Киа Шума SD
коды ошибок, расшифровка
Отправлено 16 March 2021 - 15:30
Коды ошибок Kia Shuma (SD)
G 1.8 DOHC > Engine > Engine Control
P0100 Mass or Volume Air Flow Circuit
P0110 Intake Air Temperature Sensor 1 Circuit
P0115 Engine Coolant Temperature Circuit
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0130 O2 Sensor Circuit(Bank 1 / Sensor 1)
P0201 Injector Circuit/Open-Cylinder 1
P0202 Cyl. no.2 Injector Circuit Malfunction
P0203 Cyl. no.3 Injector Circuit Malfunction
P0204 Cyl. no.4 Injector Circuit Malfunction
P0335 Crankshaft Position Sensor A Circuit
P0336 Crankshaft Position Sensor Circuit Range/Performance
P0340 Camshaft Position Sensor A Circuit Malfunction (Bank 1)
P0501 Vehicle Speed Sensor A Range/Performance
P0560 System Voltage
P0601 Internal Control Module Memory Check Sum Error
P0604 ECM Failure(ROM)
P1123 Fuel Trim too Lean at Idle (←Additive) (Bank 1)
P1127 Long Term Fuel Trim Multiplicative
P1505 Idle Speed Control Actuator Circuit 1-High
P1506 Idle Speed Control Actuator Circuit 1-Low
P1507 Idle Speed Control Actuator Circuit 2-High
P1655 Unused Power Stage B
P0101 Mass or Volume Air Flow Circuit Range / Performance
P0111 Intake Air Temperature Sensor 1 Circuit Range / Performance
P0116 Engine Coolant Temperature Circuit Range / Performance
P0131 O2 Sensor Circuit Low Voltage(Bank 1 / Sensor 1)
P0132 O2 Sensor Circuit High Voltage(Bank 1 / Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0136 O2 Sensor Circuit(Bank 1 / Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 / Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 / Sensor 2)
P0139 O2 Sensor Circuit Slow Response(Bank 1 / Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P0141 O2 Sensor Heater Circuit(Bank 1 / Sensor 2)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0300 Random/Multiple Cylinder Misfire Detected
P0422 Main Catalyst System Efficiency below (Bank 1)
P0443 Evaporative Emission System-Purge Control Valve Circuit
P0506 Idle Air Control System-RPM Lower than Expected
P0507 Idle Air Control System-RPM Higher than Expected
P0712 Transmission Fluid Temperature Sensor "A" Circuit Low Input
P0743 Torque Converter Clutch Circuit Electrical
P0748 Pressure Control Solenoid "A" Electrical
P0753 Shift Control Solenoid Valve "A"-Electrical
P0758 Shift Control Solenoid Valve " B" Electrical
P0763 Shift Solenoid #3 Electrical
P1307 Acceleration Sensor-Range / Performance
P1308 Acceleration Sensor - Low Input
P1309 Acceleration Sensor - High Input
P1508 Idle Speed Control Actuator Circuit 2-Low
P1586 M/T-A/T Encoding Signal Malfunction
P1780 Torque Reduction Request Signal (TCU-ECU)
P1800 Engine Torque Signal Malfunction
#2 krionika Re: коды ошибок, расшифровка
Отправлено 16 March 2021 - 15:31
G 1.6 DOHC > Engine > Unleaded(IMMO-)
P0111 Intake Air Temperature(IAT) Circuit Range/Performance
P0121 Throttle Position Sensor(TPS) Range/Performance
P0131 Heated O2 Sensor(HO2S) Circuit Low Input(B1/S1)
P0132 Heated O2 Sensor(HO2S) Circuit High Input(B1/S1)
P0135 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0137 Heated O2 Sensor(HO2S) Circuit Low Input(B1/S2)
P0138 Heated O2 Sensor(HO2S) Circuit High Input(B1/S2)
P0141 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0170 Fuel Trim (Bank 1)
P0202 Injector Circuit/Open-Cylinder 2
P0203 Injector Circuit/Open-Cylinder 3
P0204 Injector Circuit/Open-Cylinder 4
P0301 Cylinder 1 MISFIRE
P0302 Cylinder 2 MISFIRE
P0303 Cylinder 3 MISFIRE
P0304 Cylinder 4 MISFIRE
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0326 Knock Sensor Circuit Range/Performance(B1)
P0336 Crankshaft Position(CKP) Sensor Range/Performance
P0507 Idle Control System RPM Higher Than Expected
P0562 System Voltage Low
P0563 System Voltage High
P1308 Chassis Acceleration Sensor Low Input
P1309 Chassis Acceleration Sensor High Input
P1386 Knock Circuit Error
P1505 Idle Speed Control Actuator Circuit 1-Low
P1506 Idle Speed Control Actuator Circuit 1-High
P1507 Idle Speed Control Actuator Circuit 2-Low
P1508 Idle Speed Control Actuator Circuit 2-High
P1693 TCM Malfunction Indicator Lamp (MIL) Request Line Malfunction
P1610 Smartra Unit (No Answer or Invalid Message From Smartra)
P1801 Smartra Transponder Malfunction or Invalid Data
P1802 Smartra Unit(Antenna Malfunction)
P1803 Smartra Unit(Invalid Request)
P1805 Control Unit Deffective Or ECM Fault
P0105 Manifold Absolute Pressure (MAP) Sensor Circuit Malfunction
