idle Speed Control Actuator Circuit 2-Low
P1508 Idle Speed Control Actuator Circuit 2-High
P0722 Output Speed Sensor (Pulse Generator B) Circuit No Signal
P0753 Shift Control Solenoid Valve "A"-Electrical
P0758 Shift Control Solenoid Valve " B" Electrical
Отправлено 06 May 2021 - 11:55
D 2.0 RE(RF-TCI) > Airbag > Airbag Control
00 Crash Occurred
31 ADU Fault
37 Connector Fault
D 2.0 RE(RF-TCI) > Brake > Anti-Lock Brake
D 2.0 RE(RF-TCI) > Engine > Engine Control
01 Np Sensor
02 TDC Sensor
06 Vechicle Speed Sensor
09 Engine Coolant Temperature(ECT) Sensor
12 ACCEL Sensor
14 Boost Sensor
23 CSP Sensor
25 Q Adjustment Resistance
26 Atmospheric Pressure Sensor
31 Feedback System-Injection Quantity
32 Timer Position Sensor
33 IT Servo
34 Intake Air Temperature Sesor
41 A/D Conversion
43 Accel Position Sensor Reference Voltage
44 Boost Pressure Sensor Reference Voltage
45 Battery Voltage
46 ECM Internal Error(EEPROM)
48 Glow Relay
86 Fuel Temperature Sensor
93 Selection of Unset Equipment
94 DOM/EUR Conversion
95 AT/MT Conversion
96 TPS Learning
97 FCV Short
98 ACCEL Learning
D 2.0 RE(RF-TCI) > Transmission > Automatic Transaxle
D 2.0 RT(RF-TCI) > Airbag > Airbag Control
00 Crash Occurred
31 ADU Fault
37 Connector Fault
D 2.0 RT(RF-TCI) > Brake > Anti-Lock Brake
D 2.0 RT(RF-TCI) > Transmission > Automatic Transaxle
Ещё обсуждения по киа спортейдж 1 al на MyKia.club:
