Киа Рио 1 BC
Сообщений в теме: 10
  • 24076 сообщений
Отправлено 28 February 2021 - 12:05
G 1.6 DOHC > Transmission > Automatic Transaxle
P0713 Fluid(Oil) Temperature Circuit High
P0717 Input/Turbine Speed Sensor No Signal
P0727 Eng. Speed Input Circuit No Signal
P0748 Pressure Control Solenoid "A" Electrical
P0753 Shift Control Solenoid Valve "A"
P0758 Shift Control Solenoid Valve " B" Electrical
P0763 Shift Control Solenoid Valve "C"
P1121 Throttle Position Sensor (TPS) Signal Malfunction
P1500 Vehicle Speed Sensor Signal Circuit Malfunction
P1780 Torque Reduction Request Signal (TCU-ECU)
P1800 Engine Torque Signal Malfunction
P0707 Transmission Range Sensor Circuit Low Input
P0716 Input/Turbine Speed Sensor "A" Circuit Range/Performance
P0726 Engine Speed Input Circuit Range/Performance
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0741 Torque Converter Clutch Circuit Stuck Off
P1700 Over Drvier(O/D) Lamp / Hold Lamp Circuit Malfunction
Последние обсуждения по киа рио 1 bc на MyKia.club
