Киа Каренс 2 UN
Сообщений в теме: 8
Отправлено 09 March 2021 - 17:09
Коды ошибок Kia Carens 2 (UN)
G 2.0 DOHC > Air Conditioner > Air Conditioner
B1200 Humidity sensor open (High)
B1201 Humidity sensor short (Low)
B1202 Water temp sensor open (High)
B1203 Water temp sensor short (Low)
B1208 Intake potentiometer open (Low)
B1209 Intake potentiometer short (High)
B1233 In-car temperature sensor short (Low)
B1234 In-car temperature sensor open (High)
B1237 Ambient temperature sensor short (Low)
B1238 Ambient temperature sensor open (High)
B1241 Evaporator sensor short (Low)
B1242 Evaporator sensor open (High)
B1245 Air mix potentiometer open (Low) - Driver
B1246 Air mix potentiometer short (High) - Driver
B1249 Direction potentiometer open (Low) - Driver
B1250 Direction potentiometer short (High) - Driver
B2406 Air mix motor (Driver)
B2408 Intake motor
B2409 Direction control motor (Driver)
B1101 Battery voltage high
B1102 Battery voltage low
B1326 FIS-Driver short to Ground
B1327 FIS-Driver short to Battery
B1328 FIS-Driver defect
B1330 FIS-Driver Wrong ID
B1331 FIS-Passenger short to Ground
B1332 FIS-Passenger short to Battery
B1333 FIS-Passenger defect
B1335 FIS-Passenger Wrong ID
B1395 Firing loops interconnection fault
B1400 SIS front-Driver defect
B1401 SIS front-Driver circuit short to Ground
B1402 SIS front-Driver circuit short to Battery
B1404 SIS front-Passenger circuit short to Ground
B1405 SIS front-Passenger circuit short to Battery
B1412 SIS rear-Driver communication error
B1413 SIS rear-Passenger communication error
B1414 SIS front-Driver Wrong ID
B1415 SIS front-Passenger Wrong ID
B1416 SIS rear-Driver Wrong ID
B1417 SIS rear-Passenger Wrong ID
B1418 SIS rear-Driver defect
B1419 SIS rear-Passenger defect
B1451 SIS rear-Driver circuit short to Ground
B1452 SIS rear-Driver circuit short to Battery
B1454 SIS rear-Passenger circuit short to Ground
B1455 SIS rear-Passenger circuit short to Battery
B1527 Passenger Airbag on-off switch open or leakage to Battery
B1528 Passenger Airbag on-off switch short or leakage to Ground
B1529 Passenger Airbag on-off switch defect
B1530 Passenger Airbag on-off switch instability
B2500 Warning Lamp
B2505 Passenger airbag off warning lamp failure
Отправлено 09 March 2021 - 17:10
G 2.0 DOHC > Brake > Electronic Stability Program
C1101 Battery voltage high
C1102 Battery voltage low
C1112 Sensor power voltage
C1200 Wheel speed sensor front-LH open/short
C1201 Wheel speed sensor front-LH range / performance / intermittent
C1202 Wheel speed sensor front-LH invalid/no signal
C1203 Wheel speed sensor front-RH open/short
C1204 Wheel speed sensor front-RH range / performance / intermittent
C1205 Wheel speed sensor front-RH invalid/no signal
C1206 Wheel speed sensor rear-LH open/short
C1207 Wheel speed sensor rear-LH range / performance / intermittent
C1208 Wheel speed sensor rear-LH invalid/no signal
C1209 Wheel speed sensor rear-RH open/short
C1210 Wheel speed sensor rear-RH range / performance / intermittent
C1211 Wheel speed sensor rear-RH invalid/no signal
C1235 Primary pressure sensor - electrical
C1237 Primary pressure sensor - signal
C1259 Steering sensor - electrical
C1260 Steering sensor circuit - signal
C1282 Yaw rate and lateral G sensor - electrical
C1283 Yaw rate and lateral G sensor - signal
C1503 ESP switch error
C1604 ECU Hardware Error
C1605 CAN Hardware Error
C1611 CAN time-out EMS
C1612 CAN time-out TCU
C1613 CAN wrong message
C1616 CAN bus off
C2112 Valve relay error
C2227 Excessive temperature of brake disc
C2380 ABS/TCS/ESP valve error
C2402 Motor electrical
G 2.0 DOHC > Engine > Unleaded EOBD
P0011 Camshaft Position-Timing Over-Advanced or System Performance(Bank 1)
P0016 Crankshaft Position-Camshaft Position Correlation(Bank 1)
P0030 HO2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 1)
P0031 HO2 Sensor Heater Circuit low (Bank 1 / Sensor 1)
P0032 HO2 Sensor Heater Circuit high (Bank 1 / Sensor 1)
P0036 HO2 Sensor Heater - Heater Control Circuit (Bank 1 / Sensor 2)
P0037 HO2 Sensor Heater Circuit low (Bank 1 / Sensor 2)
P0038 HO2 Sensor Heater Circuit high (Bank 1 / Sensor 2)
P0076 Intake Valve Control Solenoid Circuit Low (Bank1)
P0077 Intake Valve Control Solenoid Circuit High (Bank1)
P0101 Mass or Volume Air Flow Circuit Range / Performance Problem
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0121 Throttle / Pedal Position Circuit Range/Performance Problem
P0122 Throttle / Pedal Position Circuit Low Input
P0123 Throttle / Pedal Position Circuit High Input
P0130 HO2 Sensor Circuit (Bank 1 / Sensor 1)
P0131 HO2 Sensor Circuit Low Input(Bank 1 / Sensor 1)
P0132 HO2 Sensor Circuit High Input(Bank 1 / Sensor 1)
P0133 HO2-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 HO2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
P0136 HO2 Sensor Circuit Malfunction (Bank 1 / Sensor 2)
P0137 HO2 Sensor Circuit Low Input (Bank 1 / Sensor 2)
P0138 HO2 Sensor Circuit High Input (Bank 1 / Sensor 2)
P0139 HO2 Sensor Circuit Slow Response (Bank 1 / Sensor 2)
P0140 HO2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P0170 HO2 Sensor System - Lambda Controller at the Limit (Bank 1)
P0196 Engine Oil Temp. Sensor Range / Performance
P0197 Engine Oil Temp. Sensor Low Input
P0198 Engine Oil Temp. Sensor High Input
P0230 Fuel Pump Circuit Malfunction
P0300 Multiple Cylinder Misfire Detected
P0315 Segment Time Acquisition Incorrect
P0325 Knock Sensor 1 Circuit Malfunction
P0335 Crankshaft Position Sensor Circuit Malfunction
P0336 Crankshaft Position Sensor Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Malfunction
P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted
P0506 Idle Control system- RPM lower than expected
P0507 Idle Control System RPM Higher than Expected
P0551 Power Steering Switch Circuit Malfunction
P0560 System Voltage Malfunction
P0562 System Voltage Low
P0563 System Voltage High
P0600 Serial Communication Link Malfunction
P0625 Generator Field/F Terminal Circuit Low Input
P0626 Generator Field/F Terminal Circuit High Input
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit Low
P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction
P0700 TCU Request for MIL On/Freeze Frame to ECU via CAN
P1505 Idle Charge Actuator Signal Low of Coil #1
P1506 Idle Charge Actuator Signal High of Coil #1
P1507 Idle Charge Actuator Signal Low of Coil #2
P1508 Idle Charge Actuator Signal High of Coil #2
P2104 ETC (Electronic Throttle Control) System Malfunction - Forced Idle
P2004 Intake Manifold Runner Control Stuck Open (Bank 1)
P2006 Intake Manifold Runner Control Stuck Closed (Bank 1)
P2008 Intake Manifold Runner Control Circuit/Open (Bank 1)
P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
P2097 Post Catalyst Fuel Trim System Too Rich Bank 1
P2159 Vehicle Speed Sensor B Range/Performance
P2187 System Too Lean at Idle(Additive) (Bank1)
P2188 System Too Rich at Idle (Bank1)
P2191 System Too Lean at Higher Load(Multiple) (Bank1)
P2192 System Too Rich at Higher Load (Bank1)
P0721 A/T Output Speed Sensor Fail
P0722 A/T Output Speed Sensor Circuit - Open or Short(GND)
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0885 A/T Control Relay Malfunction
U0100 No ID From ECU
U0001 No ID From ECU
G 1.6 DOHC > Air Conditioner > Air Conditioner
B2408 Intake motor
G 1.6 DOHC > Airbag > Airbag Control
B2500 Warning Lamp
G 1.6 DOHC > Brake > Electronic Stability Program
C1616 CAN bus off
Отправлено 09 March 2021 - 17:11
G 1.6 DOHC > Engine > Unleaded GEN
P0011 "A" Camshaft Position-Timing Over-Advanced or System Performance (Bank 1)
P0012 "A" Camshaft Position-Timing Over-Retarded (Bank 1)
P0016 Crankshaft Position–Camshaft Position Correlation (Bank 1 Sensor A)
P0030 HO2S Heater Control Circuit (Bank 1 / Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 / Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 / Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 / Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 / Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 / Sensor 2)
P0068 MAP(MAF)-Throttle Position Sensor Correlation
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit-Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit-High (Bank 1)
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle Position Sensor 1 Signal Circuit Low Input
P0123 Throttle Position Sensor 1 Signal Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0141 O2 Sensor Heater Circuit(Bank 1 / Sensor 2)
P0172 System too Rich (Bank 1)
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0261 Cylinder 1 Injector Circuit Low
P0264 Cylinder 2 Injector Circuit Low
P0267 Cylinder 3 Injector Circuit Low
P0270 Cylinder 4 Injector Circuit Low
P0301 Cylinder 1-Misfire detected
P0302 Cylinder 2-Misfire detected
P0303 Cylinder 3-Misfire detected
P0304 Cylinder 4-Misfire detected
P0327 Knock Sensor 1 Circuit Low (Bank 1)
P0328 Knock Sensor 1 Circuit High (Bank 1)
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1)
P0342 Camshaft Position Sensor A Circuit Low Input (Bank 1)
P0343 Camshaft Position Sensor A Circuit High Input (Bank 1)
P0444 Evaporative Emission System-Purge Control Valve Circuit Open
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0501 Vehicle Speed Sensor "A" Range/Performance(Wheel Speed Sensor)
P0561 System Voltage Unstable
P0625 Generator Field/ F Terminal Circuit Low
P1505 Idle Speed Control Actuator Signal Low of Coil #1
P1506 Idle Speed Control Actuator Signal High of Coil #1
P1507 Idle Speed Control Actuator Signal Low of Coil #2
P1508 Idle Speed Control Actuator Signal High of Coil #2
P1550 Knock Sensor Evaluation IC
P1560 Knock Control Serial Port Interface check (Bank 1)
P2096 Post Catalyst Fuel Trim System too Lean (Bank 1)
P2097 Post Catalyst Fuel Trim System too Rich (Bank 1)
P2232 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank1 Sensor2)
U0101 Lost Communication With TCM
Ещё обсуждения по киа каренс 2 un на MyKia.club:
