Киа Кларус FE
Сообщений в теме: 5
Отправлено 22 March 2021 - 12:39
Коды ошибок Kia Clarus (FE)
01 Accelerometer Error
02 CPU Error
03 Safing Sensor Open
04 Safing Sensor Short
05 Low Side Driver Error
06 Driver Squib Error
19 Reuse Error
20 EEPROM Checksum Error1
21 EEPROM Checksum Error2
23 Internal Error
08 Driver Squib Error
10 Driver Squib Short
12 Firing Circuit Short to Battery
13 Firing Circuit Short to Ground
14 Ignition Power Supply Circuit Low
18 Ignition Power Supply Circuit Low
16 Warning Light Circuit Short to Battery
17 Warning Light Circuit Open or Short to Ground
15 Driver Capacitor Error
G 2.0 DOHC > Brake > Anti-Lock Brake
C5103 Battery Voltage high
C5200 Wheel speed sensor Front - LH open / short
C5201 Wheel speed sensor Front - LH Range/Performance/Intermittent
C5202 Wheel speed sensor Front - LH Invalid/No signal
C5203 Wheel speed sensor Front - RH open / short
C5204 Wheel speed sensor Front - RH Range/Performance/Intermittent
C5205 Wheel speed sensor Front - RH Invalid/No signal
C5206 Wheel speed sensor Rear - LH open / short
C5207 Wheel speed sensor Rear - LH Range/Performance/Intermittent
C5208 Wheel speed sensor Rear - LH Invalid/No signal
C5209 Wheel speed sensor Rear - RH open / short
C5210 Wheel speed sensor Rear - RH Range/Performance/Intermittent
C5211 Wheel speed sensor Rear - RH Invalid/No signal
C5604 ECU hardware error
C6112 Battery Voltage low
C6114 Valve Relay Error
C6402 Motor Electrical Error
Отправлено 22 March 2021 - 12:40
G 2.0 DOHC > Engine > Engine Control
02 Crankshaft Position Sensor Malfunction
03 Camshaft Position Sensor Malfunction
08 Mass Air Flow Sensor Malfunction
09 Engine Coolant Temperature Sensor Malfunction
12 Throttle Position Sensor Malfunction
15 Heated O2 Sensor Malfunction
17 Feedback System Malfunction
18 Cylinder 1 - Injector Malfunction
19 Cylinder 2 - Injector Malfunction
20 Cylinder 3 - Injector Malfunction
21 Cylinder 4 - Injector Malfunction
24 Fuel Pump Circuit Malfunction
26 Purge Control Solenoid Valve Malfunction
28 EGR Solenoid Valve Malfunction
34 Idle Air Control Valve Malfunction(Opening)
35 Fuel Adaptation Error(Injector Error)
36 Fuel Adaptation Error(A/F Ratio Error)
37 Fuel Adaptation Error(Air Leakage)
41 VICS Solenoid Circuit Malfunction
49 Power Stage Error
56 Idle Air Control Valve Malfunction(Opening)
57 A/C Compressor Input Signal
65 Torque Reduction Signal from TCM
73 Vehicle Speed Sensor Circuit Malfunction
88 ECM Internal Error
99 Battery Voltage Error
P0717(66) Input Speed(Cylinder) Sensor Circuit No Signal
P0722(55) Output Speed Sensor Circuit No Signal
P0743(63) Torque Converter Clutch Circuit Electrical
P0748(64) Pressure Control Solenoid "A" Electrical
P0753 Shift Solenoid "A" Electrical
P0758 Shift Solenoid "B" Electrical
P1121 TPS Signal from ECM to TCM
P1780(65) Torque Reduction Signal Failure
G 1.8 DOHC > Airbag > Airbag Control
02 CPU Error
19 Reuse Error
23 Internal Error
G 1.8 DOHC > Brake > Anti-Lock Brake
G 1.8 DOHC > Engine > Engine Control
Ещё обсуждения по киа кларус fe на MyKia.club:
